It indeed sounds like a lock-up problem of mine. The "miss"/hesitation/shudder should be most noticeable going up a hill at rpms below 2000.
Also, I had slow lock-up release and slow downshift problems. After tranny replacement, these problems were also gone. In fact, I was very surprised how different the same car responded to gas. Do you also have these problems?
Thanks for your reply?
As far as brakes, I prefer to stick with Honda parts. Used Bendix pads once on my 91 and they caused the rotors to warp. I then had to replace the pads again and have the rotors turned. Since then, I have always used Honda pads.
If you recall I have a 2000 Accord SE and the check engine light came on. The code was P1486. Dealer reset code and about a month later Check engine light came back on.
This forum was kind enough to explain that the code meant range/performance problem.
Just brought the car in on Monday to Dealer. Dealer called and stated it was the same code P1486.
Dealer asked me if I had left the hood open for an extended period with engine running.
The answer is no. I did open the hood with the engine running to fill the washer fluid. I would not think this would be a problem. Did not do this first time around.
In any event the dealer has stated that the thermostat is fine but the computer appears to be reading it as faulty. The dealer is ordering a new Computer and due to the delay has offered to pick up the tab for a rental car (I do not have an extended warranty or coverage for this as I do for my HO). I declined as it is more difficult to pick-up and return the rental car but appreciated the offer.
Is there something specific I should ask regarding the replacement part?
It appears the dealer is being helpful and I have received good service to date.
Thanks in advance for your help.
I saw an earlier post knocking the Accord. I would still recommend buying one as I did exstensive research and they are far superior to most of the cars out there. Quite frankly the handling on this car is simply wonderful.
We have adjusted some door strikers to fix similar noises and we have also had to clean some dash areas due to armorall or similar products.I would try to clean the area first then check the door adjustment.It may be too tight.The back edge of the door when closed should be about a dimes thickness outward from the front edge of the rear door/rear quarter panel.If that is correct and cleaning doesnt help then we will have to try something else.
Snowman,
I wouldnt think they are any differant due to it is the same manufacturer however I dont work with Acura so I dont really know.The after market brakes will still stop the car and have a good pedal but usally they make more noise and or dont last as long because they are softer.I use, even in my 86 Monte Carlo, OEM parts because they keep the car original and if I have problems I dont have any doubt that it is a faulty aftermarket part.Example: OEM tune up but car still runs rough...well I know it is not the tune up parts.If they were aftermarket I could not say that because I have seen many cause problems.
Xfactor,
Keep us informed on the repair I am interested if it is the thermostat or the computer(ECU).Good luck with the repair.
found some white strings are coming out from
bottom of the both passenge doors. If you
pull them, they will keep coming out. This made
me upset. Anyone expereinced the same problem?
What are these white strings?
Dealer installed a new Computer (ECU) and a new Thermostat.
We may never know which caused the original problem.
Thanks for your help and I will keep you updated.
Hopefully I will not have to post here again.
Regarding reliability, yes every car model has a lemon. Yes the Accord owners posting problems here. I am one of the many Honda owners who has a good Accord. It has been very good to me (only 25,000 though) so far. But if something does go wrong, it will not push me to buy a Galant, 626, Jetta, Taurus, or even a Volvo. I think the odds of not getting a lemon is still better with Hondas and Toyota.
My dealer is very good (Yeah, there are couple rotten apples salesman who bring down the dealer a bit). I think a good dealer is a big factor in purchasing. Look at Saturn. They are not the super high tech best performing vehicles but they are successful. Toyota dealer in my neighborhood is terrible. So if something does go wrong, I still will get a Honda. But most likely a different model.
(P.S. When I hook up the voltmeter to the black and white wire, do I put the other probe to ground or somewhere particular?)
I have seen this problem on many cars. Most often, it will be a loose connection on the starter solenoid, or a bad solenoid. A solenoid is a relay that takes the signal from the ignition switch to close a contact from the battery to the starter. I'm not sure where the solenoid is located on an accord. If it is external to the starter, then it is easy enough to replace.
If that doesn't fix it, or if the solenoid is inside the starter, then a rebuild of the starter is in order. Dealer will charge about $300 to do the work. A shop that only rebuilds starters and alternators will charge about $100 to do the work. Check yellow pages.
That tire warranty or lack of warranty has always been a problem.For as long as I can remember we have sent people with tire problems to the tire dealers as they are the ones that carry the warranty.Why the customer has to take up the fight I dont know and I disagree with it, however they may feel that the owner has a better chance pleading their case.Or maybe they are affraid of dealers trading out tires from out of warranty cars. I think I get it now......lol...now it all makes sense, thats why they have the customer do it I bet..Anyhow I will stop talking to myself now and wish you luck with the tire company...
Bought a brand new Protege last month and the initial quality seems to be much better. No complaints about cosmetics or performance thus far. I know cars can have "bugs", and as of almost 1 year I am still exterminating them in my Honda. Still a great car though.
You compare Accord's refinement with Protege's???????? Then I quess you are a Protege person.
I have driven Toyotas, Subarus, Mazdas but Accord has the best refinement among others. Well this is my idea and I also think, it seems to be your dealer is not capable to address your concerns.
But please, comparing Accord with Protege is not an objective comparison and is also insult to Accord but will make protege owners spoiled.
I hope you don't expect someone else to do your homework for you....{%^), all you have to do is read 186 posts.
Your host, Bruce
I understand that there wont be the SE for 01. Shd i wait and buy a 01 LX/EX or grab this. Any pointers appreciated,
If you use the Topic Search feature on the left side of the page once for Accord and then again for Camry you'll find lots of topics in a more suitable conference than this one.
Good luck!
Pat
1) remove the glovebox
2) remove the bolt, the screws and the glove box frame
3) remove the filter lid from the evaporator, then pull out the lower A/C filter assembly and the upper A/C filter assembly in that order
4)remove the A/C filter from the filter housing. Replace the A/C filter.
5) install in the reverse order of removal. Make sure there are no air leaks.
If it were me I'd either buy a service manual OR let Honda do most maintenance work.
4DR LX died on I-95 20 miles s of Richmond, VA last
week. I'd blown a hose about 8 weeks ago which
apparently corrupted the head gasket, resulting in
major failure. Upshot: I need a new engine. The
body is in pretty fine shape, interior is
excellent. My independent mechanic recommended
against a Jasper re-built (for around $3,000) and
has instead, ordered a used motor from Japanese
Honda which he says has been pulling them from late
model Accords following a change in emission laws
there. They're guaranteed to be under 50K miles
and are warranted for 12 mos. Cost is only about
$1500.
Anyone have *ANY* experience with this? My
mechanic says after two years of installing them he
has yet to have any problems.
Honda zone office said the dealer has to observe problem. How much is the record for rental car fee's before they fix a car? Should I ask the Kool Green Honda CART team if they can fix it?
Disregard last two questions.
Any suggestions? Thanks.
when I begin driving the car I can't press the
brake in and the car will not stop. Then if I try
pressing it again, I can press it in. It doesn't
always happen and when it does it only happens
first thing in the morning or when I haven't driven for a while. I have taken the vehicle to the dealership and they can't figure out what the
problem is. The mechanic said that we should pump
the brake before driving. I feel like this is not
acceptable for a car that is one month old. I am
wondering if anyone else has experienced this
problem.
Also check out the reputation of the yard-some of these places are as crooked as a barrel of snakes-there are some good ones though. good luck
And the problem described was reproduced in any gear. So it seems to quit but pressing down to downshift will get it going. If you do not change the throttle setting it will just slow down to almost a creep. It's also an automatic.
Anyone? The car runs great most of the time. Just this one problem. The dealer is clueless.
