Visitor Agreement.
Have to travel to lots of places and rent cars. If I lived in LA I doubt I would get 25K out of a set of pads. You are forever on the brakes - eeech the traffic is horrid. So brake pad life is really dependent upon how and where you drive.
My 02 Accord Ex V6 has a moonroof rattle problem. When I open my sunshade with moonroof closed, it rattles and I can hear the squeasy sound in the cabin.
The dealer said they will put some glue or silicone into it. Is that a good solution? I saw there were some TSB on 01 Accord regarding this. Does anyone have some suggestion on how to handle this?
This is better then Silicone grease but still not a real solution. I think replacing the rubber seal (hopefully the new seal fit tighter) is the real solution.
I notice more wind noice after the tape is installed.
In my opinion Honda and dealer use a cheap fix and hope that you don't come back.
worked for me
AL.
Eric
After 89,000 trouble free miles, my '93 Accord EX automatic no longer runs. When I start the car, it turns right over, but as soon as I release the starter, it simply dies. No sputters or coughs, it just shuts down.
Oh yeah, the gas tank is full.
Any thoughts?
I'm due for state safety and emissions inspection, I think I'll have them check it out then.
Thanks for the advice...I just don't have the time to get under the car right now to try your suggestion.
Thank you for the response. I appreciate it!
Recently I got into a situation where I basically had to pick up this car very cheap for about US$400? ($NZ900 inc 4 'new' tyres second hand).
The (what I thought was _one_) CV was clicking but I thought I could live with that until I could afford to get it fixed (which I did, *both* of them), and had 194,xxx km on the clock (121,500 mi), timing belt (and water pump?
Anyway, this is a very nice car, and while I try not to let such things sway me too much, I like the body shape very much (more than the new ones (ie 97+), but then I'm gonna say that aren't I?
It's a 2.0l Si auto , and my symptoms are thus: 50% of the time the transmission is absolutely sweet, 25% of the other times it shifts really badly (like I have to gun the engine to get it into third on the way down) and it never goes into 4th but is manageable, the other 25% of the time I'm pleading (out loud) with it to be sensible-it won't go out of second, or sometimes it seems like its gone from 3rd to Neutral (or 4th at low speeds?).
I didn't have it serviced at a Honda dealership (mainly for convenience of drop off and short walk to work) and the guy there recommended a transmission flush (and waved a glossy brochure under my nose and pointed to some Wynns additives) but I has already read a thousand or so messages here by that stage so I put him off (I don't think the flush would hurt, this car looks like it has not been maintained that well, but maybe I can tell him to hold the additives?). But from further reading of the mine of information that this board is I thought it could be other causes, like the TCU maybe? Any thoughts on that would be appreciated. Can I get one from a wreck and swap it myself (I'm ok with the electrical stuff)
It also has the rough idle, which I gather from here could be anything, so I'm not too concerned about that yet (bad engine mounts, clogged EGR manifold, TW sensor, PCV valve?) My question there is what order would you use to attack that problem bearing in mind that I'd be paying someone else to do it since I'm not mechanically abled/inclined
One more question is what kind of Accord have I got?? People talk about LX's and DX's and I see CLs etc, mine is a CA.. which I gather is a Canadian model? (The VIN starts with C) That's really weird since I'm in New Zealand where our market is flooded with Japanese imports. What is the CA equivalent to?(no offense to the Canadians
As I said I really like this car and am very impressed at how well it scrubbed up and is doing after a lot of neglect and probable abuse (tyres were *bald* when I got it), and I'm willing to put quite a few extra $$$ into it (up to or around its market value of course, which here is about half of what I've spent so far). So the main decision I have to make is whether the transmission is a biggie or not and whether to just put a second hand tranny in (not much point if it's the control unit, right?), thoughts or comments appreciated.
I have read most of the 3000 messages here and I have learned a lot which has put my mind at ease about a lot of things about this car and made me think of quite a few things I wouldn't have thunk, so thanks guys, keep it up!
Any ideas?
I'll post the results if and when.
Question: There's no 'problem board' under the Prelude section, so I'll try to post a quick question here. We have a '97 that appears to have an ABS/brake problem. Shortly after starting the car, the warning light comes on. The dealer says it's registering a code 81-1 for ABS unit failure. The regular brakes appear to be working fine, but the ABS system doesn't appear to be engaging. Anyway, we've been told that a repair bill will run ~$1,000 ($800/parts and $200/labor). To your knowledge, is there any other potential or real problem that may be causing this unit failure; when in fact, it's not a bad ABS unit, but instead something less catastrophic!?! This problem doesn't appear to be common on the late model Preludes.
On the '85 Civic Wagon: I may have it back Saturday -- completely restored. Talk about a rare vintage!?! At least that's my opinion.
http://www.honda.co.jp/soeno/photo_id/civic_ws/jpg/138_1b.jpg
Thanks again.
It could be an idle control valve going bad as they can cause what you say. However I do not see many of them go bad. Is the coolant level ok ? If that is low, that can create an idle problem. Is there a check engine light on ? Is the throtlle cable too tight? One last thought is the possibility of a vacuum leak, a hose could have been loosened up by the replacement of the transmission by mystake. I know that isnt much help but it is all I can think of for now.I havent seen any idle problems with these as of yet...
dash400m
I do not reconize that code, however the best thing to do would be to remove the abs fuses from the abs fuse box under the hood and reinstall after 15 secounds. This clears the codes. Now start the car and see if the ABS light comes on and goes off. Now, if so listen and see if you hear the ABS pump running, if so does it shut off after like 10 secounds or so or does it continue to run until the ABS light comes on? Most of the time just about all ABS problems are air in the system and or lack of use which leads to frozen/stuck valves inside the modulator. Try the above and let me know if you can what happens....
As always -- thanks. You da' MAN!
I have a 92 Accord EX and lately whenever I switch on the A/C, a big rattling sound starts coming out from near the engine block, more towards the left side. Can someone tell me what might be the problem and how I can fix it ? The A/c seems to be working fine, cooling normally.
Glad it worked out-how long did it take. Betcha less time than going to a repair place and then having to fight them from selling you up on something you don't need/want.
If it is not a heat shield then it probably is your A/C compresor. My 92 has a pinging like rattle that is the ac compresor and has been like that for about 2 years now.
maxhonda99
If it is not a ball joint starting to go bad then it probably is just a little tire roll/skip/movement. I have come accross it a few times on slow moving tight turn as the cars weight shifts a bit. Other than that do not know of any known problems. Sorry to not be of much help on that one
AL.
In the real world, outside the EPA lab, there is no practical difference, and even dealers are widely ignoring this alleged change in requirements. You can too.
Pat S.
When the transmission was replaced the car drove horribly. Couldn't climb hills, didn't shift well. Felt like the engine and transmission from my old 1999 Mazda Protege was in the vehicle. I took the car back to Honda 8/5/2002 and they mentioned something about internal stuff failing and needing a new transmission.
This tranmission runs great, it climbs hills well, changes without a hitch, and the car drives like when I drove it off the lot, like a dream.
Question: What would cause the transmission to fail twice? Should I be alarmed? I'm thinking that the something else major may go in the car, and my warranty is almost up. Why doesn't Honda warrant their drivetrain for 50k like most other manufactures?
Thanks for your input.
XheVoice
So does this mean that I can continue running the car ignoring the sound coming when I switch on the A/C or should I take it to a mechanic/service station ?
I do think factory ones are capable for 140...
BTW, do you guys know where to get the radiator bug screen..?
AL.
$55 and an hour under the steering column. All is good again.
Thanks a lot, you saved me money and grief!
-Sukal
The window is most likely a power window master switch.
The trunk lock is a bad lock cylynder or worn key.
The light panel lenses are probably broken, they have little clip tabs on them.
Running hot could be anything but my guess is either a radiator or thermostat.
SRS light can be reset and if continues to come will probably be a srs unit failure. Only a big deal if you want the air bag system to work..
So yes the list of items add upto a few bucks but all in all not too bad depending on the srs which is probably the biggest dollar item..
