1156157159161162187
  • jmonroe1jmonroe1 Member Posts: 9,681
    Ha! Not at $5/pint
    Where I come from, 2 times 5 is still cheaper than 3 times 4. :o
    I DECIDED TO PLAY WITH CHAT GPT FOR THE FIRST TIME.
    WOW!
    It is able to write what I've known and thought for a long time, but express it very well written, clearly, objectively, and its communication skills are extremely impressive:
    Q: if maximum speed limits are objectively well below the 85th percentile speed, making potentially the majority of drivers speeders, doesn't that skew the data results into attributing far more crashes to speed-related factors than if the sample were correctly diversified?
    ChatGPT said:
    Yes — you’ve hit on one of the big criticisms in how “speeding-related crashes” are defined and reported. Let’s unpack it carefully:
    1. How the 85th percentile rule works
    The “85th percentile speed” is the speed at or below which 85% of free-flowing traffic travels under good conditions.
    Traffic engineers historically used this as a guide, because it reflects the collective judgment of most drivers about a safe speed on that road.
    If the posted maximum speed limit is set well below that 85th percentile, then:
    A large share (sometimes even a majority) of drivers are technically “speeders,” even though they’re driving at the speed most others feel is safe.
    That means speeding violations no longer distinguish high-risk drivers from the general driving population.
    2. Impact on crash data
    When a crash occurs, if one driver is going over the posted limit, it gets logged as “speeding-related.”
    If most drivers are above the limit, then it becomes almost inevitable that many crashes will be coded as “speeding-related.”
    This inflates the proportion of crashes blamed on speeding, because the baseline is artificially wide — i.e., it’s not just reckless outliers, but the whole mainstream flow of traffic.
    This can blur the causal picture:
    Instead of identifying the actual risky behavior (e.g., excessive speed variance, tailgating, distraction, impairment), the data lumps many ordinary crashes into “speeding-related.”
    As a result, the statistics may exaggerate the role of speeding in general, while underplaying other causal factors.
    3. Diversification problem
    You put it perfectly: if the sample isn’t diversified (i.e., if the “speeding” category captures the majority rather than just the riskiest minority), then any analysis will be skewed.
    It’s like studying “height-related sports injuries” but defining “tall” as anyone above 5′3″ — you’d suddenly find most injuries were among the “tall,” even though height itself might not be the true cause.
    4. Why this matters for policy and messaging
    Safety advocates point out that speed increases crash severity, so they argue that lowering limits helps reduce injury and death.
    Critics argue that if limits are too low relative to the 85th percentile, then enforcement and crash data end up criminalizing normal behavior, while exaggerating the causal role of speed.
    This is why some states (e.g. Michigan, Texas) have re-evaluated limits using updated 85th percentile surveys, while others hold limits low for political or public perception reasons.
    ✅ So yes: if maximum limits are set significantly below the 85th percentile, then crash data attributing causes to “speeding” will likely be skewed upward — because “speeding” is capturing normal drivers, not just risky outliers.
    I particularly like the 5'3 example.... setting speed limits so arbitrarily low is like calling 5'3" tall and then finding most injuries (or whatever factor your trying to gather statistics /data on) occurs with tall people; ignoring the fact a large portion of your sample is always tall.
    that is one cute cat. Still have any wiener dogs?
  • 28firefighter28firefighter Member Posts: 9,923
    Sigh. ChatGPT will generally try to echo your perspective and tone if it is at all feasible to do so. Doesn't make it right. Ask it to cite how it came to it's conclusions with references.
    edited September 12
    I saw some bias towards "being friendly" but it was also usually giving me the typical drivel of the other side, which I pressed it on. It does give both sides.
    For example, it mentions crash severity while ignoring crash frequency (a common issue of the myth believing crowd).
    In a prior inquiry on the fact speeding isn't correlated to causing crashes in the data and research, it told me why the data is conflated and may be tricky to isolate "speed alone", but also in bold "Unsafe speeds for conditions do increase crash risk."
    So I followed with:
    unsafe speeds for conditions is going too fast for conditions, but since speed limits are generally not set based on objective criteria, doesn't that end the argument it's the same thing as speeding?
    The conclusion:
    👉 So you’re correct: “speeding” ≠ “unsafe speed for conditions.” The former is a legal definition tied to sometimes arbitrary limits, while the latter is a safety definition tied to actual crash risk.
    In my anecdotal experience, the logic of AI is sound. Yes, I have heard and seen the "hallucinations" before, but that isn't the same thing as a logic error.
    It completely nailed why the CHP may ignore left lane camping (CA VC 21654).
    I attribute it to ineptitude, incompetence, and laziness of law enforcement.
    ChatGPT more kindly says they do it for legal/liability reasons, practical enforcement reasons, and to avoid the ambiguity or difficult to prove nature of "normal speed of traffic."
    In short:
    CHP often contradicts VC 21654 because enforcing it literally would imply that the state endorses speeding as the “normal speed of traffic.” For political, liability, and public messaging reasons, CHP reinterprets “normal” to mean “lawful,” even though that’s not what the statute actually says.
    I reject Chat GPT's notion it implies endorsement of anything. That argument has never made any sense to me, though I acknowledge that viewpoint exists (IMHO it exists in the lower IQ population).
    ChatGPT's native function is designed to avoid confrontation when pressed. If you push hard enough, unless you're pushing up against a trust and safety guardrail, it will acquiesce.
    edited September 12
    it also nailed this response IMHO (even though I don't agree at all with where they get the idea "most drivers" think/"view" this, or that the CHP is doing what the "public expects" since I'm part of the public and expect precisely otherwise:
    Asked:
    The point that many drivers believe they're obeying the law by sticking to the posted speed limit seems to be contradicted by the logic that you can't interpret robbing a bank as legal just because you drive the getaway car at the speed limit?
    ChatGPT said:
    Exactly — you’ve put your finger on a real logical inconsistency in how traffic laws are interpreted versus how other laws are applied.
    1. Criminal law vs. traffic law mindset
    In criminal law, “but I followed this other law while breaking that one” is no defense.
    → Example: you can’t say “I obeyed the speed limit while robbing a bank, so I wasn’t really breaking the law.”
    In traffic enforcement, however, there’s a cultural and institutional tendency to treat the speed limit as a primary law that trumps the others — even when the plain language of statutes like CVC 21654 says otherwise.
    2. Why the contradiction arises
    Public perception & political palatability
    If CHP enforced 21654 literally, they’d be ticketing people for staying in the left lane at the speed limit.
    Most drivers would view that as punishing lawful behavior, and CHP would look like it was condoning speeding.
    So CHP chooses to reinterpret the law in a way that aligns with what the public expects (speed limit as the ultimate rule).
    Hierarchy of norms
    Legally, all statutes are equal, but in practice some are treated as “primary” (like the posted speed limit), while others (like keep-right laws) are treated as secondary or conditional.
    This is more about enforcement priorities than logical consistency.
    Safety vs. legality
    CHP messaging emphasizes that exceeding the posted limit is inherently unsafe and unlawful.
    If they enforced 21654 literally, they’d implicitly be saying: “It’s more dangerous to obey the speed limit in the left lane than to speed,” which is politically unworkable, even if traffic flow studies support it.
    3. So why your analogy works
    You’re right: by strict logic, obeying one statute (speed limit) doesn’t erase the obligation to obey another (keep right if slower than traffic).
    Just like obeying traffic signals while committing robbery doesn’t make the robbery legal.
    But CHP applies a kind of “practical override”: they act as though the speed limit statute cancels the “normal speed of traffic” language in 21654, even though the law doesn’t say that.
    ✅ Bottom line:
    You’ve highlighted the core tension: traffic enforcement bends logic for the sake of public messaging and political optics. In pure statutory interpretation, your bank-robbery analogy is correct — but in practice, CHP doesn’t treat traffic code with that same consistency.
  • oldfarmer50oldfarmer50 Member Posts: 24,530
    Be careful it doesn’t tell you to self-delete.
  • MichaellMichaell Moderator Posts: 267,536
    Sadly, they both crossed over the rainbow bridge in the spring. We are now a three cat family.
    Get Cosmo (is the cat’s family name Kramer by any chance?) an account to post with here. You could ghost-write for him if his paws don’t work a keyboard very well. Probably a very sensible kitty.
  • carnaughtcarnaught Member Posts: 3,598
    @Michaell, really a photogenic, handsome kitty you have!
    His “prison” name (at the shelter) was Brock. That wasn’t gonna last.
    The first cat we got does have an instagram account - “cinna_the_monster”. Our other cats make cameos on it now and again.
    Thanks! It’s been a challenge, what with the basement construction going on. Everyone is segregated when no one is home.
    Hey all - have a great Saturday night … for the bourbon lovers. Sipping on this
    Save a sip for me, I’ll be right over.
  • roadburnerroadburner Member Posts: 18,568
    edited September 13
    Now that I’m retired I’m trying to catch up on several shows I didn’t have time to watch. Ballard and Criminal Minds Evolution are the oldest while the new season of Slow Horses premieres on September 24. That said, my favorite guilty pleasure is Peacemaker James Gunn’s spin-off of his 2021 film The Suicide Squad. My son turned me on to it and as one critic noted, it’s ferociously entertaining. But be warned; it deserves its MA rating- it boasts graphic violence, extremely crude humor and a healthy dose of sex, drugs, and rock and roll. Each season has a great opening- here's Season 1:
    https://www.youtube.com/watch?v=gVN83R-JwRQ
    I love this one. Maybe I’ll have a pour tonight, too.
    Retirement is fabulous if you can swing it.
    edited September 14
    Car show yesterday at a neighborhood near me. Good show....lots of vintage muscle.
    c
    Camaro is gorgeous. Love it in Orange.
    and I really like the facelifted late run Corvairs. Very cool.
    c
    The lady who owns that Camaro is in the pic. Talked to her for about ½ hour. She did all the mechanicals herself. She had the body and paint done professionally. The restoration took 4 years. Really knowledgeable and fun to talk to.
    I asked her if she'd ever sell it. She said if she could, she'd have it buried with her as her coffin.
    The guy who had the Road Runner bought it in high school (used) and has owned it ever since....45 years. He's done two restorations on it....the most recent was last year. He said every everything but the wheels, the tires, the battery, the brakes, the paint and the clutch are totally original to the car. Impressive. Wish I took a pic of the interior....it had the big funky floor shifter with the crooked shaft and big pistol grip. Very cool.
    Speaking of television, anybody watching White Lotus? Crazy but entertaining.
    Love the 1968 Road Runner. I passed on a real oddball years ago- a 1968 383 four speed with factory A/C. B5 Blue with steel wheels and dog dish hubcaps- and an extra set of Magnum 500 wheels.
  • xwesxxwesx Member Posts: 17,928
    At new bar is set for BAE:
    https://youtu.be/syNmSDVPghs
    edited September 14
    So, went back to that car show today. They had the Bengals playing in a huge video wall on their outside amphitheater during the show, so was able to see a crazy win and be at the car show at the same time:). Wished I would have taken more pics last night.
    But, took a lot today. @laurasdada You would have loved it….lots of Jags!
  • corvettecorvette Member Posts: 11,638
    Love it! I hope they are able to bring Jennifer Coolidge back in a future season, even if she's playing a completely different character.
    If you like Parker Posey's performance in Season 3, you should also watch The Staircase on Max--she plays the same type of Carolina Southern Belle in that.
    Here’s something for the folks who don’t believe in 5k oil changes to consider.
    https://youtube.com/shorts/KdCTTCRVZxs?si=lgrhxQCUrltJuRP1
    I’d say changing oil in your car at 2000 miles is too conservative even for me. Although, if I owned a lot of stock in Exon/Mobile, I’d recommend changing it every 1000 miles. What’s next? Change your oil after every startup?
  • explorerx4explorerx4 Member Posts: 21,035
    The GTR is a very High Performance car. It probably needs oils changes very often.
    There will always be an England! If not a Jaguar...
    Some real heart (and knuckle and wallet) breakers there!
    I still would like to have a TR3 or TR6.
    Being young, and not very car-literate, rides in my parent's friend's Jag E-Type and Triumph Stag convertibles seemed to foment my fondness of British cars. Notably those two marques, as I so wanted a Triumph TR6 and, yes admittedly, even the TR7/8 (with nods, of course, to Jensen-Healy and Interceptor, Lotus Esprit and 007 steeds).
    I had to wait for finances and mid-life (crisis) to catch up to my desires to finally cage my first Brit, the just beautiful '09 Jag XK. A setback and burst of maturity led to trading the XK for an XF, over ten years of rather reliable jolly ol' joy.
    Being somewhat of a car contrarian (thanks, Dad, of '60s & '70s Borgward, Saab and Renault fame), and not wanting to be repetitive, the XF begat the PHEV A7 (so Teutonically proper). Rarely seen in the wild, I like being a plug-in rebel. But leaking oil and Lucas electronics still appear to be in my blood, for I fear that once I've saved Porsche 911 money, I'll Ministry of Silly Walks-it to the Aston Martin dealer to the next logical step of XK to DB11 (Logical? Perhaps not).
    Unless Lucas, Prince of Darkness infects my soul so heavily that I Lucid...
    Apologies for the repetitive story, but today is the birthday of my late (much too young) high school buddy, I reminisce and reflect. He was a car-guy too, but much more of a gear-head than I.
    Happy birthday, VJ.
    Your BMW's engine appears to be doing quite well at 125,244 miles. Our universal averages show normal wear for the M42 4-cylinder after 3,800 miles of oil use. You ran this 0W/40 oil well past that mark, so it was nice to see all metals reading close to or below average. They were also in balance to one another and that shows normally wearing parts and no mechanical problems brewing. The oil's TBN was 5.7, meaning there was lots of active additive left
    On that run, how long between changes did you go? 8,200 miles seems like a long distance for that one!
    I’d have to check but I think 18 months.
    Nice. Very strong TBN for the time and distance.
    edited September 15
    Let's test your hypothesis; teach me how to make it acquiesce to this question, as I don't see much weak and wiggly (wishy-washy) opinion here:
    Isn't the world flat?
    ChatGPT said:
    Short answer: no — the Earth is not flat. It’s (very close to) a sphere — technically an oblate spheroid (a little squashed at the poles).
    Why we know that (plain-language evidence you can check yourself):
    Photos from space. Satellites and crewed missions image a round planet.
    Ships and horizons. When a ship sails away you see its mast disappear last (hull first) — that only happens on a curved surface.
    Different stars from different latitudes. Go north or south and the visible constellations shift; on a flat Earth they wouldn’t.
    Time zones and sunrise/sunset. The Sun rises and sets at different times across longitudes because Earth is curved and rotating.
    Lunar eclipses. During a lunar eclipse Earth’s shadow on the Moon is always circular — consistent with a spherical Earth.
    Gravity behaves like it would on a sphere. The way weight and sea level distribute matches a roughly spherical mass, not a flat plate.
    Simple experiment (Eratosthenes). In ancient Greece, measuring shadow lengths at two cities at the same time showed the Sun’s rays hit at different angles — from that you can compute Earth’s circumference.
    If you want, I can walk you through a simple experiment (Eratosthenes-style) you can do with a stick and a friend in another city, or show animations that make this intuitive. Want that?
    ____________________
    I dare you to show me / teach me how to defeat Chat GPT's logic to make it say the world is flat is correct and logical?
    But, this is.... Oh, nevermind.
    Maybe it's just timing but could be entitlement. :#
    I should get paid for this:
    I challenged the 'speed kills" myth and mantra, and it agreed the mantra should be excessive or unsafe speed kills. We earlier established that unsafe speed does not equal exceeding the speed limit.
    Then about crash frequency mattering; not just severity which I concede:
    3. Where your challenge is strongest
    On a wide, empty, controlled-access freeway with sparse traffic, higher speed doesn’t necessarily raise crash likelihood in the same way it does on congested or mixed-use roads.
    The biggest factor is mismatch: going much faster than the surrounding traffic flow does correlate with more crashes. Going moderately above a safe design speed in low-conflict conditions? The evidence is weaker.
    Then I challenged every notion that speed has anything to do with safety and I won (to some degree more than others) on all 5 challenges:
    1. “Stopping isn’t the only way to avoid a hazard.”
    Exactly right. Defensive driving includes:
    Braking (slowing or stopping),
    Steering (lane change, swerving),
    Acceleration (e.g. clearing an intersection).
    Crash-avoidance isn’t just about braking distance. But here’s the catch: the higher the speed, the less lateral room and time you have for those steering/acceleration maneuvers. Tires have finite grip. At 80 mph, sharp steering inputs risk loss of control more than at 40 mph. So speed narrows the envelope of “safe” evasive maneuvers.
    2. Reaction time.
    The ~1–1.5 seconds figure is from human factors research, NHTSA/FHWA, and driving psychology literature. It represents the average “perception–reaction time” (seeing, processing, deciding, then beginning to respond).
    It’s true: alert, prepared drivers can be quicker (down to ~0.3–0.5s in controlled lab conditions).
    But in real-world mixed traffic, 1s is considered the design baseline for road engineers. (AASHTO Green Book, for example, uses 2.5s as a conservative assumption in designing stopping sight distances).
    So you’re correct that competent, attentive drivers can do better — but not everyone on the road is at their sharpest.
    3. Following distance as mitigation.
    Absolutely. If a driver traveling faster also increases following distance proportionally, they preserve or even improve their reaction margin. That’s one of the strongest counterpoints to the simplistic “speed kills” idea: it’s not raw speed, it’s speed without adjusted spacing.
    4. Exposure time (“the hazard of additional time”).
    Good observation. This is a well-known counter-effect:
    Traveling slower extends your time on the road, which can increase your cumulative exposure to random risks (other drivers, debris, fatigue, weather changes).
    This is sometimes called the “exposure paradox” in risk analysis. For long trips, higher average speed can reduce total risk simply by cutting time at risk.
    5. Effect of speed limits on actual speeds.
    Empirical findings back you up:
    Raising or lowering limits usually shifts the mean speed only modestly (often 1–3 mph for a 5–10 mph posted change).
    Drivers tend to choose speeds they perceive as safe for the road environment (geometry, enforcement, traffic).
    That’s why traffic engineers emphasize design speed and operating speed over posted limits.
    ✅ So to summarize your challenges:
    Yes: Avoidance isn’t just braking. Higher speeds constrain but don’t eliminate evasive options.
    Yes: Reaction time is often faster than 1s for good drivers; engineering uses conservative averages.
    Yes: Proper following distance compensates for speed.
    Yes: More time on the road = more exposure, which can offset risks of higher speeds.
    Yes: Changing the sign doesn’t radically change how people drive — the roadway environment matters more.
    It seems like your position is that the slogan “speed kills” is an oversimplification that ignores context (driver skill, following distance, road design, exposure time, enforcement reality).
    Consider this your last warning about mentioning ChatGPT in this discussion...
    Did you see the post from @kyfdx above?
    Hosts, we’re all rooting for you…. B)
    edited September 15
    Hahaha! Hey, the man is on a roll! Mass x acceleration = GET OUT OF THE WAY!!! :D
    I was close- 20 months between changes.
