Terrible rotten egg smell, dealer has stated that a fix is in the works (new catalytic converter). I hope so. If we sit at a stop light for any lenght of time we have to open windows as the odor finds it's way into the car.
Vibration from A/C is brutal, a passenger couldn't believe the amount of vibration. Dealer stated that's the way it is.
We also have the clunk at startup that several others had commented on. Mine started after they did the recall for the breather tube and the transmission reprogram.
I had a loaner accord and that car had the same problems as I mentioned in my message. I guess the Honda quality is not what the reputation would lead you to believe it should be.
The dealer made me feel like I was the first to make these complaints and that the majority were more or less my imagination and they could not find anything wrong(the messages posted here tell me differently). I was also surprise to see what was put on the formal work order and what they verbally told me was not the same. I may not be able to live with these problems on a day to day basis.
Anyone have any ideas or has your dealer fixed your problem?
Upsides: very smooth transmission and attractive interior. 4 cylinder has good passing power. Overall a smartly designed vehicle.
However, I find it very hard to believe that the idle speed cannot be adjusted, so I guess I'd find another dealer.
My previous vehicles needed 2 miles to get me any warm air and get the temp gage to register above C. How does the 03 Accord heat up so much faster?
>>>Also had the rotors resurfaced 2 twice and then replaced. I am starting to feel the brakes pulse again! now with 10000miles. I think they have a cronic problem on the their hands.
Check the torque on your lug nuts. If they all are not at 80 ftlbs, they will warp. I checked them on my 03 and 04 upon delivery and they were all different and way off. I promptly retorqued them all and have not had any pulsing problems on either car.
Once retorqued a badly overtorqued front wheel on an 80 accord I had and the most of the braking shimmy went away.
Fairly easy to change the rotors on the newer accords-but was a bear on the old ones-had to press them in as part of the wheel bearing assembly. If you ruin the wheel bearing "holder"-another part to replace.
Final rant-never ever let anyone turn a rotor that is not warped-some dealers-particularly BMW dealers say this is necessary-well maybe for their bank roll but don't let them do it.
Am about to pull the plugs, then turn over engine with large ratchet connected to the bolt on the pulley which is connected to the crankshaft.
Any ideas-sounds like no compression-engine has 160K on it. Maybe will squirt a bit of oil into each piston. But is not burning oil so compression should be ok.
Leaking fuel injectors, faulty fuel pump, pressure regulator, etc.(all part of fuel not reaching fuel rail)
Broken, loose or disconnected wires at the ignition coil or faulty coil
Broken, loose, or disconnected wiring at the starting circuit.
Ignition components damp or damaged.
the whole ignition circuit should be able to be checked with a spark plug checker.
Hopefully it's just some loose wires or something... hope thyis helps.
So now I know-don't start it for just a couple of seconds.
thanks again
A whining sound is noticeable from either the transmission or the engine when I ease off the gas pedal at highway speeds (50 - 70MPH). The sound has been getting progressively worse over the past 6 weeks. My dealer first stated it was a wheel bearing, then it was the transmission, then the engine. My case manager at Honda America told me today that it was a "normal" noise from the transmission and that it has been reported in other '03 Accord V6's. They told me that there is no corrective action going to be taken to remedy the problem - of course I'm not settling with this lame answer. Anyone have success in getting this problem corrected with their Accord?? Any advise is greatly appreciated . . .
One thing that will fry an alternator quick is too loose a belt-runs too slow and will burn it and also if someone overtightens a belt, will trash the bearings. Have had both problems. Yeah 47K is a problem.
This is the first time I am posting to this particular forum. My other car is a 2000 Impala.
My wife owns a 2002 Accord Special Edition with the 4-cyl engine. We have encountered two problems:
1) Hesitiation upon take-off from start. Dealer could not replicate. Anyone else had this problem?
2)Sunroof squeeks and rattles. Dealer applied some "tape" to stop the problem, but neither the squeek nor rattle stopped. Any suggestions?
Any help is appreciated!
Jas
The alternator should run you about 150-200 for a brand new one, and probably about 100 for a rebuilt one. Some rebuilt ones may come with a lifetime warranty, not sure now.
This same thing happened to me only once though after sitting for about a week, while on vacation. Has your car not been started in a while? Also read my post # 3897
1. Wiped the windows clean with Lacquer thinner to remove clear coat residue and deposited wiper rubber
2. Cleaned glass with Bi-mami (sp?)
3. Washed car
4. Installed New (non Honda "exact-fit") blades from NAPA
5. Three coats of Rain-X
Now, I'm waiting for the Seattle rains to arrive.
I'd like to hear if others have had this problem, and if so, what was your fix (and did it work)?
Took it to Les Schwab... he did a look-see and a quick fix.
He noticed that the wiper itself(main body of the blade) was not parallel to the windshield. So he took a adjustable wrench(with a towel wrapped around the arm,) and tweaked the arm a little so that the wiper sat parallel, then tested, and no problem with skipping or chattering now.
never did have it leave rubber, though...
Guess most people know-just do not push on accelerator at all when starting a FI vehicle. In the before auto choke carb days it was a dance between the accelerator, choke and starter button/pedal in winter to get those things started.
How old are your plugs-they will last for 100K but not a bad idea to replace at 50K.
the TCS light came on as well at same time-- but it is now off....
any suggestion? i assume take it to someplace whose computer checks out hondas is the way to go... wonder what the cause is....
thanks for any help
unfortunately, if it is the check engine light, the only way to check that is to get an OBD-II reader, take it to a mechanic, or jumper the maintenance pins and get the readout manually. On a 94-98 Civic, there is a connector under the passenger side kick panel. Jump those two wires and turn ignition on. then the check engine light should start flashing a sequence. If you don't feel comfortable doing this, take it to a mechanic or spend the $100 to buy the reader, or see if you can rent it at the local auto store.
evidently there's a recall that i hope works....from reading on the internet-- evidently a common problem on V6 accords and oddyseys.... TB-99-085 from what i read on a forum elsewhere....
am hoping this won't cost me.. think i'll email my salesman.... let him know and see if he can help out here with the service.... am due for a new car in a few months... if he can't help, or won't, there may be a solara in my future....
here are the things to check as this states it...
Clogged fuel filter(probably should be changed at least every 24k or so)
Vacuum leak
faulty Fuel injection system
timing off
emissions system clogged
air filter clogged
another thing to check out is a IAC(?) Idle air controller/computer. it controls the air flow during idle, I believe it is in the throttle body somewhere.
hope this helps some... it's not an accord manual, but most of these should still apply to both.
After 12 months, I too have had to replace my rotors & the black molding around the windows (twice and quickly on the way to a third time). I have a transmission noise that Honda states is normal on the 03 V6's (whining upon decelaration at higher speeds) - it might be normal, but it isn't acceptable. If you have this problem - complain loudly (say hi to Pat at American Honda for me, I'm sure she has my phone number memorized by now) I'm getting a 3rd party to test the the tranny then I'm off to court or arbitration. Wish me luck . . .
Are there squeaks in my 03 LX Sedan built in 8/02? YES. However they are few and far between and do NOT change how much I truly love this car. They would not sway my buying decision, and have been remedied by my dealer. My other car (92 civic) had a much louder ride due to engine and road noise, and since this car is leaps and bounds quieter I think I a creak stands out much more.
The only one I have had linger is the drivers and driver's-rear window area as described in previous posts. They are nearly gone and I think that's partly due to the break in.
This is not exactly my issue but similar. For me, the first two or three brake applications on my 03 Accord induce a groan that tracks the rotation of the wheel. WHHNnnnnnn sort of sound.
After the third braking or so (before I leave my subdivision) the brakes do not make this noise. They did not used to do this.
I attributed it to the colder weather but perhaps there is something wrong.
Thoughts?
Also, do you see a round cut near the edge of the rotors?
My console door buzzes over bumps as well...my dealer said there's nothing they can do.
Still, I love this car.
I recommend that you call Honda Customer Relations before your dealer service visit. They can authorize whatever repairs are necessary, so you don't have to negotiate with the dealer. This is assuming that your car is within the brake warranty period.
I had to get the serv mgr involved, after a couple of visits, they finally admitted it needed to be welded to be repaired. I wish the service depts would stop this practice of trying to push obvious problems off as being a normal car function. I guess this works on a lot of owners who don't know any better. (Not us edmundites!!)
My father suggested the following - there may be a glaze building up on the rotors. This is especially likely since my car has a Manual tranny and I do downshift to brake as well so the brakes are lightly use. His suggestion was to hard brake a few times to try to clear this glaze off.
chuck03 - I'll check and see if there is a line on the rotor. I do not think there is.
