If anyone else has experienced this, please respond!!!
One other question. Is it REALLY necessary that all parts replaced on a Honda be HONDA parts rather than aftermarket (as they call it)?
I plan to put about 50,000 miles on this car this year, with a 76-mile daily commute. Would it be a wise or foolish thing to get an extended warranty when we pick the car up in two days?
thank!!
Honda Oil Filter $5.00 (with crush washer)
Honda ATF $3.68 per quart
Honda Antifreeze $16.00 per gallon (gulp)
Annualizing these costs vs what I would normally pay for generic brands of fluids and filters, I am spending the whole amount of $13.75 more per year!!! A small drop in the bucket when compared to the total annual cost of operating a vehicle.
The cost of Honda antifreeze seems kinda high vs Prestone, but I think it is worth it. After all I will only change it every 45k miles. And when I drained the old out it was still VERY clean. It must protect from corrosion better than generic brands.
BTW, my local dealer puts Texaco antifreeze in their customer's cars. They had stacks of it in the back of the parts department.
This is an individual decision that you need to make. If you need the peace of mind, then go ahead and purchase it.
rt4,
Didnt come accross one today hopefully tomorrow but looking at the book it looks as though it should be as said.You will have to keep the motor jumped for several min before it will bleed.You will hear a pitch change in the motor as it starts to build presure.The peice that I am talking about is in the modulator resovoir not the main brake system one just in case I wasnt clear on that one..I will get back to you but in the mean time you can try opening that bleeder you saw just be careful it is high presure.
One other thing for MYRIDE2,
I have always said to people I talk to about aftermarket parts. If you want to save money use aftermarket mechanics not parts..:) I'll shut up now...
- Anthony
Finance, Warranty and Insurance Conference
Pat
We got a 100,000 mile/7-year warranty last year on a new Civic DX for $700, but this may be comparing apples and oranges.
Also, my front rotors are warped again. I been having this rotor problem ever since I bought the car. After the car was out of warranty, I installed Powerstop cross-drilled rotors thinking the OEM rotors were defective. Well it turns out the Powerstop rotors are warped and can't be turned. Has anyone been able to turn cross-drilled rotors? It looks like I have to go back to the OEM rotors, I will miss the stopping power of the Powerstops.
I've been told that the rotors warp due to over torque lug nuts. Each time I have my wheels rotated I tell the mechanics to torque the lug nuts to 80 lbs which is specified in the manual.
I've got an 89 Accord LXi with 114,000 miles on it. The reliability has been outstanding but there is one problem. Sometimes the car will take about a minute or more and several cranks to start. However, this only happens occasionally, if the engine is warm or if the car has been parked out in the sun for awhile. I've read that replacing the "TW Sensor" can solve the problem. Has anyone ever experienced this with their Accord, and if so, did replacing the TW Sensor solve the problem?
Thanks!!
Sometimes the rotors have to be turned on the car to eliminate these problems completely. Most Honda shops and Midas can do this.
I don't know what else to do if it still quits unless I have every possible problem part replaced. Something on it is getting hot b/c it starts after 30 minutes or so. Someone did mention the coil as a possible problem. I've had two tuneups with all wires and plugs replaced within the past 12 months. The second go around was after this little problem started occurring. However, they are aftermarket parts.
Another problem that may be related is that the car seems to want to hesitate at times almost like it is "missing." Any ideas?
My Accord doesn't stall or want to stall at any speed. Also, the hard starting is not necessarily worse after short trips; it could happen after any trip. I'll take your advice and get the main fuel relay checked out.
I bought an Accord LX 2000 1 month ago and
now it has 1500m on it. Yesterday I noticed
that when I shift the transmission to "R"
position (the car does not move since I
step on the brake), there will be an short
crispy noisy explosive sound, just like the
sound an electrical fan will have when its blades
hit something plastic. I am not sure if it
just began to happen or I did not notice it
until yesterday. It it normal? Does anyone
else have the same problem?
Thanks for the info. I contacted the company that makes Powerstop rotors and they said the rotors can be turned (cut) with a slow sharp lathe.
The one the car lathe rotor repair job is what I'm looking for. Hopefully low cost due to not removing the rotors from the car. Also, does the pads need to be replaced after the rotors are cut?
I found a used strut (50k miles) for $40 on the net. What is the average life of a Honda strut? This is much cheaper than quoted $300 for a new one.
Silvercoupe:
Honda brake pads were used when the car was repaired by the Honda dealer. After the warranty, I replaced the rotors with Powerstop rotors and the recommended Maxxis pads. Brakes worked great for about 2 years until I had the tires rotated about 3 months ago. The mechanic must of over torque or unevenly tighten the lug nuts.
To All:
Here are a couple of other problems I've have had with my 94 Accord. Some of these problems I have seen posted as a TSB and topic in this forum
I had a problem with the electronic door locks. After you would lock all doors from the driver's doors, the doors would repeat the locking process. I fixed this by replacing the driver's side door lock actuvator.
Fuel guage not registering properly. I replaced the fuel sensor in the fuel tank.
Blown balance shaft seal at 70k. Had a mechanic fix this problem which cost about $500. Honda should of issued a recall for this problem. I was shocked to have such a major engine problem with a Honda car.
Had a national tire chain to change my tires a few months ago-I really ranted and raved-do not overtorque my lug nuts-did not have a torque wrench with me-had a damaged tire and had to get it replaced asap. Well the jerks overtightened the lug nuts. Luckily it did not warp my rotors. In some cases I have been able to reduce the amount of warping by simply retorquing the lug nuts. By the way I have never used anything but aftermarket brake pads and have never had a warped rotor caused by brake pads.
Beware of people with impact wrenches-they can harm your honda.
If you come to a fast stop, especially when the brakes are cold, the rotors can reach very high temperatures, and that can lead to trouble.
Would it be a good idea to replace both rear struts? I'm thinking that the left strut could fail in the near future. Also, since the right strut would be stiffer than the left (since it has less miles) it could somehow effect the handling of the care.
With regard to the tranny, sounds like it is going into the tranny lock out or overdrive. 30-40 sounds like a low speed to do this however. Mine does the same at about 55. Also just a suggestion-change the tranny ATF at 30K intervals using only honda ATF. Got a tranny trouble code at 70K on my accord-fluid was dark. I drive at 70-85mph 95% of time and assumed this would not heat up the tranny fluid-was wrong. Now change the fluid at 30K intervals-easier than changing engine oil. Just do it when the engine/tranny fluid is hot-takes about 30 miles at speed and watch out for the tranny fluid-it can get to over 300 F-will burn hell out of you.
Well without replacing everything I would start out with a Honda cap,rotor and plug wires.That will be the cheapest parts to throw at it and see what it does then.I have had nothing but nightmares trying to avoid replacing aftermarket wires and dist rotors that were bad that customers had insisted they werent.So that would be a good start.
Snowman,
You can buy a torque wrench, other than that you can ask them to torque the lugs if they normaly don't.
Freshowner,
There is a normal amount of engagement noise that sounds kind of like you described.If it is extremly loud then it may be going bad and would need to be heard by a tech.
Itastet1,
The brake pads if they are good do not need to be replaced just sand them down a little to give them a fresh bite.As far as the struts go, I dont think I would replace the good one with another used good one even if it has less miles on it.You should be fine ride wise and handling wise.
Thanks for your advice.
After an expensive repair, I contacted Honda customer service and told them about the problem. They told me there was no recall issued
for the balance shaft seal. Anyway they logged my complaint. I also contacted NTSB and reported the problem.
RIZZO5 - My daughter has a '93 Accord. The timing belt is scheduled to be changed at 90,000. That's when she changed hers. The manual confirms this.
