2025 Ford Mustang Mach-E Lease Deals, Incentives, Rebates, and Prices
2456715
  • kyfdxkyfdx Moderator Posts: 275,573
    Carlos66 said:
    May I have the MF, residual, and incentives for a 36/10 lease Premium RWD Ext. Battery in 90806? Thank you!
    1.73% APR
    51% residual
    $4000 lease cash
  • crescentonepointfivecrescentonepointfive Member Posts: 11
    May I please have MF, residual and incentives for 2025 Mach E Premium RWD Ext Battery 78704?
    24/10
    26/10
    39/10
    If there is a better MF and residual than the term I'm asking for can you please provide? Trying to find the sweet spot.
    24/10
    26/10
    39/10
    0.24% APR and 57% residual
    1.73% APR and 51% residual
    1.75% APR and 49% residual
    $4000 lease cash
  • CarreraaCarreraa Member Posts: 3
    Hi! Can I please have the MF, residual and incentives for a 2025 Mach E GT AWD 21701 - 36/12 & 26/10?
    1.73% APR
    50% residual
    $3500 lease cash
  • mysteryhowellmysteryhowell Member Posts: 5
    edited April 2025
    Looking to lease a 2025 Premium Extended range RWD with panoramic roof, Glacier blue, 36 (and or 39) months, 10500 miles zip code 90713
    $4000 lease cash
  • Squee477Squee477 Member Posts: 1
    Hey there! Could I please get the MF, residual and incentives for a 2025 Mach E Premium, RWD, Standard Range - in the 91601 area?
  • mike70243mike70243 Member Posts: 2
    Hi There - Could I please get MF, Residual, Incentives etc for 2025 Mach E Premium, Extended Range for 3/36,000 and 39/36,000k - Zip: 28104 - Thanks!
    RWD or AWD?
    RWD or AWD?
    RWD - Thanks!
    mike70243 said:
    RWD or AWD?
    RWD - Thanks!
    If you take 12K Mi/yr, then you get 39,000 miles with the 39 month lease
    1.73% APR
    50% residual
    39/12
    1.75% APR
    48% residual
    $4000 lease cash
    Hi I asked a few weeks ago, but I think the lease cash changed
    Looking to lease a 2025 Premium Extended range RWD with panoramic roof, Glacier Gray, 36 (and or 39) months, 10500 miles zip code 90713
    36 mo
    39 mo
    $6500 lease cash
  • r_mach_er_mach_e Member Posts: 2
    Hi there - looking for APR, residual, and incentives for a premium AWD extended range in 80031 for both 39 months / 10,500 and 36 / 10,500. Thank you!
  • MichaellMichaell Moderator Posts: 270,715
    36: 1.73% APR and 52% residual
    39: 1.75% APR and 50% residual
    $6000 incentive
  • skf42010skf42010 Member Posts: 1
    Hello, can you please provide the MF & residual for the Premium with sports package, RWD, extended battery 36/10 lease. Can you also please quote the same for AWD. I’m in zip code 07716. Thank you!
    1.73% APR
    RWD: 51% residual. $6500 lease cash
    AWD: 52% residual. $6000 lease cash
  • cristo327cristo327 Member Posts: 6
    Hi, can I get the residual and MF for a 2025 Mustang Mach-e RWD with a 36-month lease and 12k miles a year? The Zip Code is 32819. Also, are there any incentives?
    Which trim?
    Standard or Extended range?
    Extended Range please
    Which trim?
  • ev_curious98ev_curious98 Member Posts: 2
    Hi there - looking for APR, residual, and incentives for a premium AWD extended range with panoramic roof in 98107 for both 39 months / 10,500 and 36 / 10,500. Thank you!
    36: 1.73% APR and 52% RV
    39: 1.75% APR and 50% RV
    $6000 incentive
  • CodeWzrdCodeWzrd Member Posts: 2
    Hi, I'm looking for APR, residual, and incentives for a premium AWD extended range with panoramic roof in 06604 for both 24 months / 12000 and 36 / 12000. Thank you!
    I was quoted 2.73% for excellent credit which is too high based on this thread. I was also quoted a residual value of 51%.
    $6000 lease cash
    Looks like they are marking up the rate on your quote
  • FireflyShipWorksFireflyShipWorks Member Posts: 1
    Hi, could you please give me the MF/APR, residual, and incentives for a Mach-E GT on a 36-month lease for both 12K miles and 15K miles, in zip code 75238? Do you need included options when calculating the MF or residual? If so, my options are the Performance Upgrade, Interior Protection Package, and Exterior Bumper Protector. My understanding is that if an option is factory installed then it would be included in the residual determination, but if it's dealer installed then it's not included. Is that accurate?
    When you provide MF/APR, is it the buy rate from Ford Credit, and assumes a "good" credit rating? If so, I would expect there to be some level of dealer markup, which should be negotiable for those with excellent credit.
    1.73% APR
    48% residual
    $5500 incentive
    The APR is the buy rate for top tier credit, and the dealer can mark it up for extra profit.
    For the residual, use the bottom line number from the factory window sticker, including options, packages, and destination charges.
  • saladaze88saladaze88 Member Posts: 5
    Hey there. I'm looking for MF/APR, residual, and incentives for a Premium AWD Extended Range with panoramic roof in 19064 for both 24/10,500 and 36/10,500. Thanks!
    0.24% APR and 58% residual
    $6000 lease cash
    hello, may I please have the money factor, residual, and incentives for a 24 month / 10,500 mile lease on the 2025 mach-e premium RWD Extended range in 91354?
    $6500 incentive
    thank you!
  • finya20finya20 Member Posts: 12
    Hello, thank you for all your help. Could you please provide the residual , MF and incentives on AWD Standard range For 1) Select and 2) Premium.
    Looking for 24/10K and 36/10K programs. ZIP: 07652.
    TIA
    TIA
    24: 0.24% APR and 57% residual
    36: 1.73% APR and 51% residual
    Prem: $6250 lease cash
    Select: $5500 lease cash
  • pmax9113pmax9113 Member Posts: 2
    Hello, may I please have the money factor, residual, and incentives for a 36 month / 13,500 mile lease on the 2025 mach-e premium AWD Extended range in 44720? Thank you.
    1.73% APR and 50% residual
    $6000 lease cash
    $6000 lease cash
    Shoot! The dealer is quoting 2.98% for top tier credit. Walk away? This is my first lease so I greatly appreciate your help!
    $6000 lease cash
    Insist on the base rate, if you have top tier credit
    Hi there - looking for APR, residual, and incentives for a premium AWD extended range in 80012 for both 39 months / 10,500 and 36 / 10,500. Thank you!
    $6000 incentive
  • JaydeeTreJaydeeTre Member Posts: 1
    Hi can you please help in providing rate, residual, and incentives/cash for a premium RWD extended range in 85310 for:
    24/12
    24/12
    24/12: 0.24% APR and 56% residual
    36/12: 1.73% APR and 50% residual
    $6500 lease cash
  • iBortexiBortex Member Posts: 3
    Can you provide the residual percentage and money factor for a 2025 Mach-E Premium RWD Extended Range, 36 months, 10k miles/year, zip 32820
    1.73% APR
    51% residual
    $6500 incentive
  • cjdrummercjdrummer Member Posts: 1
    Can you please provide me the RV, MF, and incentives for 2025 mustang mach E Premium AWD Extended battery for 36m/10,000/12,000 in zip 78642?
    1.73% APR
    51% residual
    $6000 lease cash
  • ExuberantBananaExuberantBanana Member Posts: 58
    Hi there - looking for APR, residual, and incentives for a Select AWD in 60491 for both 36 months / 10,500 and 24 / 10,500. Thank you!
