Dealer haven't done anything you mentioned. One time they replaced one bolt in lower front of transmission housing that dealer called pressure bolt, and last time they put some dye in the ATF and asked me to come back after 500 miles as they could not determine where leakage comes from, but they didn't bother to clean up all the grease and dirt built up after putting in dye which I found out same day after I got home. I'm very interested to see how they are going to do trouble shooting with so much mess around area tomorrow.
I have a fairly new 2001 Accord EX-v6 sedan. Recently I have noticed a humming sound (very evident) at highway speeds (anything over 60mph)when all the windows / sunroof are closed. It is obviously an air leak, I suspect it is coming from around the sunroom seal. Has anyone else experienced this? Any luck at a solution. I haven't tried the dealer yet.
J.
Mwcarlso- I hope we can figure this one out.. love my car.. and don't want to get rid of it... but this problem is very very annoying!!!
Hardball is necessary, because they do this for a living.
Today I decided to do the replacement. I took the pads and caliper off and realized that the rotors are bolted to the hub. It looks like I need a hub puller to pull the hub, and then unbolt the rotor. Is this correct? Will a harmonic balancer puller do the job?
Any advice would be greatly appreciated on the proper way to replace these rotors.
My car has 132K and has been driving great. I just had an oil change about a couple of weeks ago at the dealership.
I'm waiting for that dreaded phone call from my advisor.. "About your car...".. Ugh, bad way to start a week.
I guess some seal must have broken? Oil seems to be coming from the front driver's side. Underneath where you have the power steeering fluid. Around the area.
Are there various seals down there? Or just one? Expensive?
I was just out in the parking lot (at lunch time) dusting my car (Ok, Ok, I'm a Zaino user). A woman who works with me walked by and complained (rather bitterly) about the paint job on her '98 Accord. She says her paint is peeling off! It hasn't happened to me probably because I protected the paint. But the fact that normal conditions would result in paint peeling is rather troublesome. Has anyone else had the same problem?
I love just browsing the old appends to this forum! I have no clue when you talk mechanical stuff, but at least the words stick to my head
thx
I have a 99 V6 coupe and thought after two years it would be a good idea to take a look at it.
Phil
Now for a new problem I haven't seen addressed here. The SE fuel gauge operates fine, but the low fuel light stays on all the time (no, it is not low on fuel), conversely, the LX low fuel light works fine, but the fuel gauge will only go from full to about 3/4 full as fuel is used. It never drops below that.
One last problem with the LX. While using the cruise control, my speed will vary 3-5 mph and the transmission in constantly shiftly between 4th and torque converter lockup. Could this be related to the above transmission problem? The LX has 142,000 miles on it.
Other than these items, I love the cars.
As for the searching with the trans and cruise, try adjusting the throttle control cable that goes down to the trans a bit tighter.
My coupe only has 3500 miles, but the paint is flawless...not one chip. I recently waxed it with Meguiar's Gold Class Wax, which I picked up at Wal-Mart for about $10. Beautiful wax and it feels like it puts a thick layer of protection against road debris. I was going to use Zaino, but it's expensive, and frankly this Meguair's stuff is better than any "cheap" wax I've used previously...it looks like it has some optical enhancement ingredients because my silver paint is so reflective and deep. Well worth the effort (2 hours total).
IIRC correctly, someone once posted on an Edmunds board that paint on today's cars is as thick as two sheets of newsprint inclusive of primer, paint, and clearcoat.
New waterbased paints don't seem as chip resistant as the old solvent based one.
I think we all drive a heck of a lot faster and rocks and the such are hitting the vehicles much faster.
I think most manufacturers have gone to thinner paint to help boost mileage estimates as well. Paint is pretty heavy stuff. I once read that American Airlines didn't paint their planes because of the additional weight - hence the polished skins we see today.
Thanks for the tip on the moonroof noise. I have a 00' V6 and the roof started making a lot of annoying noise a few months ago. I was going to try using Armorall on the rubber seal but I'll go to the dealer first.
Thanks for your input.
My Accord 98's headlight burned out. Will I be able to replace it myself. What do I need to do?
Thanks in Advance
Sri
At 45K, my Accord 98's breaks are making noise.
I hade to made a sudden brake few days back, it worked perfectly. Noise comes only when my speed
is a low.
Do I need to replace my brake pads. What is the $
I will have to spend. I know I'll have to change
brake fluid at 45K. Will this be enuf?
Thanks in Advance
SridharP
