Visitor Agreement.
btorlv: It's probably your ABS self-check. You will feel a slight rubbing or hear a slight noise when you first start to move.
Also let me ask you this... Have you ever needed to use any of your extended care packages? How many have you purchased? The fact is that you are unlikely to take advantage of an extended care package given Honda's reliability record. This is especially true in your case given how much you over-maintain your vehicles at even more cost. Multiply this by however many Honda vehicles you have owned over the years and your are really wasting money. Not to mention the opportunity cost of not investing the money or using it for something more enjoyable like a vacation or a new widescreen HDTV!
Saying something over and over again simply does not make it true. Your numbers are not "facts", they are merely opinions. You are buying piece-of-mind.
Hey, that's why ice cream comes in different flavors. Do what you feel comforatable doing.
I really hate this car, but I'm stuck with it because when you sell or trade in, you lose.
Very disappointed.
ramida
Definately call Honda customer service to find out the exact details this may take care of the problem. Or simply call the service dept. at your dealer and give them your VIN and they will tell you what work needs to be done. Hope this helps.
http://www.curryhondacare.com/
Probably a better idea to buy at your local Honda dealer it is the same price. Just remember these are sold at full retail price and are not as comprehensive as independant warranties but at least it is backed by Honda so they won't go bust. It might pay to get a copy of the Honda warranty and read it thoroughly and compare to warrantydirect.com and sleep on it and make a decision. Warrantydirect offer the best warranties available (also options for a much longer terms), have a very good rating and you can choose any service shop you like including your local Honda service dept. for repairs, but remember they are nowhere near as big as Honda and could very well go belly up at any time.....though not likely.
Personally I would stick with the Honda backed warranty as you are taking a big gamble anyway and you don't want an extra gamble of the company not honoring the deal. I choose to have that money working harder elsewhere but as always different strokes for different folks.
As for the tendency to "jump" when releasing the clutch, you can feel the car springs up, at the final release (just when I thought the clutch is fully released). The clutch is probably high.
Sorry, I don't feel comfortable trying to shift from first to 3rd gear (as you suggested).
ramida
Thanks again.
ramida
NHTSA CAMPAIGN ID Number : 04V176000 Recall Date : APR 13, 2004
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Potential Number Of Units Affected : 1099796
Summary:
ON SOME MINI VANS, SPORT UTILITY AND PASSENGER VEHICLES, CERTAIN OPERATING CONDITIONS CAN RESULT IN HEAT BUILD-UP BETWEEN THE COUNTERSHAFT AND SECONDARY SHAFT SECOND GEARS IN THE AUTOMATIC TRANSMISSION, EVENTUALLY LEADING TO GEAR TOOTH CHIPPING OR GEAR BREAKAGE.
Consequence:
GEAR FAILURE COULD RESULT IN TRANSMISSION LOCKUP, WHICH COULD RESULT IN A CRASH.
Remedy:
ON VEHICLES WITH 15,000 MILES OR LESS, THE DEALER WILL UPDATE THE TRANSMISSION WITH A SIMPLE REVISION TO THE OIL COOLER RETURN LINE TO INCREASE LUBRICATION TO THE SECOND GEAR. ON VEHICLES WITH MORE THAN 15,000 MILES, THE DEALER WILL INSPECT THE TRANSMISSION TO IDENTIFY GEARS THAT HAVE ALREADY EXPERIENCED DISCOLORATION DUE TO OVERHEATING. IF DISCOLORATION EXISTS, THE TRANSMISSION WILL BE REPLACED IF DISCOLORATION IS NOT PRESENT, THE DEALER WILL PERFORM THE REVISION TO THE OIL COOLER RETURN LINE. THE RECALL BEGAN ON APRIL 21, 2004, FOR PILOT, ODYSSEY, AND MDX OWNERS. OWNERS OF THE ACCORD VEHICLES WILL START RECEIVING LETTERS ON JUNE 28, 2004, AND ON JUNE 29, 2004, FOR OWNERS OF THE TL AND CL VEHICLES. OWNERS SHOULD CONTACT HONDA AT 1-800-999-1009 OR ACURA AT 1-800-382-2238.
Notes:
HONDA RECALL NOS. P30 (ODYSSEY AND PILOT), P31 (MDX), P38 (ACCORD) AND P39 (ACURA). CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
From honda.com:
TORRANCE, Calif., June 29, 2004 -- American Honda Motor Co., Inc. today announced that it will expand its existing voluntary recall of light truck models for a potential transmission defect to include certain Honda and Acura passenger cars. The voluntary action involves approximately 499,000 Honda and Acura passenger vehicles with V6 engines and 5-speed automatic transmissions. Affected models include certain 2003 and early 2004 model Accord V6 sedans and coupes, 2000-2003 and early 2004 Acura TL sedans, and 2001-2003 Acura CL coupes
We've had our 2004 EX V6 for only a few days now and I have a few questions about some little things - i.e. I'm curious if what I'm seeing is "normal". Any comments would be appreciated.
1. "Courtesy" light
(That little red led light that shines down onto the gearshift area at night when you lights are on.) My question is: does that light ever go off? It comes on when I turn the lights on, and I've never seen it go off during driving.
2. Recirculate on Auto climate control
I've noticed that occassionally my Recirculate is on when in Auto climate control mode - and then never goes off. For example, today, I got in and set the temp to 70 (outside temp was about 75). After a minute, the recirculate light turned on and air volume was increased. However, after quite a few minutes, it was very cold in the car and recirc hadn't turned off. The only way to make it turn off was to turn the temp way up to about 85. Once it did turn off, then I could turn the temp back down to 70 and it was fine. This has happened twice.
3. Distortion in windshield
I know I asked this before, but got no responses. I have some distortion in the windshield on the passenger side. It is right above where the black screen pattern is on the bottom of the glass - about a 1-2 inch band. I looked at several others on the lot today when I was at the dealer, and they all had some distortion there too. So either this was a bad lot, or this is pretty common.
Guess that's it for now.
-n
He ordered a new "seat track" to try and fix the shifting driver's seat. No charge under warranty. We'll see if it works.
Get this though... all the 25K service under severe condition schedule (4cyl) calls for is an oil change. Guess how much this cost? $82.63! FOR AN OIL CHANGE AND TIRE ROTATION! What a rip-off. The oil change alone cost $61.47! Dealers are such crooks. I had the entire 20K service done at my personal mechanic including all the required "checks" and a tire rotation for a total of $36.72. Last time I go to the dealer for anything but warranty work.
Sounds like isellhondas is from a reputable dealer as well (of course I remember you from back in 99 discussing the Odyssey too, so I know you're an honest Honda dealer).
I do have a question for you (isellhondas). Have you heard of (or have any information on) any of the items I noted in message #8399? You're closer to this than most people so I'm interested in your experience.
THanks.
-n
This is the same dealer that forgot to tighten my oil drain plug after my 15K service.
At least they are replacing my driver's seat frame to correct the seat shifting problem I am having without any argument.
A couple other dealers nearby are $24.99 + tax and $29.99 + tax for an oil change, but I rarely go to either of them.
I just bought a used 1997 Honda Accord LX and wanted to change the oil in the transmission. I wanted to put synthetic oil and was wondering what the requirements were and if you guys had any links to buy the stuff from?
Also should I look out for or change any stuff in the car? it has 130,000 miles.
It will reach 4000 RPM before changing gears sometimes and when it does shift, the car jerks a little. Is it the V-6 or what? I plan on getting a full tune-up ASAP.
I have a Camry and know that when I punch it, it goes. This is our 3rd Accord and this is making me worry a little. I appreciate any help.
THANKS....
Do keep in mind that until the current generation of Accord, the automatic transmissions shifted VERY firmly, particularly 1st to 2nd. But there shouldn't be any noticeable slippage.
When you say it shakes when it goes up hill, does it feel like it's making "mini-lurches" as you go uphill when the transmission is in lockup mode?
If it's what I think it is, Honda has a TSB (00-038) on the torque converter. Here's the basics:
Vibration While Driving at Low Speeds
(Supersedes 00-038, dated April 25, 2000)
SYMPTOM
Shudder/judder when driving at speeds between 20
and 40 mph. This vibration is most noticeable when the torque converter lock-up clutch is in the partial lock-up mode.
PROBABLE CAUSE
Irregularities in the torque converter face prevent the lock-up clutch from smoothly engaging.
CORRECTIVE ACTION
Replace the torque converter.
I'm not sure if this would correct the shifting irregularities... the following symptoms may warrant a transmission replacement.
• While driving, the D4 indicator on the instrument panel flashes.
• An abnormally loud noise from the transmission.
• Extremely slow or delayed gear engagement, upshifts,
or downshifts.
• Abnormal gear slippage during upshifts or downshifts.
• Erratic or excessively harsh shifting.
• Automatic transmission fluid (ATF) leaks.
This is from TBS 02-062.
If either of these would be the case, the extended warranty that Honda provided for 00-01 V6 Accords (7 years/100,000 miles) should cover it.
Hope this helps...
Any suggestions or costs... it would seem that lack of driving would of minimized any damage.
Thanks for any advice.
I noticed this week that I need to press the brake pedal in a lot further to get the car to slow down. I mean, almost to the floor. If I pump the brake pedal twice, the second pump is a lot more resistive.
Also, I can feel a few light pulses (or vibrations) IN THE BRAKE PEDAL as I depress it through the first few centimeters. It happens every time I press on the brake no matter what speed I'm going.
The brakes just seem to have gone weak, and it's been a little scary driving this week when traffic would slow abruptly on the interstate.
The brake fluid is full and I don't see any leaks near what I guess is the master cylinder, at the wheels, or on my garage floor. The pads look plenty thick, and the disks look/feel smooth and normal.
I certainly feel I'll need to have the car looked at, but does anyone have an idea of what could be going on?
1. The Honda owner's site stated the 1st oil change should be 7500k mile...Is that a mistake??? Shouldn't it be every 3K. How often do you guys change your oil???
2. I have a accord v6 coupe and it states to ONLY use 5w-20 oil. Is that a must? what is the drawback and the difference of the other ones e.g 5w-30, 10w-30, 10w-40???? What is synethic? Please help clarify this for me...I'm a newbie to this auto stuff
Much appreciated and thanks in advance your time & help
Mark
I'm not complaining.
-n
