Visitor Agreement.
The scratch is very thin but relatively deep. Thanks god it doesnot touch the metal so it won't cause any corrosion.
I have tried G24 but it did not help much.
Any body here have experience to deal with this kind of scratch ?
Thanks in advance for any info
Several of my cars with ABS have made this noise. Ford, Cadillac, etc.
Some people are getting carryed away saying this is a transmission problem.
The V6 transmission problem I've heard about only involved several months production of 2000 Year Model Accords.
All claims to the contrary, there is no product that is going to replace paint like paint...if the cut is deep enough to have gone below the color coat [even if it didn't get to the metal], then paint is the only solution that will make it look like new.
You should be able to buy it anytime before the original 36mo/36kmi manuafacture warranty expires. And if you get it before 24mo/24k there is no surcharge(which is @ 60.00). It makes sense that Autonation can't sell the Honda warranty, but that doesn't mean you can't get it.
Although I agree that repainting is the ultimate answer, you might try some touch up paint first. Your dealer can supply the correct color paint. Even though the scratch didn't reach the metal, you will have to clean it out. A few strokes with a women's nail file should do the trick. Then use a tooth pick dipped in the paint to apply the paint to the scratch. Use multiple coats. Don't try to fill the scratch hole on the first coat - just coat the inside of the scratch. Then build up the paint with multiple tiny coats until the new paint fills in the scratch to the level of the original paint. Not totally perfect but not noticable by most folks.
bolivar:
The clicking noise is the ABS applying your brakes in small increments so as not to allow your tires to loose traction and start a skid. And that brings up my problem. Although I never gone into a complete "panic" braking situation, I have (in near panic situations) applied a lot of braking pressure - short of a skid by what I consider microscopic amounts. But I didn't get that clicking effect. My dealer says the ABS system checks out correctly. Via their computer no doubt. But I'm still not sure that the ABS system is working. Any ideas?
My questions are:
1. Is this only for 2001 4 cylinder Accords in the Bay Area? (Owner's can you take a look and let us all know about your vehicle?)
2. Is this normal? (Doesn't seem like it!)
3. Is it cosmetic?
Several months ago, I came down to my car in the garage and was barely able to open the driver's side door. I saw what appeared to be an indentation from somebody hitting me---it hadn't been there when I parked there in the morning. The strange thing was that my car was parked in a location where it did not seem possible that someone could have hit me in that spot.
Just recently, a friend of mine smashed into a pole pulling his car out of a parking spot, causing damage to approximately the same location as my mystery indentation. When I saw his damage, however, something jumped out at me---his spot was banged and bruised with chipped paint, black streaks and the other markings typical of impact. It struck me then for the first time that my indentation was completely smooth--no marks whatsoever.
One final point: Over the last few months, I've noticed a number of Honda Accords (around the same model year as mine) with indentations in the same spot as mine. I assume this was a coincidence (maybe it's a common spot for collisions?), but now I'm not so sure....
Could another car have struck my car without leaving any marks other than a smooth indendation? Has anybody heard of a defect involving the door hinge, or something like that?
Thanks for any insights!
What I said was - Several cars I've owned with ABS made a small noise just after being started.
ALL THE TIME!!!!
You get in the car. You start it. You back up. You start moving forward. You hear a muted, clicking noise. THIS IS NORMAL. It is the ABS, and is NOT a transmission noise.
And yes, I know what the ABS sounds and feels like through the brake peddle when you actually activate the ABS with heavy braking. I was NOT talking about these noises and/or pulses....
Then, he takes me out on his own EX 4 cyl and we both hear the same thing again! He explained that the tire size and its contact with the road produces the sound and that it was normal. He also mentioned that theLX model was quieter because they have 70 series tires (not as wide) vs. the 60 series on the EX.
Has anyone else experienced this road noise and if so...is it normal? Is it caused by the "wide tire contact" with the road?
All answers appreciated. Many thanks!
I just purchased an '01 Accord V6 Ex. I've noticed a lot of discussion regarding automatic transmission problems. I hate to bring up the subject again but I've looked at all the msg's and can't find anything specific.
I've noticed while backing up, if I get up to approximately 10 mph then release the gas pedal, I hear a metal clanking sound and the car kind of shutters.
This is not normal right? Is this the start of the transmission problem discussed on this board?
Thanks for any help
If the noise you're experiencing doesn't happen *without* releasing the gas pedal, then I think it's a different situation. I can't really speculate as to whether or not it's a problem. To my knowledge, the "clunk" problem affected only a small production run of MY2000 V-6's, and shouldn't be found in any MY2001 Accords.
Although its 1/2 inch long, the paint has come off and I can see the metal.
How long does it take to rust? Can I fix it myself by just touching up over it or should I take it to a body shop?
I would appreciate any advice.
I have a V6 accord and generally get between 23 and 28 mpg; I average probably 26 mpg. I can't remember ever getting under 23. But I've never done much bumper-to-bumper or stoplight to stoplight city driving. Maybe the 10 miles of city driving is enough to bring your average down.
I do drive pretty evenly with very little stop and start.
What kind of a filter is this-does Honda now have a filter for outside air before it goes into the AC/Heating system. News to me-or is this a dealer scam.
I would personally like to have the outside air filtered before it comes into the vehicle.
Listen to Auburn63..He is a Honda TECHNICIAN !!
This is yesterday's news.
Now...will EVERY Honda transmission last 200,000 miles?? Of course not! There will always be some kind of failure rate for anything mechanical.
Just compare that failure rate to most other cars.
My question, are the really going to put 5W-20 in the car? Is it bad for the engine if they put
5w-30?
Also, the owners manual says you need a special tool to remove the oil filter. Is that true
Keep an eye out for all the other problems tht may surface...ie. hard starting, fuel gauge problems, cosmetic defects, etc. Hope you have a good service dept.
Purchased a 2001 exv-6 in Jan.
Following things have developed.
1. Tire went flat- Hole in aluminium wheel, dealer fixed , no problem
2. Wind noise/whistle from drivers outside mirror.
Dealer wasn't able to fix. I fixed it by
placing electrical tape over the front part of
mirror housing seam.
3. Squeak from drivers seat from the back lumbar
area.(very bothersome)
4. Vibration from the rear passenger area. I think
the door panel is a little loose.
5. Starting to get a intermentent creak from the
dashboard.
I think the accordv6 ex is a very fine car. Drives like a dream. But all these darn little problems are taking the joy out owning it.
I plan on getting these things fixed on my 6 month oil change. Anybody else have these types of troubles.
robr: When you say 2 AC filters, do you mean 2 filters for the A/C in addition to the primary air filter for the engine? Or do you mean a total of 2 filters?
2kaccardv6: Something ain't right! I've got the '98 EX V6 Coupe and I'm getting about 27mpg on my daily 30 miles in each direction commute. My mileage improved over time, but still, my commute include primarily highway driving but with a significant amount of stop and go traffic jams. It could be the air filter or any of a number of other causes: Timing, belts, too much A/C drag, bad spark plug, tranny linkage, etc. The dealership "should" have a method for tracing this problem.
about 40 to 60 miles drive on My Accord V6-ex.
Please inform me more detail what part of mirror housing did you put on electrical tape to solve Nose Problem?
IIRC, to replace them you must must cut out a crossbar under the dash to reach them. I've heard it's a pain.
On my '98 Accord, I had them changed at 35,000 miles. They were just FILTHY! Guess they must work pretty well!
The side mirrors can make a wind noise. Honda solved the problem in 98 by making the mirrors non breakaway. People complained and breakaway mirrors came back the next year.
The wind noise isn't THAT bad but I know some people are sensitive to every little noise.
So if you colapse it, the tape peals off some. It took care of the wind nosie. Funny thing is there isn't any wind noise/whistle from the passenger side mirror. My noise starts out about 25-30 m.p.h.
Hope that helps.
I recently bought a 96 Accord EX, automatic with 57K miles on it and in near perfect condition. After doing the 60K mile servicing, I went on a 1K trip, and soon after that I noticed that the engine was running not as quite and smooth as it was before the trip. Also, when accelerating from the 3rd to the 4th gear, I get a hollow or an echoiee sound rather than the crisp pickup feel I used to get. It doesnt seem to be anything major, but I do love my Accord and want to keep it in a great condition. Can anyone have an educated guess as to what might be wrong, so that I can go to a service center with some informed background on the problem. Thx.
I had a used Mazda 626 and I am finally selling it off and buying a new Accord Ex V6.
Are there are dealers in Northern Virginia who can sell me this car below invoice price of 22,375
And what are the other costs involved and how much are they ??? for eg, tax, tags, title, processing, destination ??? How can I save some money...Also is it good to get Extended warranty ??? How much out of the door price am I a looking at ??
I have an appointment with the FairFax Honda on Friday. Please advise.
Harry
