Visitor Agreement.
Of course, I'm assuming 10w30 is what is called for in this application. In dino (SL) oil, most major brands are good for at least 3K if no internal engine problems contaminate the oil.
Have you read any Dakota forums to get an idea of the longevity of this particular engine? Are there any documented weaknesses in this design. I think that would be a good area to investigate if your looking to go the longhaul.
Equilon is history, but I assume that Shell will use some of its excess capacity to shift production to its ex-Equilon plants when the Shreveport blending plant is history. It's a little hard to keep up on what's going because Johnny the PZ/QS insider no longer posts regularly to BOBISTHEOILGUY.
Here is the Shell 10W30 VOA from Bob's site. Unlike SuperTech it doesn't have moly. Assume the Equilon Havoline was essentially the same.
Aluminum - 0
Chromium - 0
Iron - 1
Copper - 0
Lead - 0
Tin - 0
Molybdenum - 1
Nickel - 0
Manganese - 0
Silver - 0
Titanium - 0
Potassium - 0
Boron - 3
Silicon - 2
Sodium - 1
Calcium - 1604
Magnesium - 5
Phosphorus - 731
Zinc - 857
Barium - 1
SUS Viscosity @ 210F - 61.4
Flashpoint in F - 425
That's why I'm comfortable changing the oil every 3k miles and not bothering with the synthetic stuff any more.
Both my Highlander and Sebring Convertible get their oil changed between the 3-4K mark. Excellent value and piece of mind for the money.
With the Highlander and the sludge risk I try to drain as close to 3k as possible.
I bought case of Mobil 1 0W40 and I am waiting for 4000 mile to tick in my new Passat (1.8T) to change oil.
5W40 is recomended but I only found 0W40 in Mobil 1 line.
When I asked dealer what oil they are using I was told 5W30, which is against owner's manual. I told them this but I did not get any response.
Krzys
PS VW suggests 5000 miles interval for 1.8T and 2.8 V6.
2.8 VR6 has initial 5000 and then each 10000 miles recomended interval.
I am considering buying a 2002 5-speed Chevy Prizm from a private seller. It has 20000 miles on it, clear title, CARFAX shows it was registered as a private party vehicle in the town the seller is from.
Now my question: the seller claims to have done all the oil changes himself at 3k intervals, with synthetic oil, too, but he did not keep the receipts. He has no problem with the mechanic of my choice going over the car in detail and confirming (or disproving) his statements. I trust this mechanic since I worked with this little shop for several years.
Is it reasonable that a mechanic can determine whether oil was changed regularly on a car of this type? I am not talking every 3k miles - 4 or 5 times over 20k miles would have been nice.
Thanks for you input,
The seller does have a good story - commuted 35 miles one way for year, then got a job 5 miles away from his place, and bought an SUV (of course). Sellers had no problem with the inspection at a shop of my choice. According to CARFAX, the title is clean and the car has been registered to a private owner in a little town in Wisconsin the seller is (claims to be?) from. I ran a reverse phone lookup on the number sellers provided, and it is a private residence in that town. See, I am pretty paranoid...
It is probably time for me to come clean and mention that I bought this car on regional eBay. This is not the first used car I bought and checked out, but definitely a first big eBay purchase. I am willing to take the extra risk, mitigated somewhat by a mechanic's inspection. As for driving the car hard, that's certainly possible and probably hard to ascertain, but the sellers are a 30-ish couple with 2 kids - not the type you would expect to be joyriding, especially a Prizm. Unless they will borrow the kids tomorrow to APPEAR like a responsible married couple - they are bringing this car and another one to the Twin Cities for inspection and pickup.
jmo
JMO
I don't see your logic on this one! Over the years, I have found it to be every bit as good as any of the "big name" oil company brands, and therefore I have a predilection toward using it. I'm curious why you consider it a lesser brand.
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;- f=11;t=000008
response to: "What happened to Valvoline?"
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;- f=1;t=001851
Can't speak for their claim, but I can somewhat answer the rest.
I use Valvoline products currently, may not in the future.
General consensus is that their oils tend to have a weak additive package in comparison to other brands. One example is no moly in in gasoline oil formulations (it is used in their diesel formulations). In addition, their dino oils seem to shear back rather quickly. On top of that, their Synthetic Product, synpower, is a group III base oil and not a true synthetic oil like Mobil 1 etc..., although it still gets priced like one. And, on top of that, a lot of their product line can be called gimmicky, witness the huge new line of Maxlife products (the motor oil is decent) like ATF, Antifreeze, etc... Its also tough to get a striaght answer out of tech support (although who makes it easy these days?).
All that being said, the three samples I have had, one durablens sample looked great and had plenty of life left - Vis and TBN were great- currently running it out to 5,000 miles. Another had good wear numbers but was DONE - there was no more mileage to be had on that sample - it had sheared back way into 5w20 range and the TBN was 3.5. The only dino sample I did was at 3500 miles and had sheared back to nearly a 20w. TBN was good, tough to gauge wear due to a bad air filter. I'm running Durablend in it now, so we'll see how it compares...
I was hoping to find a nice chart showing motor oil market share. I found a reference to Pennzoil having 22% of the market and PZ/QS having a combined 37%. That leaves QS with 15% unless Wolf's Head or their private brands have a cut of that pie. Valvoline was listed in an article as having 14% of the market so it's certainly close to Quaker State. I think Valvoline makes a great deal of private brand stuff but don't know if that's part of the reference market or not. Interestingly enough, Valvoline almost put in a bid for Quaker State when Pennzoil did-- that would have made the combined company #1 in market share. I'm not sure how Valvoline compares with Castrol but think they vie for #4 in market share.
So... Valvoline might be the little guy, but Ashland Petroleum really isn't that small-- just in comparison with the big guys.
I too don't believe in paying a great deal for oil-- use SuperTech, which will probably soon be the same as Shell. I don't think any of these are as good as Pennzoil, but probably good enough. I prefer SuperTech for Wallyworld oil changes because it's a few bucks cheaper AND it's a bottled oil. There's a small chance that bulk oil isn't what it's supposed to be, an even smaller chance that bottled Valvoline is bootleg, but who's going to be screwing around with Wal-Mart's house brand?
I also used it in my Accord I-4 during break-in before switching to M1.
But biases are hard to overcome and if you were burned years ago by their product I can understand using another brand. Most "SL" major brand oils are very good today for upto 4K mile intervals.
When Wallyworld doesn't have the M1 5qt jugs on sale, I have no problem using Pennz, Chevron, and Castrol "SL" products.
It took years, and lots of reasearching data before I was willing to use Pennzoil again. I'm now convinced today's Penn is one the best oils available. Gone are the days of the grey sludge.
