Visitor Agreement.
(This should be fun) Now that we know that my '98 Accord Coupe EX V6 is not well "Insulted", how can I "Insultalate" (OK, insulate) the car. Where should I place more "Insulting" material. And don't tell me to bend over! Really, there must be a few spots were we can put some foam or sponge like material. And don't tell me "in your ear" either.
And no, I'm not bi-polar, just in case anyone was curious!
I have own a 94 Accord LX, and currently Own a 98 Accord LX-4 and a 01 Accord Coupe V6.
At about 65,000 miles, I noticed the brakes of my 98 start to have some problem. When braking (light) at relatively higher speed ( 65 to 80 MPH), I can feel strong pulse from the brakes though it diminishes below 60MPH. The vibration or pulses are difficult to detect at normal street driving speed.
And the exact problem has happened to my 94 Accord LX, and it was never fixed.
I went to different Brake shops and Pepboy, and they all failed to find out the exact reason, and some of them say they can not drive it on the highway so they don't see any problem with the brake. But they did refinish the surface or the rotor or even change a new rotor but that didn't help the situation.
One guy from Midas did mention once to me about a part which pushes the brakes together might have getting jammed with dusts, and he recommend changing it. But I don't recall the name of the part.
I am hesitate to bring it to the dealership or any other shops, because from past many times experiences, I don't think they can find out the problem. Hopefully some owner out there have the same problem before and can help me with it.
kirstie_h
Roving Host
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
As isellhonda said above, all leather wears just like cloth does. But the Honda leather is of the cheap-o kind compared to Toyota. But it's still not as cheap as GM Or Ford leather.
My 99 EX coupe at 45,000 miles hasn't been affected.
Anywayz, I still have to condition and renew.
Auburn or Isell, do either of you know (ballpark) how much a new oil pan gasket goes for at a Honda shop...is it a straightforward affair, or it it one of those "three hours of labor to get at the $20 gasket" things?
Makes up for some of the crappy jobs.
Auburn, correct me if I'm wrong.
The second question: is there an easy way to check the ratio of coolant and water in the radiator before I top it off ?
Does anyone have any good stories of high mileage Accords? Horror stories of them blowing up at 206,000 miles?
I've seen many Hondas hit high 200,000 miles numbers and beyond. I once took in a Civic with 357,000 miles.
Still, 200,000 plus miles are a LOT for any car.
I have to assume that you would be paying a very low price for this car? If so, and you have the car checked out by someone who really knows Hondas, you could have a long lasting bargain.
Bear in mind, you will need to drive it until it dies because you will find few takers with those miles.
If it's a well maintained car with service records etc and the price is RIGHT, I wouldn't be afraid of it if it checked out.
Ideas anyone?
keady
It lasted a couple of years and now I'm getting the same problem again. I am planning to pull out the radio and see if I can clean the antenna and power connection on my own. If this doesn't work, I'll bring this up at my next dealer maintenance visit. Tell us the exact symptoms...does it affect all stations, does it stop when the engine stops, does the noise get louder or faster with engine revs...
The radio gets worse every day. The signals are weak on all stations but I can still get a couple just fine. Not much better with engine off. I can get the stations fine with a cheap portable radio and the Accord radio worked perfectly until a few weeks ago.
Does anyone know how I can fix it?
99 EX V6, 45k miles,extended warranty
Did you see any degradation in the FM reception? Did the problem come on suddenly or gradually reach this point?
If your extended warranty is with another provider, give them a call and see what's covered.
Just had another thought...is your antenna a metal mast type or is it on the rear window (like mine)? I would check to see if any of the antenna wires on the window are broken - you could probably repair that with the same kit they use for repairing the rear defroster grids.
I have a 1998 Honda Accord with 60,000 miles. Up until last week, I have had no problems with it. However last week 2 things happened and I am wondering if it has happened to anyone else. First, I was travelling along on a highway on a very hot day, and all of a sudden I got no response when I pushed down on the accelerator pedal. I pulled over, turned the car off and was able to turn it back on after a couple of tries. I continued along for 1 more minute and it happened again, and then I couldn't restart it. We took it to our mechanic at a private garage (not a Honda dealer). He was able to reproduce the problem, but unable to solve it. Now that it isn't so hot, it seems to be running OK, but now the malfunction indicator lamp (CHECK) warning light has come on. Has anyone had this problem? HELP!!!
Regarding your burst hose...
Could have been a defective hose.
Could be an improperly installed radiator cap.
Could be a defective cooling fan sensor, that's not turning on at the proper temperature.
Could be a bad fan.
Could be an improper mixture of coolant and water.
Could be a bad water pump.
Could be an air blockage if the coolant had been changed recently without purging the air bubbles.
Have you been properly maintaining the coolant system with regular changes?
Did you have any service done on the car before the hose burst?
What made you purchase the radiator? Is the current one clogged or leaking?
How many miles on the car? All original hoses at the time of the burst?
What was your driving condition before the burst? City, Highway?
Did you have any coolant leaks before the bursting incident?
We need more data to help you!
It is still under warranty but I'd like some ideas in case the dealer doesn't agree with me.
I should have insisted, but then thought that maybe they don't even carry the Honda fluid if they didn't want to sell it to me.
Is prestone OK ? What about the new red prestone that is supposed to last 5 years. Can that be used or not - I think I heard it was not compatable with the yellow prestone, but the container says nothing about this. I will be flushing the system, but there is always some left behind.
All of the anti-freeze (including generic at wal-mart) says it is OK for all cars. Is this true?
If I could easily get the Honda stuff I would do that and not worry, but what is the best substitute, and how much protection if any am I giving up by using it?
Thanks for your commend
Tom
Now I take my own overpriced snapon torque wrench with when getting new tires and watch them like a hawk. Replacing rotors on a pre 98 honda is expensive-gotta press em out of the hub PITA because u can screw up the wheel bearings-been there and done that-hey why is my front wheeeeel wobbbbling in turns.
