2025 Chevrolet Silverado Lease Deals, Incentives, Rebates, and Prices
1246789
  • kyfdxkyfdx Moderator Posts: 275,761
    md99800 said:
    Can I have the 36:10 numbers for the Silverado 1500 WT, 4x4 please? I don’t know if there’s a difference but specifically I’m looking for the 4-door.
    Zip 83854
    Double Cab and Crew Cab both have four doors. You'll have to specify which one.
  • turbo320turbo320 Member Posts: 56
    Can you please provide the MF, RV and Incentives for a 2024 Silverado EV WT4 36/12k and 24/12k for 93015 zip? Thank you
  • md99800md99800 Member Posts: 42
    edited March 2025
    Heh, crew cab and double. Either works.
    Sorry wrote that without much coffee this morning. I meant just not the regular cab
  • MichaellMichaell Moderator Posts: 270,871
    Please repost into the 2024 Silverado discussion
    Zip 83854
    Double - .00242 MF and 65% RV
    Crew - .00257 MF and 66% RV
  • tjptjp Member Posts: 11
    Hello, can you please provide the MF & RV for 2025 Silverado 2500 ZR2 6.6L gas and 2025 Silverado 2500 LTZ 6.6l gas 36/10 and 24/10.
    LTZ
    .00400 MF and 78% residual
    .00353 MF and 69% residual
    ZR2
    .00410 MF and 80% residual
    .00363 MF and 70% residual
    LTZ
    ZR2
    Sorry I am new to this. Do these change every month? So April 1st it will change?
    tjp said:
    LTZ
    ZR2
    Yes, new programs start on Tuesday. They may or may not change
    LTZ
    ZR2
    Can you please update this with the April numbers when they are released tomorrow.
  • khoward2001khoward2001 Member Posts: 56
    Can you please provide the MF, RV and Incentives for a 2025 Silverado High Country 1500 4x4 36/12k and 39/12k for 28546 zip? Thank you
    tjp said:
    LTZ
    ZR2
    No change for April
    .00129 MF
    61% and 58% residual
    Can I please get the MF, RV, and incentives for 2025 Silverado 2500 High Country 6.6l Gas 24/10, 36/10, and 39/10 for zip 45005
    .00393 MF and 74% RV
    .00344 MF and 67% RV
    .00344 MF and 64% RV
  • hooligans34hooligans34 Member Posts: 4
    Could I please get the RV, MF, and incentives for a 2025 Chevy Silverado1500 LT and LT Trail Boss. 3/15000 zip 16836
    LT: .00173 MF and 59% residual
    TB: .00208 MF and 61% residual
  • SuaveRCSuaveRC Member Posts: 24
    Hello.
    Could you please provide the MF,RV & incentives for a 2025 Silverado 1500 LT Trail Boss Crew 4WD cloth interior, & GMC Elevation with leather & sunroof in 78748 for the following terms:
    48/15
    https://www.capitolchevy.com/new/Chevrolet/2025-Chevrolet-Silverado-1500-aec47635ac183f1287c59be78aefc2ae.htm
    https://www.covertbuickgmcbeecave.com/inventory/new-2025-gmc-sierra-1500-elevation-four-wheel-drive-crew-cab-3gtuuced0sg141507/
    SuaveRC said:
    Hello.
    48/15
    Trail Boss
    .00208 MF and 59% residual
    .00233 MF and 53% residual
    Ask Sierra questions in the appropriate discussion
  • AllianceHaulerAllianceHauler Member Posts: 6
    Can I get the MFs, RVs, and any incentives for the 2025 Silverado EV RST, zip 32766:
    36mo/12k
    24mo/12k
    36mo/12k
    24mo/12k
    Extended or Max range?
    Can I please get the MF and RV for 2025 Silverado 2500 LTZ, ZR2 & High Country for 24/12 and 36/12
    What is your location?
    45005. Sorry forgot to add that
    LTZ
    .00400 and 77%
    .00353 and 68%
    ZR2
    .00410 and 79%
    .00363 and 69%
    HC
    .00393 and 73%
    .00344 and 66%
    Max range please. Thanks!
    36mo/12k
    24mo/12k
    .00205 MF and 68% RV
    .00300 MF and 74% RV
    Are there different tiers from GM financial for lease money factor or is the money factor the same across the board and the tiers are only for financing?
  • wheelspinwheelspin Member Posts: 68
    Can I get MF/RV for 2025 Silverado EV LT (ext range)?
    24/10
    27/10
    78738
    No, there are tiers for money factors, just like APRs for finance
    24/10
    27/10
    78738
    .00292 MF
    85%
    83% residual
    So are these money factors you provided a lower tier and they could end up being different if you get a high tier during credit check?
    LTZ
    ZR2
    LTZ
    ZR2
    No, those are the top tier rates
  • ShepDogShepDog Member Posts: 2
    Can you please give MF/RV on 2025 Silverado RST Crew Cab 4WD with 6.2 in 76210 for
    36/15k
    36/15k
    .00173 MF and 59% RV
  • cmcquaid3788cmcquaid3788 Member Posts: 9
    Can you please give me the MF and RV for a 2025 Chevy Silverado LT Trail Boss Crew Cab - VIN 3GCUKFED4SG133692 (if this helps?). Looking at 36/12 in area code 35759.
    .00208 MF and 63% RV
  • cvrobotcvrobot Member Posts: 22
    Can you please provide the MF, RV, and Incentives for a 2025 Silverado RST and LT EV (Extended Range for both) 36/12k/15k and 24/12k/15k and 15 for 32311 zip?
    Thanks in advance!
    Thanks in advance!
    LT
    24/15: .00292 MF and 83% residual
    36/15: .00284 MF and 76% residual
    RST
    .00300 MF and 73% residual
    .00205 MF and 66% residual
    No incentive info
    Are there any rebates/incentives for silverado 2500 right now? Dealership website says $1000 manufacturer offer customer cash but I do not see that listed on the chevrolet website
    I don't see any incentives applicable to a lease. We don't have a list of all possible purchase incentives
    Can you please provide the MF, RV, and Incentives for a 2025 Silverado LT EV (Extended Range) 36/12k/15k for 35759 zip?
    .00284 MF and 76% RV
  • Joeltorrez11Joeltorrez11 Member Posts: 5
    edited April 2025
    Hi can i Please get the MF , RV and Incentives for a 2025 Silverado LT 2FL Crew Cab 4x4 Location 90706
    I am also a current Silverado lease owner.
    Thank you!!
  • Rimas9813Rimas9813 Member Posts: 9
    Hi, was looking for incentives, RV and MF on 2025 Crew Cab 4WD Rst and Trail Boss
    3yr/36k mile Zip code 77469
    Thank you!!
    .00187 MF and 66% residual
    .00240 MF and 74% residual
    $1000 incentive
    We don't have the loyalty information
    TB: .00208 MF and 63% residual
    RST: .00173 MF and 61% residual
    Could I also ask about the LTZ 4WD
  • ElonSigElonSig Member Posts: 39
    Hi, folks. Would greatly appreciate MF and residual on the following:
    2025 Silverado EV
    RST Trim
    Zip 20105
    36/12 and 24/12 terms
    .00173 MF and 62% residual
