Mystery car pix
1145914601462146414651485
  • ab348ab348 Member Posts: 20,958
    That's Fisgard St in Victoria. The Don Mee restaurant is still there today.
  • andys120andys120 Member Posts: 23,690
  • tmarttmart Member Posts: 2,437
    Not a clue but foreign and prior to 1968.
  • stickguystickguy Member Posts: 54,794
    FIAT 600 something? Multipa?
    Fiat 600 Multipla is correct. c. '58-'58 IIRC
  • fintailfintail Member Posts: 59,096
    Milwaukee, mid 60s, not crystal clear but zooms enough to ID several:
  • 1961 Dodge Polara.
    gen 1 Corvair convertible next to a '65 Riviera
    64 Ford Country Squire
    1963 or '64 Riviera at the far right side of the front row.
  • kyfdxkyfdx Moderator Posts: 275,963
    GTO "The Judge"
    '70?
    Another car with probably more fakes than originals out there.
    GTO "The Judge"
    '70?
    Yup, it's a '70.
    The place: Delta BC. The time: malaise. Zooms well enough to pick out several:
    the worlds supply of Aspen wagons. In HS my friend's folks had one. We called is the ashcan. Had a habit of stalling when you made a left turn. Not really something you want to experience.
    Had a 77 Aspen wagon with the slant six with a 3speed with overdrive on the floor. Got many comments on the factory floor shift. Was a very good car, my first with AC. Put over 100k miles on her. Since the color was yellow, my kids called her the Banana.
    I remember seeing one of those, when new. I was impressed with the stick on that vehicle.
  • sdasda Member Posts: 7,837
    edited May 2025
    Not all Aspens and Volares were bad cars. I knew several who owned them, had few issues, and liked the cars.
    I think the bulk of the running issues were related to the lean burn system. I would bet if you didn't have to worry about emissions inspections it would make a world of difference to strip that stuff off and put the engine back to about 1968 spec.
    Actually, Hoovie recently got a 1982 Imperial that ran like garbage. The fix was to yank off the jenky electronic carb and some associated bits, and replace it with a carb (and maybe distributor) off a late 60's Dart. Ran great after that!
    Dodger Stadium, probably either at its debut in 1962 or shortly thereafter. This one pushes a lot of buttons for folks here. :D
    2 1960 Fords (I think that is one next to the white T Bird). White Ponton. and a '57 Buick Century
  • roadburnerroadburner Member Posts: 18,728
    That was what you did on 1971 to 1980 BMWs- you'd remove the thermal reactors, all of the vacuum lines, dashpots and solenoids- and often replace the distributor with a Bosch hi-po unit. The carbs weren't so bad but they were a bit complex so they were usually replaced with a Weber 32/36 DGAV or DGEV. It was amazing how much better the cars would run.
    Dodger Stadium may be a rerun? B)
    Apparent 4 cyl MB Ponton at center R.
  • xwesxxwesx Member Posts: 18,220
    Hey, you can never have too many 1960 Fords!
    No, that's impossible. :D
    Cleveland per the source, maybe around 1970, zooms fine:
    Two Mustangs and a Corvair convertible.
  • 1962 Imperial.
  • texasestexases Member Posts: 11,289
    ‘64 Dodge 330 or 440
    1964 LeMans convertible next to the red Mustang
    That Imperial really stands out and looks dated compared to the others. A neat car in its own way.
  • bhill2bhill2 Member Posts: 2,659
    Yes, it does look a little dated, especially when you consider that the Dodge was only two years newer, and from the same company. I also agree that it was a neat car, though.
    62 is the same year as the It's a Mad Mad Mad Mad World Imperial. Today all styles have to be very rare.
    1000 block of Robson St, Vancouver, 1976, zooms well enough to ID several:
  • MichaellMichaell Moderator Posts: 270,911
    edited May 2025
    Pagoda Benz on the left.
    Early '70s Corolla on the left behind a Mustang II. That gen of Corolla was biodegradable in most places but perhaps not so much in Vancouver and on the west coast.
    Our next door neighbor when I was a kid had one of that vintage. Same color brown as our Corona.
    Green Valiant (or Dart) in front of the caddy.
    Interesting picture from London, England in 1960. Very large pic.
    the '62(?) Caddy must have been fun to pilot around London. especially with the steering wheel on the wrong side for the roads.
    1960.
    Is that the US Embassy in the background? Would explain why the Cadillac is there...
  • explorerx4explorerx4 Member Posts: 21,345
    US flag flying on top of the building.
    Two 57 Chevies and a 59 Ford.
    Huh. Didn’t see the flag. I was looking at the eagle.
    It’s possible I’ve posted this before. The Broadway store in my hometown.
    Sadly, doesn’t zoom all that well.
    A red mustang convertible next to Fin’s Fintail. I think a VW square back next to it.
    A couple of cars to the right of the Fintail, a 67 Mustang coupe and 2nd car from the right a gen 1 Olds Toronado.
    In London the 59 Ford appears to not be a Galaxie, in front of that a Rover P4, Morris Minor, looks like Austin A50 parked behind the British Ford (Zephyr I think) in the foreground. Hillman Minx between the Caddy and 57 Chevy. Cool pic.
    At The Broadway, the fintail does appear to be the color of my car. Hard to tell specifics but maybe the shorter nose of a W110. Maybe a red VW Squareback beside it. Just to the left of the 67 Mustang looks like a GM bubbletop.
  • gsemikegsemike Member Posts: 2,490
    Brooklyn Queens Ezpeessway probably late 60s
