I also have an 88 Accord, and I just lost my 2nd condenser over the winter. My failure is due to road salt, not rocks.
Good luck
If anyone's had a high-pitched rattle coming from in front of the moonroof, what was the fix? I have that rattle too, as well as a few others.
Yes, since they are close to the ground, the red door reflectors can be seen for perhaps a half mile away in an oncoming vehicle's high beams and at least a half block away in their low beams (try it). This provides ample time for the approaching driver to react if they are at or below posted speed limits.
You may find that "The big red rear/brake lamp...", that you wrote of, will not be visible once the driver has removed his/her foot from the brake pedal and turned off the ignition & lights immediately prior to the doors being opened.
If the other driver doesn't see a reflection from that lense (even without brakes/light
are on), what is the chance the driver will see a 1"x2" reflector on the door when the door is open?
Also, if Honda thinks it's there for safety, why didn't it make the same for the front door where it's opened often (by the driver)?
Daniel
Congratulations on your new Accord and Civic. I have been driving Honda (motorcyles and automobiles) for over 40 years and so happy with them. Now, I have 4 Accord at home. My top is the brand new Accord Hybrid 2005. I am planning to buy another Accord hybrid soon. No need to buy the Acura TL as the Accord hybrid gives me better MPG and so quick and quiet. I am sure your son and you will definitely enjoy your new Civic/ Accord. You made excellent decisions.
Check those tiny white reflector strips on the back of most sneakers. They work very well in alerting drivers to the presence of pedestrians and runners after dark.
The buyer SHOULD have taken the car into a shop first for an inspection but that's water under the bridge.
It's 105,000 miles between timing belt changes on a 2001 Accord and I'll bet it's been done but maybe not.
A trained mechanic can spend a half hour by prying back the t-belt cover and looking at the belt with a flashlight. If it's the original belt, they can tell by the markings. If it's been replaced they can usually tell. If the person checking the belt has any doubts it would be smart to replace it along with the water pump and drive belts.
A compression or leakdown test would be a waste of money if the Accord is running well. These never have ring or valve problems. They can get carbon under the valves which will cause a loss of compression. We cure this with a "carbon blast". Strong solvents through the intake system will clear this right up.
my 92 honda accord has been giving me some problems lately with the brakes. i'll be driving normally and then my brakes will barely work!! my foot will be on the floor and the brakes won't work. this only happens on hot days and i think it's an overheating problem but i dont use the brakes in a way that would cause the overheating....is there any way to correct this ??? :confuse:
You have 2 options:
1- Replace the (brake) master cylinder.
2- Donate that car and buy a brand new Accord with a loan at 1.9% interest at Honda Inc..
I had replaced my 92 Accord's master cylinder a long time ago and I have given .it away years ago now. Good luck.
Make sure you remember to disconnect the electrical clip to the power window and lock switch before pulling the door panel too far away from the door. Also, as i recall we had to pull on the white plastic pretty hard along the line where it was glued to the top of the door to get it off intact. But the glue remained very sticky and we were able to put it right back up again when we were done.
Happy motoring!
-FS
brakes. My brakes work normal when the car is running. When stopping at traffic light, the brake pedal sometime starts shinking. In that case I just pump the
brake pedal a few times. Then it's back to normal.
People thinks it's the M/C. I think it's either the diaphragm in the booster or the booster check valve. I will test the check valve first. It's an easy test.
I will test mine soon when the hot days are here.
deek01@yahoo.com for responses please.
Just a suggestion..
Btw, the check valve connects the vaccum hoses between the booster end & the manifold end, not to the M/C. I will order a new one on-line along with other tune-up parts next week. Summer is almost here.
Thanks for the info, Mr Bill.
I was wondering if you guys could give me some information on a clicking problem I'm experiencing with my 2000 Accord EX 4cyl (manual trans). On acceleration, especially when the engine is cold or the weather is cold, there is a noticeable clicking or rattling noise coming from the engine compartment between about 2,000 and 3,500 RPM. It also occurs up over 5,000 RPM (of course only revved up there after the engine warms up). However, in the summer (pretty much if the weather is above 80 degrees) it never seems to happen.
I have been to 3 Honda dealers who couldn't replicate this on their own but were able to hear the notice on ride-alongs. However, they couldn't find the cause of the problem. Even though the noise seems to correspond in quickness to the speed of the engine, they claim it's not drivetrain related but cannot identify the problem.
Has anyone else had similar issues or know of any documented problems similar to this one?
Thanks in advance!
MrBill
I have the same problem as you....I bought a 2005 Honda Accord 4cyl AT last month and it has 1100 miles on it.
Am getting 29 on the highway and about 18 mpg city driving. Just like you, I don't drive like a maniac and no panic stops either. The window sticker advertises 24/34 mpg. Am not even getting 20 let alone dream of getting 24 in city driving. I open the windows a bit so I don't often use the air-condition, but am still not getting any good gas mileage.
Infact I called the dealer today and am going to get the car looked at this Saturday....I don't know why this is happening and even though I love this car, am very disappointed with the gas mileage..... :mad:
I will let you know if the dealer finds anything......
Good luck
Take the few days required to drive a tank at 65 or so and see what you get. If it goes up over 30, then it's something like underinflated tires or an impatient driver, not the car.
I just took a long trip in a 05 V6 at 70-80 mph, and averaged exactly 28.0 mpg for the trip. EPA is 30.
Since yours is a cross-post, here's mine:
You will find that your mileage is significantly better at the speed limit, rather than at 75 to 80 mph. It's a matter of pure physics.
I average in the low to mid 30's in all flat steady-speed highway driving with my 2004 V6 AT Coupe. Hilly highway driving, with varying speeds, will lower those numbers.
I raised the issue that if it was normal noise, why didn't it happen the first 2500 miles that I had the car? The service rep didn't have an answer. I'm bringing it back in on Friday because of a dent they put in the headliner today while fixing a rattle up in that area. I'm going to take in a printed copy of the post and solution and ask them to "humor me" and put some insulation around the plastic piece behind the B-pillar.
This is the third time I've taken the car in for interior rattles. It's wearing me out.
Good old wind resistance gets you every time
The EPA "highway" test is done at a simulated 48mph on a chassis dyno (no wind at all) and is "corrected" to produce a "Real world" number. So it is no big surprise someone going 70-80mph is not getting EPA highway numbers.
Dennis
In a modern, very aerodynamic car leaving the windows fully closed would produce less drag at highway speeds than running the A/C.
Most cars return worse mileage in the winter or cold months - part of this is gas wasted "warming up the car" . Likewise most cars improve fuel mileage as the new car breaks in after some miles.
The EPA numbers are just guesses, we all live in different parts of the country and put various blends of gas in out cars. For me, my commute into work is about 17 miles but takes about 45 minutes. The more sitting you do in your drive to work has a direct impact on your MPG for your "city" driving. Since you are getting 29mpg on the "highway", sounds like your car is doing OK. Maybe your "city" driving just involves more stop than go that what other folks have to face? How long does it take you to travel to work and how many mile? How long to get home?
My wife is getting 21-24mpg "city" commuting to work in her new LX I4 AT.
Dennis
Set COLD pressure to what's recommended by Honda.
Seems like the most likely reason for change in ride quality......Richard
It takes about 20-25 minutes to get to work and about 30mins going home and about 12miles each way. The speed limit is mostly 45, but I must admit I usually do 50 on a 45mph speed limit road. On average, I do 5 over the posted speed limit.
I called the dealer yesterday, and the service guy told me that even when the low gas indicator light comes on, you still have about 4-5 gallons in the tank, so if I want to see what the true mpg is, I should drive the car a little bit more - say another 80-100 miles before filling up.....can be scary I dont wanna get stuck somewhere, but I will give it a try, a VERY VERY cautious try.
Somebody asked how I calculate the mpg - basically I fill the car up with a full tank of gas and the reset the trip odometer. When the gas indicator approaches the 'E' (empty), I divide the # of miles driven by the tank size (17.1) per Honda specs. This may not always hold true as you read on......
So what the service guy told me makes sense (if it's true) that even when the low gas indicator light comes on you still have about 4-5 tanks and can still drive the car for a while.
The last trip odometer reading was 310 miles (gauge very close to 'E') but the warning light hasn't come on yet......and dividing this by 17.1 gives me about 18mpg.
Am posting this so if am calculating it wrongly, then someone can correct me and also if anyone can backup the claims by the service guy. And as Tanya, et al mentioned I will check the tire pressure to see if it's correctly inflated. My wife indicated last night she thought the tires looked a little on the flat side.
Thanks for your insight, and please keep'em coming. This is an awesome forum
Dennis
There is your problem!
I thought everyone knew how to calculate MPGs, but I guess not
1) Fill the tank until the pump shuts off. Make sure it is really full and not a pre-mature "burp" of the tank (i.e. if the tank is near empty and it shut off after 6 gallons it is not likely full).
2) Reset the trip meter
3) Drive until the tank is near empty, don't worry about getting it really close to "E"
4) Fill the tank up until the pump shuts off - make sure it is really full
5) Note the gallons needed to re-fill the tank
6) Note the miles and tenths on the trip meter
7) Calculate actual MPG by dividing miles travelled by gallons used (e.g. 294.3 miles on 15.301 gallons = 19.2 MPG).
8) Reset trip meter
9) Repeat steps 3-9
Dennis
On my old Accord, I had a similar problem after I rotated the tires myself. Turns out that one of the tires had a bulge in it. The defect wasn't noticable until the tire was put on the front of the car. Anyways, you could have a damaged tire, a tire that has uneven wear, or maybe even a bent rim. I have also read that a wheel thats over torqued can also cause problems.
the fuel pump.
When the Fuel light comes on, there are still about 2 gallons in the tank.
