You in Wichita by any chance? Was wondering if you had experience to share regarding Scholfield's Service Center.
have this little quirk: the starter relay buzzes. theres really nothing wrong. Just tell your customer to turn the ignition switch a little faster, and the relay wont buzz.
Today the side of my Accord was keyed (actually, it looks like someone used the side of a coin), but anyway I was able to lighten it greatly with TurtleWax Color Cure. However, the scratch is still lightly visible, but not too deep, are there any really good scratch removers or procedures recommended to remove the remaining mark? Thanks a lot!
I had my car scratched fairly deeply next to the door handle. Took it to the dealer body shop for the brand of car. He said he'd try something first and then see how much he had to paint to touched up that area.
He called later. Tried something new in the realm of a compound and buffing. Perfect. $22. Best dollars I'd spent letting a professional try it on a car less than one year old.
Finally took my 2002 Honda accord to the deal for the smell. One technical consultant stepped over to my car to check the mileage. When he came back, he said it smells.
Waited for about two hours in the waiting room before he came back with the conclusion: there is no leaking. (In other words, they were not able to identify any apparent cracks on the tank and pipes.) He said the oil shop when removing the filter, somehow allowed the oil come out. I lost some oil but there is no leakage. They had wiped it out.
I saw the wire-shielded pipe from the bottom. Is it the manifold exhaust?
altheaU
The car currenty runs fine, but I've refrained from driving it, until I can fix this problem. Anyone else experienced the same situation? Thanks
Recall TSB:
02-031 SEP 02 Recall - Ignition Switch Replacement
Any pointers on trouble shooting this little headache?
According to the service advisor, Honda USA will replace at no charge said pads within warranty even if they're wear-inherent parts.
Anyone experiencing rough and/or noisy front brake operation might want to get the pads soon to prevent brake rotor work.
The mileage did improve by about 2 mpg over the first 10k miles or so. But how you drive is a large contributing factor. I accelerate normally and don't tailgate or ride the brakes. Also, I generally drive alone or with one other person, and the only things I keep in my car are a few maps, a flashlight, and a tire pressure gauge (i.e. very little extra weight).
Before hardwiring my radar detector and possibly an auto-dimming mirror into my 2004 Accord EX V6 Coupe, I might as well seek some expertise here.
I'm planning on a non-compass mirror (Donnelly Model 19713 - CIPA 36100) since I already have Navigation and don't need a compass. Therefore, I don't plan to run a wiring harness down the "A" pillar.
Since I don't yet have a Honda wiring diagram, all I'm concerned with is determining (before dismantling my headliner) if anyone here has found an ignition-switched wire in the overhead lighting/sunroof area. If so, what color-code is it? I'm presuming that I can find a simple place to connect a ground in the same area.
Have your battery checked. On one of my accords the srs light came on and was caused by a cell in the battery which was going dead. The battery still seemed to have plenty of juice as the car started fine, but the slight drop in voltage triggered the srs warning light.
