Chris
1998 Accord LX
Manual Trans
newbie posting from a guy on his 6th honda!
i bought a new 5-speed ex coupe with leather and paid 21400 + tax and tags in metro dc area
it was a UBS buying price (included a rear spoiler, mats, door trim, and mud flaps)
anyway, it is the first honda that has so many pesky problems:
1) defect in left wheel well edge where factory welds are made
2) passenger front seat - leather is rough and clumped together
3) wind whistling noise (others have posted this problem that only occurs on windy days with brisk cross winds)
4) 5-speed transmission- the shifting/shifter is clunky and makes knotchy/clunky sounds when shifting and pops out of 2nd gear on the way to 3rd (honda is still using the same shifting stalk from the previous style accord, circa 1997)
5) a/c- a) the front right center vent is significantly weaker than the left center vent b) the temperature is mid to high 40's warmer than the 38 on previous hondas so the air does not feel that cold nor does it do a good job cooling a car with lots of glass and a dark grey interior
have any of you had any of these problems?
or did i really just get a "bad one"?
i have had poor response from my dealer who claims these are normal conditions
i am presently in negotiation with BBB for a settlement but that is not going well
will keep you all posted
take care
There was no negative effect on smoothness with the remanufactured transmission. The way it was explained to me by someone on Edmunds is that the remanufactured transmission has all new mechanical parts... it just "recycles" the case or housing or whatever they call it, which is a major expense to replace. So, in other words, for all practical purposes it's a brand new transmission.
If the 21 is somewhere in the EPA range, it may be normal.
We now have 22,000 miles on our car, and the only complaint is the moon roof rattling when it is closed and the shade is open.
Second, our EX V6 with 4500 miles gets about 21-22mpg in mixed suburban driving, with trip lengths of 5-19 miles. The occasional longer drive at freeway speeds [say 100-200 miles] yields 26-28 mpg. These figures are almost exacty 2 mpg lower than our '98 LX 4 Automatic that this car replaced. Given the extra power and refinement, I am very happy with the tradeoff. [These figures for both cars are smack in the target area of the EPA numbers, as well.]
To the person having gas mileage problems: How old is the car? How many miles? What about driving range/weather conditions? You may want to check (or have someone check) several things including the oxygen sensor, thermostat and other electronics which go into the ECM which control fuel control. You might just be running to rich. Do you ever notice a gas smell when you start up? Does any smoke come out of the exhaust?
I also had the moonroof rattle when the shade was open, I had that fixed last month when I got the 7500 mile service, it's completely gone now.
Could it need a tuneup? A belt or 2 replaced? Any ideas or input would be appreciated. Thanks!
SOMETIMES, if I drive it for a short distance, say 5 minutes, and stop go in a store for 3 to 5 minutes and come back to the car, it cranks right up, but runs ruff and dies immediately. Then I have a terrible time getting it to crank again.
One time when I was leaving the office for lunch, while the engine was cold, it did this to me.
Anyone got an idea what may be the cause of this?
It sounds as if you need to reset the multiplex unit. What you need to do is set the intermitant wipers on the lowest setting, then pull the accessory fuse in the under hood fusebox(if that doesn't do it then disconnect battery)and wait for 15 sec. Then reinstall and if that was it all will be fine...If the circuit looses power and the wiper delay is in the wrong position it sometimes confuses the multiplex unit.Good luck
Bobgordon
Most of the problems were in the 6 cylynders and back in the late99 early 00..Most of the other complaints we get are normal characteristics..
Silly me, I thought that facts would win out over the slick talking dudes that Honda sent down. Just me in arbitration against the best in the company. Sure wish I had taken a Lawyer with me after the "sweet luvin" I got.
To ease your mind, the vibration has never gotten any worse and has never caused any problem other than being an irritant. Also, I have had no other problems with the car other than slightly low mileage (20-24 range). I sure hope you find an answer because I would love to get mine fixed. I plan on passing it on to my nephew next year when he turns 17.
If it will make you feel better next time you go on a trip fill up right before you leave, drive a few hundred miles, then fill up again to see how much you have used (never judge fuel used with the gauge). If you keep at a steady 65 I am confident you will get over 30 mpg. If you take a slower trip on back roads and go about 55 you will probably get closer to 35 mpg. Of course 75 and above mph will keep you in the mid to upper 20's.
BTW no mid size SUV will get 21 in any kind of stop and go driving. Maybe a CRV or RAV-4.
started up to replace the squeak. What happened with honda quality fit and finish?
some transmission issues. The clunk occurs, but is not too pronounced and only happens occasionally. The big problem is during cruise when on a level road or going downhill and I let off the gas pedal. If I hit the gas again lightly to accelerate, the transmission downshifts, then upshifts, then down again a few times. This also happens with the cruise control on. The jerky transmission is noticeable and annoying. I am bringing it in for the first oil change this week and will have them look at it. Anyone else had this problem?
Also I have noticed the lack of ice cold a/c. It seems to be mainly when it is over 85 degrees outside. My 1993 Civic had better cooling at 145k miles on the car. Overall I am happy with my Accord, but it has some problems.
Second, had coolant changed and tech's usual routine did not include draining engine block. When I asked about this he referred to Honda manual and said it was recommended. The bolt he thought was drain plug was at front of engine under exhaust heat shield(19mm brass colored flange bolt). He said he couldn't get it broken loose and I told him to forget about it. When I checked it later it looks like he may have turned it just a little. Do you have any idea what this bolt is. Nothing seems to be leaking from it. I tried to turn it myself and it won't budge. Could it be some type of connecting bolt and should I worry about it. Where is the drain plug for the v-6?
As always, thanks.
How do you flush the engine. Just add plain water and run the engine for a little while and then drain it?
Oh, also I did set the temperature control knob to the heat position before he began.
By the way, thanks to all of you that help us non mechanic types with your valuable info.
The dealer found that I had a "bad bearing" in the final drive of my transmission or differential. The car is still at the dealership, waiting for the part from Honda, so I don't know if the rattle problem is fixed or not. Good luck!
I bought my Honda Accord V6 I/leather fully loaded car two months ago, and put 4000 miles on it already. Love the car, but I have questions regarding some weird things going on:
--when I am on an incline at a parking garage or outside in a parking lot my car will starting rolling backwards when I take my foot off the brake pedal (this happens most of the time)---the parking attendant thought I had a stick---I told him it was an automatic
---my boy friend also felt a weird vibration while driving it this weekend
--I did hear a flunk when I shifted from park to Drive while on an incline once too
Heck...whats going on? This is my very first car. I do have the Honda Care on the car too. My friend told me my oil changes are included is that true? The dealers web site did list this under the program....
I would really appreciate everyone input because you guys are very insightful.
Thanks for your help,
Angela
I was just curious as to anyone out there with a high mileage Accord with the V6. How well has it endured? Just wondering if the V6 is just as durable as the famous Honda I-4 with proper maintenance of course. The reason I ask is because I think I finally found a car I really like after about a half dozen previous vehicles. Thanks.
There will always be some small noise [a click, or muted clunk] when engaging either drive or reverse from park...this is also normal. If you are doing this on a hill, the noise and jump can be a bit louder, depending on how you shifted into park in the first place. If you set the parking brake first, there can be less pressure on the pawl that moves in the transmission to lock the drive axles; if you put it in park, release the foot brake, and then set the parking brake, it is likely the pawl is going to be under a lot of stress when you try to shift back out of park. This is hard to explain via this medium...suffice to say I haven't read anything in your messsage to be concerned about, unless you can define what you mean by "wierd vibration".
Any advise is greatly appreciated.
I have 90 Accord LX 5spd with 173K miles with original engine and still going strong, no oil leaks (lately) etc.
The problem that's killing me is that the spedometer keeps dying out. Sometimes it does not work at all or if its working, suddenly the needle would fall and rise regardless of actual car speed. Plus the check engine light would come on also. The light is not on when I start the car, it always happen after couple of minutes of driving and when the needle starts dying out.
I read a while back someone was suggesting that it is the speed generator in the spedometer or it could be the speed sensor on the trasmission.
Should I take it to dealer and let them find out what the code is for or repalce the speed generator/sensor (either) and hope the the check engine light would go off after replacing either part. Any suggetion would be apreciated,
