Visitor Agreement.
I figure adding oil is cheap but I am begining to wonder if the end of the cars life is near.
What is the likley cause and what repair am I looking at? I like to keep the car for another year but I am not sure if the smoke is the the end of the life of the car or fixable problem?
There is several possibilities for the oil smoke problem, valve seals, oil rings piston slap cold are just a few.The other remote possibility worth checking out would be oil leaking down into the spark plug hole. Pull your plug wires out and check them for oil leaking onto them. If there is then you need to get new gaskets for the valve cover.If it isn't that then you can try having the motor flushed and ran with a cleaner to try and clean the rings. Other than that keep adding oil and driving it until it gets worse.I doubt that it will fail before getting much worse if it is an internal problem..Good luck
dshed,
If you are still within the 3- 36,000 warranty then there should be no problem with getting the handle warrantied.Unless of course it has been mis-handled
read elsewhere about problems with this transaxle. What am I facing here? Can anyone help with diagnosis, service bulletins, typical dealer-service response, cost estimates, etc. Many thanks.
BTW, 2000 SE, with 10K.
1. With cooler mornings on first start up, notice noise, seems passenger side under hood, almost sounds like noise an air compressor, or vacuum pump makes. It is engine related, increases with throttle, stationary or moving, etc. Can be heard easily with radio on. After warm up, noise goes away. (does seem the colder, the louder).
2. Had any CV or axle problems with this model?
On dry street, car pointing uphill, turned 90 deg. from STOP, sound or felt like somethin was binding. 2 days later, spun tires on wet street, but going straight this time, same sensation. Neither time was loud, etc, but more thru the steering wheel.
3. Occasional "stumble" @ idle like sitting in traffic. Kind of like a reverse deal if AC was on. All accessories OFF tho. RPM's will just sometimes drop for a second.
Got one more small thing, but this post is getting too long (sorry). Will say in regard to above 3 items, cannot sense any decrease in performance / function (yet). Thanks in advance.
Check and see if it is still leaking. If so then take off the valve cover and replace the o ring gaskets and the valve cover gasket itself and see how it goes with the smoke.
joe111,
If once it does run it runs rough then I would take the top of the carb off and try cleaning the bowl and the jets,as well as replacing the needle and seat in the top horn.I say this because it sounds as if there is dirt in the carb causing it to run rough. Also check the vacuum advance on the distributor but it is most likely a dirty carb..Good luck
bjklinton,
Monte is still going I forget exactly how much but somewhere around 285 or 286,000.Now as far as yours,is the noise like a electrical whine or is it more like possibly the power steering pump because they get a little noisy cold.If it is more like a whine then check and see if you have a ground strap going from the right side shock tower over towards the motor on the top.Check those and write back. 2..No cv problems but have had a few shocks blow out and some sway bar links come loose.Check the shock for a leak and the sway link for play. 3..No none problems for the stumble except for fuel(mostly winter fuel)related.Try differant brand or if your area uses the winter fuel it may qualify for an updated computer and presure regulator but not for sure on what the qualifications are and what vehicles are affected because we no longer use it.Good luck
mpdrew,
The trans is not the smoothest on reaccel from a near stop so what you are saying may be normal. However you may want to check the throttle presure cable and make sure it is adjusted to react at the same time you step on the gas.Just have someone slowly press on the gas(engine off) while you watch the 2 cables at the throttle body.If they move at the same time or the trans slightly later then it is ok.But make sure that if they do move at the same time that the trans cable is not too tight, it should have a little play.
Is opening up the door to take a look a big job or should I just take it over to the mechanic and get my checkbook ready?
The idle would from time to time surge from normal
idle to between 1500-2000rpm and just bounce back
and forth. It would also stick sometimes at a
high
idle when started or when put into park. Rapping
the petal used to bring the idle down (even if it
took several taps sometimes). However, now the
idle will not drop down below around 1200rpm and
it
usually wants to stick up around 1800. If I do
get it to drop down to around 1200 it does it's
surging thing.
Where should I start? I have read reports of
distributors causing similar problems, but it
would
also seem that maybe the carb is also contributing
to the problem. I assume there is some kind of
idle air control valve as well that may be the
cause. Any advice would be appreciated.
Thanks in advance,
After all, he has the information on the models that were affected!
Thanks for the suggestions on the 86 Accord with the stalling problem in the morning. In the mornings, I just let it warm up for a minute or two. After that no problems. The car runs great after that and I enjoy driving it.
I'm not going to go to a mechanic just yet. Unless it gets worse.
Thanks again for the suggestions
We just welcomed into a family a "new" used 94 Accord with around 60,000miles.
We bought it from a Honda Dealership. Managed to get them to throw in a timing belt change. Paid slightly extra for them to do the water pump. The seals etc were also changed. I think i got a pretty good deal. Here in Toronto, used accords with low mileage are either very expensive or hard to find.
One thing. The manual in the car was french! Which I dont speak. I was pretty annoyed, and did not find out till I returned home.
I phoned the used car manager and asked. As usual I got a little of the runaround. This manager would "do anything for me" last week. However as soon as I paid, he kept me waiting for an hour when I picked up the car, and he gave me the run around for the manual.
Anyone know where I can get a 94 Accord manual?
Thanks to butch11 and others around here, I had a lot of information when i talked to the dealer.
One other thing. The car hasnt been driven very much for the last year. is there anything special I need to know? It needs an oil change. Another mechanic told me to drive it on the highway for a while, then take it for the oil change. That way all the fluids will be circulated.
What type of servicing is essential to do at the Dealership?
You mentioned that some Honda fluids like ATF, coolant had extra additives added by Honda. Can I purchase these fluids from the dealership and take them to my local mechanic?
The techies at the Honda dealership are great. Its just that the dealership is more expensive then my regular mechanic and its not very close.
The oil changes at the dealership are very competitively priced. Around $22 CANADIAN ($15US)
also...what kind of maintance would I need for the next few thousand miles? i got the car checked out by a mechanic and he said it was great. Sorry for asking such a basic question...however the freaking manual is in french. The guy at the dealership "misplaced" the english version. I'll keep on bugging them about it. However...you probably know this stuff inside out!!
Thanks again auburn63!
Usally at 60k you would do a major tune up,fluid changes and check the car out. Things such as brakes, ball joints,struts,blah blah blah..But being that your mechanic and the dealer that sold you the car probably went over it, it is probably good to go until 75k.Mostly just make sure you are starting out with all clean fluids(and yes you can buy them at Honda and bring them to your tech).Trans, power steering and ATF are the most important to use Honda. Whenever possible Honda coolant performes the best in the long run as does the brake fluid. As for the oil, any good grade oil that you like is fine.
As far as what is necesary at a dealer, just the warranty stuff. Check in every now and then to have them run your VIN to check for updates and recalls. Honda techs know Honda's probably better than non but a good tech is a good tech just remember to use Honda parts for the best use out of your car.
What kind of Honda and what year is it. Some differances in the years can cause differant problems.
Butch11
97 Accords have a VIN break(why I don't know they use the same design and seal I think)So the best thing to do is have the VIN ran to check for updates and recalls at a dealer. You can call and ask them to do this, stop in, or let me know and you can e-mail it to me and I will check(if you want).I will try and remember to bring home the paper work on it and post.
Have fun.
Thanks again
Problem!!! I like dealing with a dealer like this one.
If the idle will not come down then first check that the throttle cable is not too tight.They sometimes get bent at the bracket from pulling them out of the way of the valve cover.Then the next step would be to set all of the idle screws. There are 4 if you have A/C.Start with all backed off. The base idle is adjusted first(passenger side/back adjustment firewall side of carb)600rpm's, then the curb idle(front of carb passenger side)800rpm's, can go as high as 1000.Then electrical load (if auto trans put into gear)front drivers side of carb, same rpm as curb.Then the A/C idle which is on a diaphram on the driver side back of carb. This too is same as curb.
After all that if it still surges then it may need either a frequency valve or possibly even a computer. If you are bringing it in just ask them to check the throttle cable adjustment and the idle adjustments and tell them your problems.Good luck
Jeremy
My VIN# for a 97 4 door LX is JHMCD5631V000688
Was this VIN recalled.
Mine was built in Japan if that makes a difference-and thanks again for the suggestion on the valves.
recall 98-081 emission extension warranty, good from 75-150K, replace plugs, ignition wires, rotor and oil change/filter (?what does oil/filter have to do with emission system)
recall 98-072 AC wiring harness rerouting
Recall 00-073 Balance shaft seal recall
The service guy also told me to try and get a few bucks knocked off the timing belt change since they will have to replace those seals as part of that service.
Thanks again-may drive the 200 miles back to that dealer for the service.
We started putting them on in like 1998 sometime so it would depend on when they started.The ones we used to use were aftermarket and shapped differantly but still work.Ask them to see the receipt showing the part if in doubt.
jhickey9,
The clicking is a built in relay for when the motor works too hard.Try lubing the window channel and see if it gets better.We use white lithium greese but you can use a spray silicone for the test. If not any better you may need motors.
Butch11
I will now have to go and check again because I didn't see any Japan VIN numbers in the 1997's.Which would mean that you shouldn't have showed up on his report for open recalls.I run the VIN also and see what I get. As far as knocking any money off the seal holder only pays the dealer about .6 hours plus the holder so maybe like 40.00 or less.As far as the oil and emissions their thoughts are that if the car is running to rich then the excess fuel is getting into the oil pan(oil) so it needs changed to prevent the blow by and pcv system from raising the emission levels.Good luck
I'm still waiting for the notice on the balance shaft seal, but it has already been taken care of by my dealer.
Sounds as if it was done then, most dealers started using this aftermarket one like 2 years ago.Saves you the trip now so thats good..
Butch11,
I ran the VIN and as I should have, I got the same result as the other guy. So you do get the recal but I re-checked and your VIN isn't on the paper work so it must be a mis print or something. Either way good news for you because most of us go by the DCS and it says you get it..
Silvercoupe,
Just wanted to say hello as I keep seeing your name.Have a good one..
