Visitor Agreement.
At 79k, I've only had to replace front pads(~68k) and fluids so far. Still it is reassuring to have that document in the glove box.
Oh and I am looking for replacement tires. Those darn Michelins didn't make it to 100k...LOL
bodydouble
Although you can do the tweak tie rod method and get the wheel straight it is not prefered because it is not a precise way of repair and can actually take the toe out of adjustment. Alignment machine is about the only correct way to set it. A slight shift in steering rack position or beam can cause this and is usally the reason why.
Still, he wasn't talking about a squeak in the sunroof! I would hate for his suspension to fall apart in the fast lane during rush hour.
Pretty informative site also.
I am curious why you had to join 2 sites to get to this procedure. I only registered on superhonda.
Most recent, and most important to me, is a distinct click that I hear when I apply the brake to shift out of Park. It sounds like it is coming from near the gearshift. I first noticed the noise when I left work last night, and heard it both times I took it out of Park today. The click doesn't happen any other time.
Second, a minor issue, is the moonroof squeak/rattle. For me, it happens when the roof is CLOSED, and I go over rough parts of road in town. When it's open or even tilted, there is no rattle. I can reach up and push on the (closed) roof and can hear the squeak from the rubber strips compressing, and it sounds exactly like what I hear over bumps.
I plan to see the dealer about the apparent shift interlock switch click, but is this likely to become a serious problem in the immediate future? And is there anything that can be done about my moonroof rattle?
Can't make sense of your brake symptoms, except the possiblity of warped rotors, which is really discouraging on a brand new car. There have been a lot of complaints about warped rotors in the '03s, but you generally have to get some miles on it for that to happen. Otherwise....?
Normal driving situations can cause this and no, no major problems or defects as I dont see any..
ronsteve
Slip tape for the sunroof works the best so far but if not available then Shin-Etsu greese works well also just not as long lasting of a repair.
We have lots of 2003 Accords sitting outside in our heave Seattle rain and I've heard of no leakers.
Pretty unlikely the sunroof drains would be plugged at this early stage in the car's life but that's the first place I would look on an older one.
The trouble was a leak in the front of the car, so they pulled up the carpet, put in some more sealant, and the problem was solved.
Your leak sounds a lot more serious. I think they should give you a new car. Good luck.
Bob
Anyone noticing steering wheel vibration on '03 Accord's auto.tranny? Test drove 2 (at 2 dealers) and both had it, although one less than the other. Seems to appear when idling and in Drive or Reverse. Odd that the '03 Civic we tested had no vibration in the wheel at all.
And wheels why are the brakes exposed? Except ABS which has cover.
Anyways just wondering..Thanks
Since I changed the shocks, the front left one has developed a squeak at all speed, even standing still, if you bounce the car. I thought I have a bad shock, so got a new one (all shocks are Gaberial form autozone) to replace this one. But once I took it off and disassemble it, the shock made no noise and has perfect bounce etc. I thought I may have some dry seal or strut ribber etc, so I applied grease to each and every matting part of whole shock. Put it back did a bounce check, the noise continues for 3-4 bounces but disappear after that. I was content.
But after a week of driving it has come back again and its driving me crazy, since I need to have alignment done also b/c of the whole suspension replacement etc, but I want to tackle this shock problem first.
Looks like the squeek is comming form the lower part of the spring, and IT IS a spring noise, I can tell. Could it be that I compressed the spring in the wrong way etc that made the spring develop this noise? I have changed planty of shocks before and never had this problem with any car.
Sorry for the long post, any advise is appreciated.
I wonder whether i need to change the following washers when i change:
- coolant
- ATF
Many thanks.
PS: The reason i am asking is that when i change the engine oil i also replace the corresponding washer. But i am not so sure about these for coolant and ATF.
Ken
Atf---yes change the washer with every fluid change. It is aluminum just like the oil plug.
there are so many things that can popup at 37k miles, much less 350k miles w/in 3 years. I would take it to the local tire/suspension shop and see what they say. =o)
Linux70, perhaps it may be the idle setting is too low. maybe you can't adjust it, not sure. If you have mechanical inclinations, it may be worth your while to buy a Haynes or Chilton. I have found them very helpful in the past for troubleshooting small problems.
Fluid drained with green color, let it settled in container overnight, poured into another container, then it became 2 distingushed kinds of fluid, with color of fresh green and red/brown.
Now how extended the repair will be? Any potential long term damage to the transmission and cooling system?
It has been a year and half since my question on other problem, thank you!
1.Park the vehicle on level ground.
2.Make sure the fuel tank is full.
3.The driver or someone who weight the same should sit in the driver's seat.
4.Load the trunk with the items you usually carry.
5.Push down on the front and rear bumpers several times to make sure the vehicle is sitting normally.
Now that the technical stuff is out of the way,
Clean the outer lens so that you can see the center of the headlights.
Align the center of the headlights to 7.5 m (25 ft) from the wall or a screen, and park the vehicle.
Turn the low beams on.
Measure the height of the headlights and the lights should reflect 52 mm (2.1 in.) below headlight height
If necessary, adjust the headlights to by turning the vertical adjuster which is the metal teeth spin wheel on the back side.
gye
The only way that I can think of coolant in the ATF (other than adding it in your self) would be if the radiator cracked internally into the transmission cooler. I dont think there will be any long term effects but it is hard to say, just flush out both radiator and transmission real good.
AL.
02 V6 Acc.
but where is the aiming indicator though? or does it even have an indicator?
Auburn, is it typical that ATF looks green with dye in it?
BTY I also asked you about the ATF leaking question year and half ago, you seems always be there for us, not only as great tech guy, but also as licensed therapist to calm stired souls, truly "Dr. Phil" for the car guys. Thank you.
Very possible that it could be the tracer dye as usally it is a neon green like color. Shows up nice with a black light when looking for the leak. Sounds like the mystery has been solved..Good memory. Thanks for the kind words also..
cokane5227
I think they got rid off that bubble like indicator in 01. The new way is too measure the height of the lights reflection on the wall.
sumendap1
There are several reasons why it could be on but to get an idea have a look at the abs fluid resevoir and see if it is low or any signs of a leak in the area of the modulator
Also only use Honda ATF-yeah they don't make it but somebody posted a great deal of info about how tranny's are different-apparently if the ATF has the wrong lubricity-it will cause big problems with the clutch. Just cause it is synthetic ATF does not mean it is right for your tranny.
Just got 03 Accord and has been following the boards for a while. Also got a 02 MDX. How difficult to do routine maintenance at home like oil change, trans fluid etc? Have time and a quite a few tools but not averse to idea of getting tools. Considers myself kinda handyman around the household and thinking of getting into these normal auto maintenance. Is it easy to drain the transmission or brake fluid like the engine oil change?
Auburn, You have been giving some good advice to others on this. Do you think that warranty will be better covered if I get things done from the dealer rather than on my own? I mean to say that God forbids if something goes wrong then can the dealer ask for the records for the oil change and stuff as if I do it on my own then I won't have anything.
Thanks for your time.
It does not show anything, that I remember, for the brake work. I've never worked on Honda brakes, but assuming they are like other car's brakes, replacing brake fluid is more complicated than the above other fluids. It takes 2 people, unless you get specialized tools, and you have to know what you are doing and be careful. Otherwise, if you get air in the brake system, you have no brakes. Very dangerous.
This should also be replaced. Which requires a vacumn pump (a $25 hand one will do) or someone to press on the brake pedal while you open the bleed screw.
And pushing the piston back into the caliper with the bleed screw open is somewhat risky as to getting air in the system.
