2025 Porsche (All Models) Lease Deals, Incentives, Rebates, and Prices
1679111217
  • MichaellMichaell Moderator Posts: 268,554
    V8PRO said:
    V8PRO said:
    Hi, can I get the latest MF, residual and incentives in 94941 for Macan 4 EV and Taycan 4 EV.
    24/10k and 36/10k. Thank you!
    I don't see a Taycan 4. Please check the trims and try again
    Hi Kyfdx,
    If you don't have info on the taycan 4 could you please check taycan base (rwd). Thanks!
    Standard MF (we don't have the rate for Q2, yet)
    Macan - 63% and 54% RV
    Taycan - 68% and 59% RV
    Hi V8PRO,
    Thank you for this info on all the models!
    Looking please for lease rates and residual %-
    Macan 4S EV, zip 95032. 36 months/ 12K miles, and 36 months / 15K miles.
    Do the lease rates vary with credit- Tier I, II, III, etc?
    Are the April rates/ Q2 out yet? Or is the .0035 money factor from Q1 still what dealers are using?
    Standard MF and 54% RV
    Yes, lower credit tiers have a higher MF.
    We don't know what the standard rate for Q2 is, yet. It was .00350 for Q1.
  • DDT99DDT99 Member Posts: 65
    Can I please have MF , residual and MRM for 25 Panamera Turbo e-hybrid in 91436. 24/10 and 24/12. If standard MF, is that .0035?
  • kyfdxkyfdx Moderator Posts: 272,422
    Standard MF and 63% residual
    We don't know the standard MF for the 2nd quarter.
    Last quarter, it was .00350 MF
    What happens at 10K miles and do you know the MRM?
    +1% for 10K/yr
    $226,500 MRM
  • tomdzhtomdzh Member Posts: 13
    Can I please have the MF, RV, and any incentives for a 2025 Porche Macan EV base? 98006, 24/10k and 36/10k. Thanks!
    Standard MF
    64%, 55%, 55% residual for 24, 36, 39 months
  • silverstar336silverstar336 Member Posts: 24
    Hello, what are the RV, MF, MRM of a 2025 Taycan Turbo for 36/10 in 27519? Any rebates? Thank you
    Standard MF and 50% RV (either 36/10 or 39/10)
    $7500 incentive
    $207,900 MRM
  • Tonyatlanta8168Tonyatlanta8168 Member Posts: 6
    Can I please have the MF, RV, and any incentives for a 2025 Porche Taycan base? 30350 12/12k and 24/12k?
    The only mileage available for the 12 month term is 15K
    Standard MF
    12/15 - 72%
    24/12 - 67%
    $7500 incentive
    Standard MF
    67%, 58%, 58% residual for 24, 36, 39 months
    $7500 EV credit
    Standard MF
    $7500 EV credit
    12 month term?
    Standard MF
    $7500 EV credit
    12 month term?
    See my answer, above.
  • mkr_f30mkr_f30 Member Posts: 24
    Can I please get the numbers for a Cayenne Coupe S and Coupe S-E.
    98006 but willing to buy anywhere in nation
    $7500 incentive
    $207,900 MRM
    Thank you, what is the Standard MF?
    $7500 incentive
    $207,900 MRM
    We don't yet have the rate for Q2, but it was .00350 in Q1.
    36 months and 10 and 12k
    Do you have 2026 number yet?
  • echppechpp Member Posts: 44
    Can i please have numbers for a 2025 Macan GTS
    7500 miles / 3 years / 92618
    and 10k miles / 3 years
    36/12 (and 39/12)
    Standard MF
    57% RV
    Either model
    No 2026 numbers, this month.
    36/10 (and 39/10)
    Standard MF and 59% residual
    36/10 (and 39/10)
    7500 miles?
    36/10 (and 39/10)
    7500 miles?
    +1%
  • mjferrerasmjferreras Member Posts: 11
    Can you please provide the lease program for Cayman 718 GTS with 36/10, 39/10 for 07940?
    Standard MF and 57% residual
    Either term
    36/12 (and 39/12)
    Standard MF
    57% RV
    Either model
    Thank you, what is the standard MF rate right now?
    36/12 (and 39/12)
    Standard MF
    57% RV
    Either model
    We haven't seen it since the 1st quarter. Then, it was .00350 MF
  • vvk826vvk826 Member Posts: 15
    Hello; can I please get the MF, residual, and any incentives for a 2025 Cayenne S E-Hybrid?
    10k/36 and 10k/24. 94103. Thank you!!
    Standard MF
    67% and 58% residual for 24/36 months
  • ChristianPChristianP Member Posts: 7
    Could I get the MF and residual value for. Any incentives?
    2025 Cayenne Turbo e-hybrid
    10K/ 39 mo
    10k/36 mo
    10K/ 39 mo
    10k/36 mo
    What is your location?
    90066
    10K/ 39 mo
    10k/36 mo
    90066
    Standard MF and 56% RV
    Either term
  • jcarseyjcarsey Member Posts: 1
    edited May 2025
    Porsche Boxter $85,815
    $4500 out of pocket
    $1479/mo including tax
    $50K residual
    covering 8 months of remaining payments on my Macan
    This was over the phone, said they might be able to come down in person.
    Is this a good deal?
    $4500 out of pocket
    $50K residual
    Which model Boxster?
    Lease term and mileage?
    Location?
    Selling price?
    Adjusted cap cost?
    $4500 total out of pocket?
    As you can see, we don't have nearly enough information to give you any feedback.
    Hello, what are the RV, MF, MRM of a 2025 Taycan Turbo S for 36/10 in 27519? Any rebates? Thank you
    Standard MF and 47% RV
    $7500 incentive
    $245,000 MRM
    Either 36/10 or 39/10
  • DetectDetect Member Posts: 6
    Looking for RV and rebates on '25 Taycan Turbo GT, 12/15 and 24/7.5 in 01887. Thank you!
    Standard MF
    62%/57% residual
    $7500 incentive
  • llngoc2llngoc2 Member Posts: 21
    Looking to lease a 2025 Macan Turbo EV. Will the MF be lower if I do a shorter term with fewer miles? Or will it just have a higher RV?
    I can go down to 5000 miles/year for 24 months. (Or even lower if it helps with the MF)
    Thanks in advance for the help.
    MF is the same for all lease terms; the RV goes up for shorter terms.
    24/5
    Standard MF and 62% RV
    10k/39 and 10k/36. 94103. Thank you!!
    Standard MF and 58% residual
    Either term
  • John_SmithJohn_Smith Member Posts: 44
    Can you please help me with RV, MF for 2025 macan s , zip code 98075
    12k/36 months
    12k/36 months
    For either 36 or 39 months
  • 2004for2004for Member Posts: 52
    Hi, can you share residual, MF and incentives for 2025 Macan EV turbo for 24/7.5 and 24/10 and 36/7.5 and 36/10 for zip 95014? Thanks!
    Standard MF
    60%, 51%, 51% residual for 24, 36, 39 months, 10K/yr
    Standard MF
    Could you also share for 2025 Taycan GTS?
