Visitor Agreement.
Thanks also for the info on the tranny flush. I will have it done as soon as I have time (hopefully I will not see my O/D light flashing before that...).
G.
However since that time I had lost a pint of fluid. Repaired for $105.00.
Glad it was checked before the long trip. I wonder how it would have survived 1200 miles through 90 degree deserts.
Now the engine is loud after many quiet years of operation. I just took it to a mechanic and they had to weld 2 large cracks in the exhaust pipe to fix the noise. I guess $85 beats a $700 replacement bill. The mechanic told me the exhaust pipe sits over a protective plate that doesn't let the pipe dissipate the heat correctly and eventually caused the cracks and noise problem. Just thought I'd share and see if others had the same problem.
We'll, as I said before, the ECU gobblins heard me and decided to torment me again. The CEL is blinking away on my 626 (4 cyl. ATX). However, as I mentioned before, I learned this has a EEC-IV Ford diagnostics thingy, and got the codes myself. Just jumper STI to SIG return with a paper clip, turn the key (but not the engine), and voila! Codes! I get "111" for hard faults (which means nothing is broken at the time of the test), and "181" for the memory codes. Now, 181 in three-digit EEC-IV jargon, according to my little manual, means "Fuel system lean at part throtle Single. Right or Rear HO2S". Now, I don't think I have a rear O2 sensor, right?
So the question is, what the heck does "181" means on a four-banger with a single O2 sensor? Some posts ago this was said to be MAF, so just in case I'll clean the darn thing again. I know I didn't break it last time because the little filaments were fine...
Suggestions from any 626 gurus that may have heard of this will be thoroughly appreciated...
G.
PS: If you you are stuck with a 4cyl 94-95 with ATX, the stupid EEC-IV connectors are right in front of the battery...
So to answer your question, I guess the Mazda 626 has a rear O2 sensor.
Rick, I am also hearing a 'rattle' on acceleration coming from the general vicinity of my exauhst, so maybe I have a similar problem to the one you had. Who knows, maybe I have a hole in the muffler or cat and that is throwing off the ECU.
As for cleaning the MAF, I did not do the 'spray with carb-cleaner' part. I only blew air from a compressed air can (gently) to dislodge dirt. I wasn't to kin on coating the filaments of the MAF with lubricant (which my carb-cleaner had, or at least it said it had a 'revolutionary product that will lubricate and protect all moving parts of your carburator'...). Anyway, I'll get some 2+2 which has only solvents (pretty nasty ones too) and do the 'full' cleaning. I'll also change the air filter (which pretty much requires you to take the MAF appart...).
Cheers,
G.
PS: Windowphobe, does your 'call-name' means you are a Mac/Linux fanatic? Good for you!
BTW, the '95 only has one O2 sensor.
G.
I would suggest using electrical contact cleaner, NOT Carburetor Cleaner.
(Actually, I got this name from hanging on to DOS as long as possible.)
I have tried to find out if Mazda has had auto tranny problems in the past. I have found none. I now turn to you. I have a 98 626 w/ 86000 miles on it and the tranny just went. My Mechanic said there was nothing I could do regardless of how many time I changed the fluid and kept up on it. This sounds almost like defective equipment to me!!! Has anyone else had a simular thing happen or do I just have bad luck?
Without getting into the the standard religious debate here, I'll say only that neither of the two automatics offered in the 626 is likely to be a joy forever, and the LA4A-EL tranny in the four-cylinder cars (sourced from Ford, who calls it the CD4E) has had a higher failure rate than the GF4A-EL box (a revised Mazda design) in the V6 cars.
And yes, sometimes there is nothing you can do, but there's no way you can possibly foresee this, and if you could, you wouldn't be here posting - you'd be at the racetrack picking winners.
As for cleaning the MAF, I did it 'right' this time, and used 2+2. I made sure that it only had solvents and no lubricants, and I sprayed into the 'hole' in the sensor. It has two resistors (not simple wires), which look like 'diodes' (i.e., black little cylinders). After cleaning it, a lot of grimme came out the other end, and I made sure to dry it out well with compressed air (again, gentle blowing, not 20 pounds of air). The thing is fine and working (my friend actually tested it), so I think that this can be done to keep it going for a while before replacement.
Again, I'll keep the group posted as to how things evolve with time...
G.
I can wait to fix them since the driver console still works, but is there a known issue with them, or something easy to fix on it?
Otherwise I'll have to visit my local junk yard.
Good luck with the exhaust irishalchemist! You'll know there's a crack, it'll sound like a tank.
My car is nice and quiet again. I used to hear my wife drive up with it, and she snuck up on me this morning, I didn't even hear the car. That's one of the things I liked about the 626, it's a quiet car, but still has some pep to it.
http://www.flash.net/~rfm2/massair.htm
The filament is actually wound into a coil on a ceramic rod. So, metal and ceramic, I don't think solvent will do any harm (except if the stuff goes into the electronics above the filaments, then you are up the creek with no paddles...).
Also, the 'rattle' on the exhaust was the heat shield on the pipe connecting the resonator with the cat converter. The welds holding it in place cracked, and the whole thing was loose. A couple of clamps and the rattle is gone...
G.
1) Has anyone done it? If so, any suggestions?
2) What order, before or after the stock cooler?
3) What size? I'm thinking a B&M 16K GVW should be more than enough ($42 at carparts.com).
4) Should this be done before or after a tranny flush, or does it even matter?
Thanks for any ideas. I plan to take pictures and put everything up on a web page when I get around to do it...
G.
After reading all the horror stories regarding the CD4E I am trying a pre-emptive strike. First, I'll install a tranny cooler as I posted before. This will be done in a couple of weeks.
Now, I have had conflicting advice from people reagarding a full ATF flush. Since the CD4E does not have pan/filter (right?), the 'regular' ATX service does not apply (again, am I right here?). So, the full flush sounds like a good idea. However, several people have told me that they would not do it on a transmission with 80K miles and no record of service (I've got it since 68K, and I doubt the previous owner did anything to the ATX). What they say is that if I flush the old fluid out and add new, the detergents in the new fluid will dislodge dirt/grimme/varnish and this will kill the ATX right after the flush.
So the question is, should I or shouldn't I flush it?
G.
How does your fluid look, anyway? If it's the right color and doesn't smell burned, you may be in better shape than you think.
As for the fluid's current color, I would say is a redish 'terracota', meaning, not dark sludge, but not bright pink either. And it does not smell like 'burnt toast', as other people has described, so I guess it's still OKish...
G.
Any objections to this method, appart from it's cumbersome-ness? I think that it would be safer than a power flush with a machine, and if the new fluid does dislodge any junk, it could be sucked out in the successive dilutions.
G.
Really light red suggests aeration, hence leaks. You don't want it to look pink.
A couple of the guys here swear by Lubegard.
Just wanted to let everyone know. After the valve cover gasket, plugs, and wires replacement, and the MAF/throttle body cleaning, the CEL hasn't come back to haunt me! It does not 'ping' either when I accelerate hard, and feels a lot more 'peppy' than before (all this is probably subjective, but...). In any event, it's nice to be able to got WOT without the thought of having the stupid CEL coming on...
One more thing. My friend told me that to do what he calls a 'complete' tune-up I would need to change distributor cap/rotor and fuel filter. I looked for prices and found that Mazda stuff is twice as much than, say, Beck/Arnley. Any reason for going OEM Mazda and not aftermarket?
G.
G.
My Mazda mechanic worked for the dealer for 20 years before setting up his own independent shop.
He recommends the following procedure. A drain and fill every 15K. When refilling Add the proper proportions of Lubegard or WearGuard. My son's 1997 had his auto stick between first and second. A complete drain and adding in his case WearGuard completely took care of the problem immediately.
If you are not having any problems right now I would do the drain and fill with a good transmission fluid like Valvoline Maxlife, and add LubeGard as well. It can be purchased from NAPA. It has saved 3 of the transmissions on my family's vehicles. Just adding the new transmission fluid will be better than not doing anything, but the Lubegard gives it the extra boost needed to keep the transmissions more stable. I have used it for 3 years with nothing but success.
ALLDATA says that the official labor charge for changing this hose (on the '93, anyway) is almost twice the charge for changing the one that leads to the rack, which makes me think it's probably not that easy, but not impossible either.
As for the leaky PS hose, the leak it's not that bad, and after a more detailed inspection I realized it's the 'easy' one; That is, the short piece that connects to the PS pump with a banjo nut and runs over the cam cover. Provided that there is no pressure there when the engine is off (to avoid getting ATF all over the place), it should be a 20 minute job.
Cheers,
G.
Well, tomorrow I'll do the cooler install as I mentioned before. I have a couple of questions. After my friend learned that the filter is not accessible on the CD4E, he suggested I install a remote ATF filter at the same time we do the cooler installation. I checked on some pages, and they do mention it as a good idea.
Now the questions:
1) Is it a good idea, or am I just going to screw things up by making the ATF pump push the fluid through more hoops?
2) If they are a good idea, which ones are better? I've seen 'spin-on' types that use regular oil filters, and the 'in-line' type (which have magnets inside).
As usual, suggestions/answers/thoughts will be appreciated...
G.
Spent all morning cutting/welding together and fitting an alumiinum frame and steel lines for the cooler. It's almost done, and next week we'll do the connection to the tranny. As I said before, I will take some pictures of the whole process.
Anyone knows, top of their head, wich lines goes from the tranny to the radiator, and which one is the 'return' in the CD4E? It should be easy enough to figure out, but just to make sure...
G.
In a GLC I had in Texas I had really bad milage in the summer one time (and the GLC was VERY economical), and I was able to track a fuel cap that was not sealing properly. With 100 oF day in, day out and the car parked under the sum, the stuff just evaporated from the tank. But again, new cars seem to 'know' when the fuel cap is not holding vaccum by turning on your CEL (however, I think this is only for OBD-II cars, which the 95 ain't).
Hope this helps...
Something is probably reading the needed air/fuel mixture as too rich if there are no leaks in the fuel system.
93 143k mile ES. I was fearing that there were leaks which require a much more expensive repair.
The neighborhood Goodyear store tested the system and detected no leaks and just one pound is needed for the recharge. Hopefully, their diagnostic is correct and it won't enlarge the hole in the ozone layer.
Is it normal to loss a pound in a 9 year old car?
And how much freon does the system actualy hold?
Anything in particular I should look for on this car? Thanks.
If you're worried about the environment, in my area they can do a conversion procedure for under $400.00. It works well if they get all of the older fluid out. I recommend an air conditioner or Mazda specialist to ensure the procedure is done correctly.
I converted my oldest a few years ago when I had to get a new air conditioning compressor. I really like how it has performed.
In case someone is planning to ask, the later models use 26.5 oz (not quite 1.7 lb) of R-134.
I would also change the PCV valve.
http://www.batauto.com/Ford.html
You will hear the fans and other stuff self checking, and then the rest is looking at the flashing CEL. If everything checks out OK, you should get "111" for hard faults, and "111" for memory codes. The codes are three-digit, and the ones for the 4 cyl. 626 don't correspond with the ones for Ford. You'll have to do a google search for 'EEC-IV three digit codes', and you'll find pages that describe the codes for non-Ford cars with Ford brains.
Now, if you are not seeing a flashing CEL, there may not be any codes in memory. This is OBD-I, and only registers codes when the CEL flashes (I think...).
I agree with others, your problem may be the fuel filter, so have plenty rubbing alcohol and band-aids to clean and patch your busted knuckles after you change it (believe me, you WILL bust your knuckles badly when changing this thing...). What made it a thad easier (although longer) for me was to remove the cruise-control actuator that sits on top of the fiter.
Good luck
G.
Also, look here:
http://home.golden.net/~trinity/nav.htm
look under MALF CODES...
G.
