Unfortunately it will be more of a crapshoot since the quality of the repair is determined by the quality of the dealer and not by Honda.
If you could, please elaborate on EXACTLY where on the car you have found this corrosion. Even take a picture and post it somewhere if possible. I want to inspect my car thoroughly and could use the guidance.
By the way, to see what I'm talking about, visit the Mazda6 forum. There you will find a link to a website totally devoted to the topic.
I have a friend who hit something and cracked her tranny case. She is going to seal the crack with some sort of temporary fix and trade the car in. 1995 EX-L with low miles. Beware.
My first thought with your complaint was the EGR system, more so 2 or 3 clogged ports causing all the gases to dump in 1 cylynder. Pull the vacuum line off the egr and try it to see if it is better. You can power brake the car in the range of 1700 to 2000 rpms and feel the same stumble, then disconnect the hose from the egr and try it again.
keung
My thought on your car is the ignition switch, have you had the recall done or checked on your car?
Also, did anyone ever install Piaa ultra white headlight bulbs to their car? Any comments on that? Thanks
Thanks very much
In my opinion, if you can find a good mechanic who is NOT a dealer you will save an enormous amount of money over the life span of your car. Try the Mechan-X-Files at cartalk.com to search for a good mechanic in your area.
Thanks again for the help
Brakes are a good thing to try somewhere else though and check and see if you like an independant. Accords are so common that most any independant has worked on them previously anyway. Personally I would seek out a person you already trust or try a Honda specialized import shop. A Honda specialized shop will be very current and if really honest (in my case) will direct you to the Honda dealer if a repair is covered by any secret extended warranties. (In my case $1500 repair performed by dealer for free on Civic-New Cat and two O2 sensors on a 96 Civic 141,000 miles).
I want to avoid taking it to the dealer. Through searching I've come to the conclusion that I can insulate the area with padding. I can probably just jam some foam in, but I was wondering if anyone had details on how to take down the headliner so I can apply foam EVERYWHERE. Possibly Dynamat in the future. Thanks.
In my opinion I would never take my car to the dealer unless there was a major malfunction and the vehicle was under warranty. Otherwise a dealer is only good as the tech's that work their. Many of them are fresh out of a six months training course that makes them certified. We have a personal mechanic that's unbeatable in our opinion.
If the dealership can some how secure the insulation without ripping it all off that would be great. The down side is, once the headliner comes off, it's really never the same again. Minor things like that, I would first attempt to fix myself, maybe taking some silicone sealant and trying to have it stick to the liner and the roof. It's such a shame that the quality/craftsmanship of these cars have dropped in the past years. It goes for the Camry's also. A person spending close to 30K for a vehicle does not and should not have to deal with these problems.
And yes, we're all paying a lot of money for our cars, but the fact of the matter is , you know you have a good car when the only thing you can complain about is a little tapping when you have the radio down and you're reallly listening for it.
Nw1997, thank you for the comment about the headliner not looking the same after taking it down... I'm encouraged just to wedge some craft foam in from the gap between the headliner and the windshield. I'll let you know how it goes. A lot of these things are DIY jobs that don't require a tech, just a little information.
In the years that I have been on this board I cant tell you how many times I have known what the problem was just by the description, while the poster has spent alot of money and many trips to privates and still not been fixed. You will not hear of many stories where a private fixed something a dealer could not..
But most of the time I go back to the dealer for a thermostat, fuel filter, etc.,rather than buying aftermarket to put on myself. They know me by name at the parts counter, not just in the service department.
The service manager helps me with questions about what's possibly wrong. Then when I repair, I use their parts. When I have to have it repaired, I don't shop the other repair shops; I just pay the dealer what they charge. It's fair trade for the excellent tips they give me when I can do it myself-- or they say don't bother, it won't get worse by 175K when you'll have traded the car.
He has always had a specialty mechanic who only solicits Honda/Acura business. The guy charges a little more than a corner mechanic who does all cars would, but this guy is always checking for needed items that go bad and checking on regular scheduled items that need replacement. He anticipates and saves money. But the guy doesn't replace something that can go longer safely.
I would readily trust these guys for any work other than warranty work... of course, they could do the warranty work, but coverage would be an issue.
