Dodge Intrepid Problems
                    I have a '95 Intrepid ES which looks good and runs
good.....most of the time. I have heard and read
of others with this car having certain recurring
problems and I think I'm one of that
"crowd"-----rotors needed to be re-surfaced twice
and only 60K miles (mostly highway); water pump
failure at 36K miles (just past 3 year warranty
time limit); etc. I know the auto trans in this
car is also on the watch list.
Now, today, and twice in the past 4 days, my car
has died after being driven for 20-30 minutes in
warm weather. Main problem-----it stalls out and
either won't re-start (cranking ok) or after
starting roughly, it won't idle in park or let you
get into gear before dying. This morning, my poor
wife almost got rammed on a major highway in the
Phila. area as she limped to the shoulder.
The car is at the dealer now being diagnosed and
I'm looking for some similar experiences....help!
I hope it's not the fuel pump as I understand they
are very expensive for this model.....any comments
or suggested fixes???
Go to autotrader.com
click on "find your car now"
click on one of the '94 Intrepids for sale to open up the ad
click on "more about this car"
click on "model info"
click on "recalls" on the grey sidebar
click on the recall named "electrical system"
It sounds exactly like your problem and you may be able to contact Chrysler and complain enough until they fix it. Good luck!
Do any of you have any thoughts for dnebb?#0 of 0: (dnebb) Mon 03 Jul '00 (06:15 PM)
I'm having a problem with severe vibration in the steering wheel of my 1999 Dodge Intrepid. I've been told that Chrysler has acknowledged there is a problem but I can't find it documented anywhere. The Dealer says it's caused by defective tires - The Goodyear Dealer says there's nothing wrong with the tires. The problem showed up at 12K miles and I've had it in twice for servicing. Gotten nothing but the run around.
Does anyone have information?
Pat
The dealer changed the front brake rotors to fix this.
They know very well by now that they have a problem with vibrations caused mainly by alignment and or tires. If your car came equipped with the Goodyears and they are still original then it is Chrysler's problem. Don't let up on them until it is resolved.
If the dealer doesn't give any satisfaction, you should call the area rep you probably could find the number at the following site. www.4adodge.com
Pat
Pat
Does anyone have any advice for esj1?#0 of 1: (esj1) Sun 09 Jul '00 (04:17 PM)
I've got a 96 Dodge Intrepid. While having the engine oil serviced at a Lube Shop, the plastic handle broke off the dipstick and the stick is stuck in the tube. The mechanic has said this is common (his experience) with the Intrepid. Has anyone had this problem?, How do they resolve it?
Pat
I hope this is covered by the warrenty. On a closing note this is the second time I have purchased an American automobile and will probably be my last.
We also had a problem with the car not being able to go over 35 mph. Dodge fixed it, but kept the car for two weeks.
left interior push light bulb has blown. Does
anyone know if this is a big deal to replace?
Will Dodge try to rip me off to replace the bulb?
"In October 1998, we purchased a Dodge Intrepid from your dealership. Since that time it has been in your department about six times within the last six months. This letter is to let you know of our total dissatisfaction, with the car itself and quality of workmanship from the service department.
For air conditioning alone, it has been in for repairs five tomes and we continue to have the same problems. AC only works when the blower is on high. A new motor and/or compressor is now in stock, and scheduled to be installed, but this has not taken care of the problem for longer than one week's time in the past.
Our back door lock has been previously repaired as well, and it works only about 10% of the time."
Etc.................
Since this letter, we finally did get the problems fixed, but I hate the car! The outside paint is also pealing around the windows!!!!!!!!!
We are in the process of buying a different car.
The Shift-Cable (linkage) on my '99 Intrepid w/37K
miles became VERY STIFF & BALKY, overnight,
without prior symptoms. I had to use significant
FORCE to get the car in (any) gear. Dealer would
not cover under 3-YR/36K warranty, it cost me $200 to fix. I spoke with the service technician, who told me that he's seen a 'few' of these 'go bad' on Intrepids -- but he could not tell me why. I have the old 'worn' part -- I plan to FIND OUT what happened, and why. The old cable appears undamaged, and may have only needed lubrication (?).
This is ridiculous -- I've owned lots of cars, and NEVER had a Shift-Cable or any other transmission LINKAGE part 'go bad', EVER, especially not while the car sat in the garage overnight, especially a 'pampered' car with only 37K miles.
For Sherlock Holmes types out there, a couple of
facts might prove interesting:
1) I washed the car, including an underbody flush
with my electric (non-nuclear) pressure washer,
before parking the car in the garage, where the
Intrepid sat unused, over a long weekend.
2) Unused (see above), except that my 14-year old
'sat' in the car with his friends 'listening to
CD's', at least once during this weekend ('honest,
Dad, we never touched the shift-lever' . . .).
Regardless, I'm angry that the dealer refuses to
cover under new-car warranty, and I'm curious --
if the dealer service tech has 'seen a few' of these (failures), HOW MANY OTHERS out there have failed?
Concurrent with the transmission shift-cable
failure, I noticed a VERY FAINT 'tin-cans-rattling' SOUND, a 'brief' sound (from somewhere under the car, front-end), that occurs only when I touch the accelerator, to maintain a steady 'parkway' speed of 25MPH. I can hear this when the windows are down, while driving very slowly -- it's a faint noise. RELATED ???
Has anyone else out there experienced this
problem? If so, how was it resolved? Thanks.
Pat
1) I don't know what state you live in, but if your state requires regular safety inspections, go talk to a licensed inspector. In many cases, the moisture inside your headlight assembly can corrode the light socket, cloud the reflective material, discolor the lens, and thus lower the candlepower output to the point that the headlights do not shine brightly enough. Therefore, this is a SAFETY related problem, not just a cosmetic one. Talk with a licensed inspector, he will probably agree. My 89 Eagle Premier had the same problem, and it discolored the lenses so badly that I had to replace them to pass VA safety inspection.
2) I have seen some mechanics drill a couple of SMALL weep holes in an area that is both not visible and not subject to the entrance of moisture. They then use an air hose to blow out the existing moisture. (CAUTION) Speak to a licensed inspector before you attempt or have anyone attempt this. It may be an illegal procedure in your state.
Maybe if you pose the question to your SM as a safety issue, along with the advice from an inspector, it may push them to correct the problem properly, instead of telling you it's "cosmetic". Besides, your warranty is 3-36 Bumper to Bumper. The headlights are, afterall, between the bumpers!
I have a good friend who happens to be employed by Mobil/Exxon in their, of all things, chemical analysis lab. I'll post the results when I get them and probably forward same to the NHTSA
My Intrepid punished me in all the "usual" areas, including transmission, water pump, fuel rail, front end, etc. The worst was the A/C problems. The intermittent problem described by marimik was an early problem that I had. I thought it was a relay since shutting down and restarting the engine brought back air for awhile. Problem turned out to be a transducer. Dealer replaced and the AC worked for awhile. Next was evaporator, discharge hose leaks, compressor, then condensor. $1200 in all. Ironically, my Intrepid, which, by the way, was a great driving car, and very comfortable, started costing big bucks in repair after I finished paying off the 4 year loan, about 60,000 miles. My average monthly costs for the duration of ownership exceeded my earlier monthly payments! There apeared to be no end to the costly repairs. I finally decided to throw in the towel and buy a car that is relatively immune to gross depreciation and maintenance problems...a Honda! Trade in price was a joke. Independant used car dealers don't want LH cars because the lemon law in NY state costs them too much in warranty costs. New car dealers offer $1500 to $2000 below Edmunds trade price. I had 81,000 miles, sold the car for $4800, and cut my loses.
My recommendation to others is to do the same. Good luck.
If I turn the fan off, then I turn it back to high, it sounds as if the air is going to blow hard, but then it backs off again to near nothing. Turning the fan off for a while seems to fix it.
The GM full size cars are OK for the most part and the power/gas mileage is pretty good but I like the Intrepid.
All of my associates have the same type vehicle and report the same experiences,for the most part.
At 60040 mi. this car has had its first real service other than the work prescribed in the owners manual maintenance schedule.It received its first set of brakes,front and back. They cut the front rotors because it is a good thing to do and the vehicle management company didn't approve of new rotors.
Early on the '99s Check Engine light would come on due to "a bad gas cap seal".Never a problem with engine,trans,A/C,wipers,windows but Goodyears "best" were quite worn and hydroplaning like crazy after only 30,00 mi. A new set of Goodyears other"best" solved the problem.
Regular maintenance,oil change every 3,000 mi.,dealer service as per the manual etc... is the key as has been the case with my own private vehicle('95 Voyager with 0 problems other than a bum rear wiper motor in its 126,000 mi.)and other non-Chrysler vehicles,15 in all. Maybe I'm just lucky but I'll choose and Intrepid over any of the vehicles in the same "full size"class.
found what is called a FAULT. A fault is something
that the computer sees as not being in its normal
range. A bad sensor will cause a fault . When the
light comes on your best bet would be to take your
car in to have the computer read and the fault
repaired. Fault's are stored in the computers memory
The last time I had the check engine warning the dealer found a vacuum leak, and a complete different problem from what the computer indicated.. At least thats what the sm told me, I'm certainly not a mechanic, no reason to question him on that.
the transmission has been replaced twice, the paint is falling off the car and it has left me stranded at least 30 times since I purchased it. Unbelievable. I also have a '94 Camry with the same number of miles...the only thing I have done to it is change the oil and buy new tires. I am on my way to trade in my Intrepid for a Camry because I couldn't imagine selling it outright to anybody-- I will NEVER purchase another American car
Stick to maintenance or repair issues that you are having, or can assist with, on the Intrepid.
Please review your (recently revised) Participant Agreement, paying particular attention to the section on "Contributions and Participant Conduct."
It appears that this dispute has been carried over from somewhere else. Leave it out of this topic.
Pat
