Visitor Agreement.
I'd tell the dealer: oil, lube, filter, tire rotation. Check the air filter and wiper blades yourself and get these parts at the dealer if you need new ones. Before you hit 30K, I'd get the brakes inspected for wear. I'm pretty firm on giving the dealer all of my service needs, but I don't let them service whatever they'd like.
keep the service rercords.
the transmission from neutral into drive? Does it harm the transmission
if u just skip applying the brake?
I used to a manual tranny & can't explain this?
2. - no, it doesn't hurt the transmission
The main reason they want you to have foot on the brake is to be sure that the car is not in motion when engagement is made.Mostly they are concerned about any reverse motion before going into a forward gear.This can and does casue internal failure. However excessive forward motion before shifted into drive could cause damage.
Auburn, does that mean i should do that (stepping on brake when shifting
from P or N) when I start driving my car away in the morning? By the way,
could u clarify on what u meant by excess?
Thanks a bundle.
1) Does the temperature gauge on the dashboard have to be perfectly centred when the car is at operating temperature? Mine seems to rest slightly below the middle hashmarks. Is this allright?
2) Regarding that balancer oil seal recall. i think that there are in the process of recalling them here in Canada. Any idea of how long the job usually takes? It sounds pretty labour intensive. Is all the oil drained from the engine? I.e will i be getting a free oil change
3) Regarding the "maintenance required light". I understand that it turns to red every 12500 kilometres. I had the car checked out at a dealership around 2 months and 3000 km's ago. Is it pretty safe to reset this? The manual just says to put the key in the slot.
Thanks a lot for answering these questions.
Auburn...remeber the time I asked you about the 86 Accord with startup problems and problems when it was cold? Well..the problem isnt entirely resolved. I took it into the dealearship to replace a leaking power steering fluid reservoir. They had a look at it and had some difficulty coming up with some solutions. The car runs quite well when fully warmed up. So I will leave it at that. There is no use spending too much money on that car. I am quite happy with the way it runs when warm.
thanks again
There should be some guys from Toronto here...TitoPuente? others?
Can anyone here recommend some mechanics in Toronto, Ontario that are good with Honda vehicles?
I have visited the shop of "Dr. Honda" based in Mississauga Ont. I wasnt very impressed. Its a pretty dirty workshop.
I would be intersted in getting some recommendations.
To get the most out of your trans without any self inflicted problems it is best to always be at a complete stop before changing gears.Rocking(like when stuck in mud or snow) and shifting on the move causes internal damage.Any motion can cause damage but the faster the motion the more likely the chances of hurting something.
Mack20
Outside temp usally effects where the guage will be. When it is cold outside it will remain below the half way point for the most part and when it is hot it will be as far up as 3/4 and still be normal.Anything lower than 1/4 or higher than 3/4 will most likely be a problem but sounds as if you are ok...
The balancer holder recall takes about an hour from write up to completion.Depending on how many are a head of you if you are waiting.It doesn't require the oil to be removed so no free oil change this time.:(
The light comes on every 7500 miles so as long as you know it has been serviced then reset it.
I would and actually am doing the same thing with my car. It starts rough in the cold and then runs great warm so I am waiting for summer to come around.:)
Auburn,
Thanks again for the information. Its not that cold here in Toronto. Slightly below freezing. The gauge is still slightly below middle. The car was bought fairly recently used from a Honda dealership. My dad knows a tech there and he gave the thumbs up. However the temp gauge was not noticed until later. Is there any reason for a temp gauge to be slightly below middle? The car runs fine. Heating, etc works alright. I have taken it for 90 minute highway trips a couple of times. No problems!
alcan
I looked at your profile here on Edmunds. Where do you teach? Hamilton is not THAT far from where I live. Probably around 45 minutes. We only very recently started taking our car to the dealership. We usually use an independant. But after a few mixups, there are some things better taken to a dealership. We have been lucky that any repairs have been few and far beween!
The hourly repair rate for mechanics is extremely high! I wish I had more of an interest in mechanics back in high school. I would have become a mechanic! $96 an hour! Wow!
Also..I noticed that you are a forensic mechanic. What does that mean?
Does anyone here know if replacing the timing belt on a Toyota Camry is cheaper than replacing the timimg belt of a Honda Accord?
I was lurking in the Camry discussions and it seemed cheaper to replace the camry timing belt.
Also...while car shopping, I looked at an engine for a 4 cyl Camry and it seemed that there was a lot of room under the hood. The accord engine was really packed. Seems like its easier to work on a camry.
I would be intersted in the opinions of any techies out there!
That $96/hr is the service dept. rate. Good techs in TO make about $26-$30/hr, flat rate (piecework). But you're quite right about taking some concerns to the dealer. They can more often pinpoint the problem and correct it faster than independents, considering they have factory training, specialized diagnostic equipment, and the familiarity of dealing with a limited number of models.
A forensic mechanic inspects vehicles after fatal or serious injury accidents to determine if mechanical failure was a contributing factor.
If you post the year, model, engine of the Toyota and Honda, I can quote you the flat rate time for timing belt replacement on both from my Mitchell mechanical labour estimating guide. BTW, after changing a timing belt on an '89 Accord with AC last weekend, I'm now firmly of the opinion that anyone who'd work on them without it being court ordered community service must have been dropped on his head at birth.
It was a drop on the head for me but if you think they are bad you should try a late 80's civic with a/c and p/s or almost any dual cam prelude.We won't even rehash the pain of the top mount a/c in the early 80,s..:)
rgaines
They should be able to get the steering wheel centered so if it is not then I would go back and have them get it right..
BTW, did you ever take a few spare minutes and slip a timing belt on a Lumina 3.4, or a chain on a DOHC 2.3 Quad Four? Now I know what Purgatory's like LOL.
Do you know of any possible reasons why my 94 Accord would show a temp gauge below normal? Car runs fine and I had it cheked at a dealership when i bought it a few months ago.
Can you tell me how many labour hours needed for:
1994 Honda Accord EX 2.2 L
1994 Toyota Camry XLE 2.2 L
These cars both have AC, and power everthing!
1988-94 Accord 2.2 w/A.C....... 4.5
Add:
where cruise cont interferes (it will).... .3
where Power steering interferes (it will).. .3
1987-94 Camry 2.2 w/A.C. ...... 3.0
Combinations:
Gear or sprocket, camshaft (ea), R&R... .2
Gear or sprocket, crankshaft, R&R...... .2
Seal, camshaft (ea), R&R............... .3
Tensioner (pulley), Timing Belt, R&R... .1
Looks like the Accord's 5.1 and the Camry's 3.8
Don't forget the $175.00 surcharge for BandAids :-)
If your temp is just below half this time of the year then that is normal.As long as it is comming off the cold mark.If you think that it is not normal then one reason for a colder reading would be a stuck open thermostat.
T-Belt times for Honda
Here in NJ we are getting 4.4 hours(3.9 T-Belt only) for the timing belt,water pump,seal holder and external belts.(Power steering,a/c and cruise control @ no aditional time)..
Markz2k, Alcan can give you a direct quote on that one, I am not for sure but I think we get 5.5 or 6.0 hours.
Markz2k - sorry, my labour guide only goes to '96.
Alcan, we can get them done and still make time and these days thats a good thing because some of the seal recall cars are not making it in, in time, so we have to do the belt also which Honda has been covering most.
Tick, V6's do not need valve adjustments as maintanance so I wouldn't think it was a valve noise either unless you have a lifter not working right.I haven't heard that kind of noise yet so it is hard to say what it could be.Take it in and see what they say.Good luck
You may even want to wonder in to your local Honda dealer and complain about the brake noise. If your pads are OEM then you will still be in warranty as long as they are installed correctly and you are within 3 years of purchase.Just so you don't get cought on the technicly side of things, tell them you put brakes on the front trying to get the noise to go away but it didn't work if they ask.Once again to cover your end also ask for a estimate if their is going to be a charge.
One last thought,if all else fails you can ask the dealer if they have a softer, less metalic brake pad.These will be quieter but last not as long.Good luck
Ugh! And they act like it's MY fault.
On another note, while I'm here: If my car sits out in the sun on a hot day (this is not a problem right now of course :0) ), then when I start the car, the airbag light stays on for at least five minutes, sometimes a lot longer. What causes this? Is it a hazard if (god forbid) I get in an accident? Can it be fixed? Has this happened to anyone else?
I recently had the valves adjusted and the mechanic said he has only seen one dirtier engine, and he seemed sure the oil was NEVER changed by the previous owner (I suppose others might disagree). I looked at the engine and saw it was coated with a black substance that looked like tar.
Currently I am changing the oil very frequently (every1,000 to 1,500 miles) (I also use gunk engine cleaner at 1/3 recommended strength between changes, but will stop that once the can is gone - one more change) I have just switched to synthetic oil (supposed to clean engines better) and will change the oil every 2,000 and work my way up to 3,000 (depending on how dirty the oil looks). After 30,000 miles the valves will need adjusting again, and we shall see if the cleaning worked.
The vehicle runs very well. It gets good gas mileage. It has decent acceleration. So far it sounds like most other 4 cyl Honda engines. (I also have an Acura Integra). The longest I have gone between oil changes is 1,650 miles, and over that distance I couldn't tell that it used any oil (less than .1 qt anyway). The car does not smoke. It starts right up and idles smoothly.
I have two questions. First, should I do anything differently, and secondly what are the chances that my engine will have a normal healthy life (well beyond 100,000 miles).
By the way the mechanic said that because Honda uses a solid valvetrain instead of hydraulic that may have saved my engine. He thinks a hydraulic valvetrain (self adjusting) would have been trashed.
If your routine gets the engine clean without plugging anything up you should be good to go to well over 100k miles.
Leo
If no one answers your question by Sunday night then I will try and remember to look on monday and see. I haven't had to do one yet so I don't know.I know on Civics you can look under the right side of the dash and see the three screws that hold the motor in and can see that once removed the motor will fall out the bottom.Take a look and see if you can see yours.
Vcuan,
Yep thats the part I was talking about, some people call it a sender, so thats cool it wasn't anything more serious.I have 2 92 Accords one coupe and a 4 door I like that style/year range also.
Fortunately, my 2001 coupe shares precious little sheetmetal with the sedan and I'd say its the most attractive 2-door Accord ever.
