Subaru Legacy/Outback
12467230
  • originalbitmanoriginalbitman Member Posts: 920
    John -
    BTW, we were looking at Volvo V70s when we rented an OB. But we ended up with the GT as we really didn't need the ground clearance, liked the handling better, and wanted the dual moonroofs. No regrets. Fun to drive and stands out from all the OBs out there.
    bit
  • Hi Juice me again well I finally touched base with Darlene thanks to your perserverance with info. Thanks a lot I spoke to her and got the info. I wanted I said hi from you, incidently she still sounds dreadful like she has come back too soon. She did apologise for not responding to my emails but did explain that when she is not there nobody picks up the slack. anyway no big problem especially when people like you will go the extra yard to help.
    Thanks again from Pat. I can assure you if I can be of any help to anyone on these posts I will jump right in.
  • j_walkerj_walker Member Posts: 99
    Maybe the GT is something I should really consider. I wish the GT had the H-6. Perhaps next year which is when I plan to make the purchase. Hmmm. So many choices.
    John
    bit: actually, both have 4.11 final drives. It's the GT's tires that are 7% smaller in diameter, making it a bit quicker.
    John: drive one and see. They're fun. An H6 would be heaven. So would a turbo.
    -juice
  • francophilefrancophile Member Posts: 667
    would be TWO turbos.
    Cheers,
    -wdb
  • c_hunterc_hunter Member Posts: 4,487
    I also overlooked the GT while shopping for an OB. My progression was Forester --> OB. It never even occurred to me that a GT was more inline with my tastes. I'm very happy with my OB, but would get a GT next time around. If Subaru drops the H6 into the GT wagon with a 5-spd, I'll be there!!
    Craig
  • donjacdonjac Member Posts: 3
    Given that forward visibility is improved by higher driver seating position, is there more than only a one inch difference between GT and OB?Or do you sit even higher than that in OB for some other reason? Which car with stick is better for city and freeway driving? And what are the odds for side-bags in 2002 for GT and OB standard wagons? I am a newcomer and really enjoy your board.
    I checked Subaru's web site for some numbers.
    --Wagons--
    Height, GT/OB: 59.6/63.3
    Ground clearance, GT/OB: 6.3/7.3
    Front headroom, GT/OB: 38.5/38.5
    (For the headroom #'s I used OB Ltd. because it and the GT both have the moonroofs. Overall height was reported to be the same for all Outback wagons.)
    So! An inch more ground clearance, undoubtedly due to the difference in tires. And yet the overall height difference is 3.7". Because the interior headroom is the same in the GT and OB Ltd., that means the difference is either suspension height or... blast, that's right, roof rails. Who knows how much effect they have on overall height? It's probably not 3.7", so my guess is that the differerence is in the suspension, and therefore the driver of an OB will sit roughly 3.7" higher than the driver of a GT. No wonder the GT handles so much better ;-)
    Cheers,
    -wdb
    wdb: right on!
    Craig: dealers seem to have to few, you can't even blame customers. You could even say the same about certain models with 5 speeds.
    Actually, the tires make up 0.88" of that, and taller springs make up the rest.
    The seat itself may be mounted on tracks that set it higher. Anyone know for sure?
    -juice
    If the seat was higher then interior headroom numbers would show it. They don't.
    Cheers,
    -wdb
    Good point. So we have taller tire sidewalls and taller springs that make up that inch difference.
    FWIW, the Forester's seat isn't that high either. SUV shoppers actually find that's a nit they like to pick, though I prefer the more stable seating position it has.
    -juice
  • barresa11barresa11 Member Posts: 277
    I tend to capitalize on the height advantage for visibility w/my OB vs the GT by setting the power seat setting a little higher on the toosh area w/o comprising my headroom too much. Just a thought. I enjoy the advantage of heightened visibility w/my OB vs the better handling of the GT. I also like the increased ground clearance. We have a lot of hills to go up and down on in Seattle. I was forever scraping the front air dam on my Acura Integra w/its lower clearance. I won't even go into the ground clearance advantage for my off-roading forays.
    Stephen
  • tlbistlbis Member Posts: 25
    Don, If you don't want the sunroof/moonroof and opt for the standard OB or L Wagon, you gain 2 inches in the headroom dept. Not sure about side air bags in 2002. I have driven both the GT & OB and did'nt notice any difference in shifting. However, most posters here feel the GT handles slightly better than the OB. Happy shopping!
    Stephen, I had an Integra as well. Always had to be careful when parking in a spot with a curb.....
    Reminds me of our Miata. I have to slow down a lot for speed bumps. Heck, I have to pull in to my driveway slowly!
    The Forester plows right through at twice the speed with less drama.
    -juice
  • armac13armac13 Member Posts: 1,129
    I'm often amused by some of the tricked out Hondas and BMWs on our campus. Many of them scrape their bottoms on the speed bumps, the ones Rufus totally ignores. At least they *look* like they go fast! ;-)
    Ross
    Speed bumps? What speed bumps?
    -juice
    Juice,
    Is hard to remind yourself that you have to slow down for some dips (indentations, not other drivers) w/the Miata vs the Forester? I drive my housemates Camry once in awhile and sometimes I forget....but don't tell him! :-)
    Stephen
  • nematodenematode Member Posts: 448
    so I messed around with the tire pressure on my wifes OB Ltd. a couple of days ago. Perhaps some of you guys may have already tried this. For driving in snow 33 front /32 rear is too high for the Firestones. You can acually quite a bit of wheel spin at that pressure. I use the higher pressure most of the time because I dont like the "floating" the OB does. If there is heavy rain I always dropped it to 30F/29R.
    For something new to do...When it snowed I dropped it to 27 front / 26 rear and drove around in the mud/snow and the difference was huge. I know most people depressure for sand but it make a big difference in the mud/snow too. I would not drive on the highway with it that low but its pretty cool in the mush.
    Only problem....I did not get the car washed (remove mud) before my wife got home. She is still a little upset about that.....ooops.
    Thanks for the numbers explaining the difference in height. I think I'm getting closer to the right car for the money!
    Stephen: it's bad. I bottom out all the time with the Miata. It's really a completely different experience, but you do feel every bump. It's hard to believe people actually lower these things!
    nematode: take any muddy photos? :)
    Just remember to air back up, and don't drive on pavement with low pressure (29psi and up is good).
    -juice
  • ddgtmddgtm Member Posts: 1
    anybody. I'm just starting my comparison shopping between the Legacy and the OB. I'm never going off-road. Why would I want to spend the extra $$$ for the OB. I want a wagon primarily for the all-wheel drive and carrying lots of stuff. The new OB has the V-6. Is it worth it?
  • subearusubearu Member Posts: 3,613
    ddgtm: Sounds like you're a perfect candidate for a Legacy wagon. Since the Legacy only comes with the 4 cyl right now, many have suggested the 5 speed tranny as a way of bringing out the best of that engine. It really makes for a 'sleeper' wagon. Take one for a drive; you'll probably end up driving one home that night!
    One plus for the Outback: heated seats. This comes in the All Weather Package, which includes heated mirrors and the heated wiper area of the windshield.
    -brian/subearu
  • mrglickmrglick Member Posts: 19
    Has anybody heard any recent announcements concerning Subaru recalls?
    -Glick
    I have posted this so many times I guess it is getting old.... but, we went looking for a Volvo V70, rented and OB for a weekend and ended up with a Legacy GT wagon and love it. Just like you we didn't need the extra ground clearance just wanted a nice wagon. Get the 5 speed.
    Here's a nice review of the GT wagon:
    http://www.epinions.com/auto-review-7412-BACE6BB-39C393E8-prod1
    bit
  • grahampetersgrahampeters Member Posts: 1,786
    http://townhall-talk.edmunds.com/engaged/edmund.cgi?c=Clubs&t=36&q=111-
    This link has the full details on the recall.
    Cheers
    Graham
  • jagsfanjagsfan Member Posts: 2
    Any thoughts about a single female in her 30s purchasing the Outback Ltd?
    I'm an SUV lover who can't find any good options in the mini-utes. I really like the Mazda Tribute but am concerned about the reliability since it's a first-year model that already has had 5 recalls.
    The Outback Ltd has the higher clearance and rugged looks that I want (although the SUVs are still better), but my concern is buying a station wagon. Is it too much of a family car? Are there other singles out there with the Outback?
    With all due respect, it sounds like you're more interested in image, rather than the vehicle itself.
    If you can put the (debatable) "mom/dad-mobile" image aside, I think you will find an excellent automobile in the Outback, or any Subaru wagon for that matter.
    Have you considered a Forester? It's more SUVish than the Outback. It's also a bit more nimble and quicker than the H-4 Outback. The Outback H-6 is quicker, however.
    Another suggestion is the Legacy GT sedan or wagon. Its image is a bit more "Euro" than the Outbacks or Foresters. It also drives more "Euro" too.
    Bob
    I just purchased a 2001 OB lmtd. It's a tremendous car. I don't feel the stigma of driving a wagon. And the Lmtd is fully equipped. I would have considered the H-6 versions however:
    1- H6 does not come in manual tranny.
    (I must have a stick)
    2- first year model was a concern.
    3- I thought with all the OB Lmtd had to offer, that H-6's are a bit pricy.
    This is my 2nd outback, they are great & fun.
    Good luck!
    -Glick
    Even though I'm really not single anymore, I think the OB is definitely a "cool" enough car for a swinging single person who actively seeks excitement and moves with the latest trends. It rained a lot today, and I went tearing down a muddy road in my OB and had loads of fun. Couldn't stop giggling with excitement, in fact. My girlfriend almost peed in her pants. Certainly not something you would do in a regular old station wagon.
    From my driving perspective (previous car was a Honda Prelude), the Outback rocks! I actually think most SUVs are as exciting to drive as a granny-mobile, and wouldn't be caught dead in one. This notion was confirmed when I test drove an XTerra, supposedly the most butch SUV out there for those of us in the active set. It has all the driving dynamics of a pickup truck, which is to say, NONE. Same goes for the other SUVs I drove. The OB (and Forester) are actually cooler in my opinion, just because they handle and drive so much better than the typical SUV.
    I agree with Bob, check out the Forester -- it handles even better than the OB, and is a tad faster. Looks a little sportier too.
    Don't worry about the wagon image, just concentrate on the driving experience. From my driver's seat, the OB (and Forester) are loads of fun!
    Craig
  • ins23ins23 Member Posts: 17
    I just returned from my 1st 300+ miles H6 L.L.Bean trip to cross country skiing (from S.F. Bay Area to Bear Valley). It’s fairly short trip going from 0 to 7000 ft. elevation in about 100 miles (and another 100 miles back), so it’s mostly in mountains.
    Car is fantastic.
    Cons:
    - Soundproofing of $40K+ car
    - Athletic suspension (supple but controllable)
    - Amenities (everything is heated).
    Pros:
    - lumbar support isn’t sufficient (is it really so hard to make this simple device effective?)
    - auto climate control. It simple refuses to maintain desired temperature. It continually blows cold air when set to 84F with outside temperature is 32F :-) I hope it’s simply broken and I’ll fix it next visit to dealer. If it’s a design flaw, it’s perfect example for ASAP manufacture recall.
    I made few accelerations from 65 MPH to 95 MPH and H6 felt impressively strong. It hit ~5800 RPM only once when I was executing the same maneuver uphill at about 4000ft (I had 2 adults + kid + luggage).
    Nikita.
    Thanks for the H6 report! We've been getting a lot of driving impressions from dealer drives but too few from actual owners out there on actual roads. Thanks for sharing.
    I found it interesting that you didn't mention the power dropping off at altitude, something that gets mentioned in regards to the H4. The climate control complaint has been heard several times before, so I wouldn't be surprised if it eventually becomes a recall. Let us know what was wrong and how they fixed it! Oh, and "pro" means "good" .
    Cheers,
    -wdb
  • tauyeungtauyeung Member Posts: 12
    In response to C Hunter's comments, I think the OB is a great looking car. However, the GT is even more sporty looking. It has the lowest clearance (no outback driving!), big alloy wheels and a uni-color body. All 2000-2001 GTs come with limited slip differential, too!
    I would have gotten a GT if the dealers didn't have 5-speed L's in stock.
    If you are *really* into looks, go to some aftermarket places to replace the air-dam/rear bumper and add side skirts. I accidentally found www.cobbtuning.com and they have all kinds of stuff to make your Subie look different (good or bad is subjective).
    Haven said all that about looks, has anyone tried to double-clutch and toe-and-heel on a Legacy? Double-clutching should work on all 5-speeds anyway. Turns out the Legacy padels are also set up for toe-and-heel shifting. It works even for my tiny 7 1/2 sized feet ;).
    I do agree with most posters about the lack of H6 with 5-speed. *Sigh*!
    --Tak
    Yeah, I agree that the GT is an even better and better looking) choice if you want a sport-wagon, but I think Jagsfan was trying to decide between an Outback and an SUV, and trying to avoid the wagon image. Car and Driver (April 2000) put it well when they said they liked the GT wagon better than an Outback, but they thoroughly endorse the OB if it detours would-be SUV shoppers. These are the shoppers who would probably not consider the GT.
    As a sport-wagon, the GT wins hands down. For a sport-utility-wagon, the Outback (or Forester) is the way to go.
    Craig
    sorry for flipping around pros. and cons. in post#188 ;-)
    Probably I was too tired after the trip.
    Nikita.
  • HI Juice I need to pick your brain again. DO YOU know if qsubaru has a web site with on line catalogue with parts and prices if so I would appreciate you giving me the site address,I tried qsubaru.com but nothing but then I am not very computer literate so I am not surprised.
    Thanks again.
    Pat.
    pat,
    the url is http://www.qsubaru.homepage.com/.
    Site has some parts and pricing but no full catalogue of parts and prices.
    Tom
  • Hi Tom just want to say thanks for posting the info on qsubaru site, always amazed at quickly one gets a response on these posts, anyway I will just log in and see what they have.
    Thanks again Pat.
  • andytandyt Member Posts: 10
    Sorry if this question gets posted twice. It seems to have gotten lost in the mail the first time.
    It has been a while since I checked out the postings here, so I only checked the last 195 of them. I am wondering is anyone has noticed the following noises in their Y2K OB's.
    - Creaky suspension. Especially in cold weather.
    - Creaky seats. Again, this may be a cold weather phenomenon.
    - Squeaky brakes. I think this is a Subaru feature. If anyone can confirm that it would be appreciated.
    -andyt.
  • mmmsmmms Member Posts: 25
    I have decided to get an Outback, but I was wondering if anyone knows of any available Super/Turbocharging for the H-4?
    Click here to see a post in the Subaru Crew - Modifications forum that's filled with links to Subie mods.
    Cheers,
    -wdb
    Plenty of forced induction options. There was even a group buy on turbos in i Club. $2 grand for a full package, I believe.
    Andy: I'd ask a dealer to look at those. Your sway bars may need some lithium grease, front and back, on the bushings.
    First I've heard of seats making noise, but have a dealer check and lube if needed. Brake pads can be scuffed if they are glazed. You have a 12k miles adjustment period, so ask them to look at these issues.
    Darlene's site has a sample of Subaru OE goodies, but she carries everything Subaru offers. Touch-up paint, filters, wheels, accessories, and even clothing.
    David: no off road? Legacy L or GT. If you can afford the GT, it handles really nice and comes with nice wheels and a moonroof.
    Jagsfan: I think the OB has a pretty good image. It's very recognizable and popular. My dad has one and loves it.
    Still, if you think it's too wagony, or doesn't have enough power, check out the smaller, lighter Forester. It's short wheel base makes it fairly nimble and it looks more "trucky" withouth the penalties that come with actually being a truck.
    The Forester S Premium has heated seats, huge moonroof, alloys, and a nice monotone look. The OB LTD is similarly nice.
    Happy shopping.
    -juice
    Hey a fellow Y2K owner! We have the Y2K Ltd.
    Creaky suspension: Nope. Ours is dead silent there. You can hear the keys gingle when you are driving and at low speeds thats all you hear. At highway speed (70mph) its mostly wind noise from the mirrors. Over bumps you can hear the suspension give but no other noises. I see that juice suggested the same cure I would have so I can officially second that.
    Creaky seats: Nope. I have complaints about the height of the passenger seat (its too low) and about the lumbar adjustment (its not very useful) on the drivers side but no noises to date. Do you have the leather seats or the cloth?
    Squeaky brakes: Yup. When cold, ours will sqeak for a few stops and then go away.
    Do you have the ticking noise from the dash when you use the defroster on cold days? He have that.
    I still dont have any significant complaints about the car. Lots of minor ones but nothing major.
    Nematode - I have a '01 OB and I hear it in all settings, not just the defroster mode. I notice it (I define it as a popping noise) for the first few minutes and then goes away. I'm going to have my dealer check it out when I take it in for the recall....
    Tom
    The ticking noise is gone by the time we get to the dealer. Its gone in 5min and the nearest dealer is 15min away. The only way they would get to hear the noise is if we left it there on a cold night and they start it first thing in the AM. Our problems with that are:
    1) When your other car (my car) is a 11 year old Ford Taurus...my wife is not too keen on leaving her OB anywhere in the winter when we (commute together) need it.
    2) I'm the only one in this family who cares about the ticking. My wife, friends, dog, and cats dont care at all.
    3) You can reproduce the ticking by pressing on the dash really hard so its probably do to heat expansion/contraction.
    4) All the OBs seem to do the same thing.
    I'm glad that you will have it looked at. Please post the dealers opnion/solution to the noise. After my Ford Contour nightmare I cant believe that I am complaining about a little ticking/popping noise.
    Little things can bug you... I know. My roof groan returned even after my "jam a piece of foam rubber in there" routine. Took it into to the dealer for a headliner pull and fix (hopefully) today. Of course it is cold and raining today and the cold contracted metal of the roof made the groan disappear. Felt like an idiot having the sr. service tech hold his ear against the roof as I tried to make it groan. But finally he heard it and agreed something was amiss. The service manager did say that creaks and groans are a 12k warranty thing... contradicting SOA CS who said it is 36k.
    I get my black Legacy dash pieces to replace the GT plastic wood today. Will post the install pics when I get a round to doing it.
    bit
    To clarify - there is a 12 month/12k mile "adjustment" period that covers things that aren't necessarily broken, and a 36 month/36k mile warranty for defects.
    Still, if you have issues, I'll put you in touch with someone at SoA and make sure you get taken care of.
    bit: in the Forester, at least, you start at the back of the center console and work forward.
    -juice
    It's a Legacy thing, not just an OB or wagon thing. My GT sedan does it. I think it's kind of cute. If you really, really want the dealer to tear your dashboard apart to fix it, that's your prerogative of course. But, like bit's groaning roof, you have to weigh the possible downside of having your car opened up far enough to fix it.
    Let us know how it goes!
    Cheers,
    -wdb
  • gatorbandgatorband Member Posts: 12
    Well it's been almost 2 mo. with the new subie & so far, overall, I've been really impressed. As for pros/cons/impressions at this point:
    CONS:
    1) One warranty repair to replace a leaky o-ring seal on the A/C system which caused it to not cool as it should. (after about 500 mi.)
    2) Gas mileage is not what I expected. Averaging 19-20mpg in hard city driving & 24mpg. in mixed city/highway driving. Have yet to take it on an extended "all highway" trip yet thought, so I'll reserve complete judgement till then.
    3) I wish that the ignition switch & door buttons were lit at night, as they are in the wife's Honda Accord. Also, the switch operations are backwards from the Honda, which takes getting used to. (up to lock, down to unlock vs. vice-versa in the Honda).
    4) The horn is a bit touchy. If you barely bump the edges of the wheel, you inadvertently beep at the guy in front of you!
    4) Leg room may be a tad tight in the rear seat with the front seats slid backwards completely & slightly reclined.
    PROS:
    1) Service at the dealer was outstanding (in/out in only a couple of hours), especially considering that I brought it in around 2pm. BTW, they also gave me a loaner car overnight when I had to leave it w/them (after work one nite) the week before to have the spoiler/sec. system installed the next morning. I plan on mentioning their excellent customer relations on my soon-to-be-completed company survey.
    2) I LOVE smooth ride, particularly on the highway, and good braking.
    3) The gated shifter -- it took some getting used to, but it really grows on you.
    4) Since it never rains in Fla. anymore (where's a good T-storm when I want one?), I had to resort to dirt/sandy roads to try out the AWD and I was VERY impressed. However, I must remember to plan these outings a little better next time, as it was too cold outside to wash it myself for 2 days afterward!
    5) I get TONS of looks/stares from other drivers and lots of compliments (particularly on the Wintergreen color) & questions, including the standard "how do you like your Subaru/AWD?" and "I've never seen one of those before, did you get it here?" It's great to be unique in an ocean of SUVs & mini-vans.
    BTW, JAGSFAN: Don't worry about the "image" you're afraid you might project if you drove a wagon. I live in Jacksonville and am proud to say that I have 2 single women in their 20's in my office that now think I have the coolest car in the building. (& one of them drives a Mazda Navajo (aka. Explorer) too!). I also, was originally looking at the Tribute before I got my OB and am so thrilled/relieved that I went with the Subaru. Go drive a Forester AND OB (make sure you drive each of them in both the 5spd & the Auto) and do your homework. It's worth the effort & I think you'll be impressed with the results.
    As for the ongoing 5spd/Auto debate: Yes, I agree that the 5spd has a little more pep from the starting gate than the Auto & may be a little more fun to drive because of it, but after driving in gridlock for the last 2mo. in my Auto after having standard transmissions my whole life, I'll probably never go back. Long/short of it: If you don't have gridlock/traffic issues, get the stick. If you do, save your leg cramps for other, more enjoyable, kinds of workouts.
    Stephen (SE)
    Thanks everyone for responding about the image of the Outback. Your comments are moving me closer and closer to purchasing a Wintergreen Outback Limited. I did try the Forester but I was far more impressed with the Outback, both for its looks and its handling. And, of course, you can't beat the room.
    Stephen: So you're in Jacksonville? As you can tell by my name, I'm a big Jaguars fan, although I live in the Northeast. Not a good year for us Jags fans but we've been spoiled...
    Has anyone been able to get invoice or close to invoice on a Limited?
    Stephen, since the EPA for your OB is 22 - 27 you are in the ball park for mpg. Actually your 24 mpg in mixed is pretty good (I've been getting 23 in mixed).
    Did you buy your OB from Subaru Regency? The owner also has a dealership in CT where I bought our '98. Good guy and gave us a good price.
    Jagsfan, where in the Northeast? Since we have so many dealerships up this way I find they have to give you a fair price just to compete. The only down side is if live and buy in New England you are subject to Subaru of New England pricing (not SOA) which is higher than the rest of the country. For example destination charge is $550 as opposed to $495 and I have found after looking at three dealer invoices the base OB is $50 more than what is listed at sites like KBB or Edmunds.
    So getting invoice or close to invoice in NE can be done. Just make sure you have the dealer show you their cost. Good luck with your purchase. Winter Green is a great color.
    Glick, I'm jealous. I was so close to going to Fitzgeralds myself. At the time, they were offering OB's $300 under invoice! My trade in was the deciding factor to stay local. Who knows, Fitsgeralds probably would have offered me the same price.
    Tom
