Got another problem now. The tape the dealer put around the moonroof opening to stop the squeaking sunroof is now peeling off. What do I do? If I remove the entire tape, the roof will start sqeaking again. IS there anywhere I can buy that tape? or is there another fix?
As far as taking to my dealer for the window, I actually called my insurance company to see who they recommended and that place, giving me the insurance rate (though I was paying for it) was $60 over my dealers'. Also, I needed the other services done so I didn't really want to take it two different places to get it all done, which again wasn't an issue when the dealer was the cheapest I found... yeah, surprised me too. Would have been nice to have them wash and vacuum like yours. I personally think that should be standard for a place charging $82hr labor, and is just good PR. What I think is even funnier is that after writing a complaint to the service manager (which also took the time to give credit where credit was due) I have not even recieved a response. Oh, well. To all those out there in MD, I would honestly recommend Jim Coleman Honda's internet sales department, it was a VERY easy sales process, but I'd stay the heck away from the service department.
My troubles with my dealer brought me to thinking, how do I find out who the best rated Honda service departments are?
I have an '02 EXL V6 sedan. This is normal for this car. I thought it was odd too and had it checked at dealer. Alternator was putting out 14.2 amps. What happens is both the compressor and the A/C fans engage at the same time, creating a split second drain on the alternator. That creates the blip you're seeing. The car is designed this way. Part of Honda's efficient motors.....Puts out the minimum req'd amps and kicks them up when there's a requirement. Tell them to run a check on it when you bring it in to make sure. Mine was fine and the test gave me some piece of mind.
Anyone experiencing the same problems? Solutions??
Consider getting Honda Care x-Warranty if lemon law route doesn't fly.
keep checking NHTSA web site for latest and greatest TSB for this car. Your problems may show up there.
With reference to the sales people-well let's say it is almost universal within the car business-over the years have encountered a few who are honest-but for the most part I find most of them worse than useless. Course it is not a job I would want-think of having to deal with every yahoo who walks thru the door. A good motto for car sales people-"There is a seat for every [non-permissible content removed]".
JIM
Is there any way to improve the fuel economy? Or should I bring it to the shop?
Alex
Brings to mind my first Accord ('98) salesman, who said that the sunvisor extenders are "receptacles for gas receipts and other things." And the 03 coupe internet salesperson who said over the phone "...your new car's been washed and it's flawless, waiting for you to just sign the paperwork" - well, the car was not washed and it had 2 dings. Oh well...
I was turned off by honda salesmen as I shopped this time. They felt the stereotype and marketing of honda's past should sell the car this time. Didn't work for me. Guess it works for those who think that mortgage rates used to be 8 percent so now they should be happy to pay 8 percent.
But then you talk with the one guy who's sizing you up and trying to work with you and still do his job for himself and the dealer.
Please don't be offended by my anedotal evaluation through 35 years of car-buying. I believe the 1 out of 3 is the reason the internet is not making great cuts into car selling in my area of the midwest. People still like to deal... My analysis there is shaded, perhaps, because I'm in a heavy GM and Ford worker/related business area, so lots of people get 3 percent below "invoice" with no dickering. Wish I worked somewhere that gave good perks like that, grin...
I recall being told that our 1995 Accord had a noisy distributor, and then a few years later at about 120K miles the tach started acting funny because the distributor went bad, so we got it replaced.
Have any of you ever experienced this problem?
Bob
Apparently the speed sensors do go out of operating limits and this causes the CEL codes. My crack tranny guy said the solenoids and clutches rarely crapped out on honda trannies-hope he is right.
I also use Fair Honda"HondaPartsForYou". Usually recieve order in 2 to 3 days max.
Fastener sizes refer to the thread pitch diameter, not the head size.
And thanks for all the info provided-solution cost less than $140 and took 1/2 hour to fix under a shade tree. Hmm guess that is why some people are called shade tree mechanics.
Thanks for helping me before.
I have a 98' Accord with a 2.3L VTEC 4 cyl and would like to know when the timing belt/water pump should be replaced. I have also read about 3 service recalls including an ignition switch, lower ball joint and A/T noncompliance. Should I bring it in for these recalls? Thanks again, Greggo1
Re: recalls. IMO, if they mail you a recall that involves your car, It would be advisable to take it in and have them fix whatever needs to be fixed. It should be at no cost to you.
By the way, what mileage do you have??
They also did a 4 wheel alignment that I was complaining about. The invoice had 3.6 hours of labor all under warranty!
Also shop around for the best value on getting the timing and other drive belts replaced. The dealers that said it was necessary to replace the water pump also had significantly higher prices on just doing the drive and timing belts without the water pump than did the dealers who only replace water pumps if they are leaking for the same timing/drive belt replacement. Range was from $300 to over $550. Hmm wonder if that is just a coincidence or do the replace the water pump guys also charge more. I think I know the answer to that one.
https://www.ahm-ownerlink.com/login.asp?page=/prod_main.asp
It was the 2000/01 that got the extended autotrans warranty from Honda, but other 6th Gen model years have gotten taken care of if they had tranny failure and were aware of the problems Honda had with this Gen.
Front brake pad on my wife's Accord (98 I4 auto 4dr) was replaced at 54K miles, the dealer also cut the front rotors at the time, and inspected rear brake, that they said it was fine. After the brake job, my wife complained about vibration (shimming - as auto technicans call it) when braking at high speed (>50mph). Last week, I had dealer checked the brake, the car has 61KM now (I know, I should do this early, my fault), they said the rear drum warped and need to be replaced. My understanding is that the rear drum will last much longer than this (rear drum brake on my 96 Accord is fine with the original shoe and drum at 80K currently). I guess the service department at that honda dealer must did something wrong during last service, like over tighten the lug nuts. Otherwise, the car probably only need a pair of rear shoe. By the way no one took wheels off my wife's car during this period.
So the question is: how often Accord's rear drum need to be replaced at normal condition? What usually will cause rear drum to warp? How much time is needed or dealer usually charge for a rear brake job, including replace the drum and brake shoe?
I'm at 100K miles and have not needed to repair my rear brakes yet.
Since everything has to be taken apart anyway, the water pump is exposed and only needs to be unbolted. No extra labor to speak of.
It really doesn't matter if it's leaking or not. a water pump with 100,000 miles on it has a questionable life span.
If it starts leaking three months later, the whole thing will have to cme apart again.
Not to mention the hassle factor.
I own two vehicles with this engine. I bought them specifically due in part to the timing chain. My thinking was that I would never have to spend the ~$500 every 100k miles to have that service done. But now it seems that my water pump might break and I'll still have to spend the $$.
Me, I want the peace of mind.
Turning rotors is a different story. Unless they are warped I don't want mine turned.
Timing chains and their tensioners wear out and fail too eventually.
Me, I don't think replacing a timing belt and water pump every 100,000 miles is that big of a deal. For most people it'll be a one time thing anyway.
