The car also has the transmission recall done. One thing I am not sure that the dealer did not change the tranny oil -- How can they inspect the 2nd gear without opening the tranny?!.
The car also does not very stable when it is hit my sidewind, any experience on this, also pelase post. Thank you all.
The engine knock could be anything but it can be isolated and detected. The problem may be the service at the dealer that you are using. It is worth the time to look for a dealer service elsewhere to have your problem corrected.
In reference to your transmission question, this is the information from the recall notice:
ON VEHICLES WITH 15,000 MILES OR LESS, THE DEALER WILL UPDATE THE TRANSMISSION WITH A SIMPLE REVISION TO THE OIL COOLER RETURN LINE TO INCREASE LUBRICATION TO THE SECOND GEAR. ON VEHICLES WITH MORE THAN 15,000 MILES, THE DEALER WILL INSPECT THE TRANSMISSION TO IDENTIFY GEARS THAT HAVE ALREADY EXPERIENCED DISCOLORATION DUE TO OVERHEATING. IF DISCOLORATION EXISTS, THE TRANSMISSION WILL BE REPLACED IF DISCOLORATION IS NOT PRESENT, THE DEALER WILL PERFORM THE REVISION TO THE OIL COOLER RETURN LINE. OWNER NOTIFICATION BEGAN ON MAY 12, 2004. OWNER NOTIFICATION FOR THE ACCORD AND ACURA MODELS WILL BEGIN ON JULY 26, 2004. OWNERS SHOULD CONTACT HONDA AT 1-800-999-1009 OR ACURA AT 1-800-382-2238.
The sidewind issue is dependent on too many things to answer. Hope the other information was helpful
They're 2 different symptoms, with knocking indicating worn internal parts typical of high-mileage/marginally maintained engines and pinging suggesting bad gas, computer malfunction or both.
Since you're just at 23k miles, the second, less serious condition is more likely. Either case, it'll be free warranty work for you.
Re your tranny, if I remember correctly they snake an optic-fiber device through a second, non-drain hole to inspect the 2nd gear; they then replace the plug with the oil jet kit. This procedure does not entail a tranny disassembly or a fluid change.
Any ideas as to what could be causing this odor? Is there any way I can clean my car's vents (I'm not very automotive-inclined) or check out the problem? Is this something I can take to the garage and have them solve/fix? Any help or information would be greatly appreciated! Thanks!
Think about it. If they have new, it's the same as in your car already. From experience I know that some two year old cars are better than the new ones. The first owner has suffered through fixing all the problems.
So mechanically, a remanufactured transmission is every bit as good as a new transmission.
Service Bulletin 04-050
Engine Spark Knock on Acceleration
SYMPTOM
The engine has a spark knock (ping) during
acceleration.
PROBABLE CAUSE
The programmed ignition timing is too advanced during
specific engine operating conditions.
CORRECTIVE ACTION
Update the PCM software using the Honda Interface
Module (HIM).
I don't have access to Odyssey TSBs, but perhaps there's a similar TSB for them. The fact that it has happened with Accords despite the knock sensors shows that they have to be properly programmed to prevent knock.
If you disconnect the negative terminal of the battery and wait five to ten minutes the electronic control unit should lose its memory. Once the battery cable is reattached and you run the car for a while the ECU will learn the new settings. This may resolve the pinging issue. One caution, have the anti-theft radio code available because you will have to enter it in order to your radio to work again.
Any suggestions? Thought of trading it with 04 TL but the difference is 10K+.
very annoying...i have been considering trading in my car for awhile now.
I don't remember the exact fixes, but perhaps they'll post them when they see your message.
Not placing any blame here, but where are you parking and driving your car?
Actually, no. But I've know of incidents on Long Island where new cars (because the paint hasn't sufficiently hardened) parked in certain areas have been suceptable to environmental paint damage.
Parking new cars near dieseal RR trains, salt or asphalt plants (among other things) have come up with paint damage.
I am writing here to see if I can find anyone else who has had the same problem. There has to be others out there, maybe only shows up on the Tafetta White.
Be sure you write that code number down and keep it in a safe place. As far as I'm concerned the codes are almost more trouble sometimes than they are worth. I know they have dramatically reduced the theft of these since the thief knows the radio will be useless.
Your problem seems very strange. I agree that if Honda replaced your vehicle that there is indeed a real problem. Since you have had two vehicles with the same problem I wonder if the dealer is somehow ruining the paint with some sort of prep work on the cars. Personally I have never seen this on any Honda.
I would take it to a reputable body shop or a good detailer (the kind of professional that knows how to use a rotary buffer to repair swirls, scratches, and other paint defects - not one that just slaps on a coat of wax) and get their opinion.
I think there is a problem with the undercoating or primer used before the car is painted.
Thanks for the info! Good to hear from someone who doesn't think it's something I am doing!!
I bought a new 2004 lx accord one month ago from the honda dealer. The mileage info on the car sticker said 24 city miles/gal and 34 highway. I am driving both in a mix of city and highway roads. The car has performed at 16.9 miles/gal on the first two tanks of fuel. I am higly disapointed. I would like to get my money back. The airbag lights also turns on on the dashboard indicating an airbag problem. I can't believe i bought this car.
Ed
A new 4 cyl. Accord with AT should get about 22 mpg in the city and 33 mpg on the highway. Many Accord owners do better than that.
Are you being exact in calculating mileage and not just estimating from the gauge needle?.....Richard
Nothing I've heard of.
What's your point? Just because your car's paint is "flawless" doesn't mean that a paint problem in one or two cars deserves to be disregarded.
My point was/is...from my vantage point I see a lot of cars and I hear about it when there are problems. This is the first I've heard of this and I have no explaination as to what's causing it. Nothing that's widespread so far as I know.
"My wife's 2004 Accord EX V6 has a slight clattering/clanging sound whenever the car goes over bumps or road imperfections. It's much more audible from the back seat"
My 2002 Accord V6 EX at 25,500 miles got the same sound in the back of driver seat when I went over bump or sharped turn. I am going to take it to the dealer this Tuesday. Also, at 15,500 miles the oil leaked underneath the engine. But that oil leak problem has been fixed under warranty. I hope the problem with the driver seat is going to be fixed under warranty too even though the car was bought a little bit over 3 years old, but it is only 26,500 miles.
I know i am an efficient driver when it comes to mileage. I had better than standard mileage with my previous car. I am driving on fairly large roads and highways, no downtown stop/start driving.
I calculated the mileage by filling the tank to maximum and driving until the tank is empty. ok i have not read the fuel volume on the pump so i am not exact but with 16.9 miles/gal, instead of 24 (printed on the car MSRP sticker, and not 22!) you have to question Honda's advertised mileage. I went to the dealer saturday they could not care less, told me they would look at the car on monday while they were working on other cars. You can guess what i think of Honda, this is the first (and last) car i buy from them.
