2024 Defender 110 S P300
36/10 and 30/10
zip 07631
68% / 66% for 33/36 mo, 10K
33/36 7500miles
Any incentives?
zip 10305
thank you
S P300: 69%/67% residual
XDynSE: 65%/63% residual
Looking to order a 90 S or 110 S. What is the best value or sweet spot now in terms of residual and MF for these with 10k miles/year? Zip 92128
Ideally I’d get a 90 x-dynamic SE with the 6 cylinder so what’s that and what is the best residual you see now?
.00389 MF and 62% RV
S with the 4-cylinder has an RV that is 7% higher
110 S: .00298 MF and 66% residual
110 XDynSE: .00298 MF and 62% residual
90 S: .00389 MF and 66% residual
90 XDynSE: .00389 MF and 60% residual
Hello- looking for RV, MF and any incentives on a 24 Defender 130 X 36/12k. 43221.
If S, then P300 or P400?
.00311 MF and 65% residual
2024 Land Rover Defender 110 P300S
36M/12K
Zip code: 85142
Hi - looking for residual and MF for ‘24 110 X-Dynamic SE (P400) - 10k/36mo. Thanks
2024 Land Rover Defender 110 P300 S AWD
36/10,000
90210
Rates, Residuals and Incentives please! Also, which trim has the best lease program.
Money factors are lower for some of the higher trims, but the residuals fall off a cliff, compared to this base model. This one will lease for the lowest payment, I'm sure
Looking for MF/Res
2024 Defender 110 V8 Carpathian Edition
zip code 60189, 10k/33 mo and 10k/ 36mo
.00119 and 50%
24/33/36 7500 miles, zip 10305
thank you.
.00311 and 67%
.00311 and 66%
MF/Residual
2024 P400x 110
15/24
15/36
15/39
12065 - Any incentives?
.00183 and 50%
.00189 and 47%
Defender 130 x 36/12 and defender 130 x dynamic SE 36/12 in 93730? Thank you!
X Dyn SE - .00155 MF and 56% residual
Hello, I’m looking for MF/RES for:
Both 2023 and 2024 Defender 110 S P300
36/10 and 36/12
zip 91604
Thank you in advance!
.00311 MF and 64% residual
Ask 2023 model questions at this link
Hello can you provide the MF, RV, and any incentives for the 110 X dynamic SE and the S for a 10k/24m please? If a different configuration is optimal, please let me know. Thank you!
Zip 33415
Both please
Both please
.00376 MF
75% S P300
70% S P400
70% X-Dyn SE
Can I please RV and MF for defender 130 s p300 and 130 outbound 36 months 15k miles
Zip 90813
36months 15k thank you
P300 - .00311 MF and 63% RV
Outbound - .00145 MF and 54% RV
7500 / 36
92260 and 90277
75% S P300
70% S P400
70% X-Dyn SE
Hello, just wanted to follow up and request the 36m/12k numbers for the 110 p400 X-dyn SE please
.00311 and 60%
