Visitor Agreement.
-mike
-juice
Or is that difference due to the difference in tire diameter?
-mike
The tire diameters to have an effect, too. If we use the L as a base line, the Outback is geared 5.4% shorter. But then its tires have 10% more diameter, so the net effect is about 4.6% taller gearing.
The GT is also geared 5.4% shorter, but its tires have just 2.7% more diameter, so it is effectively geared 2.7% shorter than the L.
So the GT is probably the quickest, while the Outback probably revs lowest at high speeds.
The L is lightest, so it probably falls inbetween the two, actually.
-juice
Matt
Cheers!
Paul
Patti
Patti,
A while back I had just made a quick call to SOA - I think I talked to the warranty dept. - I've got the classic 2 yr coverage. I don't even remember who I talked to - they just said they didn't have that kind in info...I was just curious... not a biggie Patti
I am wondering, though, if I should get the motor checked. Lot of lifter and main bearing noise until she's warm... got 75K on it... any sugg? - No oil loss, just concerned...
Matt
I have an '00 L 5sp wagon, and it runs at about 2700 rpm @ 60 mph. With the larger tires on the OB, I would expect the rpm's to be lower than 3500 for 5th gear.
Patti
It's harmless, though. Fresh oil quiets them a little.
Carl: sounds like you need the brake shim fix. You are the perfect candidate for it. The fix is trickling into dealerships.
-juice
-mike
Greg
-juice
Only "problem" with car so far (12K now)...
Under normal circumstances, engine speed at 60mph is about 2300rpm (overdrive with the torque converter in 'lockup'). This produces some strain on a steep, continuous grade such as NY Rt 17 at Wurtsboro Mountain. A fast 'lift and jab' at the accelerator pedal knocks it out of 'lockup' mode but keeps it in 4th gear. RPM jumps up to about 2800 and it pulls like nobody's business. Probably as well as my Camry V6 did in its day. Has anybody seen a Torque/Horsepower graph for this engine? I have only seen peak numbers published. Just curious.......
On the subject of valve noise, I pulled a steep climb immediately after a cold morning startup and was suprised at the amount of valve tappet noise. It diminished and went silent as soon as the engine temp rose (about 1-2 minutes). How is lash adjustment achieved on this engine? Hydraulic lifters or mechanical (shims or screw/nut)? I wonder how much free-play noise is considered normal....
Is there a better forum for asking technical questions?
Steve
An engineer from Fuji was in the USA last week and drove my car. After the car was consistently pinging he swapped computers with one he had in his briefcase. (Identical computer but with a different program). The pinging stopped and has not reappeared. Under speeds and driving conditions that previously resulted in heavy pinging now result in a few brief pings and then it immediately stops. You really need to be listening to detect these few brief pings.
The revised program is still undergoing final testing. Since the program mods do not impact vehicle emissions it does not need to be re-certified by the fed'l govt. The program should be available thru SoA in a few weeks for downloading onto ecm's of cars that are experiencing similar problems.
It sure is nice to finally be able to drive my OB with a quiet engine.
I'll also cross post this in the maintenance forum.
Vince
-juice
Took long trips over the last two weekends and now have over 4,200 miles on the 'Bean. I love it more and more the more I get to drive it. (Wife drives it most of the time). It sure is a smooth running car.
Paul in MN.
I just had the oil changed at Whitebear Subaru on Monday. I asked about the break squeal fix and he said they have the shims in stock to fix the problem.
--Jay
-juice
If your dealer says they have not heard of a fix, ask them to contact SOA or their Rep. The shims are available. I don't think a dealer would simply play dumb on purpose. Sometimes, the information does not get shared as quickly within a dealership. Let 'em know what you know and I'm sure they'd appreciate it.
Patti
Greg
-juice
Juice,
Thanks for the input. Most cars recommend the sequence you both indicated but I know of some manufactures (think VW is one of them) that has a different sequence. I called 3 Subaru dealers and two indicated the same sequence listed by juice but one indicated a cross pattern such as RR, LF, LR, RF. I installed speedbleeders on my car and forgot to monitor the break fluid level. It got too low and air entered the break line. I've put back the original bleeders and have bled the system 3 times now. The breaks still don't feel quite right which is why I wanted to verify the sequence. Since the Legacy uses ABS, I think there might be a bit more involved then just bleeding at the calipers. I've heard that you must also bleed at the master cylinder, i.e. break the hose connections. If anyone has done the additional bleeding at the master cylinder, could you please provide some guidance on this procedure. By the way, the car is safe to drive as the normal bleeding process has gotten almost all air out of the system. I just feel like there still might be a bit left as there is a noticable difference when I apply the breaks now then before I started all this.
Chuck
To OTIS123 - Agree, I guess one can refer to the noise as an added feature!
Chuck: wish I could help more. Haven't done any work on my brakes yet. Mine was recalled to replace the brake master cylinder, so they changed the fluid by default. IIRC I have only about 22k miles on the current fluid.
-juice
RPM: Wow!!! 3k rpm at 65? Our OB Ltd. (2000/auto) sees 3k rpm at 75mph. 85mph is close to 3500rpm. Even then the engine is pretty quiet. Wind noise is mostly what you hear. That (I think) is mostly from the really big side mirrors that I would not give up anyway.
My Mazda Protege ES 2.0 on the other hand is at 3500-4000rpm all the way to work at 70-80mph. Its a screamer but it does not seem to mind...I still get 27-28mpg.
Another strange thing is that both the Mazda Protege ES 2.0 (auto) and the Outback (auto) have similar EPA fuel economy ratings. The difference is that I can actually get 28mpg highway easily witht he Mazda even at 70-80mph for my daily commute. Driving the same way in the OB gets me 20mpg so I tend to drive it a little slower. Over the last year my fuel economy has even been dropping slowly. From 24mpg mostly highway to 22mpg driving the same way. In about a month its going in for its 30k so lets see if a combination of stuff helps it back to full strength.
Do you know what year/models were recalled on the break master cylinder.
chuck
I like the Protege5 lots, even test drove one recently. It's quite a bit smaller than the Outback, though. No fair comparing a 2.0l FWD compact with a 2.5l AWD mid-sizer.
-juice
-Eric
Do you just bring in the car for the computer replacement under warranty? Does SoA indicate the range of VINs for a free replacement?
--Tak
Vince
77mph @ 2750RPMs
XT6:
77mph @ 3100RPMs
both 4EATs
-mike
When I drive the Protege without visiting red line in 2 gears several times and drive 65mph on my way to work I get 33mpg (65mph constant, light foot). Driven the same way (with even ligher foot and closer to 60mph) the best the OB does is 24mpg. Usually in the Protege I take the long way to the highway so I can have the long on-ramp where I can bury it all the way to 80mph. Yea, its just so I can hear the engine rev. I just like the sound. Not as much fun as a muscle car but there is a nice little curve I can catch at 45mph on the ramp....now thats fun. Then usually I get off at an exit to get dougnut and, more importantly, so I can do the 0-80mph thing again. Still the Protege gets 27-28mpg and thats still going up. I dont drive the OB like that. If I did I would be lucky to be in the teens.
Really my commute is all highway and I commute off hours so there is little traffic. 25 miles highway and 2 miles back road. No stopping and starting and no sitting in traffic. Its really the most highway one can get in real-world commuting. So when I cant get what the ratings say it makes me cranky. The 89 Taurus I traded in with 157k was still getting 27mpg on the same ride. Right now we are only getting about 22mpg in the OB so it really needs to get checked out. Thats pretty bad. We are moving on the third dealer to resolve some of the issues that remain annoying.
The 626 does slightly worse, averaging about 22 or 23 mpg. It doesn't match the Forester in city or highway, really. While it is a V6, the Soob actually has 1 hp and 4 ft-lbs of torque advantage (165/162 vs. 164/160).
The 626 has more passenger room, but the Forester can haul about 4 times as much cargo as the sedan. The 626 is a bit quicker, but the short gearing that makes it quick also makes it consume more fuel.
If you compare AWD competitors, the Subies start to look better and better.
-juice
Still... it beats any SUV.
Ron
Should I call SoA again and discuss this as an option. The pinging drives me so crazy that I let my husband drive it to work daily and I drive his old honda civic.
Sharon
My Bridgestone Potenza's have worn down to the wear markers in only 15,000 miles and 15 months. Has anyone else experienced tire life so short?
Steve
I find the gear ratios evenly spread. First is low enough to tow 1500 lbs or get me around on the beach sand, while 5th puts the revs nice and low, for quiet and efficiency.
What I'd like to see is a 6 speed, then you could get the lower 1st and taller 6th without having the ratios spread too far apart.
Speak of the devil, here is Edmunds' preview of the next 626:
http://www.edmunds.com/reviews/preview/articles/47610/article.html
Looks good. The wagon is gorgeous, and may put additional pressure on Subaru. Even though AWD is not offered, Subaru used to pretty much have the wagon market to themselves.
219hp, 5 speed auto, side curtain air bags, ... this stuff is getting more and more common.
-juice
