Sounds to me as if you Power brake assist booster is not working properly, as if it has a vacuum leak or bad check valve.Definitly keep going back until they fix it for you, if necessary let them keep the car overnight and explain to them or show up in the A.M. and show them how to make it happen.
Yoda209,
I don't really understand your problem. If possible could you try to explain it again or if there is another post (other than the 2 previous)
let me know where.What did you mean by. "If you do not change
the throttle setting it will just slow down to
almost a creep."Start at the begining I guess descibing your problem, if you dont mind. You can leave out what the dealer has done since it didnt fix anything yet or if it did fix it for a while then maybe you should have them do it again..
O.K. a 1998 Accord V6 LX automatic.
The car mostly runs fine. But now and then (frequency of occurance goes up and down) You start driving and as you leave a stop sign the rpms reach maybe 2000 or so the car starts slowing. If you punch it it will take off (after downshifting). If you just hold the throttle where it was when slowing started the RPMs will drop to idle before the car starts to accelerate again. The forward motion doesn't stop completely,
but maybe to 5 MPH. It also will occur sometimes while cruising. Then we just press down or downshift to get it going. Have taken it in numerous times and they find nothing and of course it won't do it for them. And apparently they find no fault code. They say everything is in spec. and they find no problem. They drove it 99 miles the other day and it didn't do it. Did it to me 4 times on way home.
I will look in the service bulletin areas and on the Hondanet but I dont remember seeing your complaints. There is or was a problem with the winter fuel and some Hondas in certain areas.I dont think any areas are still using it durring the summer and I think it is too early for its return so I wouldnt think it was that.The only thing I can think of is a faulty throttle position switch(tps) and you are catching it in the right spot and they are not.The tps goes from 9% closed to 100% fully open and everything else inbetween. Possibly you are hitting a spot at partial throtle that is reading closed instead of lets say 45%.I would suggest asking to take an extended road test with a tech or the service rep.Durring this road test have the PGMFI machine hooked up and monitoring the tps and other key sensor readings.Try to take this road test at the most comon time for it to act up.
Suckyhonda and possibly even yoda,
If the hesitation you feel is a one time a day thing and within the first few miles of driving as the engine is warming up then that is a normal characteristic that you can do nothing about.However if it happens several times a day at differant times then I would suggest you do the same as the first part of this post.Unfortunatly on this problem tech line needs to know what certain sensors are doing when this happens.If it is a case of winter fuel causing the problem then there is a fix for this..
Bruce
I would start bringing in at the next oil change 4.5qts of a quality brand oil @ 5w-30 and see if that helps...They probably use bulk oil and may not be of the best quality.Also ask to speak to the Honda rep and let him/her know you expected more out of your car than this and see what he/she says.Good luck
As far as replacing the aluminum crush washer on the oil drain plug-bought 5 replacement aluminum crush washers 20 years ago-still got them and have changed oil on a variety of Honda's for over 400K and only a slight leak and never had to add oil to any of them. Current 97 accord has 105K and does not leak or burn any oil-original crush washer.
Hope this helps.
Honda reccomends replacing the 20 cent crush washer every time...right? You have five washers that you have been saving for 20 years, yet you won't use them?
What am I missing here?
Isellhondas,
I guess people just like to do things there way.Keep crushing and crushing till they cant get it off.AAAAhhhhhh maybe that it is how it all starts.
Was that something someone had recommended doing to an engine that has been sitting for an extended period?
By the way-I wonder what % of drain plugs get cross threaded by the quick oil change guys. Really admire all those brave people going to those places. Enjoy going in and seeing what specials they are offering. Latest was cleaning out all that gunky gasoline.
Sorry, Butch, in my opinion, it's false economy to take a chance stripping out a 200.00 oil pan by skipping a lousy 20 cent washer!
Especially when you have a supply of them!
And...cross threading the oil plug is different than stripping it by overtightening it to stop a drip.
And you call that "saving" money?
I still don't understand.
I have learned from my mistakes, but guess some others won't.
It was just something I thought of out of the whim and to Auburn (the expert in the room) it may be the stupidest thing in the world but that made sense to me.
Please let me know what should be the fair price for the HOnda's single cd player installed by Dealer ??
such a great resource. I have learnt a lot just
by browsing/reading.
1. Ok, here's my problem. Whenever I take slow
left turns (< 15mph) in my 88 Accord DX 2dr,
I get a very strange clunking sound from
passenger side wheel. Took the car to
Honda service center. They checked out CV
Boot & Joint. Both OK. Checked out out axle
that is also ok. They don't know what is causing
noise, but say car is in otherwise good shape.
Any ideas what could be causing the noise?
2. Recently spent $900 to fix A/C.
My Accord has 147k miles on it. I really do
love the car, but it's getting old. I am
debating either trade in this car for a new Accord EX 4dr or keep it. Car has sentimental value, but after years of being exposed to Arizona sun, clear coat is coming off, and the car does have lots of scratches and dings. The interior is quite good.
I'm not sure if I should keep the car or purchase
a new Accord. If I decide to purchase new Accord
is there any reason I should wait for 2001 model?
I keep going back and forth on this decision, and I have to admit it's more emotionally based than
practical, so I would appreciate hearing your
thoughts and comments? What do you think the best course of action would be?
a. Keep current car?
b. Get new Accord?
your quick response. I will ask Honda Tech about ball joint the next time I go into service. I
can afford new Accord, but have to decide once
and for all to part ways with old car.
One question though. Is there any reason I
should wait for a 2001 model vs a 2000? other
than traction control and cosmetic changes
I am not aware of any differences. Any info
or insight you may have on the 2001 Accord
would be greatly appreciated. Thanks again
for taking the time to respond to my question.
You should check the front wheel bearing-it can make strange noises when you turn. Raise the front wheels off the ground and do the 12/6 and 9/3 o'clock tug and if you get excessive wiggle, your wheel bearing maybe fried. A wheel bearing failure can ruin your whole day/life.
Your problem sounds like a CV joint-all it takes is a few miles with a split boot-and they are gone. Let us know what you find.
I will try your suggestion and let you know
what I find. Since my car is already scheduled
for an oil change later next week I will have
the Honda Techs take a look at the bearings as
well and see what they say. So far this noise
has the Honda Techs stumped! I will let you
know what they & I find out. Thanks again for
you suggestions...
have reservations about replacing the factory
stereo though since I think Honda put audio
controls onto the steering wheel for 2001.
Is that right? If that is so, then replacing
the stereo could mean sacrificing the use of
the audio controls on the wheel? I had a chance
to look at pictures of 2001, and I have to agree
with the sentiment, that the car looks more like
a Camry. What a shame!
Now with that said I think I should have said this first.Does the light come on and go off after start up.Then come back on after 30 seconds or so? Or does it come on and stay on? If it comes on and goes off then back on again it is a presurization problem most likely.The bleed may fix this.If it comes on and stays on then you may have a bad sensor or wiring and yes they could have broken a sensor or damaged this durring a brake job if they were not carefull exspecialy if they removed the rotors from the car to cut them.Good luck
so I'm off to take a look at them today. The
model/config I'm really interested in is the
EX 5spd Manual, but they seem pretty rare.
Wish me luck!
I have heard that the Maxima has a great stereo,
but I don't like the way the car looks compared
to the Accord. Don't you think the back end is
strange? The only good thing is that you can
get a manual with a 6cyl engine. Too bad Honda
doesn't offer one as well. The thought of having
a 200hp Vtech engine mated with a manual makes my mouth water. Maybe someday Honda will make that dream come true? Thanks for the insight though.
I will have to check now but I may not be describing it well for you because I am almost sure there is something in there where the fluid returns to the resavoir.I think if you remove the screen you should see a cut out to allow this piece to come up into the screen area.I could be wrong though so i will check.In the meantime you can open that bleader and that will also bleed it. If I remember though it doesnt do as good of a job.After you are done if the light stays out you should go out and find some sand or wet road and give it a funtion test.The solenoids need to be excersised every now and then or they tend to stick..Good luck and sorry if I was wrong but I will check.
Hondaman,
If you go to your Honda dealer and get a tube of Shin Etsu greese and lube the sunroof seal all around the noise will go away.If you sit in your car and push up on the rear side of the sunroof you will probably hear the same noise it makes on the road and this can be cured by using the lube..
