Visitor Agreement.
I just traded in my 03 ex-v6 for a brand new 05 ex-v6 with navi.
about 80 miles into my car and the 2nd day I get this horrendous and very loud creaking noise coming from the A-pillar windshield area. My 03 never did this but did have it's share of other rattles
I haven't called the dealer yet because i'm scared they will just make it worse or make something else start rattling. Although they do still have to install my day/night mirror.
Apparently this is happening in the TSX as well. It almost sounds as if my windshield is going to fall out
Sprayed some WD-40 on the 2 layers of weather stripping on the doors and perimeter of the door openings on the body. I don't hear any annoying noises now.
Honda Accords have 2 rubber door gaskets insulating the inside of the car from the outside. The rubber parts probably squeak a bit against each other and a spritz of WD-40 seems to fix that. Try it.....Richard
Just purchased a '98 Accord EX V6 coupe. Seems to be in great shape. 78k miles on it, and it had the tranny replaced at 74k miles by honda under warranty. I'd like to have the timing belt/water pump replaced, along with the distributor, spark plugs, air filters, and brakes flushed. Can anyone recommend what else i should do? Anything problems i should look out for?
Plaza Honda in Brooklyn, NY quoted me a price of $750 for the timing belt/water pump job. South Shore Honda quoted me $695. Dont these prices seem quite?
Can anyone recommend a quality shop in the NYC area? To me, $750 seems like borderline sodomy.
thanks in advance.
ABS Grunts When Doing a Self-CheckNOTE: This article applies to ’98–04 Accords, ’96–04 Civics, ’97–04 CR-Vs, ’00–04 Insights, ’98–04 Odysseys, ’03–04 Pilots, and ’00–04 S2000s.
Are owners of vehicles with a “compact” ABS complaining of hearing a short grunt or groan when backing or moving the vehicle forward after its’s been sitting awhile? It could just be the ABS doing its self-check. A compact ABS has a modulator, a pump, and an accumulator all rolled into one. (Later model vehicles don’t even use an accumulator.) The system is designed to do a self-check when the vehicle reaches a speed of at least 7 mph either forward or backward after sitting. So the grunt is normal; it doesn’t mean there’s a problem with the ABS. On some models, you’ll even feel a vibration through the brake and accelerator pedals when you hear the noise.You can show your customer just how this ABS self-check works by connecting the Honda Diagnostic System (HDS) to the 16P data link connector, and running the ABS function test. (This test cycles the ABS solenoid and runs the ABS pump.) The noise from the test may be louder than the noise made by the actual ABS self-check, but it lets your customer hear the noise and helps you to determine if the noise is ABS-related or coming from another source.
I have 04 EXV6 with Navi.
The climate control is always in automatic mode.
Over the last few days, I started having the following problem - After the car is started, the climate control would not turn on. I have to switch to manual mode and then back to automatic to get it going.
Anyone else having this problem? Any ideas?
Seriously, the only thing I'd wonder about is whether the tires would flat-spot and thump a little when you first drove it again (if the weather was very cold). I think that's unlikely though.
I DID read a post once from someone who parked a hybrid electric vehicle for over a month and came back to battery problems that the manufacturer wouldn't take care of under warranty. Yikes. That's the only post like that I've ever seen though. Enjoy your trip.
One month isn't so long--think of all those unsold Saturn LS things that have been in dealers' inventories for months. They run OK after somebody eventually buys them......Richard
alcan, "Honda Accord Owners: Problems & Solutions" #8977, 12 Dec 2004 12:15 am
Make sure NOT to have anyone start it up while you are away. That would just be an invitation for a weakened battery if the vehicle isn't driven enough to recharge the battery after the start (probably at least five or ten miles).
Does anyone know how to disable this "feature"?
There is an extremely simple fix for your problem. It does not require any disablement of the "all window roll-down" feature designed into your Accord.
When you unlock your driver's door, just press the unlock button on your remote control BRIEFLY once. Don't HOLD it down. If you want to open all doors, press the unlock button on your remote control BRIEFLY twice. Don't HOLD it down.
If you don't want to use the "all window roll-down" feature, just don't.
I agree with you. I too thought for sure that the sound was coming from inside above the driver's sunvisor. Driving with my nose on the steering wheel today, I could hear that the sound is actually coming from the A-pillar. I'm going to try lifting the seal on the windshield and lubricating it to see what happens.
Hopefully, Honda will generate a Technical Service Bulletin on this issue soon so that dealer service departments will know what to do.
I agree with the previous poster about not holding down the buttons. From my experience it is rather difficult to get all 4 windows to roll down accidentally. The amount of time required to hold down the button is significant enough that it can't be done just shifting around in your pants pocket or in your purse.
I have not heard of this feature being disabled.
You really don't like that feature???
Under normal driving conditions the engine suddenly stopped and the dash lit up like xmas! I turned the car off and it restarted as if nothing was wrong. Over the last 30 days the car has stalled at least once a day. No light show, just a sudden shut down. No idiot lights...nothing and for no apparent reason. I suspect electrical (maybe fuel pump or ignition module). I reviewed most of this forum and found several similar posts but, with no apparent solutions. The car usually starts right up as if nothing was wrong once I reset the ingnition to "off" then "restart". ANY SUGGESTIONS? 99 Accord 4cyl AT 42k miles
If the stalls are at idle, I'd recommend increasing the idle speed slightly. If it's too low, the engine won't be able to recover from an ignition stumble.
On the other hand, if this is happening when you're driving at speed, then I'd be looking at spark plugs, plug wires, and fuel filter first. Also, Discount Auto Parts will pull trouble codes from your car's computer for free (if any codes are present).
Has anyone else out there had a similar experience, and any "solutions"? The dealer told me that if they were to cushion the area with foam, for example, that that would be considered interfering with safety (horn system), and would not be allowed (i.e. 'illegal move'). Very frustrating on new car!!! Let alone 'top of the line, luxury model' Honda! Any thoughts, ideas, empathy, would be appreciated. Thanks.
I drove an 03 Buick Century recently (company fleet) and the brakes were so smooth! My Accord's breaks should not have this annoying problem. Every thing else about my accord is perfect - but the brakes get on my nerves. Any tips?
My wife did lots of driving yesterday, no noise. Hope this information helps.
Is it a blown fuse or something else? How can I fix this?
Post 8945 suggests adjusting the calipers, in case they're not fully releasing when you let off the brakes. Subsequent posts, however, expressed some skepticism about that solution.
I got rid of my 03 Accord due to the recurring brake problems, but I didn't try the aftermarket solution or caliper adjustment mentioned here. I simply lost confidence in the brake system and felt it would be better to move on.
You may find that one of the solutions mentioned here solves your problem though.
If this is being handled as a warranty issue, until the car is out of warranty I'd keep going back to Honda again and again. Out of warranty, I'd have a trusted independent shop put on aftermarket rotors and pads with a 12-month/12,000-mile warranty and see what develops.
The car stalls while accelerating, steady speed and deceleration. I thought the recall of the ignition switch may have something to do with it, I have not had that done yet. Car is in a body shop at the moment. After I get it back, I will get the switch replaced before I start hunting other possible causes. Your idea of going to discount parts for trouble codes is a good suggestion. Thanks.
I really wish I could get this feature disabled - I live in the Pacific Northwest, where it's rainy lots of the time. I assume the only advantage to this feature is being able to vent the car before you get in it?
Your car can learn to read up to three remote transmitters and it's easy to program (although entering the car into program mode erases all learned codes and you have to learn all your transmitters, new and old, at the same time).
I search the Honda forum here, over 2 millions according to the quiry, but didn't find anything resemble my problem. So I figure I post the question here and see if anyone can offer useful insights.
Thanks in advance for the help...
