Visitor Agreement.
I guess you just need another identity with your actual address.
Mr Kane?
I learned this when we were about to close and I called the utility company to get us set-up, and they could not find out house as something they covered (which I knew they did). I think they had our neighbors though. It took calling back and getting an agent that was more on the ball to unravel that issue.
That's nuts. You should follow up with your county office to make sure it is recorded against the parcel. You can also go into Google maps (not sure about others) and request to add it there.
If you find your house on the map, right click, select "add a missing place," and then enter the relevant information. After approval, it will come up by the "name" you give it (e.g., your street number), even for other users.
19 years is a good run for a fridge but I’ve seen longer. Like the Frigidaire unit built by General Motors that was my parents first fridge. They got married in 1940 and that thing outlived my Dad (he died in 1983) but my Mom outlived it. IIRC that beast hung it up in the mid 90’s but it became the basement fridge around the early 50’s. It’s true, they don’t make em like they used to.
I’ll go along with that but when I buy an appliance I want it to do what it was meant to do. In the case of a fridge, I want it to work long and hard to keep my food from spoiling. And the longer the better.
I don’t understand these high efficiency washing machines today. They supposedly save water but a cycle takes over an hour, whereas the older machines cycle time was less than 30 minutes. So, water is saved but more electricity is used. Where I live, and I’m sure it’s the same everywhere in the USA, electricity costs more than water. So, what tree hugger thinks that’s a better way to wash clothes (same for dishwashers too). So, it seems like carbon foot prints only work when it’s a convenient way to make a point.
Our condo building is six units. It used to be three separate street addresses and then unit 101, 201, 102, etc... at some point the township made them change it to units A-F but still with three different street addresses. So strange.
In my sample size of 1, it seems the only thing that makes a lick of a difference in my electric bill is the air conditioning. No difference whether I changed an appliance or switched over to LED lighting. It all comes down to the air conditioner.
How many guesses do I get to hit on why that contraption lost out to electric washing machines?
I've never seen a gas powered washing machine. How would that work? Is your washer not plugged in?
The only thing I’ve learned is it’s going to be a cold day in Hawaii when you see one in our laundry room.
Son #1 has several rental units and when he puts in washers and dryers he buys used ones. The place where he buys them told him they don’t bother trying to repair the HE top load washing machines anymore because parts are too expensive, too hard to get and no sooner do they repair one (they sell them with a 6 month warranty) they get calls that they quit working. After 3 or 4 times of that happening they stopped fixing top load HE washers.
Here’s the thing; most every person who needs to know my location can find it. I prefer that the general public does not, as I’ve made more than a few enemies since I first took office in 1986.
A 2HP pump is about 1500 watts
A 4 Ton (240V) compressor is 5040 (plus another 400 or so for the blower motor inside)
Now if you add a pool heater heat pump, then you're really in trouble.
Understandable that you wouldn't want crazy people to be able to find where you live easily.
This reminds me of my first GPS clamshell unit, it literally was trying to drive me off a cliff in the Sierra Nevada Mountains between South Lake Tahoe, CA and Nevada's valley (after passing the ridge/summit of the mountain) to the southeast. Make a left or right off into the abyss. Hopefully, no one obeyed and crashed due to the GPS.
Verdict? They need to repaint the hood. Apparently, the painter didn't get enough base coat over the blend area, so the artifact is some of the sanding showing through. Man, is it subtle, but in the right light, at the right angle, it is glaringly obvious (such as in the photo above). So, I scheduled to take it in next Monday, and they said they need a couple of days with it. My wife is not happy with me! We are supposed to head back to Alaska in about ten days or so, and this is cutting it way too close for her comfort. She said, "can you just cancel it? I don't think it is worth the trouble."
Courtesy of this guy......
Picking up his striped shirt from the dry cleaners?
He succumbed to peer pressure, bought an EV and is still figuring out how to charge it.
In all seriousness he has not logged in since Aug 4th. Does anyone have his personal email address? Doesn’t seem to be on his profile.
The funny thing about the hood being such a drama queen is that the impact caused only a slight crease on the front right (passenger) corner, but it split the paint there. So, they had to fix the crease and then paint/blend the hood. And, no, @oldfarmer50 , it is definitely not a cloud (in the sky), but one could easily mistake it for that. Except at that angle and in sunlight, it doesn't really even show up. Unfortunately once you know, you know!
For the record, I don't own that shirt anymore, and I would consider a hybrid car, but not an EV.
We did just return from Victoria and the taxi driver had an older hybrid Camry with 180000 miles on it, he expects it to go at least 500000 miles....the car looked like new inside and out.
I also had to do some work on getting my will up to date, some people will get less and some more.....don't ask JMonroe - you are not in it. I wanted a phrase if I died first I didn't want my wife to give my car to her new boyfriend. The lawyer just laughed!!!!!
Just for that I’m writing you out of mine.
Had stuff out of the trunk of the 14 Malibu so I decided to check the air pressure in the minispare.
9 lbs.
So I used my portable charger to run it back up to 60. Should be good for another 11 years?
My cord for the 12-volt charger I carry in each car wouldn't reach from the Malibu inside plug to the trunk, so I parked the trunk next to the Cruze's driver door to be able to barely reach.
