The service supervisor recommended going to an independent rebuilder and gave me a name. turns out this guy has rebuilt several tranny's for my brother who has a fleet of trucks in his landscaping business driven by kids.
Talked with the guy and and after testing the tranny and making certain the problem is not a speed sensor or something simple will rebuild replacing all clutches, torque converter, speed sensors and the "metal" parts contacting the clutches and a couple of bearings that have failed in prior accords of this vintage. He also replaces the part of the reverse mechanism that gets bent-don't think mine is but he says this is a common problem with honda trannies-particularly if you put them in reverse while going forward or vice versa-never never rock them to get them out of a snow drift. He will use all honda parts and the price for this if nothing else must be replace is $1,500. He gives a 12 month 12K guarantee.
Will ask him about maybe changing the CV boots-maybe just the outboard boots since he has to pull the short shafts. Any other suggestions?
The car has 156K on it and is in great shape other than the tranny. One piece of advice-change the ATF every 30K-check the ATF at least every time you change oil-I do that at 4K. Smell the ATF and look at it. If it appears dark or smells burnt-change asap. Now I will carry enough atf and a funnel with hose to do the change on the road if necessary.
Anyway thanks a bunch Auburn63-will let u know how it comes out. Am going to get all the replaced parts to just see what they look like.
Can you put cross drill rotors on to help ?
Thanks !
As for driving habits... its my wifes car and she is very gentle on the car.
I am disappointed in the brakes.
The a/c on my '02 Accord does the same thing -- the compressor cycles on and off, with the cooling fans, about every 15 seconds. I called the dealer today and they say that the refrigerant has probably leaked out. Good thing it's under warranty -- I'm afraid you have no such luck with your '98.
Otherwise my biggest gripe with the Accord are all the squeaks and rattles from the dash area and front doors. After several attempts to have the dealer fix them I've given up. Fit and finish and assembly quality of this Ohio-built car are unimpressive. Next time I probably won't buy a Honda. My '92 Plymouth Acclaim with 195,000 miles has been to the shop fewer times than this car! Oh well... guess I just got a bad one. I do like the engine/transmission and gas mileage.
The drivers side front door does not align perfectly with the rear door, it sticks out just a little bit, really only noticable when looking in the side view mirror. It does not make any noise and really is not a problem but it is a new car and it seams like it should be a simple enough problem to fix (simply move the stike plate in a little bit, right?).
So the guy in the service department tries to tell me that this is the way the car is designed "at the factory" to minimize wind noise. I asked him why the passenger side doors align perfectly and there is no wind noise from them. He says that he isn't sure but maybe it is because it is a different mirror "or something".
Now back to the subject of this posting...
Do these dealers think we are stupid? The guy was clearly making things up as he went along. Now if I do bring the car to the dealer to have them adjust the strike plate I am afraid they will only make things worse when it isn't really causing any problems as is.
*** Note to dealers and service departments ***
Lying to your customers or making up answers to questions instead of actually doing your job to find the appropriate solution will only undermine the customers' confidence in your knowledge and skills and will make them seek service elsewhere.
I will probably leave well enough alone. If it ain't broke, don't fix it.
I have a silver 03 V6 and have had the same break problems (graby, pulses very oddly during some breaking, feeling of them always being on). Also, I found a small chip in the paint on my hood very soon after purchasing it. While I know that this can happen on the hood normally, I really didn't recall anything hitting the car with ANY force. Also, since I first asked about this I have seen several posts all by owners of silver 03's. Anyone else having these issues with the paint besides freezeepop, angeral, and myself?
I'll let you know what the dealer tells me about these.
Now, I have written several messages on here about my braking issues as well. They are still very grabby, unless I am VERY soft on them while I stop. I also feel like they are on all of the time, but can't tell if that is the Grade Logic at work or what...does the computer think I WANT to slow down on a straightaway just b/c I let off on the gas? Its not a terrible problem, and I hope it goes away after break-in but still.
Any advice from you longer owners?
As for the paint, yes I have two small chips on my hood, and little tiny chips on the majroity of the lower hood section. I think its normal because I travel about 4 hours up state every other weekend, and I can only imagine the crap that gets kicked up while on 87.
Also, I was driving today, with the windows down ( FInally its not rain on the east coast) and while I was holding my hand out the window, a pretty decend sized peeble, the size of a pin head, struck my hand. Let me tell you, it was a pretty sharp pain and I can only imagine what will happen when it hits the surface of our paint jobs.
Keep us posted on the status of your brakes.
He said it was fairly rare for clutches to slip in honda trannies but the speed sensors do get out of specs and when that happens-the CEL warning appears cause it is also part of the emissions bit. Ordered the parts this morning and will install in a couple of days.
One more time-check that atf fluid level and change atf using only honda atf every 30K.
Oh called a large junkyard and used honda at's are available for around $500-not the $2k quoted by my dealer-guess he had a boat payment coming up-but he did tell me which rebuilder to approach.
The only viable option I see are the 3m clear bra's.
I too have had more paint scratches than I think is appropriate for a new car. My worst scratch is on the hood (through the clear coat) and that one is farther up than the bra covers so the bra would not have prevented it (that rock also hit my windshield causing a small star which I had fixed immediately).
I do think that the paint on the new generation Accord's is less durable than it should be based on my experience and of others on this site.
Anyway, I still love the car and am very happy with my purchase decision.
I also have a silver car, with chips in the hood and on the back passenger door (above where a door ding could occur) they look like they could possiblity be bursted bubbles.
Mike
6 Mo ago purchased (4) XOnes along with full 12 mo warranty. One just went bad due to (non-repairable) roadside hazzard. Tire dealer readily replaced under warranty - but had to replace with a Harmony. This since X-Ones apparantly are being phased out.
So front axle is 1 X-one & 1 Harmony. Tire dealer says this not a problem at all. Michelin on other hand says it is safety issue. They say must have same type tread on same axle. That would mean buying one more Harmony.
I have had several talks with both tire dealer & Michelin. Get different answers. I'm not opposed to $100+ for new Harmony tire IF it is really necessary to replace in pairs. On other hand, I know they may be forced into an overly cautious positon.
Can anyone provide insight? Not really concerned with handling, noise etc. My concern is safety or (severe) premature wear differnce.
Is it OK to have two different tire tread styles on same axle? Thanks for any insight.
Don't know what board to go to for this but here's my quality of dealer service question. I took my car in on Sunday to have the back passenger side window replaced as it was broken into, to have the glass vacuumed out, the grabby breaks evaluated, and the first service done.
Here's how the car was when I picked it up. In the back seats there were still corn kernel sized peices of glass, many shards in the seats seams, and in the front, grease around the window chrome from the instalation of the new window, the maintanance light still on, and the brakes still squeaking at times and catchy.
A staffer had someone vacuum it and clean the grease spots, and then turn off the maintanance light, but that was only because I got there early enough to still find service people working on their own cars. They didn't even give the car a quick wash.
So here's the deal, I sent them an email the next morning describing my displeasure at the poor quality of work and haven't heard a peep back. For $300 for a window I'd think they could have cleaned up properly. Should I simply learn from it and not go back? Would have liked to establish a relationship with my dealer...
And as a sidebar, I recently had to take my CL in to have a belt tensioner replaced. Because the part had to be ordered and also due to scheduling problems I had to go back 3 times within about 10 days (which was inconvenient but the dealer was not to blame). But they washed and vacuumed the car every time. Obviously for the second the third visits, the car really didn't need a wash, but they did it anyway. So I thought that was a nice bit of customer relation.
I'd check with another Michelin source to see if they aren't still available. Offer your dealer the chance to honor the Michelin warranty on the X-One.
Did you contact Michelin: 1-800-847-3435 ( from website). They also have a form on their website for sending email directly to them. I'd ask about the substitution and if X-Ones are being phased out...
The X-Ones are rated higher and have a different tread rubber and tread pattern. I'd want a match. I have X-ones on one car and would replace with same when two wear out. I'd take them over the Symmetry I have on the '03. I think they're a different ride.
Be careful out there-do it to them before they can do it to you.
http://www.fairhondapartsforyou.com
Biggest advantage, their shipping is only $3.95 regardless of weight which is very very nice. Also will price match which I had them do ever time hehehe. Over all excellent service. Try them out.
