Don't jump to any repairs with the seal leaks. Many times the synthetics will leak but after a while they have cleaned the seals and reconditioned them and they stop seeping by themselves. Wait at least on oil change interval before making any de3cisions.
Will do Armtdm. Right now i have an increasing amount of oil all over my garage due to oil leakage. It started with just a small drop of oil on the ground, and now it progressively got larger. I'll update on my progress as time goes. In the meantime, can you explain how you come up with this idea? Have you had the chance to do this and if so how long did it take for your engine to stop leaking oil? Thanks in advance.
Just a thought, but have you checked to make sure that the oil drain plug is tight and that there's no leak around the filter? I wouldn't want you to find that you've suddenly lost all your oil because the drain plug has worked its way loose.
Yes, that was the first thing i thought of when i saw the oil leakage in the first oil change. i cautiously retightened the drain plug and filter already. I don't see any oil coming through the filter or drain plug, i can see that there's some oil covering the bottom of the intake manifold component(not sure if it is this but i can locate the exact spot of the oil seeping through). The leakage is not near the drain plug, the drain plug on my car is located directly underneath the driver's side and the oil leakage is coming from underneath the passenger's side. I'm not so sure, but it appears and I suppose that the oil is seeping through the intake manifold components directly underneath probably due to the fact that the synthetic oil is cleaning all the garnish and deposits around the seals. I'll try to tighten these bolts and see if that helps any. I'll update later on.
Sorry, I don't think its the intake manifold, maybe something else. Maybe the valve cover gaskets. If only I have a diagram of underneath a honda accord engine i can tell you guys =/.
I have seen first hand in a/c systems when the change over to 134a and synthetic oil would shrink the “0” rings to half there size and leak like a sieve. No experience with autos because I don’t use it, that to me explains what happens to cars when I read the change to synthetic causes leakage.
Valve cover boxes are a common source of oil leakage in engines. I have many times seen the leaks stop with only a tightening of the retention bolts or screws that hold the covers against their gaskets. Now and then you have to replace the gaskets to cure the problem.
Yes but BE GENTLE with those rocker arm covers...easy does it or you'll squish the gasket or bend the covers. Use a 1/4 inch drive and that'll keep the muscle out.
I went to my friend's auto repair shop today and found out that the source of the leak was coming from the rear main seal located in the valve cover gasket. The suprising thing was that it'll cost me about $800 to fix this problem; gasket=$11, labor=$750, my car injured=painful (Haha sorry car but I don't think i can afford this right now). Tightening the bolts will not cut it so it appears. Im thinking of using the high mileage oil stating that it will recondition seals. I have not heard or seen anyone using these oils with leaks before hand. So, i will try to attempt the use of the high mileage oils in the next oil change if the oil leak worsens. Any comments about the high mileage oils or what I should do guys? I will update as time goes by with my results on using these high mileage oils.
There are such a things as additives in the "engine stop leak" category. I do not necessarily recommend this approach, but I suppose I would try it if I was convinced that to do so would not do greater harm than good.
I just bought some high milage oil and it just stated that its mixture of dino and synthetic oil, nothing more. I just use it in my lawnmower and snowblower.
It could take up to 5-10,000 miles for the seal to stop seepiong once you switch to synthetic and it many not stop. My experience is that it does take some time, a few hundred miles is not a good test
This leak that highroller has might be a bad gasket or seal, but also might be something else. A malfunctioning PCV system can let pressure build up in the crankcase, and cause oil to literally blow out the engine.
If you haven't done so in awhile, replace your PCV valve. It's pretty cheap, and ought to be done on a regular basis anyway. On my Honda CR-V, I found that the genuine Honda part was less plastic and more metal, for about $3 more that the one at Pep Boys or Auto Zone.
Only if it's plugged up real bad. Excessive crankcase pressure would be the symptom. You could check for this---there's a tool--you or your mechanic don't have to guess.
Yes, Mr_Shiftright that seems to make sense because everytime i decelerate, the engine hesitates and sometimes surges and also idles roughly with alot of vibration. Another point, i took out my air resonator chamber located underneath the air filter a couple days ago due to it being broken. As i recall before this, the car was hesitating everytime i start to brake. When i took out the air chamber, which i guess would allow more air flow through the air cleaner, i guess i could say there were no hesitations during this time. But now when i replaced the air chamber back to its normal spot, the car starts to hesitate again whenever i decelerate. Haha..funny thing was that when i pour in my BG44K, it helped the rough idling for awhile (somewhat truly amazing to me), but now when i think about it i think i know what is causing the rough idling problem. Hmm.. oil leak in valve cover gaskets and hesitation due to decelerating (fewer air flow)= pcv valve being plugged up real bad? i will go to my local firestone to get this checked out thanks you guys. If it is the pcv, and by replacing it, I hope the oil leak stops COMPLETELY before i go COMPLETELY insane hehe. In the end, I just hope i can stick to my synthetic motor oil with no further oil leaks and to have rough idling/hesitation gone. :P
I hope the PCV replacement works for you. The hesitation thing might be a red herring here, but since PCV valves are so cheap, and mechanics' time so expensive, I'd recommend just getting a new one and save the diagnostic charge. Can you imagine the Firestone conversation - "That'll be $40 for the diagnosis, and $10 for the new PCV valve"?
Gee it takes about two and one-half seconds to lay a gauge on the opening of the oil cap and read it for vacuum. I could do it while knitting and reading a magazine.
Yeah - at idle. How about on the freeway? And just what are you knitting ... shifter booties?
j/k, but you could get your reading at idle that has nothing to do with what's happening at speed, and under load. My theory is, don't spend too much on diagnosing the problem, if a possible solution is really cheap. I'd bet that Firestone / Honda / Mr. Goodwrench wouldn't test a PCV valve in that way, or at all - just replace it.
I don't think load has anything to do with testing crankcase pressure in this case.
If you don't diagnose you're just guessing. By diagnosing you have 100% eliminated one possible cause of the leaks, whereas a new PVC could be bad out of the box, you don't know. So you test it before and after replacement and then you know something for sure.
Mr Badwrench isn't going to learn anything the other way except how to throw parts at problems at your expense.
It's sloppy and there's no pride in it IMO.
And then there's the question of why the PVC clogged? The PVC could be the fever of the patient and not his disease.
Hey guys, i went to firestone today to get a diagnostic check to see the source of the oil leak and the problem with the hesitation. I even got in the car with them to point out the problem. Well, they saw that there was some oil leakage coming through the camshaft seals and the rear main seal. I asked them to check the PCV valves (they didnt check it) they said that PCV valves are rare to be not working properly on a 4-cylinder vehicle and especially with my 97 honda accord. They told me that they believe the cause of the hesitation is because of my downshift (they said something else but i didnt quite understood their terminologies) so they said i should get the rear main seal and the downshift thing checked out at a transmission shop. Gee.. i spent $80 just to get this checked out and i still don't believe they helped at all. As for the camshaft seals, they recommend replacing my timing belt and the camshaft seals. Can someone give me an estimate of how long my car will last if i don't replace the camshaft and rear main seals? And what can I expect to happen over a long period of time if i don't replace these seals? I plan on keeping and using my car for about 4 more years. I just don't have the money for the labor right now and probably will never have the money to repair it haha. oh, one more important question to be discussed... if somehow i have the money for the labor and i replace all the seals/gaskets with which oil was leaking through, would using synthetic motor oil be a problem or would it still be okay for the New,Replaced seals or would i have to go with conventional oil for awhile and then switch to the synthetic? Thanks in advance.
You can leak oil forever as long as it isn't too much and isn't leaking somewhere where it would cause a fire.
I wish someone would just check the damn PCV! If it hasn't been changed in say 30K miles, sure it could be plugged, especially on an older engine with high miles.
Just replace the dang PCV valve, and forever remove it from the possible problem list. What a waste of money!
Would have saved $50, and at least have had a chance. Now, nothing learned, and out $80. BTW, I've never had a bad PCV valve, right out of the box - I only buy OEM PCV's though. Your link was great - and it reminded me that I gave my '99 'V a new PCV valve, AND a new grommet. Both were less than $12, right from one of your sponsors, H&A.
I stressed (even got a little mad) about the pcv to them about several times, but they would deny to check for it... maybe they don't want to find out the truth so that way they can just make money by charging to replace only seals etc..? who knows but i will not go back there again.. as for the pcv i will go to my old mechanic to see if he can check for it. Thanks.
I wouldn't go back to Firestone. But I hope you do look at Shifty's link - maybe you should print it out and show it to your next mechanic. Personally, I don't know where the PCV valve is on a '97 Accord, but typically they're not hard to change out. Why not go down to the Honda dealer and buy a new PCV valve, and pay/bribe someone to put it in for you? On my '99 CR-V, it can be done in under a minute, with just a pair of pliers. Have them check out the condition of the PCV valve hose, and the grommet it goes into as well.
Then, get some Simple Green or some citrus-based cleaner. Wait until your engine cools down (doesn't need to be cold, just wait 30 minutes or so after turning it off). Then spray the cleaner onto the oily parts, wait a few minutes, and then hose it off. Just use a garden hose, and not a pressure washer. Avoid the Distributor (if you've got one) and the spark plugs & wires. Just go for the engine leaks The idea is to clean the area off, as Shifty suggested.
Here's an update for you guys on my car: Today, I took my car to my trusty mechanic to take a look at the pcv valve, hose, and grommet. To me and the mechanic, everything looks fine. It doesnt appear that the pcv valve was plugged too hard (we pulled it out using our hands), there were no cracks or swelling on the hose and the grommet was in good condition. I went to the Honda dealership after this and went ahead and bought a new PCV valve anyways and replaced the old one, which i found was the easiest thing to do for my car (it was right on top of the engine close to the areas of the spark plugs). ( im going to replace the pcv valve because its never been replaced, and it was recommended that i should change it at least every 30,000 miles by shifty and some car advice experts . Now, i plan to clean the parts that has oil leakage with the simple green and hose it off with water like ecotrklvr said to do hopefully by tommorrow or later this evening. I also plan to change my oil and filter in the next 200 miles with my mobil 1 oil which is probably 2-4 more weeks of driving for me. I would like to know if instead of hosing it off, can i use alot of water and a bunch of paper towels to avoid any electical or other problems?
You can brush the simple green on and off with a soft clean paint brush and cover the electrical parts with aluminum foil, which you can scrunch up pretty tight to fit around things you don't want to get wet. Since you aren't using water pressure, that should keep things nice and dry and you can work around components with the brush.
Okay Shifty, i will do that right after i finish posting this message. If after i have done the cleaning part and replaced the pcv (if it is the pcv valve's fault for the oil leaks), would you expect the leaks to stop right away or over some period of time? thanks in advance.
I would expect them to stop gradually but noticeably after a few days, presuming your engine has been doing normal duty.
BE CAREFUL of the tin foil that you don't bridge two live electrical and exposed connections! This is only for black boxes and such, not to cover a battery with exposed cables.
Yes sir, i did just that too! Well, i have finished cleaning all the parts that were leaking. Now, i will just visually observe if there's sign of oil leaks still and update later in a couple of days. Thanks again.
There's been only a couple of times that i felt the hesitation, but this was all before i replaced the pcv valve. So far no signs of any hesitation . I hope that replacing the pcv valve helped the oil leak to stop or slow down some. If not, then i guess i need to start saving alot of money right haha . I'll update on the leak progress later. thanks again.
Yes, i have. thanks for the awesome link shifty. It's been very helpful to me. i do have a question though for you car experts ... when my car idles or when i have come to a complete stop on the road (like stopping at a red traffic light), the steering wheel and the seat vibrates somewhat noticeable. I know i need a wheel alignment, but not so bad that i need it right away. i recently lowered my car some, and possibly it's the cause of the vibration. But, can the oil leakage cause this vibration when only idling or only when i come to a complete stop on the road? And is this a common problem with oil leakages? Thanks. Today, i will check to see how's the leak going also.
Here's an update on my progress on the oil leaks. After cleaning underneath the engine, changing the oil, and replacing the pcv valve, i'm proud to say that there hasnt been a single drop of oil leak. So far it's been only a couple of days and no single oil leak has occurred though. I tried going on the freeway and driving for a long period of time thinking that it would surely develop oil leaks when stopping, but when i stopped at a place where i could spot for oil leaks, there was none. As for the idling and hesitation, i went ahead and pour a can of bg44k into my fuel tank just for the heck of it and to see if it helps. Well, it did its job again. Now the car runs very, very smooth and sound (when stopping or idling). I plan on changing the air filter (it's somewhat dirty) later just to make my car happy. I'm not trying to get my hopes up but i think its working guys... but not to get carried away since this is an oil forum, I will update later to tell you guys if there's an oil leak or not in a couple of days. I bet some people are getting tired about hearing bout my oil leaks right? haha Dont worry i'm getting sick of this myself haha
No need to worry - not even close to being ill. I love getting the chance to pass on a tip here and there. So do the Moderators.
Some of us have cars we drive for fun, but most of have cars we need to get to work and to live our lives. Having one less thing to worry about is a great thing. Good luck.
It's been about 3 days since my last posted message and still no oil leaks So its been about 5 or 6 days now and no oil leaks, no hesitation, and no rough idling heheh. Update later? You bet.
Hello I bought my camry in 1997 with 170,000 miles. I'm the second owner. My car is leaking oil. It leaks the most over night.
When the car had 150,000 my friend replaced the water pump and the front oil seal. Since he replaced the water pump. He also replaced the time-belt. It took 3 hours. He also replaced the oil gastket, oil filter, etc.
Something interesting happened over on Bobistheoilguy a couple of weeks ago. A GM engineer started posting and he was contemptuous of the necessity of synthetic unless the car was specifically designed for it and came from the factory so equipped (i.e. Mobil 1 in a Corvette).
As you can imagine with all the Amsoil dealers on board he took a lot of flack, especially when he started really going after Amsoil as a sort of ponzi scheme. He was also nasty about additives which made all the Lube Control fanatics sort of nuts.
Well anyway, just when things were getting interesting, all his posts were removed, just like he never existed-- probably because he was going after all the site sponsors.
Anyway, I haven't linked to another forum, but I wanted to discuss his general points and felt he made some fairly knowledgable points before he was removed. I hope this post doesn't get removed because I don't know how to broach the subject without referencing what happened.
Some things to keep in mind-- 1. This guy did sound like he had a good grasp of engineering. 2. With the GM trip computer (just got a Malibu Maxx and it's going to show about 6K before oil change) he was very comfortable with stretching modern SM dino (group II or II+ ) oils out to 6000 miles. 3. His point about synthetic was unless you need the additional top end temperature range (and most cars don't) that synthetic is largely a waste of money.
I'm sure he made some other points, but he got yanked so fast and so unexpectedly that if there was I'm not sure what the points were. He was posting to a brand specific board and apparently made some kind of snide remarks over there about showing up all the Amsoil dealers-- don't know where though.
I agree with all points but this one is the exception that causes me to use synthetic:
"His point about synthetic was unless you need the additional top end temperature range (and most cars don't) that synthetic is largely a waste of money"
Now, keep in mind that MOST GM cars use very mild pushrod engines that don't stress the oil, either with heat or shearing. On the other side of the fence are widely reported, recent sludge problems with Toyota V-6 engines, VW Turbo 1.8's in Passats, Chrysler/Dodge 2.7 V-6's - and sludge is essentially due to temperatures getting out of control in engines, due to small oil passages, where the coolant passages are located, engine load etc. It happens. Synthetic prevents it.
That's if you are a normal driver. If you drive some mountain passes (with uphill sections) with some load (a passenger, some camping gear) on a hot day (that temperature thing) and drive hard (hey, twisties) with downshifts and high rpms - well, I'd rather have synthetic anyday of the week.
There is an additional factor, and that is "shear reduction" of viscoscity as the viscoscity index improvers (long link molecules) get "scissored" by pistons, gears, cam shafts (principally an overhead cam issue, thus the GM engineer's perspective), cam chains, etc. Some cars and designs are harder in this regard than others. GM pushrods are supposed to be relatively non-demanding on oil, specifically the older models with relatively low power output. Synthetic oils with moderate viscoscity ranges - like 5-20, 5-30, 10-30 - sometimes can get away without any VI improvers at all - the synthetic molecules are more consistent in size than non-synthetics. So synthetic oils are better if you might have shear issues or run longer oil change intervals. With 3,000 mile oil changes, viscoscity reduction is seldom a practical problem even with conventional oils, but on longer change intervals some people have seen 5-30 conventional oil slip down to 5-20. Which might be one reason why Chevy is sticking with 5-30 instead of recommending 5-20 (their oil monitor can allow 6,000-10,000 mile oil changes, I understand); it gives the oil more margin before you are in a dangerous zone (Ford limits oil changes to 5,000 miles max; Honda, which specs the same 5-20 oil, calls for 10,000 mile oil changes!).
I'd take the GM Engineer's postings as support for using conventional oil in a GM pushrod oil monitored car that's not being "raced." Even with a GM, I'd either use synthetic or change more frequently with more modern, demanding engine designs like the Ecotec 2.2 DOHC engine although this has an element of personal preference; I like to take care of my cars as though I am going to keep one for 100k + miles.
Finally, the GM engineer may have been in any number of departments not relating directly to engines or lubrication issues. I'd be most impressed with his or her comments if he is in their lubricants department.
(On a larger marketing issue, no oneat the Big Three likes to tell their customers that "regular" oil, which is cheap, might not be quite good enough, but synthetic oil, viewed as horribly expensive by the typical auto parts store shopper, is much better; even Amsoil promotes the "savings" you get from their oil by extending the oil change interval.)
I think he was especially down on Amsoil's (or other PAO's for that matter) claim that changes could be safely extended (past what the GM computer says that is). I wish I could figure out how to dig him up. He might provide some extra spark for Edmund's rather lethargic oil related threads.
And again, I'd stick with the Honda part.
Here's some Info:
http://www.carcarecouncil.org/Engine/crankcase_vent.shtml
Every 400 miles I have to add half quart.
Can anyone give me any advice??? :shades:
