-September 2024 Special Lease Deals-
Saturn Maintenance & Repair
Mark
I have problems shifting into gear after my 98 Saturn sits for a while in cold weather. It can take up to 15 minutes to "warm up" so that I can put it in gear. Is this the gear-shifter bushing problem? If so, how do I fix it? I've had it in for repair but of course, the mechanic doesn't have the problem - even after I left the car there overnight.
Also the wipers stay on when its cold for no reason sometimes, and when i try to put the car into drive sometimes it doesn't go, i have to put the car into park and then put it into drive again. I'm really hoping it is nothing serious. If you know what signs I should be looking for to see if its a cracked head, or if you think it may be something else please email me at aprilb83@hotmail.com
Good Luck!
I'm new to the list but not to the problem, sadly. 2000 Saturn wagon. Sitting cold over night and now won't shift out of park. Put more transmission fluid in, which has worked before (it's stuck in gear before), but it has not helped. Sitting on a steep hill so can't measure fluid levels. Any thoughts?
I thought my name would come up automatically when I posted the previous message so I'm just attaching it here. Thanks for any help you can provide to the question about the 2000 saturn wagon transmission problem noted in the previous message.
Doyle Sely
So far I have driven it about 400 miles and just love it. The Honda V6 was the big selling point for me. I am averaging just under 25 mpg which I consider to be excellent for this type of vehicle.
Now my question. I have a rather loud sqeaking type noise coming from the front end. It sounds like rubber rubbing together and only happens on road imperfections during slow speeds (like going over speed bumps for example). Its still under the factory warranty so it will be going to the dealer next week. I am just curious as to what it could be.
The car stalled on starting and while driving and with the foot on the acceleartor maintaining a steady speed, all of a sudden acceleration slowed by itself and lights dimmed out. Happened a couple of times. Fuel engine was replaced a year ago.
Could it be bad gas? or water in the gas?
-L
I have a 95 SL2 1.9L DOHC with auto transmission. Car has been stalling while driving every month or so for the past year. Recently started stalling more frequently and eventually refused to start. Took it in and had the fuel pump replaced &f uel filter checked. Car now starts fine and runs fine mostly, but the stalling while driving still happens on occasion.
Last night happened again while on the freeway: while cruising around 55 mph, acceleated to pass another car. Car hesitated to accelerate, then after a few seconds did accelerate, then downshifted into 3rd while accelerating. After passing the car, my car shifted back into 4th. 20 seconds later while cruising around 65 mph, the car started to buck a bit. Put it in neutral and RPM dropped to about 300, then engine died. Was able to restart. I am unable to make the car stall on-demand.
There is a hill near where I live. When I accelerate to go up this hill, car does fine, but once I top out and begin to come down the other side and begin slowing to come to a stop, the car often stalls (4 out of 8 tries). Once, it came to a complete stop and did not die but idled very rough for a few minutes (which means it can't be the Torque Converter Clutch, right?). Engine Warning Light came on for a few minutes but then went off.
Any ideas what's wrong? The mechanic who replaced the fuel pump thinks it might be the torque converter clutch or the solenoid-driven valve used by it. I am wondering if it isn't the Throttle Position Sensor.
I am considering unplugging the Torque Converter Clutch as a way to rule it out. Any concerns in doing so?
- Michael
******** My Question ***********
I have 1998 SL2 with similar problem as described above.
-L
I am just now having problems with it, fuel line freeze up, and just common problems like the oil burning and the roof leaking. The odometer stopped at 176,450 miles about 8 months ago and I drive an hour to work 3x a week. So I bet I'm pretty close to 200,000 miles.
As long as you take care of it, there shouldn't be too many problems. Best car i've ever had!!
Ian Campbell
My brand new ion, with only 4000 miles on it had the check engine light come one twice this week! On Monday, when i got in my car for the first time since the beginning of the weekend, the service engine light came on. I drove it 40 miles to a saturn dealer by my parents, they gave it back that night, told me that codes P0700 and P0717 were present, they reprogramed the ECM and cleared the light. Well, surprise, surprise, 24 hours later, the light came back on. Now the dealer is telling me that an external sensor on my transmission needs to be replaced and will take almost a week. Im not too happy with the way the cars driving, or the service at saturn...any suggestions??
