Zaino Car Care Experiences
16566687071137
    Stab in the dark, but...I wouldn't mix distilled water with the Z6. That may be the cause of your hazing.
    LIghter colors are difficult to see Zaino polish when applying. My wife's Avalon is white pearlcoat. I have to really concentrate to make sure I'm overlapping the Zaino application.
    I find it's a bit easier to see my applications if I pull it into the garage, out of direct sunlight when Zainoing.
  • pblevinepblevine Member Posts: 858
    To continue along with joebob6, did you first wash with Dawn prior to using the Clay (or first Zaino application)? I ask because if the old (ie: dealer applied) wax or 'hand glaze' was not removed, the haze could be due to aging of those old layers. If not, then as joebob6 said, chances are that you used too much Z3 or Z5. Does the hazed areas 'smear' (ie: appear non solid) when wiped with a towel. If so, wash with Z7 a few times and then let it dry overnight. Under what sort of conditions did you apply your Zaino to the finish? (ie: temperature and humidity)
  • bonlaw98bonlaw98 Member Posts: 5
    Spoke with Sal this morning. He thought it may be from applying z6 in the sun or too much.
    I told the dealer to NOT wax the car when I purchased it and I did do a dawn wash first.
    I have done all of the Z work myself EXCEPT I have my auto guy hand wash my car weekly- I supply all z products and towels and told him how to apply. I am thinking that perhaps he is using too much z6 and applying it to a hot car or in the sun.
    Per Sal I am going to just wash on Friday- no z6 and see what happens. Let you all know.
    Thanks for all of the info.
  • bh0001bh0001 Member Posts: 340
    You have an "auto guy" to wash your car?!?!? Gotta get me one of those!
  • mrdetailermrdetailer Member Posts: 1,118
    I really like 3M's results as well. I put on Black Magic on all my trim just before I wax and have no problem.
  • scottmsimpsonscottmsimpson Member Posts: 66
    I have Zaino on two of our four cars. I've been using it since the fall of 1999. I only do the Z thing spring and fall. I took Tuesday off this week, and one of the many things I got done was to get a new coat of Z2 on the cars for winter. On our dark blue green Acura CL, I saw a lot of smearing, even though I had put Z1/Z2 on thin, and it had dried over an hour. I had used a towel that had not been used for drying the car, only Z removal, but it was not 'clean'. I used some Z6 (and the same towel) and still had some smearing, although it was better.
    When it was time to remove the Z2 on our red/beige Mercury Villager, I found a clean car towel, and had no smearing problem at all. I then went back to the Acura, with a second clean towel, gave it a once over with some Z6, and the smearing was gone.
    I can only assume that the first towel I used may have been used previously for Z removal, and was not clean enough to produce good results.
    I'll have to get the towels in the washer more often.
  • genie1genie1 Member Posts: 398
    When I was growing up my parents had a guy wash their cars everyday. This in a country where there was no mud, no rain...nothing to sully your car on a daily basis other than the occasional sandstorm.
    Yep, those were the days. Now I have to roll up my sleeves, spritz the Z2 on by myself and pray for a mild winter. I'm so glad Zaino is so easy to use.
    LOL
  • dhanleydhanley Member Posts: 1,531
    If you're measuring durability by beading, i think that could be part of our talking past eachother.
    Beading occurs when the cohesive force of the water droplet is greater then the adhesive force between the water and the finish--so the water curls up into a ball.. All sort-of but i think the idea is clear.
    Just getting the crud off your car with clay will make the finish bead for a long time. Try it--i did. But is a freshly clayed car protected? Not at all!
    I judge durability by seeing if waxing/polishing makes a noticable difference in look & feel. Twisting on the surface of the car's finish will also tell you if there's protection--if it just slides, or hops & squeaks.
    Bottom line, beading does not mean that your finish is protected.
    dave
    OK OK !!! I WORK LONG STRESSFUL HOURS,AND I'M 50 SO I GIVE MYSELF PERMISSION TO HAVE A WEEKLY "AUTO GUY"; CUTE TOO. I don't mind Zing, but can pass on the washing.
  • joebob6joebob6 Member Posts: 239
    but for one thing it did not test durability. Another thing I noticed and the author stated referring to his paint finish, "Mind you, most people would agree that it looked damn near perfect before I started."
    The scratches showed up under a spotlight. I am sure that under a spotlight my finish would look even worse than his. I guess I am just not that picky.
    Zaino Z5 can do wonders on light swirls and scratches that are highly visible under regular lighting conditions and the swirls and scratches will remain hidden for as long as the polish lasts on the finish.
    Here are a couple of examples. These are not my cars. Keep in mind these finishes are a mess in comparison to the Porsche.
     http://www.geocities.com/yell00itr/TL3
     http://www.geocities.com/yell00itr/TL4
     http://www.geocities.com/yell00itr/s4-1.html
    Maybe Meguiars would do just as good a job on the scratches and swirls that are this bad too. I am actually suprised that Zaino Z5 worked this well.
  • fastdriverfastdriver Member Posts: 2,273
    bonlaw98-
    I could have used an auto guy myself these past two weeks! My car needs to be washed and Z'd! No time! I think it looks good until I see my own pics and say- WOW!- look at that shine! ;-))
    fastdriver
    PS If he's not busy, can you send him to CT?
  • BushwackBushwack Member Posts: 258
    Don't mix Z6 with distilled water. It severely depletes the 'power' of Z6 and makes wiping it off your car a bit tougher (I tried a 8:1 mix with poor results). Also, Z6 'watered down' shows as being a much less effective 'polish' (for lack of a better word) then if using Z6 'straight up".
    Bushwack-
    I agree, Z-6 STRAIGHT UP is the only way to go!!!!
    fastdriver
    to waste.
    Never mix Z6 with water. 'Don't know who came up with that one, probably the Turtle Wax folks.
    Do mix water with Z7 Car Wash. And you don't need distilled water either. I once tried using a gallon of NYC's finest super wet water as my final rinse. Up in the Berkshires, the water is very hard and I've always had problems with water spots. So this one time I filled up a gallon jug with NYC water, hauled it up to Otis,MA and used it as my final rinse. Didn't help, wasn't worth it, felt like a fool.
    The only improvement I've incorporated has been the two bucket method of washing. I fill one bucket with Z7/water in the normal manner, and also fill a second bucket with just pure water. After I've soaked my wash towel in the first bucket and washed a panel, I wash the towel out in the second bucket before again soaking it in the first. Removes 98% of the dirt so you don't dirt particals from one panel to scratch another panel.
  • keyrowkeyrow Member Posts: 214
    Being a detailer I am always on the lookout for a better (ULTIMATE) wax; one that produces an exceptional shine, is easy to apply and lasts. I came across this little goodie while surfing. It seems the Acura NSX club was also interrested in the subject so they did a comparison of Zymol NSX wax ($144.00)vs. Zaino ($12.95) vs Meguiar's Gold Class ($12.95) vs Turtle Wax's version of Zymol. For yet another "independent" test of waxes, check this out:
    http://www.nsxsc.com/nsexcitement/waxtest.html
    BTW I only use Zaino on my personal cars; looks great and it's just like the Energizer bunny - it keeps going and going and . . .
  • squidd99squidd99 Member Posts: 288
    I tell my "auto guy" never to mix z6 with water.
    Also, my "auto guy" found that mixing z7 with water and keeping it in a little spray bottle is great for bird bombs and other spots that need lubrication to be removed at times when a car wash is not needed.
    Finally, my "auto guy" uses just plain water from the tap.
    I also know that my girl friend is sleeping with the "auto guy."
    My auto guy is me, of course.
  • mgrcmmgrcm Member Posts: 53
    Hello everyone,I thought I'd get into this washing thing.I just picked up my GMC SLT Envoy in Indigo Blue back in Sep.Thanks to Zaino my fears of owning a dark color for the first time in years(had switched to silver colored SUV'S because of paint problems with black)have been relieved.I now have 6 coats of Z2 followed by Z6 on my Envoy(just can't stop putting it on).Anyway I live in Western MA. and have a well and yes my water is very hard.Back in Aug. I bought a electric power washer at Walmart,the best damn thing I bought in years.Works great just rinse first in high pressure then pull out end of nozzle and it dispenses soap in low pressure,let sit for a minute then push end of nozzle back in and rinse off the soap in high pressure,cuts wash time in half and also you don't have the problem of swirl marks or scratches from wash mit.Then I dry with the Absorber.Also have to wash in the shade or wait till evening to cut down on hard water spots.Now I'm just dreading to get my first big scatch or dent,I think I'll cry when it happens.That Zaino stuff does strange things to people.
    Rick
    Welcome aboard, and yes, Zaino usage turns you into a shine fanatic.
    Have a good weekend all.
    I regularly dilute my Z6 with distilled water for quick detailing. It can also be useful to dilute it if you use it on a hot surface or in direct sun and you are getting streaking.
    I prefer using it full strength right before and right after applying a fresh coat of Z2/Z5.
    Again, my experience is 100% different. Water beads just fine over 6-month old wax--IF i clay first, and it feels smooth--IF i clay first. I saw nothing extra the zaino was doing.
    Actually, in the test this topic was started by, the meguiar's seemed to cover the scratches better.
    The zaino site an topic make a lot of impressive-sounding claims about how the finish will look & feel, but what that doesn't turn up, the fallback seems to be "but it lasts longer!"
    dave
    I'm curious? Why did you think the author of the test was "admittedly biased"? Maybe I missed something? Skepticism isn't bias, seems to me.
    Bias is defined as an "unreasoned distortion of judgment".
    A person isn't necessarily biased because he ends up disagreeing with our point of view. He'd have to totally discount the facts he found in front of him.
    I don't believe the author was biased. I e-mailed him...he seems to be a friendly person and he may do a durability test.
    The problem I had was with his scratch/swirl filling testing. As I said before, his finish was nearly perfect (before testing) in most types of light.
    How many people examine their finish that closeup with a spotlight? I have seen the job that Z5 does hiding highly visible scratches and swirls although I never put a spotlight on them afterwards to see if they could still be seen. I just observed the difference in regular lighting conditions and there was major improvement.
    suppose you and I differ on Zaino because you are one who wants to wax a car once a month. I tend to post for someone who has spend a good chunk of change on a new car who wants it looking good but is really not willing to wax it once a month.
    No, i do not want to wax once a month. I have a BMW that i love to have look good, and i think the cleaner wax keeps it clean and protects the paint--as a point of reference, i live at about 6000 feet, park outside, and have 320 sunny days per year.
    I submit that with the regimen you suggest that the person could just use wax, since i really don't think it does better than the Z stuff anyhoo.
    I don't see why the author of the test is admittedly biased.
    Bottom line, for someone who wants a long lasting shine with little effort, Zaino is by far the superior product.
    You state that like it's a fact, but too me, since i see zero evidence of extra longevity, or extra looks ( in fact, the test here shows it didn't cover scratches as well ) i don't see where the benefit comes in.
    dave
    You're barking up a slippery tree with these guys. (A 21st century "Yogi Berraism")
    I used to get into with them on this topic. It took me awhile to realize that all they were offering were their opinions and no one ever supported any of their claims with facts. All they do is throw opinion after opinion, and when they're pressed for proof, you get name-calling and more opinion.
    None of them have attempted any emperical testing like the Porsche guy did. I mean, at least he tried. I applaude him for that.
    Be careful, my friend. Things only get worse from here. Forget about expecting them to support their statements with facts because they don't exist. And never did.
    That's in anteresting test, but i don't think it will show much--we live in very different climates, we have different cars with different finishes & ages, and there's a lot of dust that will settle on the cars, and it did so when i had zaino, an when i had wax on it.
    I'd be willing to do a similar test as before, with 1/2 the hood in zaino, 1/2 with regular wax--i still have the Z stuff. Kind of hard to test and verify all that, though.
    dave
    An aside to bret...who did any name calling? I merely offered to have dhanley do the identical thing I was going to do to my car and we could take photos to compare which product provided better protection. I've posted my "facts". Somehow, I'm of the opinion that you will still doubt me. So be it.
    If it mattered to me I'd scroll back in Store Bought Waxes and the Zaino room and find all your posts directed at me and others who challenged your assertions. How many of your posts have been deleted by the Edmunds hosts during the past two years? How many times have you been reprimanded publicly and privately by Edmunds to act in a civil manner?
    The difference between fact and opinion is that facts can be verified independently. Facts stand up to scrutiny. A fact becomes one only after some kind of test or trial. Like the Porsche guy attempted.
    If you want anyone to believe you then you will have to make the effort to fairly and objectively compare products. Then you will have to use the same objectivity in analysis and reporting. Taking a few pix of your car proves nothing to no one.
    Instead of putting all this energy responding to every little comment about Zaino, why not put forth some real effort and conduct a scientific test of products? Get together with all your cronies and develop a balanced format for comparison. Involve the car care product companies as well as their products.
    In other words, put your money, time, and energy where your mouth is.
    I have used so many products in the past, I have a large collection of half empty bottles. Use whatever products you like. Do your own testing. Research the products you want to try on the internet and talk to people with nice car finishes. Don't just assume the test done above was the "test to end all tests" and base your decision solely on the information he provides. Just like don't base your decision solely on a product's website.
    I know what works best and will keep on using it. It was the only product that lived up to my expectations. Use what works best for YOU. People have different things they want from products. If the product you are using meets your criteria keep on using it.
    Some people like a wax look, some prefer an acrylic look, and some like a polymer look. Some people are concerned about silicone oils, abrasives, price, others could care less. Some people like to wax once a week, others wax once every 6 months or less. Some people keep their vehicles garaged, others can't. Some people enter their vehicles in car shows while others don't.
    No sense in getting in a pissing match over "what's the best wax or polish".
    We have a forum to discuss Zaino and a forum to discuss Store Bought Waxes.
    I have not found any product better or worse at repelling or attracting dust. IMO Pollen is a seasonal PIA no matter what product you use.
  • adc100adc100 Member Posts: 1,521
    You are so right on. I guess I'm always willing to look at a new web site showing the results of a specific product. But in the end each will find his own "best" product. But for me, I can't resist trying something new. As they say-variety is the spice of life. I started with Meguiars, I now have the Perfect-It, Next will be Collinite, Pinnacle, One Grand and Z.
    Ever argued with a "golden eared" audiophile? The ones who claim to hear sonic differences between the types of AC power cables their amps use? No way will you ever convince them of their folly. Sound familiar?
    Give it a rest. Its just not that big a deal.
    Sometimes observation doesn't verify opinion either. When you get into really esoteric stuff, often you have to be "trained" to hear or see something---but with car waxes or polishes, I don't think a PhD is necessary.
    This is why most tests are done "double-blind", so that people's prejudices stay out of the testing results. Ideally, applying zaino to one-half the hood and a competitor's polish to the other side, with neither the applier/owner or the judge knowing which was which...and then looking at the results in 6 months....that would be interesting.
    Of course you always want to try new stuff...this is why companies spend billions in advertising, to convinice us to do that. You'd be the rare bird that could resist such 24 hour a day propaganda!
    I really don't think anyone is saying your opinion is invalid because you don't have a web page.
    I did think you were stating your opinion as fact earlier "zaino is the BEST for longevity!" but you've backed off on that a lot, so i'm appeased.
    I did my best when i ran my test to do a double-blind, but it wasn't fully scientific--i did 1/2 of the hood in each, and asked other people to pick out differences in the halves after a few weeks, then after a few months. The failure of people to differentiate between the meguiar's half and the Z half is what convinced me to not buy any more.
    Of course, i did the meguiar's 3-step along with the zaino 3-step and i clayed both halves, so it's not the exact test you're proposing.
    Part of the reason i bother here is because there's a lot of people on the Z topic saying things like "your car will glow, people will walk up and try to lick the paint, dust will fall off on it's own." After hearing that, and dropping almost $80 on the polish kit, i was dissapointed that i wasn't able to discern a real improvement from my regular $3 meguiar's cleaner wax.
    dave
  • sddlwsddlw Member Posts: 361
    After I wash, I just dampen a polish applicator with a couple squirts of Z6 directly on the applicator rather than spraying it on the car. Then wipe the car with a separate towel once the Z6 has been applied. Doing my whole car might take 10 or 12 squirts of Z6 because as long as the applicator is moist with Z6 it seems to do it's thing. No need to dilute. One bottle of Z6 lasts a very long time this way.
    That post #31 was "Classic PJYoung". You should have your own cable channel. There was enough spin and obfuscation in that post to make even Bill Clinton jealous.
    Well, i think his observations are a lot more scientific because of his methods: he used tape to separate the finishes, he showed photographic evidence of the results side-by-side, etc. If you're not doing a side-by-side comparison and providing data for peer scrutiny, it's not really scientific.
    I just went back to the original site, and i saw the note from sal zaino, claiming that dust wont' stick to the zaino. That's the exactly kind of snake-oil BS that irks me. If anything, the zaino seemed to be a little stickier, but there was too little difference to say either way; a wind shift could have done it. As dusty as it gets around here, that would have been a huge bonus for me.
    I also notice that sal zaino claims that silicone is used in all carnuba waxes. I don't think that's entirely true; i don't think there's silicone in the cheap zymol i use.
    dave
    Yes, I'd have to agree that photos and a controlled environment are weightier than a verbal opinion or claim. The photos/environment control may in fact still not PROVE anything, but they add more weight to an argument vs. just a stated verbal opinion. Doesn't mean the verbal opinion is wrong, only that there is less likelihood of winning converts among people who like as much evidence as possible.
    With some things, like claiming that Barry Bonds is the top home run hitter in baseball today, you don't need photos or even the stats....common agreed upon knowledge...but as to which product is "best" or "lasts longest", you either have to back it up with some evidence or risk not being believed.
    If someone doesn't want to believe you, no evidence will work. You need to be talking to people who's minds are opinions are flexible enough to change.
    This reminds me of the MAC vs. PC argument, doesn't it?
    I completely agree with Shifty's comments. The people that do this best are the Consumers Union (aka Consumer Reports). They employ engineers, design and create test equipment and facilities for the sole purpose of product evaluation. They've spent millions of dollars over the years simply attempting to discover the differences between products. If they don't have staff on the payroll, they employ known and respected experts in a particular field to evaluate and analyse (like wine testers). They frequently use widely accepted techniques like "double blind" method to eliminate partiality. There is no doubt in my mind that CU is the nations, if not the worlds, most impartial product tester.
    Why do I mention this? Because CU is the Standard against which all other product testing methods are measured. Anyone who is going to compare products should use CU as their inspriation; if not technical then at the very least ethical.
    Our Porsche friend may not have spent the megabucks to mimic CU's testing capability, but at least he put forth the effort to minimize conflicts. I thought he did a good job for one person in his garage.
    But there will always been "non-believers" that simply won't accept any other result that differs from their pre-conceived notions.
    It's hard for anyone to call me unconvinceable. After all, I have eight brands of products in my garage today (Pinnacle, Meguiars, Eagle One, 3M, Detailers Pride, Finish First, P21S, Lexol). I've used most every brand on the market over the last 20 years. Adding another brand to my palette is no big deal.
    PJ has 6 months to develop and refine his testing techniques and methods of analysis. He's never failed to criticise someone's opinions or findings. When his assertions are questioned, he's frequently engaged in personal attacks. Time will tell if he can grow from personal persecutor to objective analyst. Otherwise, whatever he presents in March will be worthless to most everyone but himself.
    From my post in SBW:
    #803 of 1231 MB by bretfraz Apr 30, 2001 (07:36 am)
    "forbidden product". I like that! I'm gonna start using that phrase if you don't mind.
    But seriously, I don't recall saying anything bad about that product except that I think it's pricey and I think it's a complex usage process for a novice or casual enthusiast. But those are my opinions, for what they're worth.
    Since I've never used the "forbidden product" I can't really offer an honest opinion of it but I do have experience with products very similar to it so I don't feel the need to shell out the mega$$$ to satisfy my curiousity. I've read all the proclamations here in TH and other sites and I'm sure it performs like everyone says it does.
    Thank you for the compliment. I'll continue to provide as much insight as possible for all of us who use "Store Bought Waxes".
  • mpynempyne Member Posts: 120
    but has anyone used or have impressions on durashine. i was thinking or stripping the zaino of the car and putting some durashine on for the winter. i want to do this because of the promise of no water drops. this will let me rinse the car off at the car wash with out allot of maintence.
    First, congrads to div1 for performing a good test. Thank you.
    Second, I guess many of us are just a wee bit rapid. Nothing was lost here except objectivity.
    At least dhanley seems to be comming around on testing. And finally, chief rapid mouth bretfraz is beginning to understand the value of double blind testing. Maybe there is hope after all. Hey, if we can nail Bin Ladin, maybe we can agree that objective testing has merit. Thanks, Shifty, we all needed that input.
    So while your blood is still flowing, I'll bite the bone and offer my own "non-objective" conclusions too:
    * Meguiar's is a very good product. In terms of shine and swirl removal, I'll concede that Meguiar's is up there with Zaino and may indeed (accepting this test's results) have the edge in terms of swirl removal. If you are a Meguiar's fan and like the results, then stick with it.
    * My personal criteria for an external car paint finishing product includes: Protection, Endurance, Shine, Ease of Application, scratch removal/cover up, and cost. This test covered two of these important criteria in a good fashion, and thus, should serve as a standard along with other tests that have been published here at TH.
    * At a Zaino user, I noted that shine was really rated about equal. Actually, from prior use of Meguiar's and Zaino, these products produce slightly different types of shines: clear vs color enhanced. Both are good and which is best is a matter of taste.
    * The scratch or swirl removal results seem to be extremely close with Meguiar's winning by a nose so to speak. Both products are very good and the differences small (A vs A+). Still, I'll except these results.
    * Because I drive a daily commuter in the NorthEast, I am extremely aware of road salts, brake dust, hard particals, ice, and a wide variety of enviornmental nasties (rocks, construction junk, etc). For me, protection from the elements is a primary concern. Thus, how well a wax or polymer seals the surface against water, ice, temperature changes, and those tiny micro-metal based dust particals has real dollar meaning for me. From my own (non-objective) testing and from what I've researched about polymers, Zaino's Z2 product is still the best for my needs.
    * Because I live in NYC and do not have a good facility for washing and detailing my own car, Endurance is an important factor for me too. Again, from my experiences, Zaino is still the champ.
    * I could go on with the other factors which are important to me and build a rather complete case for Zaino products. Even the harshest critic will admit that Zaino is a first class set of products and that its initial higher costs are more than offset by ease of use, endurnance, and number of applications per bottle. But rather than get into really stupid arguments which will only serve to confuse many causual readers, I think it is time to really understand what our host, Shifty, has been saying to us:
    Its not absolutely necessary to debate every attribute between two or three great products. But since that has happened, the double blind and complete factor testing as practiced by CU is the only way to settle some of these issues. Until we can get a third party such as CU to include our favority products in such a test, most of our silly arguments amount to little more than BS. I like Zaino and will stick with it, and I also expect experienced Meguiar users to do the same. Both of our cars will look really good, and that should make us all happy. And if you don't agree with me, then I'll arrange to have you dropped on Kabul and you can explain yourself to the Taliban.
    But you had better speak up soon because my friends in the US Air Force tell me the Taliban are not long for this world.
    What do you mean i'm "comming(sic) around on testing?"
    I did a test long ago! You have not. I've mentioned this several times. I did 1/2 of the hood in meguiar's, one in zaino, had other people judge looks not knowing which was which.. etc.
    I take difference with your comment :
    I very stridently disagree with this. I didn't see what a $12.95 bottle of the Z stuff got me that a $3-4 can of paste cleaner wax did not. It wasn't easier, it didn't seem to last any longer, and it wasn't some magical bottomless bottle. You can put any wax on thinly, just like you can put the Z stuff on.
    Your opinion is fine, it's your opinion, and we seem to have had different experiences. But please don't try to put words in my mouth regarding my feelings about testing, and my acceptance of value.
    dave
    Onwards to Kabul!
    I've already been to Cleveland.
    Just don't make me sit in the middle seat.
    Durashine? No, Zaino is much better and longer lasting protection. And if you have to go to a car wash due to the winter sludge, etc, then go to a brushless car wash and you'll be fine.
    At least we can agree on something. Ah, progress!
    I got sucked into the infomercial. If it worked as advertised it might be a good product. It had little shine and little protection as far as I could tell.
    I use what is left in the bottle on exterior non-painted plastic bumpers and trim in the winter when I go to the self serve carwash. I just wipe on those areas when home and rinse it off at the wash bay. It gives a little short lived shine.
  • robertp4robertp4 Member Posts: 22
    I have been using collonite for 10 years now with great results. Should I change to the Zaino?
    Have never tried Collinite Wax, but heard it is good stuff. If you are happy with the results it gives, then stick with it. If not, give Zaino a try.
    Some questions about Collinite wax: They offer 7 types: Which is the best one? And what kind of gloss does the Collinite Super Doublecoat give? I see that it is guaranteed to give a full year of protection even under adverse conditions--what has been your experience? How does it shine after a few rainstorms and high temperatures? Is it easy to put on and remove?
    My experience has been that most waxes don't last much beyond 6 weeks and the gloss quickly diminishes. I have also found most waxes much more difficult to remove than Zaino and often they leave annoying residue in cracks and edges that is a PIA to remove.
  • armtdmarmtdm Member Posts: 2,057
    I have and do use this. I currenlty use three products, the Collinite (excellent shine easy put on and remove, perhaps some build up in cracks etc) also uise #26. Slightly harder to remove for me. Also use Zaino. So, you may think this is crazy but until I use up the Collinite (which costs the same as Zaino) and #26 on three cars I use Zaino for the roof, hood and trunk and the other panels/doors I use Collinite or #26. On two cars it is straight Zaino. Zaino shine is about the same as other two products, maybe a little better but durability is way beyond the carnuba waxes. After I finish the two carnubas I will stick with Zaino, so easy to use and remove even in sunlight.
  • cyranno99cyranno99 Member Posts: 419
    the only way to settle this is to ask the manufacturers to reveal their "secret ingredients" or to ask for an independent chemist to break down the components (difficult but not impossible) I am willing to bet that the chemicals that they use are very similar.... just like those synthetic oils crowd... there are only several major types of synthetic oils going around......
