NEVER CLOSE A DEAL ON A NEW CAR WITHOUT DRIVING THE SPECIFIC CAR YOU INTEND TO BUY...NO EXCEPTIONS, EVER, PERIOD.
A good dealer will work hard to try to solve your problems, but getting a new car is extremely unlikely. And by the way, wheel shake is caused by out of round tires, or out of balance, or foreign matter stuck somewhere on one of the wheels [a clump of mud?]. Alignment will not make the car shake - it might wander or fail to track properly, but will not manifest itself as shaking. These cars are the smoothest around, and this sounds to me like one wheel has some significant problem; sorry I can't jump through the screen and diagnose it for you.
Thanks for any help you can give me
Greg
And the conditions you drive in don't help either.
But...NINE MONTHS ? Are they using beer cans?
I have the same year and engine you have. The trans drain plug faces the right, passenger, side. It has a square hole so you can fit a ratchet in it for removal. The plug, at least mine does, has some white paint on it so you should be able to identify it. Hope this helps. Also, are you experiencing a clunk on cold start ups? I've got about 750 miles on mine and has done it since day 1. As far as other things to do, don't change your oil, engine, until at least the recommended interval. Honda uses a special oil for "break in."
Auburn,
Have you come across a TSB for the trans "clunk" I described earlier? Thanks.
As BobGordon says it is on the passenger side of the car at the bottom center of the trans with a square head that takes a 3/8 ratchet to loosen it.
BobGordon,
There is a service bulletin out for the clunk on start up for cars with auto trans and cruise control. Seems that the engine mount doesnt have enough available vacuum at start up and causes a clunk that sounds about like what a rubber hammer would make striking the frame. The repair involves re-routing the engine mounts vacuum hose to the cruise control vacuum tank.
Thanks for the tips and keep posting news about your cars
Greg
It happens right when the car starts.
Auburn,
I'll look for that. I hate to take it back to the dealer for something simple.
I contacted the dealer I bought it from and they faxed me a copy of the service bulletin, by the way is number 00-059 and pertains to 1998-01 Accord L4 / auto trans. Its a simple fix that I will correct myself. I hate to spend my vacation at the dealer. It requires capping and re-routing of vacuum lines.
I have posted many times before and received personal email with hopes that I would have the answer to their problem. Well I'm sorry, but I'm in the same boat as all of you. Still getting the screwaround from Honda. The best Honda would do for me is offer an extended 5/75K warranty just on the tranny (but it is very vaguely written). However, your emails and posts have been very helpful and I have now gathered enough information to seek legal advice. I'd like to make this a class action lawsuit, but I need more people to step up. Remember if you need to contact, you can reach me at maddogv6@yahoo.com
Both our 98 and 01 Accords track arrow-straight and vibration-free. Any shop with up-to-date equipment can do a 4-whl alignment on these cars for less than $100. Anyone who tells you otherwise just isn't equipped to do it, which is OK, but not the same thing as saying it is impossible. Our local dealer certainly does it all the time, and anyone who works on the car repairing crash damage also knows it can be done.
I'm scheduled at the dealer Mon July 9.
Thank you very much.
Told them what was happening. They came back and said the motor for the cooling fan (not the one for the a/c but the other) was not working and needed to be replaced. Said go ahead as it seemed to make sense since the temp would get almost to the red zone and no fan would kick on. So when I get the car back the first thing he tells me is the temp gauge is messed up. Not the sensor but the gauge. "Your car isn't overheating even though the gauge is in the red". All he was doing was covering his butt. Sure enough the fan now goes on when the temp reaches the red zone, but my guess is the old fan would have as well but I never let it get that high. So after spending a couple of months of payments to replace a part that most likely didn't need replacing I still have the same problem of the temp getting to the red zone. Bringing it back to them today, I'm sure it is the temp sensor. So what would you suggest I do related to the unnecessary part? Contact the zone office?
Anybody ever run into this one-I plan to clean the contacts with a electrical cleaner, apply small amount of di-electric compound and hope this works.
ANy other suggestions.
Have a rattle also coming from the glove compartment/dash. Taken into the dealer 3 times and now they tell me I need a new bearing in the "final drive" section of my differential. Does this rattle continue always? Mine only occurs upon accleration and deceleration.
There is some minor "gouge" on the bottom that looks to me like a manufacturing defect, they said I hit something (no way). Anyway, the service manager said the Accord transmission problems were resolved with the '01 model, but would contact Honda technical support and the regional manager and get back to me 7/11/01.
PLEASE, can someone give me any information if they have dealt I/ this problem (& resolution). I have already been to NHSTA and printed out all the '98-'99 models consumer complaints. I think they are stalling because Massachusetts has a 15k mile, 3 tries, lemon law (I would love to dump this car). I guess my first resort would be litigation. Please help!, my mail is ad@mediaone.net
There's a lot of misunderstanding about the actual symptoms of the "infamous reverse clunk" (let's call it the IRC) with the V-6. My 2000 EX had it.
The specific symptoms were as follows: I'd put the car in reverse and begin to back up. After around 10 - 15 ft or so, I'd get a loud clunk out of the transmission. My transmission was replaced with a remanufactured transmission, and the problem has never returned.
The explanation that I've heard is that the IRC was limited to a few weeks of production of 2000 MY V6 Accords, sometime in fall of 1999. It was caused by a change to a part specification by a supplier who made the change without notifying Honda. Reportedly, the problem with the part was corrected and the IRC went away.
Some people have reported that they hear a clunk just as they move the shift lever to reverse. This *isn't* the IRC...
So, are the symptoms that you're experiencing as I described?
Sorry to hear of your problems, I would definitly complain to the service manager about the possible bad diag and if that doesnt get you anywhere then to the general manager. Maybe they will do something to help you out with what is wrong with your car. I have not yet seen(not to say that it couldnt go bad) a bad guage.Maybe you should even ask for a differant tech to work on you when you go back or if they won't help you out then maybe go elsewhere.If it is not the thermostat or head gasket then I would have to say thermoswitch for the fan circuit.Good luck..
bburton,
I am used to seeing P codes, if yours is equates to a P1457 then I would say you probably have a bad canister vent control valve. If it is a P1456 then check and make sure the gas cap is on and very tight..Good luck, let me know the P code if you could..
Advice?
It only happens when going over a slight rough road. Of course, it is too rough, I wouldn't be able to hear it because of the road noise. I have not test on the case you claim though
SmartMonkey
Your squeak from the lumbar support--is it intermittent? Does it sound like a chirp?
I'm thinking I might have the same thing.
I'm also getting a rattle in the back (right rear passenger side). I'm thinking it might be either the door or the panel that is up against the back windshield. During tinting, this might have been jarred loose?
Smartmonkey
I also hear a "snap" when shifting from drive to reverese (the car is completely stopped). Is this ok?
Talon95, did the engine smoothness decrease after your transmission was replaced? I'm just worried about the long term durability of a re-manufactured transmission.
Also, I mis-typed my email address, it is "axd@mediaone.net. Thanks for any help.
