2024 Chevrolet Silverado Lease Deals, Incentives, Rebates, and Prices
191012141518
  • kyfdxkyfdx Moderator Posts: 272,460
    jostalli said:
    Could I please request MF, Residual, & Incentives for:
    Silverado 1500 Crew, RST, RWD, 24/12k
    Silverado 1500 Crew, RST, RWD, 36/12k
    Zip: 34610
    .00219 MF and 70% residual
    .00163 MF and 61% residual
  • Lexic08Lexic08 Member Posts: 7
    Hello, Can I please get the MF/RV for a Silverado 1500 Crew,Rst,Rwd 36/12
    Also for a Hight country Rwd 36/12
    Zip Code 91791
  • MichaellMichaell Moderator Posts: 268,581
    Zip Code 91791
    RST - .00163 MF and 61% RV
    HC - .00120 MF and 61% RV
  • richardbrownhvacrichardbrownhvac Member Posts: 2
    edited July 2024
    Zip code 20601
    MF and Residual for:
    Silverado 1500 Crew cab LT Turbomax 4WD 36/10K
    Silverado 1500 Crew cab LT V8 4WD 36/10K
    Please and thank you
    Zip code 20601
    .00163 MF and 62% residual
    $1000 incentive on Turbomax
  • Bgivs21Bgivs21 Member Posts: 6
    Hello, could I please request MF, Residual, & Incentives for:
    Silverado 1500 Crew, RST, AWD, 36/12k
    Silverado 1500 Crew, RST, AWD, 36/10k
    Zip: 10601
    Zip: 10601
    $1000 incentive on Turbomax engine only
  • Jacks181218Jacks181218 Member Posts: 15
    Can I please get the MF and residual for a diesel 4WD Crew Cab, Short Bed High Country. Zip is 02116.
    36m/12k and 48m/12k
    36m/12k and 48m/12k
    .00120 MF and 61% residual
    .00170 MF and 54% residual
  • BingzirBingzir Member Posts: 10
    Hello!
    Can I please have the MF/Residual for a Silverado 1500 Crew Cab/Short Bed 4x4 in the LT Trail Boss trim?
    Zip: 46373
    Thanks!!
    Bingzir said:
    Hello!
    Zip: 46373
    Thanks!!
    .00212 MF and 64% residual
  • djbrooks03djbrooks03 Member Posts: 13
    39/12K
    36/12k
    48/12k
    Can anyone provide Money Factor, Residual %, and incentives on a 2024 Chevy Silverado Trail Boss LT in 57501.
    39/12K
    36/12k
    48/12k
    36/39
    .00212 MF and 63%/61% residual
    48
    .00236 MF and 55% residual
  • arvaniteethisarvaniteethis Member Posts: 4
    Can you please provide MF, RV, and any incentives on a 1500 RST 6.2L 4WD crew short box for 06514?
    36/10k
    48/10k
    36/10k
    48/10k
    .00163 MF and 62% RV
    .00220 MF and 56% RV
  • Deals100_DealsDeals100_Deals Member Posts: 3
    Can I have the RV / MF / Incentives on the following:
    2024 SILVERADO 1500 LT (2FL) TRUCK
    Crew Cab Short Box
    Terms: 36/10
    Zip: 33186
    Crew Cab Short Box
    Terms: 36/10
    Zip: 33186
    .00197 MF and 69% residual
    $1000 incentive
  • LoxLox Member Posts: 8
    Can I get the MF/RV on a 2024 Chevy Silverado 1500 Custom Trail Boss Crew Cab Short Bed
    Zip 27613
    July Incentives? Anything you see in August?
    Zip 27613
    .00243 MF
    66%
    64% RV
    $1000 incentive on the turbo 4-cyl only
    No insight into August programs.
  • jostallijostalli Member Posts: 26
    Silverado 1500 Crew, Short Bed, Custom Trail Boss, 4WD, 24/12k
    Silverado 1500 Crew, Short Bed, LT, RWD, 24/12k
    Zip: 34610
    Zip: 34610
    .00282 MF and 72% residual
  • hyeteckhyeteck Member Posts: 30
    Could I please get numbers for 2024 Silverado 1500 Short Bed LT 4wd Diesel for 36/12? Zip code is 91202.
    Dealer is telling me residual is 59% but doesn't match up with what the rest of the numbers here. Are they giving me wrong information?
    Which 1500 silverado Trim/drivetrain has the most favorable residual and MF numbers?
    Crew or Double Cab?
    Crew or Double Cab?
    Crew Cab.
    Crew or Double Cab?
    Crew Cab.
    59% is the 36/15 residual; likely they didn't make the adjustment for the miles.
    Crew or Double Cab?
    Crew Cab.
    Thank you. Is the 1500 RST Crew Cab Diesel 4wd same numbers?
    Crew or Double Cab?
    Crew Cab.
    Yes
    Could I please request MF, Residual for:
    Silverado 1500 Crew, LT, RWD, 36/12k
    Silverado 1500 Crew, LT, RWD, 36/15k
    Zip: 34610
    Zip: 34610
    1LT or 2FL?
    Zip: 34610
    1LT or 2FL?
    1LT. Thanks
    Zip: 34610
    1LT or 2FL?
    1LT. Thanks
    .00163 MF and 59% residual
    Zip: 34610
    1LT or 2FL?
    1LT. Thanks
    Thanks! What is it for 36/12k?
    Zip: 34610
    1LT or 2FL?
    1LT. Thanks
    61% residual
  • RogueElementRogueElement Member Posts: 7
    Could I please get the MF, RV, & Incentives for:
    Silverado 1500 Crew, Custom, RWD, 36/12k
    Silverado 1500 Crew, Custom, RWD, 24/12k
    Zip: 34987
    edited July 2024
    scratch that request. The dealership took the deal on the LT. $500/mo. (tax included) $1000 drive off. 36/12k
    Zip: 34987
    .00254 MF and 65% residual
    .00292 MF and 72% residual
    $1000 incentive
  • socal68socal68 Member Posts: 30
    edited August 2024
    May I have the 36/10k for a ZR2 Crew Cab including the diesel and 6.2L?...92869. Ty.
    .00178 MF and 63% residual
    Either engine
  • Tim5150Tim5150 Member Posts: 101
    Can I please get MF/RV/Incentives for Silverado 1500 LT Trail Boss Crew Cab with 5.3 V8, 36/12 in zip code 32547?
    .00220 MF and 63% residual
  • Bruwins521Bruwins521 Member Posts: 5
    edited August 2024
    May I please get residual and MF for Silverado 1500 5.3 V8 LT Trailboss? 36/12k. Zip is 91761. Thank you.
    May I please have a Silverado 1500 Crew, Short Bed, RST, 4WD, 5.3 V8
    Zip- 27613
    Zip- 27613
    .00173 MF and 61% residual
  • leasehnterleasehnter Member Posts: 83
    2024 SilveradoEV 4WT 39/10 11222
    .00345 and 76%
  • Masher82Masher82 Member Posts: 55
    Do you have access to 2500 HD numbers?
    If so,
    2500 HD
    Crew
    Diesel
    Custom
    LTZ
    If so,
    2500 HD
    Crew
    Diesel
    Custom
    LTZ
    Sorry, no HD truck info
  • Eftaylor15Eftaylor15 Member Posts: 2
    edited August 2024
    Could I please get: 2024 Silverado 1500 LT Trail boss, crew cab, 5.3l.
