Visitor Agreement.
Could somebody please help.
Well, I know this is sad, but for the life of me I can't figure out how to get the old battery out! It has this Delco "heat shield" thing that I have never seen before surrounding the battery. There's this piece of metal fastened to the side of the car at one end, and it passes through a slot in this "heat shield" at least half way across the top of the battery and below the heat shield. This is done in such a way that it would appear to be impossible to get any of this out without at least removing some other parts of the car -- is this correct, or am I missing something obvious?
There's a nut just prior to where this piece of metal goes into the heat shield, but removing the nut accomplished nothing. I was unable to reach the nut that bolts the other end of it to the side of the car, and besides that really didn't look to me like something I should be removing.
I easily unscrewed the two positive and negative posts and off come the cables, so they're all set.
On the other side of the battery is the filter and a big hose connected to it. I even tried unclamping the cover over the filter so that I could move the hose out of the way to try to make room to pull this "heat shield" off. Still, I could only lift the shield up about 2 inches. It won't budge any further.
Towards the front the battery is blocked in by a fuse box; I'm not moving that!
And, I have no idea what butts up against the battery towards the back, and I'm not moving it either.
Please help? I'm just a computer geek and am obviously not a mechanic, although I really think Saturn could have designed a simpler mechanism for holding in a battery (its not rocket science!)
I know it's been a particularly hot summer on the east coast, so would that have anything to do with it? What else could be the problem? Also, should I keep running to the dealer for guesses? I don't want this to develop into larger problems but I also don't want to keep spending money for potential fixes if the only thing I can really do is deal with each overheat situation as it happens (cool down engine, replace water/coolant, etc.)
After I did the tune-up the car had a lot of restored spunk, and the throttle didn't stick like it did before. I thought this had solved the problem, but after she ran a few tanks of gas through it she reported back that her mileage was still getting worse. Well, it was time to change the tranny fluid anyway, so I changed that and the filter. Pulled the plugs to see how they were burning, and they looked pretty clean. Checked everything else and it all seemed to be in order. Car shifts smoother now, like it does every time I service the tranny, but mileage still dropping - now down in the 30-31 mpg range on the interstate.
A few weeks ago I had new tires put on it - it was due anyway. I made sure the tires were all set at Saturn factory specs. I also checked the struts and they all seem good. I jacked it up and checked to see if the brakes were maybe dragging, and they're all fine - tires spin pretty freely, and CV boots are in good shape.
Her last tank, with almost all interstate driving, was a whopping 27 mpg, and its getting worse! I changed plugs again out of sheer frustration - went with Bosch Titanium 2 plugs. Car runs the same, but I don't know what her mileage will look like yet.
The car is in relatively good shape - a few rattles, but no noises under the hood. It runs smooth as butter, but when starting it while warm the idle goes up in the 1500rpm range, drops down VERY low, and goes back up to normal. Before I cleaned the sensors and TB it would die on occasion when starting it. Could the injectors just be dirty and need cleaning? What else could cause this?
Any ideas? I can't for the life of me figure this one out! I'm at my wit's end, and gas is only going up!
Thanks in advance for any suggestions!
I changed the fuel filter which might have helped the gutless acceleration and hill climbing a little but did nothing for the starting problem.
A Honda tech told me that Hondas sometimes do the same and that it could be the master fuel relay.
If you figure it out please email me.
Thanks again!
One question, though--I've heard that in later model Saturns you can't remove the bar for the cargo cover across the back. Is this true? Otherwise, it seems like it would be difficult to get any real cargo in there with the seats down.
Never had any problems with the Saturn company, either. Although, I've never had a problem with my car yet. I'm sure I'm due, and I'm sure that when I do have some problems, I'll get the run around.
I was also considering buying the Saturn ION Redline when it came out and throwing a body kit and some engine mods. I think it'd look pretty bad [non-permissible content removed] with what I have in mind. :P Never thought I'd throw a body kit on a Saturn, but hey... Why not? Lol.
I filled it up with gas this morning, so we'll see if that helped. I may also replace the post-cat O2 sensor this weekend when I'm under there changing the oil.
Thanks ya'll for the help!
97 SL2. I did and the car was a total loss. But the strange thing is they were
partly working the next day. I am currently being sued for this accident and
any info would be helpful.
accident scene to check the brake fluid. Of course it was full. I did'nt notice
if the rear brakes were dragging or not, my 15 year old son was driving at
the time. ( i was with him of course ). He did mention recently that the brakes
felt kind of soft just before the accident. Thanks for the response.
you sound very professional, and I would be happy if you could answer another question on this subject.
I have the same transmission problem on my 96 Saturn (with 86.000 mileage) as stated above.
Referring to your quote: If it happens only when hot, then the valve body will require replacement and the end cover will have to come off so the Input and out put shaft nuts can be replaced." If I would replace the Input and Output shaft nuts, would this possibly solve the problem of the alignment of the Valve Body? I am not sure if the Valve Body even needs to be replaced. Could the misalignment of the Input/Output Shaft on the Valve Body cause the transmission to malfunction.
I look forward to hearing from you!
Regards, Bill
My niece is having a similar problem with a 2003 L200 sedan with no moon roof.
The side bolsters on both front seats and the bottom cushion of the back seat get wet and soaked after a considerable rainfall. The floor and trunk are dry, as is the ceiling panel.
The local Saturn dealer checked the third break light assembly and the antenna that sits above. No leaking was encountered. The dealer says this area can sometimes lead to water leakage. This dealer also did a "soaking" test with a high pressure hose to try and duplicate the problem, but no leaks were encountered.
If you hear anything more, I would appreciate any information you may have to solve this problem.
goose65
They have a search feature for complaints on specific vehicles that they use for recalls and investigations. I always search this before I buy a new vehicle so I know what to look for if it's used, but it could be a great tool to use for your lawsuit...
gave me. There were 5 complaints about complete brake failure. Sounds like to
me this person should be going after Saturn.
I went to Kragan and they tested the battary and alternator and starter and told me they were all fine. The battery is only 4 months old.
Anyone have any suggestions or ideas?
Will you give some of the symptoms you had on your Saturn with the defective BCM?
My 02 L300 is experiencing several unusual problems which I believe is being caused by the BCM. All of the problems are intermittent, and no codes can be read with a diagnostic device. After removing and reattaching the battery cable all symptoms leave for a time. The security indicator comes on while driving; the ABS indicator comes on; the Check Engine indicator comes on; the lights flash very rapidly; and there are several other symptoms. Once, the wipers came on and they could not be turned off or other wise controlled. And yes, on one occasion it would not start. My 02 is out of warranty so I don’t want to be guessing incorrectly. TPJ
does anyone have any solutions???
thanks again!!!
It also gets water on the front passenger floor almost every rain. Is this plugged drains for the sunroof? How do you clear them?
Thanks...
The service engine soon light is on, code comes back to catalytic converter. In addition to the light coming on and staying on, when I turn the car on it may take up to 4 cranks to actually turn over. Sometimes it starts, then sputters, and dies. Other times it starts right up like there is nothing wrong. I have some loss of power, especially uphill (even small grades), and can smell a heavy sulfur smell when heading up a hill. The car seems to shift hard (manual tranny), and almost bucks when in 2nd and 3rd gear on acceleration.
I seriously can not afford any more expensive repairs so if anyone can PLEASE (!) help me in figuring out what to do I would really really appreciate it. I just put in some additive to clean the fuel injectors (hasn't made a bit of difference) and am worried that it may be the fuel pump because of the starting problems. I'm no mechanic so please give some advice if you can! Thanks. :confuse:
1) The coolant warning light flashes often, even though I replace the coolant when it does. I took it in a few weeks ago and got a (vacuum?) test done on it to see if they could find a leak. They said they didn't find any problems with it. Saturday, the light went on again and the temperature shot up into the red. I replaced the coolant but then it was all over the pavement within a few hours. I tried driving it again this morning (Monday) and the temperature shot up to the max within a few minutes. Any suggestions?
2) There seems to be a disconnect between the accelerator and the (automatic) transmission. Often, I push down the accelerator up to halfway and the reps first go *down*, then rise slowly after about 5 or 10 seconds. This can obviously get dangerous when I'm pulling out into traffic. If I push the accelerator down quite far, the car will respond by jerking into a lower gear and raising the reps really quickly. It's almost like a horse rearing back. Quite disturbing. The shop did some engine tests on that too and apparently didn't find anything significant either. They did want to replace my shocks and wires for about $300 though because it might 'improve performance'. Thanks Firestone.
Does anyone have any ideas? Maybe the two problems are connected somehow? Thanks!!!
