2024 Chevrolet Silverado Lease Deals, Incentives, Rebates, and Prices
11112131517
  • kyfdxkyfdx Moderator Posts: 261,893
    RPM_3 said:
    Thanks, can I get the MF, residual on the following. Zip 29681 36/15
    2024 LT Trail boss V8 4x4 short bed
    2024 RST V8 4x4
    Are the MF and residuals the same for a 2025 LT Trail Boss as the 2024?
    .00220 MF and 61% residual
    .00173 MF and 59% residual
    2025 model discussion
  • ajgrahamajgraham Member Posts: 52
    Could I get the MF, RV and incentives on the Silverado EV RST in 77380 please. On a 36/12k lease. Thanks in advance
  • MichaellMichaell Moderator Posts: 259,714
    .00088 MF and 61% RV
  • auburgauburg Member Posts: 8
    Can I get RV and MF for 2024 CHEVROLET SILVERADO EV WORK TRUCK 36/10, 36/12, 24/10, and 24/12. In 36832.
    3WT or 4WT trim?
  • mxhill8mxhill8 Member Posts: 4
    Can someone please provide me with MF and RV of Chevy Silverado 1500, lease terms 36/15 in 48301 for RST and LT (2FL) trim models. Thank you!
    2FL: .00206 MF and 66% residual. $2000 incentive
    RST: .00173 MF and 59% residual
  • JGJ2020JGJ2020 Member Posts: 16
    Hello - Could you share MF/RV/incentives for the following Silverado EV's in 02493?
    Silverado EV Work Truck 3WT - 36/10
    Silverado EV Work Truck 4WT - 36/10
    Silverado EV RST - 48/10
    .00160 and 66%
    .00128 and 64%
    .00143 and 55%
  • DhaegDhaeg Member Posts: 25
    Can I get mf rv and any incentives for 2024 Silverado ltz 24mo 12k miles
    71006 zip
    Dhaeg said:
    71006 zip
    .00225 MF and 70% residual
  • 240vPlug240vPlug Member Posts: 18
    Greetings all,
    May I please have the Money Factor + Residual Value for a: 2024 Chevrolet Silverado EV RST?
    36/15 & 24/15
    Zipcode is 21771
    240vPlug said:
    Greetings all,
    36/15 & 24/15
    Zipcode is 21771
    .00092 and 64%
    .00088 and 59%
  • quesenberry96quesenberry96 Member Posts: 20
    Can I have the MF and RV on a 2024 Chevrolet Silverado 1500. 36/12 in 34434 please?
    Which cab style?
    Which trim?
    4x2 or 4x4?
  • amsmith83amsmith83 Member Posts: 23
    Thanks, can I get the MF, residual and incentives on the following. Zip 77498 36/10
    2024 RST Crew Cab 2WD
    2024 LT (1LT and 2FL) Crew Cab 2WD
    RST - .00173 and 62%
    1LT - .00173 and 62%
    2FL - .00206 and 69%; $1000 incentive
    240vPlug said:
    Greetings all,
    36/15 & 24/15
    Zipcode is 21771
    .00092 and 64%
    .00088 and 59%
    Thank you. Since this is an EV do you know if GM offers the 7500 cap cost reduction on leases?
    240vPlug said:
    240vPlug said:
    Greetings all,
    36/15 & 24/15
    Zipcode is 21771
    .00092 and 64%
    .00088 and 59%
    We don't know, but as far as we can tell, they do not.
  • spr2014spr2014 Member Posts: 23
    Hello! May I have RV, MF and any incentives on 24 crew cab 4wd High Country for 36/12 in 28270? Thank you!
    .00128 MF and 61% RV
  • abm54671abm54671 Member Posts: 24
    Hello, may I have please have the MF/Residual value and any incentives for the 2024 crew cab 4wd RST with 5.3L V8. 36/12,000 in 28405.
    .00173 MF and 61% residual
    Can you also send me the numbers for 24/12,000 on same truck above? Thank you
    .00228 MF and 70% residual
    Ok. Last ask for the 2024's. Just got back from the first run at the dealer.
    Can I please have the MF/RV @ 36/12,000 for the following:
    1. 4wd Crew Cab LTZ 5.3L V8
    2. 4wd Crew Cab High Country 5.3l V8
    Does Z71 package change the RV for any of the silverado trims?
    .00178 MF and 62% residual
    .00128 MF and 61% residual
    No info on the Z71 package, but it's unlikely it would make any difference
  • mustangz5mustangz5 Member Posts: 83
    Can I please have the numbers for an EV RST. 24/36 @12K in 44070. Thanks
    .00092 and 65%
    .00088 and 61%
    Can I get mf, rv, and incentives on 24/12 and 36/12 on Silverado ev wt4, LT, and rsv? 36832
    I don't see an LT trim for the EV
    4WT
    .00096 MF and 68% residual
    .00128 MF and 63% residual
    RSV
    .00092 MF and 65% residual
    .00088 MF and 61% residual
  • khoward2001khoward2001 Member Posts: 41
    Last request;l for the evening. At the dealership now
    Can I get mf, rv, and incentives on 39/10and 48/10 on Silverado ev rsv? Zip 28546
    RST?
    .00088 MF and 60% RV
    .00143 MF and 55% RV
  • ucfnights2010ucfnights2010 Member Posts: 17
    Hello, can I please get the mf, RV, and incentives on the Silverado 1500 2.7L Turbomax for zip code 37206. 3 year, 30K miles
    2FL crew cab, short box (4WD)
    Custom trail boss, crew cab, short box (4WD)
    Custom, crew cab, short box (4WD)
    .00206 MF and 69% RV
    .00254 MF and 66% RV
    $1000 incentives
  • scho1985scho1985 Member Posts: 9
    Hello!
    Could I get the MF, RV and incentives on the Silverado 1500 (4x4) in 92821 for below models please. On a 36/10k and 24/10k lease. Thanks in advance
    LT Trail boss
    Customer
    RST
    scho1985 said:
    Hello!
    LT Trail boss
    Custom
    RST
    LT TB
    .00254 MF and 71% residual
    .00220 MF and 64% residual
    Custom
    .00292 MF and 73% residual
    .00254 MF and 66% residual
    $1000 incentive
    RST
    .00228 MF and 71% residual
    .00173 MF and 62% residual
  • USCMC3811USCMC3811 Member Posts: 27
    Can I get the MF and residual and any incentives for the 2024 and 2025 Silverado RST EV 12k/36
    Zip code 28078
    Zip code 28078
  • superfastf7superfastf7 Member Posts: 3
    Hello, could I please have the MF/Res/incentives for 2025 Silverado RST Duramax. 12k/36 and 12k/39.
    Zip 05444
    Zip 05444
    Please repost into the 2025 Silverado discussion
  • pdurant1980pdurant1980 Member Posts: 27
    Can I get the MF, Res, Incentives on
    2024 Silverado TrailBoss LT for 36/12 and 48/12 for 36526
    Also can you show MF for different credit tiers? Thank you!
    .00220 and 63%
    .00224 and 56%
    No info on lower credit tiers
  • ck20851ck20851 Member Posts: 4
    Hi can I have the MF and Res for Silverado EV 4WT, 36/10K, for 20862 and 90211 zip code. And any incentives or lease cash. Thank you.
    .00128 MF and 64% RV
    Can I also have the MF/RV for same truck in LT trim?
    36/12000 and 24/12000
    Either trim
    Can I have the MF and Res for '24 Silverado EV 3WT and 4WT, 24/10K and 36/10K, for 20862 and 90211 zip code. Thank you and Happy New Year.
    3WT
    .00143 MF and 71% RV
    .00160 MF and 66% RV
    4WT
    .00096 MF and 69% RV
    Either location
