Is this likely to cause any problems, having switched from one to the other and back and forth? Also, since both have been used (and I am finally aware of it), which oil should I stick with, synthetic or regular dino? Thanks for any input and suggestions.
Regarding black oil, in diesel engines the oil will turn black within a few miles and still be good for another 20,000 or more. In a gasoline engine it shouldn't really go full black unless the insides of the engine are really sludged up, however, even oil that is fully black may very well still be doing its job. The only way to tell for sure what is going on is to send the oil out for analysis.
Best Regards,
Shipo
Best Regards,
Shipo
What comments do you have abou that possibility?
All in all, i think that a)must be some really really expensive filter b)i dont want to say impossible but sounds too good to be true, unless i see convincing evidence. c)filter must be mostly free flowing and only traps VERY big particles, therefore can't be clogged up by the smaller particles with that much miles?? :confuse:
I didn't hear the whole commercial, just the part saying he'd gone 200K and the motor had been serviced and was clean inside if I heard correctly. I make the inference that the filter gets changed at regular intervals; the oil just doesn't get changed--probably topped off for use and filter change loss.
To say nothing of the $$$ of downtime if something breaks.
A) Is overfilling the tranny by 1/2 qt a cause for concern if i only drove the truck for about 200 miles? I say 200 miles because i drained and refill again and now i get 1.5 qts LOW...so...
My checking procedure: Startup car after tranny drain and fill, drive for 15 mins., park car on level/flat surface, shift gears from Park to 1 to all the way back up to Park, let engine idle while checking tranny level on dipstick.
Now, after all my trials and error, im happy to say that im satisfied with my level... it took 4.5 qts for it to be in the OK range. Tranny capacity is 11.25 qts (to drain all of it, would have to flush it out of course, but this truck comes with a drain plug and it's alot more to my liking) if anyone wants to know.
Thanks for any replies..
Eric
I notice my oil looks cleaner after returning from a longer trip with drives of 4-7 hours each way. The oil has run at proper temperature for hours, purging contaminants as vapors through PCV and cylinder walls. The oil has approached nearly 100% been through the oil filter to have particulates filtered out down to minimum size filter catches.
My thought is someone who drives the car could change filters and extend the true life of the oil. Maybe an additive package could be added along with replacement new oil for oil consumed by every motor.
For short trip drivers, a method of purging contaminants by vaporization is needed. It maybe the oil method is changing the oil and letting the recycler remove the contaminants.
I see a large amount of petroleum being conserved with proper application of safe longterm usage.
It looks like lots of good information, but I don't really know enough to judge.
FWIW, this site indicates that changing from synthetic to dino and back should not adversely affect newer model cars.
If anyone has anything to add, I'm still interested in your input! Thanks.
Best Regards,
Shipo
3000 miles later I went back to the dealer for the 15k work, and they changed the oil, using Castrol. Then I went back to Oil Well and they again didn't put a sticker on, so when I asked for it, I finally saw they'd used Kendall synthetic. Yikes. Now I'd changed from dino to synthetic to dino and back to synthetic.
My questions, then:
1. was that BAD for the car? and
2. Which should I stick with? I just want to treat the car right!
Which should you stick with? That's a MUCH more difficult answer. From my perspective you should stick with which ever you feel most comfortable with. Errr, that is unless the manufacturer of your car requires synthetic oil, which of course makes the answer easy, synthetic.
My own preferences are well known here at Edmunds as I am a long time user (25 years) and advocate of synthetic oils. That having been said, some folks simply cannot bring themselves to drive further than 3,000 miles before changing their oil, regardless of what is in the engine. For them I universally recommend conventional oil as synthetic oil is an absolute waste of money and resources.
Best Regards,
Shipo
I sure appreciate your help!
Diane
Best Regards,
Shipo
Cool, a little re-education is never a bad thing. ;-)
Regarding the Kendall synthetic, I have no experience with it so I looked it up and it isn't terribly impressive. Said another way, it looks to be a little better than conventional oil, however, it pales in comparison to Mobil 1 and German Castrol Syntec.
A quick way to get a snapshot of any given oil is to look at the "Total Base Number" (basically a measurement of the consumable portion of the oil protection package). With the TBN, the higher the number the better the protection package and the longer the oil can go without being changed. The TBN for the Kendall Synthetic is rated at 8.5 while the typical synthetic oil is at least 10.0 with some (like the Mobil 1 0W-40 that I use) reaching the high 12 to the low 13 range.
While the Kendall synthetic oil is a dollar or so cheaper than Mobil 1 or Castrol Syntec, it is still several dollars per quart above high quality conventional oils that offer similar performance. Me, I'd skip the Kendall and go for a better oil.
Best Regards,
Shipo
Thanks again for taking the time to explain!
The price for 5 qts. was little less than $14. How about Pennzoil Platinum Syn? :confuse:
Hi, My 2002 Odyssey seems to be leaking from the cylinder head gasket. The oil level was 3/8" over top mark on dipstick for 6000 miles and recently I've been driving faster. Think this could have caused oil pressure to blow seal or cylinder head gasket or would it tak a lot more oil? Hope you get this. Thanks.
Walt
This oil was in use for too long a distance for this engine to handle as can be seen by the higher than average amount of wear metals (Iron 35ppm). The TBN was 0.0, showing no active additive in the oil. Silicon at 44 ppm is either from a silicone-based lube/sealer/gasket or it is dirt getting past the air filter, so check that out. Oil viscosity was higher than normal due to extended use. We suggest a 7500-mile oil change to help improve wear and check back to see the results.
I know there are some people who don't like Amsoil, but I'm looking for everyone's opinion of this.
Best Regards,
Shipo
Mobil doesn't make that claim for any of their oils (haven't for decades, IIRC), and I think that Amsoil only makes that claim for a few of their oils. FWIW, oils that are capable of that many miles require additives that aren't the best for modern emissions systems, and as such the formulas for most oils no longer support that kind of mileage, even if they say that they do.
Best Regards,
Shipo
They also only recommend doing the 25,000 mile complete OCI if you are using both an amsoil oil filter and air filter.
Changing the filter at the halfway point introduces between 0.5 and 1.0 quarts of fresh oil into the system. That would tend to rejuvenate the additive package.
Nope, they only claim 15,000 for the EP product line.
Best Regards,
Shipo
SERVICE LIFE
AMSOIL Synthetic 5W-30 Motor Oil is recommended for extended drain intervals in unmodified(1), mechanically sound(2) gasoline fueled vehicles as follows:
• Normal Service(3) – Up to 25,000 miles or one year, whichever comes first.
• Severe Service(4) – Up to 15,000 miles or one year, whichever comes first.
• Replace AMSOIL Ea oil filter at the time of oil change up to 25,000 miles or one year, whichever comes first (other brands at standard OEM* intervals).
• In all non-gasoline fueled vehicle applications, extend the oil change interval according to oil analysis or follow the OEM* drain interval.
*OEM – Original Equipment Manufacturer
(1) Engines operating under modified conditions are excluded from extended drain recommendations. Examples include the use of performance computer chips; non-OEM approved exhaust, fuel or air induction systems; and the use of fuels other than those recommended for normal operation by the manufacturer.
(2) Mechanically sound engines are in good working condition and do not, for example, leak oil or consume excessive amounts, are not worn out, do not overheat, do not leak anti-freeze and have properly working emission control systems. AMSOIL recommends repairing malfunctioning engines prior to the installation of AMSOIL synthetic oils.
(3) Personal vehicles frequently traveling greater than 10 miles (16 km) at a time and not operating under severe service.
My 2001 Echo with 157k miles gets either ASL 5W-30 or Mobil 1, 5W-30 at slightly varying intervals, the last OCI was a little over 16k miles.
See: http://tinyurl.com/ybtok3
I do use a dual filter by-pass setup and I do change my full flow oil filter every 8k miles. I use the cheapest oil filters, usually Supertech from Wallyworld.
My trips are mostly to and from work, at least 40 miles every time. Another 500 miles every other weekend to the cabin.
