Zaino Car Care Experiences
11415171920137
  • yeshua1yeshua1 Member Posts: 1
    Just recently purchased a '00 Silver Acura Tl about two weeks ago. Heard about Zaino by searching the web and awaiting my first order. Could someone help me with what steps I am to go through for the first time. Also, when I do finish that, do I need to start the process all over again. Another words do I need to strip everything off, or better yet how often should that be done each year. Sorry if this question has been repeated, new to this. Thanks for any info that you can give.
  • graphicguygraphicguy Member Posts: 14,162
    Congrats on your new car.
    The best place to start is to go to www.zainobros.com. You'll find a "tips and tricks" page there as well as a page on applying Zaino. Alternatively, you can go through some of the older posts in this topic to find how some of us put Zaino on.
    No need to start the whole process all over again with each application. That's one of the pluses of Zaino. After the initial treatment, upkeep us a breeze. Just apply Z2 or Z5 (because you have clearcoat on your car) whenever you feel like it to deepen the shine even more. You'll want to put Z1 Polish Lok on your car once a year or after every 10 coats of Z2 or Z3 just to "tighten-up" your shine.
    Let us know if we can help!
  • nojalopynojalopy Member Posts: 13
    I'm curious about the comment to reapply Z1 after 10 coats of Z2/Z3. If the original Z1 is applied to "create a superior bond of polish to paint", then why would we ever need to reapply Z1 over multiple coats of Z2? It seems more logical to say that Z1 should be reapplied if we haven't used multiple coats of Z2, and sufficient time has elapsed -- in other words, when the probability is high that the polish is "gone".
    Perhaps a question for Mr. Sal?
    Sal is certainly the "Shah of Shine" and would be able to explain how Z1 works better than I would.
    As Sal has said on his WEB site, using Z1 after 10 coats of Z2/Z3 or after 1 year "tightens" the shine. I put on Z1 every spring, regardless of the amount of coats of Z2/Z3, I "only" have 8 coats on now.
    I suppose that if you only want to put 1 coat of Z1 and Z2 or Z3 per year then that would be the right prescription. That said, multiple coats of Z2/Z3 realy does make a big difference in the depth of shine and the amount of protection you'll receive. Even though many on this board have done their own "durability" tests with Zaino with great results, since it's so easy to put another coat on, I do it fairly regularly and always increase the depth of shine with each succeeding coat.
  • luck11luck11 Member Posts: 425
    Stay away from car wash. I rinse the underbody at home on my driveway using a standard hose. This will probably do a much better job than any car wash would, and consider that many carwashes use recycled water, so you may be simply pumping salt back into those little nooks and crevices. If home is not an option, then go to a do it yourself spray wash, and use the pressurized water spray to clean the underbody.
    I too am subject to salt and sand used for roads in winter. During the winter months, I visit the local spray wash at least once every two weeks and give a good rinse to the underbody. In the spring, or if the weather cooperates, I do it in my driveway.
  • joebundajoebunda Member Posts: 4
    We just came back from Myrtle Beach,it rained a couple of hours on the way, it also rained off and on a couple days while there. My son said it looked like frozen rain on the hood the water beaded so small. when all was dry the only way to tell our new Jeep was in any water was to look at the rear hatch area. water just came off in sheets everywhere else. I Dawned, clayed,Z-1,2,6,2 the week before. THE STUFF WORKS! if u read all instructions it goes on and off fast.
  • fastdriverfastdriver Member Posts: 2,273
    joebunda-
    I know what you mean. My car looks the same after the raindrops dry. I'm having Z withdrawal here in CT with all the rain. ;-)) The forecast isn't much better for this coming week either. I guess it's okay because I have to order some more Z-5 and Z-6 anyway.
    fastdriver
  • pblevinepblevine Member Posts: 858
    Ditto that!
  • paduapadua Member Posts: 4
    I hope some of you veterans will not mind rehashing a few answers for a first time Zaino user.
    1. Do I polish lock in circles or back and forth?
    2. How much pressure do i need to apply when applying wax?
    3. Which products do I need to use on my rims?
    4. Arew any of the products damaging to glass or a sunroof?" T
  • daverosedaverose Member Posts: 233
    user.
    Z1 PolishLok should be applied in a circular motion.
    applying wax?
    "Medium" comes to mind; heavy pressure would tend to insure that you're getting more of the product off the applicator, but you have to be careful that you don't pick up any grit in the process and scratch the paint. Watch the paint surface carefully, and look at the product side of the applicator frequently. Too light a pressure would seem to risk not getting the entire surface evenly and fully coated.
    Dawn (or Z7), Z1 and Z2, Z3, or Z5 can be used. If you have it, Z12, the glass polish, can also be used on chrome.
    a sunroof?" T
    The Z12 does have some abbrassive in it, so would tend to scratch coatings that have been applied to one of the surfaces of glass, but not the shading that is within the glass.
    Rehashing is not a problem; while the Zaino web site has instructions, suggestion, and tricks, some of the advice we have was not picked up there. One of mine is passing along the suggestion to wash the car with the recommended towel material (hand size) wrapped around a sponge.
    i used z-1, z-2 on my sunroof and all glass except windshield. water just rolls off
    Aplly Z1 in circles like you would any other wax. Use light pressure (no need to "rub it in" like regular wax). Just enought pressure to make certain that you are applying it thinly/evenly. Spray the applicator with a little Z6 to dampen and then put a small amount of Z1 on the applicator. This will help in evening out the Z1 and keep your application thin.
    I use Z1/Z2 on my rims, too. Works well.
    None of the Zaino waxes will harm the sunroof, windows. Z12 is specifically formulated for windows (have not tried it on chrome, though). Wouldn't attempt it on anything else (except as daverose says, perhaps on chrome). I would use Z1/Z2 on the chrome, also
    Has anyone used one of the Zaino 'Applicator' pads as a washing cloth?
    pblevine-
    Washing cloth? Kind of small for that. No? I use a 100% cotton wash mitt made in the USA. Seems to be fine so far.
    The applicator pad is perfect for applying the Z, but not good for washing. It would take forever to wash the car with that tiny pad. LOL..... Besides, with it's cotton thread stitching, I don't think it would hold up too long.
    fastdriver
  • racer_x_9racer_x_9 Member Posts: 91
    When they start to get a little ratty looking, don't throw them out. They work great for applying z16 to the tires.
    racer_x_9-
    GREAT idea! Thanks. I never thought of that.
    fastdriver
  • lynne29lynne29 Member Posts: 46
    We have the dark tinted windows on our Sienna 2000 LE van. After seeing the Z results on the rest of the vehicle, I would like to treat the windows, looking for a cleaning, rain rolls right off, treatment. Would also like to do the clear windshield.
    It appears the windows, all but the front windshield, are treated on the outside surface and could somewhat easily be scratched.
    Any advisors out there?
    lynne29: Try to find out what sort of treatment was done to those windows. Then email Sal, he'll know if Z2 / Z6 will affect them. Good olde Z-6 does it for me.
    Applicator Pads: OK, Ok, I won't use my old pads for washing. That's a good idea 'bout using them for Z-16. After ruining a cotton towel (I cannot tell a lie: my wheel rims did it!), I'm presently down to using an old T-Shirt. And yes, I cut off ALL the seams and edges. It is 100% cotton, but I don't think it does a good job of lifting dirt out.
  • boordboord Member Posts: 27
    Bought a new Avalon. Read this topic and sent away for the Zaino stuff. But I don't understand "claying". 1. I didn't order the Zaino car wash - so can I lubricate with some other car wash liquid and water? 2. How hard do you rub/pull the clay? 3. One post said to "pull, stretch, and fold" - if the clay is pulling off contaminants, how do you get the bad stuff off the clay?
    Any thoughts that would help a newbe with claying would be appreciated. Thanks in advance.
  • peterskmpeterskm Member Posts: 79
    I saw your post on the wax forum about the Z-16 tire stuff...
    How's the durability of Z-16 and what kind of shine does it have?
    The Zaino clay is a package containing two yellow bars about 1" by 2+" by about 3/8ths" each wrapped in cellophane. It comes with directions.
    (Until you feel comfortable in doing it at a speed that won't pull the bar out of your hand or so slowly that you fall asleep or get discouraged, you might want to put a clean ground cloth/shower curtain on the ground in the area you are working and, perhaps, work in clean bare feet to keep the cloth clean. You DO NOT want to drop the clay on the ground or a dirty/muddy cloth and pick up dirt/sand that will scratch your paint.)
    Basically, you have a spray bottle of lubricant, soap mixed with water in one hand, and the clay in the other. (I don't advise that you use Dawn as the soap, here; I found that it caused the clay bar to begin separating.) You spray about a 1' by 1' area of the vehicle with lubricant, place the broadest side of the bar down on the lubricant and slide it back and forth with a somewhat gentle downward pressure. The bar should slide around and start pushing the water aside and come in more direct contact with the paint and start grabbing at any contaminants; you might even hear some soft "shussing" as the contaminants are picked up. (The first few times you do this, you might want to slide your fingers in the lubricant before and then after using the clay; you should feel an increase in the smoothness after you clay.) Once you've done that first area, move to an adjacent area and start the process over in the new area. If you use too little lubricant the bar will grab on the paint and kind of "stub."
    After a while, the clay will begin to reshape from the heat of your hand. You should also notice "stuff" dirtying the clay; rub your fingers frequently over the contaminated area to remove any visible/"feelable" grit. When the clay is fairly well-soiled, fold the dirty area in on itself and re-shape the bar for further use with a clean surface.
    You might want to mix doing horizontal surfaces with vertical surfaces, rather than do the vehicle from the roof to the rocker panels, to avoid muscle fatigue in your hand/fingers. I would do the bottom panels last from back to front just so any brake dust you pick up near the front wheels is the last thing you do. Some advise pulling off a small piece of clay to do the center of the wheels and throw it away when done.
    With care, the clay should last through many uses.
  • pjyoungpjyoung Member Posts: 885
    Place an order for Z7 today! Not just for claying, but because the doggone stuff is GOOD! Aside from the initial "Dawn" wash, I have only used Z7 on my 300M. It's been two months since I put the last coat of Z2 on my car, but it's beading like new, but when I wash with Z7 it just seems to bead that much better. And one capful to a 2 gallon bucket works fine. That little bottle isn't even half gone and I got it in January.
  • disbeliefdisbelief Member Posts: 1
    So here is my story:
    I have a one month old Acura 3.5 RL-Black(wife actual thinks it's hers), which I have already used Meguirs Showcar glaze to clean-up the dealer marks and put on a coat of Gold Coat. Before I could put on another coat I found this forum. Since reading the numerous post praising the product I have sent For the Z1/Z2/Z6/Z7 group. I have decided not to clay as I am in Los Angeles, so I know there is not much(any?)rail dust(car shipped into Long Beach).
    I expect to have my Zaino by next weekend. Wife thinks that the new towels from Bloomingdales(on sale $7.99) are for her. I may have to get more just to appease her.
    Secondly:
    My car is a gold 94-Legend Coupe, which until recently has been neglected. It is currently in the body shop having six years of dings repaired and painted. The car clearly needs the entire treatment. When I asked the bodyshop guy how long I needed to wait before I detailed the car, he said I could do it immediately. This seems contrary to what I have read here for a waiting period on aftermarket paint jobs. I would love to get right to the car but I feel I should wait some time.
    Any suggestions?
    Matt
    Tomorrow is Zaino day and I'm a bit confused on what towels to uses. I have a Wal-Mart and Target near and all of their towels say 100% cotton. Are these what I'm looking for. I hear others saying they are going to Bloomingdales and Sax. Please advise. Also, how many do I need for a 2001 Acura CL?
    Do I clay the rims? Thanks
    Does the tag say Made in USA? Does it specify that the loops AND backing are 100% cotton? You want lush-feeling towels. That translates to bath department towels. Getting the softer feeling ones will normally mean more loops in a given area than less-expensive towels.
    I would say one or two hand towels (wrapped around a sponge) to wash the vehicle (using one towel at a time), a bath size towel or two to dry the vehicle, a clean hand size one, possibly two, to apply Z1 AND the Z5 or Z2 or Z3 (if you're not using any applicators) a bath size towel or two to wipe off the dried polish, and one or two clean hand towels to give the car a Z6 rubdown. AND are you going to do multiple coats of polish before you can re-wash them. So, 2 to 8 hand towels and 2 to 4 bath towels; more is better so you're essentially touching the vehicle with unsoiled toweling. (Don't forget to wash them with liquid laundry soap only, NO bleach or fabric soften, and rinse them twice BEFORE using them. Otherwise you will have a snowstorm of lint! Long-term care is the same.)
    I would clay the rims.
  • hayrdoghayrdog Member Posts: 1
    I recently had the "perma-plate" protectant applied to my new vehicle. Can I use the z products over this?
    I did the dawn, clay, Z7,Z5, &Z6 today. I wqill wait until tomorrow for the Z2. Do I need to rewash or re-Z6 before applying? Unfortunately, I do not have a garage to keep it clean in. Any advice is appreciated. Thanks
    Your sequence of applications should have included Z1 between Z7 and Z5. Did you apply it and fail to say it, or did you not apply Z1? If you did not, apply Z1 before you apply the Z2.
    Re-washing or applying Z6 depends on how dusty/dirty the car gets overnight. You might be able to just take a clean, dry bath-size towel and lightly drag, not wipe, it over the vehicle to remove any dust, or use a California Duster or similar product to lightly brush over the surface to remove the dust after any morning dew has dried. If the surface does not get fairly clean from this, then use Z6 before you apply the Z2. If you find that your towel from the Z6 application is getting dirty quickly, stop this step and wash the vehicle.
    If your vehicle is exposed to the elements 24/7, you'll want to dust it often and use Z6 afterwards some of the time.
  • jthukraljthukral Member Posts: 17
    Last month I brought Accord 00 (Golden color, metallic clear coat paint). This is my first car and hence doesn’t have much idea about proper car care.
    I went to few shops to look for car care products and was confused by so many brands and types available.
    Today I went to Costco and brought a car kit for $19.99.It contains
    Meguiras cleaner wax, car wash, natural shine (for vinyl and rubber), along with Eagle One A2Z wheel cleaner, glass cleaner and Proseries simple green cleaner/degreaser. Also in the pack is a wax pad, brush, mitt, towel and the bucket.
    If the above stuff is not right , what should I get ? OR should I buy some additional things along with them.
    The products which I’m not comfortable in the kit are cleaner wax and wheel cleaner, also not sure of cleaner/degreaser.
    I’m not sure if I got the right stuff and want your help. Also in the store was available Coral blue car wash and Meguiras gold liquid wax. Also how is Ziano and what products I need to get from them ?
    My requirement is that I want to wash car every 3-4 week and wax every 4-5 month.
    What I understood about car care is first time I need to wash my car with water, then with mild car wash and then apply wax (do I need to polish also before waxing?) What about wheel cleaning and how often .
    Subsequent, I should wash my car with water and should wax when beading occurs.
    Your suggestions and help appreciated about proper care and right products.
    Your costco "kit" is put together with what individual products they can make the most money with when "bundled" together. Nothing inherently wrong with that except you can do better buying individual products.
    Since you're here at the Zaino topic, I'll limit the post to those products.
    Let's start from scratch for your new Accord. I highly recommend you go to www.zainobros.com and see the application techniques and "tips and tricks" sections. Use only 100% cotton, made in USA towels (Fieldcrest or Cannon). Cheaper materials in cheaper towels (namely non-cotton threading) will scratch your clear coat (causing swirls/spider webbing). Get "the Absorber" to dry your car from an automotive supply store (this is a synthetic chamois that does an excellent job in drying your car):
    1. Get some "blue Dawn" (yes, the dishwashing liquid) for your first wash (using the cotton towels). This will remove any cheap wax your dealer put on.
    2. "Clay" your car. This will get all the "imbedded" impurities out of your finish and leave an ultra clean, very smooth finish ready for waxing.
    3. Dawn wash your car again to get any clay residue off your car and remove any old wax that it didn't get the first time around.
    4. Thoroughly dry your car.
    5. Apply Z1 polish lok in a circular motion using the "polish applicator" that Zaino will give you when you order (tip--dampen the applicator with some Z6 shine enhancer and then put a small amount of Z1 in an "X" pattern on the applicator. Squeeze the applicator to get the polish to spread over the entire applicator. Thin even coats are the key. Reapply the Z1 whenever the applicator is no longer putting any Z1 on the surface).
    6. DO NOT REMOVE THE Z1. Apply Z2 over the Z1 in a front to back motion on the horizontal surfaces and up and down in the vertical surfaces. You now have two coats of wax on your car that need to dry. This could take an hour or overnite depending on how humid it is in your area. After they dry together, wipe off with another clean cotton towel. (tip--if you begin to remove the wax and it smears, it's not dry yet...wait another hour. The Z1/Z2 combo should wipe right off with no smearing if it is dry).
    7. After removing the wax, mist Z6 on a 2'X2' area and wipe right off with a clean cotton towel. This enhances the shine and makes your finish deep, reflective and very "slick".
    Your wheels should get the same treatment as your painted finish.
    That's it. This will take you about 3-5 hours depending on drying time and how meticulous you are.
    I would get Z7 car wash to wash your car after you finish the above. No need to do the "dawn wash" again or to clay (unless you have some troublesome areas with tar or bugs). Just wash with Z7, apply Z6 after the wash and put subsequent coats of Z2 on whenever you want to deepen the shine. The more coats of Z2 you put on, the deeper your shine will get.
    Once you get the 1st coat on, you'll find upkeep to be really easy. Just Z7 wash, Z6 shine enhancer and application of Z2 whenever you want to deepen the shine.
    Good Luck and let us know if we can help.
  • retiredjeffretiredjeff Member Posts: 33
    Is there any preferred way of washing those little applicator pads that Zaino sells once used to apply Z1 and/or Z2? Or has anyone found a way that does the job?
    Jeff
  • joe166joe166 Member Posts: 401
    I don't wash them very often because I don't see the point. I will just put them away and get them out and spray Z-6 on it to "soften" up the old material and go to it. I have washed it once--in the machine along with the towels. They don't hold up well to that sort of treatment. At least mine didn't. But since I ordered new stuff recently, I got another one so I have two now, one cleaner than the other, but I doubt that I will wash it again.
  • cdnpinheadcdnpinhead Member Posts: 5,625
    Thanks for the excellent summary of Zaino use. My box of stuff arrived the other day, and I went out and bought a small bottle of Dawn and a couple on Penny's towels. Now, if it'll cool off just a little bit, I'll give it a shot.
    You guys have set my expectations pretty high. I'll let you know how it turns out. Could be awhile though, since 112 degrees with humidity is not the kind of weather (it's 90 - 92 at five in the morning and just goes up from there) I'd choose to do the initial, rather time-consuming, preparation & application.
    Dang. It goes on good in the cold, and it goes on good in the heat, but at 112 degrees, I doubt one would survive long enough to enjoy the shine!
    retiredjeff-
    I just wash mine by hand with some dishwashing liguid. They don't come as clean as they would if you were able to put them in the washing machine, but the cotton threads used to sew the seams won't stand up to the washer. Maybe, if you could put the applicators inside something else in the washer maybe they would survive.
    fastdriver
  • automophileautomophile Member Posts: 780
    Sal told me to do as above - soak in a little dishwashing detergent while still damp, and rinse well. The Z dries fairly hard, and I worry about scratching if I don't clean them. when dry, I use a stiff brush to "fluff" them up a little.
    Even though it's hot out (not sure you really want to work in that heat), that doesn't neccessarily rule out doing the Zaino treatment. Humidity is the mitigating factor. If it's hot yet real dry, humidity wise (like desert conditions), Zaino will probably dry much quicker. If you've never used Zaino before, wait until you get at least a couple of coats on before you judge. After my 2nd coat, I was "stunned" with how my car looked.
    Good luck with "Zainoing". Let us know if we can help.
    I've seen posts in other topics with regards to the "Zainoites" ferver in which we recommend the products. I, for one, do not have any financial stake in Zaino Bros. Never have, probably never will (unless Sal takes them public). I make no money by recommending Zaino products.
    It is rare that one finds any product that works so well and has sterling customer service. I believe that's the reason we are all so positive about Zaino products.
    Don't want to put words in anyone's mouth, but I'm certain that other ergular posters to this forum feel the same as I.
  • desmchandesmchan Member Posts: 9
    I have z1 z2 z5 and z6. I am ready to start but I decided to use clay at the last minute. Did anyone use both the Magic clay and the clay bar from Zaino Bros? I wonder there is any difference between them. It is easier to pick the clay magic up at local pep boys.
    DCC
    Peterskm: The Z-16 "Perfect Tire Gloss" seems to hold up well. I applied my first coat on July 4th, and my car has been through a sea of mud and two washings since then. Zaino doesn't make any real 'long term' claim but states that a single application should last through 'several' washings. Z-16 doesn't contain the dreaded "S" element which as an oil will hurt rubber. It is VERY easy to apply (just wipe it on!), and can be used on any rubber product. I think it is a very good product.
    pjyoung: The "small" Z-7 bottle? Ha!
    Washing Applicator Pads: I use a small amount of liquid Tide. I rub it in gently, soak, and wash it out manually. Then I let the pads air dry for a few days. They don't seem stiff and are ready for re-use.
  • scsolarascsolara Member Posts: 47
    I see everyone talking about "misting" Z-6 on the car and wiping off. My Z-6 comes out in a stream, is a mist more effective?
    Thanks for the excellent summary of how to use the Z products. I'll got to their site and study more and will come back to you with more questions.
    BTW do I hv to buy all this z series u mentioned ?how much will it cost and how long will they last (for an av use).
    You don't need every Z product. I did not clay my new car, and I'm pretty happy with how it looks. I bought the Z1, Z2, and Z7 ( and for the interior Z9 and Z10). The Z2 lasts longer than any other "wax" I've ever used - I've gone 3 months with this coat of Z2 and water still beads up like new. I do wash it weekly with Z7. I haven't used the Z6, because I don't know how much it would do for a white car. The Z2 along with a Z7 wash works just fine for me.
  • pinecrestjimpinecrestjim Member Posts: 64
    DESMCHAN - I did not purchase Zaino's clay because Pep Boys had quoted Clay Magic at a few dollar's savings. As it turned out, PB misquoted the price and I paid as much over Zaino's price as I would have saved. The Clay Magic product worked fine, or at least I feel it did. I had never clayed a car before, and really was concerned about destroying the finish of a new vehicle. It turned out beautiful.
    I used the lubricant included in the "kit" and tossed the included polish away. I had also dried the car before claying, as I had not heard prior that it was OK not to do so - the water also acts as a lubricant. If doing it again, I'd still use the ABSORBER to remove most of the water before doing the clay.
    SCSOLARA - The Z-6 nozzle can be adjusted by turning the end. You'll find the adjustment requires fine tuning to get a really good mist. You'll also find you still get a few drops along with the mist. If you're getting a stream of liquid, screw in the nozzle end until tight, then slowly back off until you get the desired mist.
    I read much earlier in these posts where someone else commented about the misting ability of the "stock" sprayer. They had purchased a plant mister and were using it instead of the one which came on the bottle. Either that, or they just poured the Z-6 into the plant mister bottle.
    TO ALL - earlier in these posts, or some other topic, someone gave a great tip for eliminating most of the water left on the vehicle after washing. REMOVE THE HOSE NOZZLE! I would never have believed that using the open-flowing hose end to do the final rinse would have eliminated so much water left on the surface. Try it, you'll agree. To whomever it was that gave that tip, A SINCERE THANKS.
    Jim M.
    To graphicguy & others: I know the Zaino stuff is supposed to work fine in our hellish weather. It's just that from May through September (especially in August), multiple hours of outdoor physical labour are to be avoided unless absolutely necessary. It's interesting to note, as the years roll by, how many fewer things fall into that absolutely necessary category.
    A lot of this is very subjective. I function fine at ten and twenty degrees below zero, and a lot of people who live here in the "Valley of the Sun" function equally well in August. Go figure.
    FWIW, but thanks for the input.
    I have been using Zaino on my car since November of 1998 when my 300M was 5 months old. I have never clayed it because I didn't know about clay back then. Sal didn't have it at the time. I know that many people in the "OTHER" topic think we all work for Sal or get a commission or own stock or whatever, but it's all bull.
    The reason we're so "fanatical" about Zaino is because it's the best, longest lasting polish with the wettest looking shine that we have ever seen. I just put some Z-2 on my car the other day, in the bright, hot sun with no problem. Last night when I was out, it rained AGAIN! I couldn't believe it. It's been hard to keep up with things in CT because of all this rain. Anyway, I had to drive home on the wet roads. I put the car in the garage, all wet, where it stayed until this morning. This morning, when I took it out, it looked like I had just washed it! I'll take some pics tomorrow morning to show you the shine.
    Even after 2 years, I STILL can't get over that wet-look shine. I can't help looking at it. So, let the doubters and naysayers "harass" us all they want. We still have the better looking cars! ;-))
    graphicguy-
    You directions were perfect! I have them saved in case you don't. If someone needs them, they can just e-mail me and I'll pass them on. Like I've said before, if they just read Sal's website (http://www.zainobros.com), they will have all the info they need, provided they read them BEFORE they apply the Zaino and not after! ;-))
    fastdriver
    Jim,
    Thanks for the info. I just went to pep boys and bought the clay magic. I am going to try it on my 5 yrs old Nissan Maxima first before I do it on my 2000 suburban (may be not - start getting lazy).
    Desmond
    CLAY
    Although my car was already "glazed" and very slick, I used Mother's clay before Z-ing it, and it is soooo smooth it is unbelieveable. I will never again polish a car without claying it first, even a brand new one.
    RINSING -
    You have the right idea about taking off the hose nozzle, but it works even better with a plastic "fan spray" nozzle. It is still very low pressure, and it allows you to make even a larger "wall of water" as you rinse, so 90% of the water pulls itself right off. Spend $0.99 and try it!
    But the Z is the greatest stuff for cars since rubber tires! My latest Z2 applictation is into it's third month. It rained on the way home yesterday and I couldn't help but notice how my car seemed to be the ONLY car with water beading up on it. Nobody else's car even came close. My car's white, so that "wet look" shine isn't as noticable as it is on deeper colors, but I DO know that it's the shiniest white car in the parking lot at work.
  • oilcan2oilcan2 Member Posts: 120
    Tried zaino on 94 Lexus is the best shine I have
    seen on a car and I go back to the 2 part blue
    coral treatment.Have one question,I got the clay
    bar from pep boys ,I got a few clay skid marks
    before I got the hang of claying,I used some
    clearcoat polish to remove clay,the z-7 was
    working but with much more scrubbing,what's the
    best way to get these skid marks off?
