At 170,000 miles it's going to use/leak some oil as it nears the end of it's life.
I also have a Toyota V6 that just beats the crap out of the same oil at 7500 miles. So much is engine design, driving habits, climate etc. etc
I'm curious though, the manual does not say what specific API certification should be used. I've done some looking on the shelves at the big box store, and I've found that you can get either API service SL or SM in a conventional, name brand oil. I'm not sure which I should use, or if I should even worry about it.
There were at least 3 brands available in 5W20, Castrol, Penzoil & Quaker State. Any thoughts on which might be best? I've used Castrol part-synthetic in the last new vehicle I bought with seeming success. I'd use it in the Honda but it seems like it's not available in 5W20, in fact it seems to be getting harder to find in general.
Dave
My e-mail is in my profile. (good to see you back posting with us!)
kirstie_h
Roving Host
Host, Future Vehicles & Smart Shopper discussions
MODERATOR /ADMINISTRATOR
Review your vehicle
There has got to be a reason why the service manual says 10w40 when 100+F. Either the owners manual is wrong or the service manual is? I'll be doing some light off-roading in 110+F. Wish I could get a straight answer out of Hyundai. I'll be covered by using whats listed in the owners manual(10w30)
Possibly the lighter weight is specified in the US owner's manual since our prevailing temps are lower than 100. If the temps are higher, they want the dealers to use thicker oil. That's just because auto cooling systems are a little imprecise and don't work that well in stop and go traffic or in consistenly high temps; the oil will heat up and thin a little.
Consider using 0-40, Mobil 1, designed for European cars, it will flow well at low temps and has a little thicker viscosity than 30W (it is a "thin" 40). If want a still thicker oil, the Mobil 1 Truck and SUV oil is more a true 40.
Be happy Hyundai is honest about the engineering requirements for their engines. In the search for higher fuel mileage, many companies gloss over these fine points. The reason Hyundai doesn't make the point in their owners manual is to keep customers from thinking that if 40 is ok, they'll run it all the time. That's not a good idea. It doesn't flow as well as 30 wt oil under sub 100 degree temps, and it does use more fuel.
Still don't trust 10w40 oils, although I'm sure they're more stable than 25 years ago when they were popular. Still too many viscosity improvers to break down.
I would be interested in your feed back thanks in advance.
sig
However, no matter how much as I would like it, I doubt in even 1-2% improvement in MPG due to synthetic, not to mention 25% gain. With such fuel consumption very few rational persons will use natural oil, even if government would not ban it.
Probably, your son did a major tune-up. Do not know about diesel, but once upon a time our fuel consumption decreased, no kidding, almost by half after engine tune-up and replacing plugs. It was our first car. We bought it used, 9 year old, with 105k miles, and, probably, it never had a major service.
Better tire pressure also improves fuel consumption. Visibly, but not by 25%.
The reason I like full synthetic is that it is more resistant to thermal breakdown, sludging, which starts on day one, it isn't a matter of how fresh or old your oil is. Full synthetic may also be more resistant to breakdown in viscoscity (thinning out) due to shearing of the viscoscity extenders which must be used in conventional motor oils - synthetic oils have more uniform molecule sizes and tend to need less in the way of viscoscity extenders, sometimes not requiring any if the viscoscity range isn't too great.
There is the extra cost to consider using full synthetic (it's at least $4.50 per quart at Wal-Mart vs. about $1.80 for most conventional 5-20 oils), but I think the cost of the oil is the least expensive factor in the total maintenance "package." I usually forego the "extra" dealer services they try to sell you at the traditional 15/30 intervals and just stick with the maintenance actually spelled out in my owner's manual, which is a lot less. Then I spend the money saved on "service" on the oil instead and pocket the rather large amount left over.
BTW, I think if you are not using full synthetic, the so-called "blends" are a waste of money. Most major label conventional oils are already "hydro cracked" or "isomerized" which is already pretty sophisticated refining, and the small amount of "true" synthetic added to such oils is just another stage of refinement, not "manufactured up from molecules" synthetic like Mobil 1, Redline, Amsoil. The "conventional" portion of a blend is still suceptible to thermal breakdown and shearing.
I do always take my cars back to the dealers for work, though, both to document the require work has been done (for warranty purposes) and for the peace of mind knowing that the work is more likely to be done correctly by factory trained technicians with access to the latest factory manuals. Hope this helps. Keep in mind the relative costs of:
Your Pilot;
A quart of any oil, regular or synthetic; and
The costs of "dealer recommended" "over" services.
I'm leaning toward using Mobil 5000 5W-20 and going with a 5000 mile OCI on my new Accord. I have done some research at bobistheoilguy.com (now there are some people that are serious about oil!) and there doesn't seem to be much consensus yet about what is the best conventional 5W-20 (some think you shouldn't even use it).
Dave
is 5000 mi. ok for oil/filter changes?
YOU CAN NEVER GO WRONG using the manufacturer's filter for warranty purposes. That way the manufacturer can't point a finger to an outside supplier.
The disagreement was if Amsoil 5W-40 European Forumula met the requirements of the 2005-2006 Jeep Liberty CRD.
Requirements are - - oil required for the CRD is SAE 0W-40 Synthetic Engine Oil that meets categories SL and CF (SL/CF) or better and the requirements of DaimlerChrysler Material Standard MS-10725. If you cannot find SAE 0W-40, then SAE 5W-40 Synthetic Engine Oil is acceptable. Lubricants which do not have both, the engine oil certification mark and the correct SAE viscosity grade number should not be used - - this is from the owners manual
Amsoil API license
My opinion is that since the 5W-40 Amsoil is not API certified, it should not be used.
What amazes me is that some individuals insist that Amsoil 5W-40 Synth. is API certifed, even a few that peddle the stuff.
Care to share your opinion?
Here is the link to the page with this product. They state it is. That they have an API number is news to me.
quote- AMSOIL lubricants meet the current API Service requirements and, thus, are perfectly suited for use in any new vehicle without affecting the validity of the new vehicle warranty -end
Wahhhh ha ha! Good luck in arbitration trying to explain how meets is equivalent to certified.
1. API certification can be done by any good competent lab. The cost of having the API doughnut on your bottle is in excess of $50K per item. That is 50K for 5W-20, 50K for 5W-30, etc. The testing standards are available to anyone who wants to see them. Amsoil uses a lab called Falex, located in IL. If the standards are followed, and the oil meets or exceeds that standard, it does not matter who does the test so long as the testing is done the way API says it should be done.
2. There is a large and growing following of Amsoil users. Many of them have been using Amsoil for years, even without the API doughnut. As far as I can see, warranties have not been voided by using Amsoil.
3. Now what it states in the manual as you have quoted, "should not use". That is not an absolute statement. There are many things we should not do, but "should not" does not equal "cannot". That is how you are interpreting what is in the manual. You are viewing this as an absolute when it is not.
4. If you feel the oil you put in your vehicle must have the API doughnut, then go for it. I chose to use what I use based on over 200K miles of experience with Amsoil lubricants, all positive. I have never had a failure of any kind. I see no risk in using their lubricants.
5. Based on some of your responses, you have never really researched any lubricants Amsoil makes.
What a vague statement. Trying to cast doubt? Be specific and tell me what I research I have not done.
Better yet, tell me why Amsoil states " If you're concerned about your warranty and feel pressures to use an API licensed oil, even after reading this answer, then the 5W-30 (XLF) or 10W-30 (XLT) XL-7500 or our 15W-40 (PCO) API licensed oils should be your choice.".
The other reason I do not use Mobil or Exxon products is that they are in bed big time with the people who would like to see our demise, the arabs. Why should I give my money to a people who hate us? Amsoil is plant based and comes from this hemisphere as far as I know.
I have heard that Pure One filters are good, but I had a drainback valve knocking when using a Pure One for one oil change on a Neon, which surprised me a little. Pure One filters are available at Pep Boys.
I have also heard that Motorcraft and AC Delco (GM) filters are pretty good.
Nowadays I try to use oem filters, to ensure no gaps in warranty coverage; although since Fram is supposed to make Honda filters, I feel a little bad about using the Fram filter.
What user's manual suggest as OCI (Oil Change Interval?)? It should read as x miles or y months, whatever occurs first.
I would change oil twice a year (synthetic) and regular 3 times (maybe 4).
With such short trips oil has no chance to heat up and boil off contaminants (water).
Krzys
Rated by whom? I would like to read the testing as I am still educating myself on filters.
The less well-known facts are that it is not, and cannot be, rated SM due its higher levels of now-prohibited antiwear additives. As an oil designated principally for diesels, it doesn't have to lower the antiwear additives to protect later-model catalytic converters. This might be a good thing and many drivers swear by it in non-diesel passenger cars. :-) However, check your manual and see what the rating requirements are for your BMW before using Rotella (same goes for other oil choices you mighte be considering), and cross check the Rotella specs. Also make sure (if you are still under warranty) that the Rotella (or any other oil) satisfies whatever obscure BMW specs are hidden in the fine print in your manual.
I considered using Rotella in my 2004 Golf, but decided, since it was still under warranty, to stick with the Castol Syntec 5-40 the dealer offered.
