Visitor Agreement.
Headlight dimming: mine does this if I let the rpm's die down too much as I let out the clutch. Do you have a 5-spd or an automatic? I would not expect this problem with an automatic, but if you have a manual try getting the lights to dim while launching at a moderate rpm (1800+). I don't think they'll dim on you then.
Hesitation, under no circumstances, is normal. You better get it checked. But also your description is not clear and informative either. Accords have very decent low-end torque, I can take off my accord from the second gear easyly on flat road, even with slight hill that could be the third gear. My previous 91 LX was in the same way too. Well, this is valid only for 5 spd, as you know.Good luck:)
If I start my 2001 5-spd in 2nd gear, the engine will lug unless I give it a very featherlight touch. Once the revs hit 2000, I can do WOT without complaint from the engine. If I shift into 2nd gear with the revs dropping to 1500 or so, the engine complains if I give it a good shot of throttle. 2000 rpms is the line. Under that, you need to use very easy throttle to prevent lugging. Over that, it's open game. My engine has 1200 miles on it.
The Accord does have "good low-end torque" if you qualify low-end as 2500 rpm, not 1500. If you look at the dyno chart, the 2.3L has its first torque peak around 2500 rpm. It then tapers off a little through 3700 rpm and then picks back up to the peak of 4900 rpm and then gently rolls off til redline. It feels nothing like a Civic/Integra engine...I only have to redline the 2.3L if I'm bored and want to hear some VTEC engine notes.
It is indeed very strange, I quess some others can express their observations too.
When I read your comments, I tryed to create same shifting environment to see whether I am ending up at the same rpm or not. Between 1.5K and 2K rpm at second gear, my accord has strong pick up but not fast and engine does not lug . Speed comes after I pass 2K line which is matter of second.
Some how we are ending up in the same rpm range but my second gear responds strong and allows me to accelerate. I am not sure it could be clutch and gas combination. I think you can eliminate the engine lug if you focus on clutch.
During my break in period (first 4k miles and first oil change)I shifted to 2nd immedialtely after take off, I got 3th at 30 mph, 4th at 40 mph to keep the engine at 2000 rpm always at 3th and 4th gear. This will put you at 2000 rpm always after shifting which gives you the best fuel consumption....I would not let my car to pass the 3000 rpm if it has 1200 mile on it. It might be early for that.....
Well there are many thing to discuss but the room is getting hot, I might melt:) I have to leave...
First, I am very brisk with the clutch. I let it out and engage the gear quickly...I ride the clutch for only a brief moment during engagement, usually under one second. I know that if I ride the clutch for a longer duration, engine power does improve, but that's just a lot of wear and tear on the clutch if you do that constantly during shifts. My engine lugs at 1500 rpm but I have the clutch completely out. Perhaps I need to lengthen the engagement period a little.
4000 miles is a VERY long break-in period. I'm at 1250 and I consider my engine completely open game. I redline it or rev it high whenever I want/need to. You say that exceeding 3000 rpm while the engine has 1200 miles on it is too aggressive? Hmmm. I'm sure that even on the night I drove my new car home from the dealership, I exceeded 3000 rpm at least once while accelerating. My word, you HAVE to if you don't want to get killed in traffic! And heck, this is a Honda VTEC 4-cylinder. Once you pass 600 miles, you can rev these things up without worry. Take it to 4000, 5000...it doesn't matter. You don't have to drive like this all the time, but if you need the power, let the engine spin. I've probably redlined my engine about 6-7 times since I took delivery. And I'm not sweating one drop! My dealer even told me, "once you hit 600 miles, let it rip. These engines can take it."
In all honesty, you might be actually hurting your engine if you don't let it spin. Your engine's hestitation problem MIGHT be a result of the lack of revving. I am dead serious. It isn't a big block V8 pushrod. It's a small overhead cam 4-cylinder. Let it rev...that's what it was designed to do. I'm not familiar with the mechanical reasons, but I've read here that a small engine that is never revved high will slowly lose performance and fuel economy. Don't get so worried over crossing some rpm limit. In other words, just drive it.
My father has some strange aversion to engine revving. He has a 97 SE automatic with the non-VTEC 2.2L. He complains it performs like a dog. I watched him drive and I commented "yea, because you never let the engine rev." I then told him, "why don't you keep your foot down and let the engine spool up and generate power?" He responded, "no, I'm not going to do that to the engine. This isn't a performance car, it makes too much noise and that's too much wear and tear." Ay! He shouldn't be driving a Honda 4-cylinder if that's his opinion. He'd be better off with the GM 3.8L V6.
Since I've been old enough to have my own car, I've driven 77K miles and NEVER had a single engine problem on the 3 cars I've had.
I don't stay on clutch more than it needs. I don't take off with second gear but my car is technically and practically capable to do it, engine does not lug. Unlike some others state, between 1500 and 2000 rpm my engine does not act like dead, it is fully operational.
I believe break-in period is not over until you change your special break-in oil. And I also believe things are not black and white to frame the break in period as 600 miles. If this was the issue, Honda might suggest the first oil change at 600 miles. Like surgery patient, after surgery first 24 hour is very critical, they stay in ECU. This does not mean that they can run after 24 hours, they still remain in care (but not in ECU room) until they recover.
I totally agree with you to rev the engine time to time. I do it when I need, especially on the highway to pass others. My favorite gear is the third one. I believe, 3th one is the most powerful gear in Accords. My former 91 was in the same way too.
I disagree with you ( agree with your father ) that Honda is not a performance car. Non of the mid size sedans are. But that does not mean that you can not drive it as performance car if you accept premature part failure and usually this comes almost anywhere except engine. Most of the engines are well capable to take the strees but not other parts of the car like tires, alternator, belts, cooling system, drive train system etc. I am not talking about 24 hour response time, affect will be come up in long term like if I never change my alternator you might chance yours, if I chance my CV boots at 120K, yours might be due at 60 or 70??
VTEC engine is put in these cars because of fuel efficiency not because of performance related concerns. (some people under the impression that if they pass the 4000 rpm they feel a kick or boost or something in the speed or movement.)
Like as I said, majority of thing we discuss are in gray area. Only time shows us the results and results will be definetelly different for everybody:^) Good luck.
Leo
I think American Honda is not different than DC, GM or Ford. Based on what I read from different topics, if you are dealing with corporate level customer service,they always give the same answer. They have tendecy to deny everything unless you are cleary %100 right.
Therefore owning a honda does not bring you good level of customer service.
Paul
It has been my experience that during the first 5 years , possibly 6, the Accord is practically fail-safe, but that after year 6, I have seen $1K or possibly $1.5K of repair work per year. (Note: I don't count maintenance, brakes, tires, batteries,etc). I have most of the records, so I could spend an hour trying to itemize the expenditures, but I honestly think that I'm not exaggerating.
Other older generation Accord owners.. Have you experienced this as well? I sometimes read posts where folks state that they have 150K or 200K on their cars with no repair work whatsover?? Is this the norm?? Or am I just at the unlucky extreme??
Reason I ask, is because my 98EX is about a month away from having its 3/36 warranty expire and I'm having nervous thoughts of whether to purchase HondaCare to extend warranty to 7/100K. I got a quote this afternoon of $1435 with free financing for 12 months.
The problem descriptions can be terse and concise to the point of non-information, but you will immediatedly recognize something that applies to your situation. The three TSBs on 2000 Accord transmission problems, for example, are well-known in the Accord community, and were the subject of a lot of frustrated postings on this very site several months ago, when they first surfaced. If, for some reason, your service advisor feigns ignorance, it helps to be harmed with the TSB so there can be no doubt that American Honda knows about it and can advise the service people on what to do.
Understand that 99% of the TSBs on the NHTSA site have nothing to do with SAFETY, per se. It's just a catch-all bucket to collect this data, and it can be very helpful if you know what to look for.
Leo
1) I was interested in peoples experiences with Accord Reliabity in years 6,7,8,9 of life. My
experiences with 2 older Accords that I bought new, was that I average about 1K-1.5K of
repair work per year after year 6. Haven't seen any responses. Still curious.
2) I was also inquiuring about HondaCare 7year/100K extended warranty. I posted a quote of
$1475 from my local dealer. "jct9454" responded with a suggestion to shop around and possibly ask for quotes for dealers over the web. I sent about 4 inquiries, and I did have one
return my query with a quote for $1095. "jct9454" thought $850 would be a good figure. Has
anybody gotten close to that?
Thanks for everybody's participation. I really enjoy this forum.
That $1475 figure is absurd. $1095 might be worth it if that's the best you can find. I would try to negotiate so that the warranty has a $0 deductible, not $50, but I'm not sure if this is possible.
You have to figure that Honda prices the warranty so that over time it will pay out less in claims than what it receives in premiums. The entire insurance industry works this way. By buying a warranty, you are basically transferring a majority of risk to the "insurer" (Honda), in exchange for an upfront premium. You basically have to choose whether you prefer a higher fixed expense mean or a lower expense mean with a greater variance.
My service advisor always uses this train of thought when I pay a $300 repair bill on my 92.. "Well consider it a monthly payment.. and remember you don't do it every month...".
I wonder what formula most typical buyers use when they need to make a decision.. "Should I keep my 8 year old car another year or should I trade it in.." With 2 car payments right now, the question is any easy one for me to answer.. No new car until at least you finish paying off the 98.
I recently traded-in a 1996 Dodge Stratus with 62K miles. It was almost 5 years old when the tranny went. While I realize that it was quite out of warranty (3/36K), I still don't believe a car <5 yrs & 62K should incur the amount of repairs this one did. While I am fortunate enough to be able to pay for a $500-$1,000 repair (and did on several occassions), I would strongly prefer not to. In my case, buying a $1,000 extended warranty for the Stratus (if such a beast exists) would have been a good move.
I traded the Stratus for a 2001 Accord EX. Since I prefer to keep my cars for at least 5 years, prefereably longer, I decided to buy the Honda Care extended warranty. At around $1,000 at time of purchase, it added less than $20 per month to my payment.
I think (again, based on past experience), that an extra $20 per month is much better than a "surprise" repair bill of $500-$1,000, especially if they occur a couple of times a year. Of course, I hope I never use the warranty on the Accord, and even if I don't, I feel it will have been money well spent, just for the peace of mind.
Hope someone finds my experiences helpful.
Mike
experiences with the Dodge all so very well.
Interestingly, I went back and looked at all the posts in the Honda forum in Sedans, and saw some neat exchanges between several folks on whether or not to buy Hondacare. What caught my attention was that all 3 folks said that 1) They had had very excellent records in 250K of experience with Hondas and 2) The repairs that they did would not have been covered by HondaCare.
I then went to the Honda website and read their info on HondaCare. It is very sparse. So it didn't give me the warm fuzzies that it would fix small things. Maybe it only addresses major failures like engine, tranny, & a/c.. Was that your understanding when you read your brochure.
There was also a post that stated that the dealer cost for the warranty is around $650. Some markup huh??
www.hondawarranty.net
These guys are authorized Honda dealers who offer the official warranties at discounted prices. You will note that none of the options exceed $1000 for a 4 cyl car already in the last year of its regular warranty - most are a lot less. There is a toll-free number to call, as well:
1-800-332-2872.
Hope this is enough to get you started - do not pay more than $1k for this coverage - as pointed out above, dealer cost varies between $500-$650.
Actually, the extended warranty is quite extensive, and I plan to buy it before my second warranty year is up on our '01 V6...but I will get it from this source or another dealer who discounts online, not pay through the nose at the prices I've seen bandied about in this discussion. Check it out....
Auburn, what do you think about that possibility of it being the purge control valve? Have you ever came across similar situations. You mentioned maybe a lifter going bad, but wouldn't the ticking increase in frequency with an increase in engine speed instead of disappearing? Thanks.
Tick noise,
I will have to listen for the purge control valve and see if I can hear it or not. I don't think the valve works that often or atleast it don't when I am testing them but I will check inot it. As for the lifters, they sometimes get quieter on accel when they are partially clogged. The higher rpms allow them to pump up. But as of yet I have never done any lifters or cam work so unless you are a service criminal I wouldn't think that would be your problem anyhow, it was just a thought.Other than that I can't remember any similar problems.
Honda also gets cheap on the warranty, too. Their standard warranty package is probably the worst in the business. 3/36 bumper-to-bumper. No roadside. No 5/60 powertrain. No 3/50 b-to-b. They are a business out to make a buck, of course, but it's interesting to find the little "gotchas" in their products. It doesn't stop me from buying one after another, though.
vcuan- Aside from a couple minor issues, (the aforementioned exhaust replacement-- and to be fair, the system on my Accord is NOT OEM, I took it to a national chain for exhaust work; a mistake, I know) My '94 LX 5-speed has held up remarkably well over time. I've now got a little over 104,000 miles on it. I've had it in for the following (beyond normal scheduled maintenance): a broken power window cable @ around 85k, new CV joints at around 99k, and a starter problem which turned out to be a loose fitting on the starter itself (it was a small piece of brass, I'm not sure exactly what it was for) at 101k. I've also replaced the battery once.
Though right now the car's pretty dirty both inside and out due to 67 consecutive days of snow cover here in Iowa, when it's cleaned up the car is frequently mistaken for a '96 or '97. The paint has held up well, except for the usual stone chips on the hood (the car is black, which makes them all the more obvious) and I just last week put a new set of tires on it, the second set I've bought.
In summary, this has been far and away the most reliable car I've owned, and that includes the two Acura Integras I had previous to this (it goes without saying that in terms of reliability, it blows away the domestics I've owned) and I wouldn't hesitate to hop in the car right now and drive it cross-country. I had thought of trading it in because it's a coupe, and now with my two-month old daughter, it's kind of a pain to get her car seat in and out of the back, but I couldn't bring myself to do it. It's been too good a car to give up.
The prices are great though.. And they seem to infer that we're talking HondaCare warranty.
Anybody bought a warranty from hondawarranty.net?
I just got a 2001 Accord EX-L recently and was wondering if this is a problem OR it is the integrated antenna...
I tried my real defroster and noticed that the upper portion (about 4-5 inches from the roof) is not working. When I look carefully, I can see all the wires in the real window area but it is not doing it job; and I know that the 2001 has integrated antenna. So, is the upper portion (4-5 inches from the roof) of the real window with the tiny wire my antenna or it is part of my defroster and it should defrost for me and is time to bring it in to the dealer and have them fix it.
defroster
Macho, good luck with your car. When I told the service tech about the ticking over the phone, he said there would be a 69.00/hour diagnostic charge to determine source of ticking. I mentioned it was still under warranty and he retracted that statement. I wonder what sophisticated diagnosis tools they use to justify that kind of money and I wonder if that same equipment was used when I said it was under warranty. Probably just the tech holding his ear close to the general area of the noise. "69.00 please"
Auburn I looked up the purge control valve in my emissions warranty pamphlet and there's 4 associated components to the purge valve. Diaphragm valve, check and relief valve, vacuum switching valve and solenoid valve. The symptoms my ticking exhibit could possibly come from the vacuum switching valve since I hear that slight pop and it stops ticking when vacuum is applied. But then if this is right, why haven't I heard it before now and is it an indication of this part going bad. Questions, questions, questions!
The reservoir is located on the left, nearly under the battery.
I find it impossible to check if the reservoir is empty or full. Is there any trick to this? You need really small hands!
I think I had somebody hold a flashlight up from the bottom of the car while I looked from above for the fluid line.
