2024 Chevrolet Silverado Lease Deals, Incentives, Rebates, and Prices
11214161718
  • kyfdxkyfdx Moderator Posts: 272,343
    Skalini said:
    Could I get the October MF and Residual for a 2024 ZR2/ZR2 bison diesel 3.0?
    39/12k
    39/15k
    Zip is 34217.
    .00178 MF and 58% residual
  • SkaliniSkalini Member Posts: 3
    Thanks for that!
    Are those subvented numbers?
    I’m assuming like last month the residual goes down 3% between 12k and 15k miles?
    Thanks for that!
    It's always +2% for 12K/yr
    Copy. Thank you. Those October numbers are the same as September, that’s awesome!
  • ds9writerds9writer Member Posts: 20
    edited October 2024
    Hi, can you please provide the RV, MF and incentives for a Chevy Silverado 1500 4x2 for 36 mo /12 k miles in zip 78240?
  • MichaellMichaell Moderator Posts: 268,521
    Which trim?
    Which cab style?
    Which trim?
    Which cab style?
    the crew cab - the simplest trim, nothing fancy - thank you!
    ds9writer said:
    Which trim?
    Which cab style?
    LT Crew
    .00207 MF and 61% residual
    ds9writer said:
    Which trim?
    Which cab style?
    LT Crew
    awesome! thank you!
  • tomcarlintomcarlin Member Posts: 14
    Could I get the MF/RV, & incentives for a 2024 Chevrolet Silverado 1500 LT (2FL)?
    36/10000
    36/12000
    zip 15049
    36/10000
    36/12000
    zip 15049
    Double or Crew Cab?
    2WD or 4WD?
    4WD Crew Cab
    36/10000
    36/12000
    zip 15049
    tomcarlin said:
    4WD Crew Cab
    .00206 MF and 68% RV
    $1000 incentive
  • Suave0420Suave0420 Member Posts: 37
    Looking for RV, MF, and any Incentives for a 2024 Silverado 4x4 Crew Cab Short Bed LT and RST for 36/12 or 36/10 in zip 66061. Thanks in Advance.
    .00173 MF and 61% residual
    Either trim
  • kyleatenkyleaten Member Posts: 5
    2024 Chevrolet Silverado 1500 Crew Cab LT 4x4
    24m/10k miles
    MF and residual please zip 48912 thanks!
    24m/10k miles
    .00228 MF and 71% residual
  • jasonbu001jasonbu001 Member Posts: 3
    Hi, can you please provide the Residual, Money Factor, and incentives for a 2024 Chevrolet Silverado Crew Cab 2WD RST & LT for a 36/15k mile lease in 33015? Thanks in advance!
    LT - 1LT or 2FL?
    LT - 1LT or 2FL?
    Can you provide me with both? I may go with either option.
    1LT/RS
    .00207 MF and 59% residual
    2FL
    .00239 MF and 66% residual
    $1000 incentive
  • malibuneenmalibuneen Member Posts: 6
    Hi, can you please provide the RV, MF and incentives for a Chevy Silverado EV RST for 36 mo /12 k miles, 36 mo /10 miles, and 24 mo/10k miles, in zip 32225?
    24/10: .00092 MF and 66% residual
    36/10: .00088 MF and 62% residual
  • dbekosckedbekoscke Member Posts: 1
    edited October 2024
    Good morning!
    Can I please have the RV / MF / Incentives on the following:
    2024 SILVERADO 1500 LT (2FL) TRUCK (4WD)
    Crew Cab Short Box
    Terms: 36/10
    Zip: 44142
    dbekoscke said:
    Good morning!
    Crew Cab Short Box
    Terms: 36/10
    Zip: 44142
    .00206 MF and 69% RV
    $1000 incentive
  • Mercadocapital1Mercadocapital1 Member Posts: 24
    Hello can you please provide MF and RV for a 2024 Chevrolet Silverado 1500 LT (2FL) Crew Cab located in 48306. Lease would be for 15k miles per year for 3 years. Thank you.
    .00206 MF and 66% residual
    $2000 incentive
  • Hockeyb79Hockeyb79 Member Posts: 17
    Can I please get the MF and RV for a 2024 Silverado ZR2 24/12 and 36/12 in zip 14580.. Thanks! Any incentives too please
  • AP2025AP2025 Member Posts: 11
    Could you please provide the MF, Residual, & Incentives for:
    Silverado 1500 custom, Crew, Trail Boss, 36/10k
    Silverado 1500 custom, Crew, Trail Boss, 36/12k
    Zip: 11779
    .00225 MF and 70% RV
    .00178 MF and 62% RV
    Zip: 11779
    .00254 MF and 65% residual
  • cod12998cod12998 Member Posts: 5
    Can you please provide the MF, residual, and incentives for a 24 Silverado, Crew, LT Trail Boss 4x4
    Zip 21114
    Zip 21114
    .00220 MF and 64% residual
  • Anabanana745Anabanana745 Member Posts: 17
    edited November 2024
    could I get the MF and residual for 36/12 for a 2024 LT trail boss 4wd? zip 27607
    does Chevrolet typically mark up the MF? how much?
    .00220 MF and 63% residual
    Typically, Chevy dealers don't markup the rate. However, if they do, we've seen markups as high as +.00100
    Insist on the base rate
    thank you! is there any difference in the MF and residual for LTZ 4wd? same location and terms
    .00178 MF and 62% residual
  • maddierileymaddieriley Member Posts: 38
    2024 1500 LT Trail Boss 5.3L 8cy Extra Short Bed. Looking for MF, residual and any incentives on 36/15 lease for zip 43725 Thanks
    .00220 MF and 61% residual
    Does the custom trail boss have the same numbers as the LT trail boss? Thanks
    No.
    Thanks, can I get the MF, residual and incentives on the following. Zip 43725 36/15
    2024 Custom trail boss V8 4x4 short bed
    2024 LT (2FL) V4 4x4 short bed
    Double or Crew cab?
    Crew Cab
    Crew Cab
    .00254 MF and 63% residual
    .00206 MF and 66% residual. $1000 incentive
  • amsmith83amsmith83 Member Posts: 23
    Thanks, can I get the MF, residual and incentives on the following. Zip 77498 36/12
    2024 RST Crew Cab 2WD
    2024 LT Crew Cab 2WD
    LT - 1LT or 2FL?
    LT - 1LT or 2FL?
    2FL
    .00206 MF and 68% residual. $1000 incentive
  • RPM_3RPM_3 Member Posts: 1
    Thanks, can I get the MF, residual on the following. Zip 29681 36/15
    2024 LT Trail boss V8 4x4 short bed
    2024 RST V8 4x4
    Are the MF and residuals the same for a 2025 LT Trail Boss as the 2024?
