Visitor Agreement.
I also won't go more than 12 months anyway, so at low usage, I never have to worry about going excessive miles between changes.
Like you, I have a Manila folder for each car, but I use a spreadsheet to track the work done. Date, mileage, description of work, cost.
One tab for each vehicle. Just made the first entry for the Kia yesterday.
My money is on the tech screwing it up, literally.
Years ago on my GM V8’s, the rule of thumb for the AC Delco metal canned oil filters was no more than 1 1/2 turns once the oil filter gasket made contact with the oil filter can mounting assembly surface that was bolted to the block.
I had a friend who took his ‘72 GTO to a dealer who obviously didn’t follow that rule. After calling me one Saturday with a filter he couldn’t get off, even after driving a screwdriver through the can so he could grab both ends of the long screwdriver to try getting if off that way (an old shade tree mechanics trick back then), I told him if he could un-bolt the oil can mounting assembly from the block, I could probably get the filter off by putting the assembly in my bench vise and using a large pipe wrench to grab the heavy metal plate on the bottom of the filter can. That worked but it still took some umph to do it. Those old metal can filters with the large round gaskets seemed to glue themselves to mounting assembly if they were over tighten. Not something you’d want to screw up by over tightening the filter.
Damn, why didn’t I do that instead of an oil filter log sheet like I used when the ‘05 XG 350 engine blew up and the dealer bounced the engine warranty because of a so called discrepancy with my paperwork?
I do log paid charging costs and the amount of kW on the Ariya. From there, it will be easy enough to extrapolate what it cost me to charge at home based on an average of 2.5 miles/kW and knowing my cost of electricity. (That ignores the very few times I've snagged a free L2 charger--the difference would be miniscule.)
I also try to measure (and log) tire tread depth, check the oil level, and test the 12V battery every 1,000 miles.
I was surprised when my daughter’s 4xe ate her most recent two 12 volt batteries. Each time, the battery was replaced at a Jeep dealer and each time, the dealer that replaced the battery said that they could not see the replacement in their system so I had to dig the paperwork out of the glove box.
Is it possible that the wrong battery is being installed?
I honestly think they had some bad batches of batteries - it is on the forums. The other one for those with towing package is larger and you have to modify the battery holder base to make it fit.
New battery has 3 yr free replacement from Jeep so we will see
My 4xe has wobble issues and hers has 12 v battery issues
They recommended brake flush as car is ~3 years old and over 30k miles, price was reasonable, so we said okey dokey. The also noted rear tires at 3+/32 and fronts 4+/32. As I want her to have runflats, somewhat limited selection. Dealer quoted the OEM Pirelli Cintuarto P7 RF, $424/tire mounted and balanced. Said we'd get back to you, grabbed some more cookies and soda and off we went (me to BJs for gas, her to Whole Foods to spend our retirement funds).
Got home, researched tires. Anyone have an opinion/experience with Bridgestone DUELER H/P SPORT AS RFT vs Pirelli's? Different category, but for her doesn't matter. Bridgestones decently rated on Tire Rack and available at Costco, a bit less expensive. Have requested my local guy to quote, too.
M240 remains a delight to drive, love the feeling of the thick steering wheel and, of course, the I6. And being topless. But annoying rattle somewhere on passenger side persists (I think in dash, behind glove box, I continue to try and locate it).
I figured an oil change every 8 months would do no harm😎
I didn’t mean to open up a can of worms with my oil change comment. I’m sure for roadburner his cars and driving style can tolerate 10k OCI perfectly fine. Maybe I’ve been watching too many YouTube videos where they have to dig sludge out of engines with a screwdriver after following manufacturer’s extend change schedules.
I tend to be OCD on OCIs so I’m always looking for validation that changing oil every year after 1-2k miles isn’t a waste of money.
If your better half is OK with that, I don't see any other issues (other than cost - $424/tire? Your retirement funds will be depleted quickly at that rate)
I would get normal tires and a spare. It is an option on the X3
What a morning… work laptop took a dump (less than six months old). Service desk said the code it’s flashing means either motherboard or ram slots.
Half the office is on vacation so I went on a wild goose chase to see if there was an old one to jump on for the day. Went through about 50 keys trying to get into the storage room. There were a few laptops but none that had login info.
So the boss says order a new one for myself and pick it up. Ugh Best Buy didn’t like our company CC and took forever to process the order. Finally got a verification call from them and it’s ready to pick up 5 hours later.
Have a meeting at 3.. and getting out of here. Best Buy is on the way home
And there was a holiday yesterday, if you lived in Canada.
I want her to have RFs just for the reason they exist, in case she gets a flat. Gives her the option of trying to make it home, calling me or AAA (or BMW? She's still under warranty, does that include roadside assistance? More to investigate) vs. being stuck roadside.
And I took the 7th off too!
@laurasdada
There is a glass of Eagle Rare waiting for me at home … (or maybe Weller 12)
But costs a little more.
Since the oil was changed the prior AMW!
What is AMW?
How much does a whale cost?😳
You’ve had your place in Florida long enough. Time to let that Canada day nonsense go. Happy 4th of July!
It had to be tough for the guy to walk around and describe the damage to his dealership.
8 minutes in, The ducks survived!
I really like both countries. I am in Canada for 7 months, and Florida for 5 months...I am only allowed to be in the U.S. for a total of 6 months in a year. I worked for a U.S. company for 16 years, so I celebrate Holidays for both countries...I really like Thanksgiving, it comes in Oct in Canada, and Nov in the U.S., twice as much turkey!
Most people follow the cooking directions that come with the turkey, mainly cooking until the pop up thingy pops up. When that thing pops up the bird is over cooked. Mrs. j cooks the turkey for about an hour less than the recommended time and she always puts the turkey in one of those plastic cooking bags. You’ll never have a dried out bird cooking it like that.
