A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
"I knew this guy who knew this man and his father knew this guy's uncle and the Pennzoil just sludged his engine horrible, or it gave it this strange coating, etc., etc."
When I was a Parts manager most of the techs I knew didn't know too much about oil at all.
I began using Pennzoil in the early 80's and have NEVER had a problem with engines, all have been VERY clean, and have put over 200,000 miles on several of these cars.
Personally, I believe that any of todays SL rated regular oils will give you great service when changed around 3,000 miles or so.
Not going to get into this brand war thing, choice is yours.
But please, let us not perpetuate this myth about Pennzoil being a dog of an oil because it just "ain't so."
Good Day!
I don't want to get into trouble clipping from Bob's board, but the Pennzoil=paraffin=sludge story has been circulating since Pennzoil and QS were both "Pennsylvania" oils (they're not any more). In some parts of the country this was considered good, and in others it was considered bad. Some feel the biggest advantage to Pennzoil is that it's group 2+ oil. In reality I don't know if that means that much. From what I hear, group I actually has more cleaning properties than other dino oils. Frankly I think every SL oil will perform nicely in any (possible except. Toyota) engine if changed every 4K or less.
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;- - f=1;t=000614
posted October 12, 2002 07:58 PM
quote:
Originally posted by Drew99GT:
A few people here have indivated Penzoil conventional oil with purebase to be decent. Any other enthusiest message board I've been to has been hostile to Penzoil because it contains perafin wax. Now what am I supposed to believe now for crying out loud
I believe the parrafin wax myth has already been debunked. At least that's what I read here, from people who sound like they know more than your average "I repeat what I hear" consumer.
Drew-
For every person who chooses BrandA conventional oil over BrandB conventional oil, you're likely to run into another person who chooses BrandB over BrandA. After reading a lot of threads here, there doesn't seem to be enough of a performance difference amongst your typical name-brand SL dino oils to split hairs over.
(Chevron is available at Costco, a case of 12 1qt bottles for $11.69)
Posts: 36 | From: SoCal | Registered: Oct 2002 | IP: Logged |
Patman
Administrator
Member # 6
posted October 12, 2002 08:02 PM
For shorter trips like that, you are better off sticking with a synthetic, even if you extend the intervals to 5k. Synthetics can handle the shorter trips better than dino oils can, there is an SAE paper on this (the Aunt Millie test, as it's been referred to)
So if I were you I'd continue with the Mobil 1, do an oil analysis, and see that it's still ok for longer than 3k. If I were you I'd make sure to go on a longer highway trip at least once per week also.
Posts: 5593 | From: Mississauga, Ontario | Registered: May 2002 | IP: Logged |
Johnny
Member
Member # 10
posted October 12, 2002 08:11 PM
Drew: Well, I have to chime in now, there's that darn word parffin wax again. I have posted this somewhere else on this board, but I will do it again. Pennzoil causes sludge because it contains pariffin wax. BS!. That is a tale that started over 70 years ago, and it just won't go away. Every brand of dino oil is made from pariffin crude oil. That's where this idea of pariffin wax comes from. One of the first things any oil company refinery does to crude is de-wax it.
I use to live in your beautiful town, wish I still did. I now live in Northern Wisconsin, and I can assure you it get's a lot colder here than where you live. As a matter of fact, when winter sets in, it's here for months with no let up. My friends in Minnesota go through the same thing. I drive a 2000 Pontiac Grand Prix and use nothing but 10W30 Pennzoil in it year round. The car is parked outside and is not plugged in. I have never had any problems starting it in the winter. The car now has 54,000 miles on it, and it is as clean as a baby's butt inside. NO SLUDGE. I change the oil on an average of every 4,500 miles. When you are talking about OTC dino oils, I will put ours up against anyones.
Posts: 392 | From: Wisconsin | Registered: May 2002 | IP: Logged |
Ken
unregistered
posted October 12, 2002 08:50 PM
quote:
Originally posted by kreativ:
[QUOTE]Originally posted by Drew99GT:
[qb]
I don't know what the myth was about paraffin, but the facts are that crude oils are either a paraffin base crude, or an asphaltic base crude, or something between the two, depending on geographic location of the oil wells. Paraffin base crudes produce the best lubes, so that's what every oil company uses.
As Johnny says, ALL crudes are de-waxed. There is no, and probably never was, any problem with lubes made from paraffin based crudes, and if it was, it's the refiner's or the blender's fault, not the source of the crude oil.
Pennzoil is excellent. So is Chevron. So is Havolin mady by ChevronTexaco. Older Havolin made by Equilon (a joint venture between Shell & Texaco) is still on some retailer's shelves and probably OK.
If you want one of the "full synthetic" oils made from a very highly refined petroleum oil call Group III base stock, that'll work very well and cost less than a true synthetic. Pennzoil's synthetic is one of these, as is Castrol Syntec. Any will do well for you..get them if the price is right.
For your application you can not go wrong with any name-brand API service category SL oil on the shelf. How long do you plan on owning your car? Well over 100,000 miles? Then do pay attention to the fine details of these various good oils. Otherwise...no problem.
Ken
A question I have though is what is moly?
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;- f=1;t=001967#000000
How do you pass inspections where you live?
If you are comparing 500miles vs 350miles before adding a quart, that is roughly a 50% improvement in miles before you need to add a quart. Or when you look at it another way, you will add 1/3 less oil over a distance of 2000 miles. At 350 mile intervals you are looking at about 6 quarts at 500 mile intervals you are looking at 4 quarts.
Add in that oil is about $4/gallon (or more) while gasoline, even in the most expensive places in the US is half that price.
Finally, when you consider the difference in fuel economy is 1-3% for the average car that gets 20MPG you are only talking about 1-3 gallons over every 2000 miles...
So going with the oil that leaves the engine the slowest is probably the cheapest solution.
Plus, think if all the money you save on oil changes. Just change the filter, drain and strain the oil in the pan and run it back through 8^) as make up oil...
TB
Jack
I really don't worry about any major oil widely sold, but SuperTech is bottled which lessens the slight risk that some crooked manager is putting SA non-detergent oil into a bulk tank and making his brother the oil pirate rich on phony transactions. I've heard stories of counterfit oils and seen pictures of counterfit oil filters which even make Frams look good in comparison. At least Wallyworld totally controls their supply chain.
If you are in to self changes, I think that Advance Auto's house brand is probably Chevron/Havoline. Hell of a deal for under $1.
I seem to remember comments (maybe in the Consumer Reports oil issue of seven years back) that Shell varied a great deal depending on which part of the country you were in.
I just took inventory since i purchased 3 of the 5 quart jugs of Mobil1 at Wally World last night
24 Quarts of Mobil1 5W30
11 Quarts of Mobil1 10W30
3 Quarts of Mobil1 0W30
4 Quarts of Castrol GTX 5W30
4 Quarts of Valvoline Maxlife 10W30
4 Quarts of Shell Rotella 5W40 (should have sent them off with the Buick)
That should get me through the next year.
The SVT and MPV will require 24 quarts of the 5W30 Mobil1 over the next 12 months. That leaves 36 quarts to use in the 94 Geo Prizm. I figure 4 quarts every 5K miles, ans 25K/year, so that is another 20 quarts. (It doesn't seem to use any at 107K miles on the clock now.)
So I'm set. (And no, I don't want any diagnosis either.)
TB
In Missouri the Advance house brand says "compare to Havoline". Staff told me it was identical to Chevron Havoline as confirmed on Bob's board. It's possible that Advance varies in different parts of the country or that Advance recently changed suppliers. Hopefully TO Chevron and away from Shell. Of course if the stuff is old Equilon production capacity it would be like both Shell AND (the old) Havoline. Since Shell has a lot of extra capacity, this is also a strong possibility. If this happened the Advance Auto Parts stuff would be identical to the suspected new supplier for SuperTech.
So how goes it with getting out of the lease with a minimum hit to the wallet?
TB
I haven't had the inspection done on my soon to be turned in leased vehicle, but I'm estimating the turn in fee will be around $1500. This is probably less than what I'd lose if I bought it, then sold it out right.
I scored big time. Just when they had the final clearance, I picked up about a dozen for 25 cents each! I bought every one that fit any of my 3 cars, actually. Still have 8 left. :-)
-juice
Krzys
My NAPA dealer said their oil was Valvoline oil. When I called Valvoline, the tech. person said that Ashland/Valvoline did make NAPA's oil, but that the NAPA stuff had a "less robust" additive package.
I wonder what the real truth is.
A lot of debate concerning the Havoline brand name has come up in this forum in the past. I stumbled over an address that has interesting information for those curious about what is what in the Havoline world!
http://www.havoline.com/products/na/faq.html
As long as the dino stuff is API cert and has the correct SAE rating for your wheels your
good to go.
No doubt about it. IMO as long as you also don't go over 3000 miles. There are huge differences in the additive packages out there. All will go 3000 but how many API certified will go 7500. That is where brand, weight and other factors come in. If you change every 3000 it makes no difference what you use.
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;- f=6;t=000513;p=1
It is amazing how the same oil can do very well in some engiens and not as well in others. I can go 12,000 miles on one car but barely 5000 on another as it just beats up the oil, well, driving habits are part of that difference. One can rarely go wrong with shorter change intervals.
