Visitor Agreement.
I do my own routine maintenance(fluids,filters,lubing hinges,inspections). I change my oil/filter at 6K-8K intervals, depending on the driving pattern, using M1 and the OEM filter and the oil level stays at the top hash mark. I don't believe in using the dealer for their 7.5K-15K-30K service packages and other upsells. I will use my selling dealer (because they have a good service shop) to adjust valves or replace timing belt/water pump. But that's about it.
Oh yeah, I use 87 octane (Sam's or Chevron mostly) and occasional (every 10K-15K or so) add Techron if I've used mostly wholesale gas.
I start my engine and let it idle less than a minute, which is just enough time to buckle the seat belt, adjust the mirrors and put the radio back on my favorite station. Then I accelerate gradually until the temp gauge reaches it's normal reading.
I also have a sweet running piece of machinery and am looking forward to seeing 300K with this vehicle, without any major repairs. Only time will tell. I will continue to use this procedure because I too have had great success and positive results, and BTW, with a much higher mileage figure. Do you have such a goal also or do you typically trade your vehicles before 100K miles.
Different strokes for different folks, but we are in agreement on one thing. Honda makes a very reliable, long lasting, comfortable cruising vehicle. Good luck with yours.
If anyone has any ideas PLEASE email me at ecelonghorn@yahoo.com
thanks!
The car was not maintained very well by the previous owner. Recently the valve cover gasket, air filter, spark plugs were replaced. The plug wires, visible ground contacts, battery & cables seem fine.
What's the most likely cause for the non-start? Fuel filter? pressure regulator? ...??
Thank you very much for your help.
I know my '02 EXL V6 has a grade logic transmission, which has programming in it that uses "engine braking" to slow the car once off the accelerator.
Not sure if the '96's had the same type of transmission. Effectively, grade logic senses deceleration as if you were going down a hill (grade). Mine is too new to determine brake wear, but I believe Accords get very good life out of the pads. This logic may have something to do with it. Also, check your brakes. If recently replaced/adjusted, sometimes the shops let the pads rub too much when off the brake. They should touch lightly when the wheel is rotated, but need to be adjusted properly for correct wear. Usually, if the brakes are set too tight, though, you'll notice the car is a bit more sluggish accelerating too. I'm no mechanic, but this may be some areas to look into.
What are everyone's impressions.
Ps How much did you pay for that nice automobile.
Al
*Room
*Drives Well-(I also have an Integra, so comparatively speaking, the Pilot is quiet and comfortable, yet strong)
*Price (we paid MSRP for Wht EX-L made in Sept 2002)
*Fact that it is closely related to the MDX, which was my first choice, but refused to pay $4,000 over MSRP in NYC.
Dislikes:
*Usual unease about driving first year model, but we are getting over that (knock on wood).
*Small looking wheels.
*Though more luxurious then my previous cars, Honda could offer such luxury comforts as seat memory and heaters (in USA model), side mirror defrost, sunroof, etc. But obviously they do not want to crowd out the MDX.
*seats could be tiny bit more comfortable by adding a better head rest.
This speaker is mounted inside the front lower area of the driver's door in a 2003 Accord Coupe LX. If I press my fingers against the grill over the speaker, then the buzzing is suppressed. So maybe the grill is vibrating based on the tone of the voice through the speaker. The speaker on the other door does not seem to have the buzz. Any recommendations?
The car now has 9,500 miles and the vibration is back. I'm sure the brakes are faulty; I'm not a 'hard braker'and hope the company will continue to have "good will". Does anyone have the same problem or can suggest a permanent solution?
Auburn, have you done this to any v6's and if so, what kind of mileage was the average? Does the price sound right and is it a fairly complicated thing to do?
My honda manual says of DTC 0720, lock up clutch does not engage. Possible causes listed as a number of things with the countershaft speed sensor-disconnected, short/open in line and faulty countershaft speed sensor.
Could the lock clutch be burned out due to low fluid? Anything else to check other than going thru the diagnostic tree in the Helm Honda manual. Suggestions appreciated.
CHECK THAT ATF LEVEL PEOPLE.
The warning is there because of a real chance that the air bags could explode causing injury. However with that said I have been doing dash work, filters and even SRS repair work without disconnecting the battery for years. Maybe I am just lucky, maybe Honda is just covering the legal end or maybe it just takes more than one signal to blow the bag like would be the case normally. It just comes down to a matter of preferance. Good luck
Also check underneath your carpet on both the driver & passenger side (front) to make sure its not wet, (moldy etc).
(I don't know how often Cabin Air Filters are replaced.. tells U I haven't had/done mine ;-).. but that could also be something to look into if all else fails)
=> As always, Good Luck !!
May be somebody can help me out. My 2002 Ex V6 Accord has been flawless so far, but just yesterday the CD changer refused to accept any new CDs and totally stop functioning, it shows CD ERR on its screen which according to the manual means that it is something mechanical and probably requires dealer's assistance ... When I tried to use it this morning, it sounded like it was trying to load a CD and then everything stops ... Is there a workaround or do I really have to go to the dealer? The car is under warranty, so I am not particulary worried but it is kind of annoying.
