Visitor Agreement.
-mike
I do recall hearing that the tweeter wires were preinstalled; maybe someone else can confirm. You should be able to use the tweeter wiring and all other speaker wiring with an aftermarket stereo. Probably not the best wire, but it should do.
Craig
-juice
http://www.jamawittman.org/matt.htm
Enjoy!
Matt
On something off subject, we had our VDC (frost white)installed with factory spoiler (wagon) however the color doesn't match right (a little darker than the rest of the car). Does anyone who has this option noticing this or just me? Can dealer repaint this or they should order another one.
Chat
Chat: did the dealer paint it in-house? Or was it painted at the factory? Lots of parts come primed black, and the shop paints them for you.
-juice
One thing though: they had to align my car twice because the first time they had specs for an '01 Outback Sport. As I was getting ready to pay, I noticed on the print-out and called to the manager's attention that under model they had "Impreza/Outback Sport (AWD)". He tried explaining to me that "sport" was the same car, just without the sunroof and leather (like mine). I bit my toungue, and politely suggested that we look at the available options together. Sure enough, there was another selection for "Legacy/Outback". Then the manager told me that he thought he heard me say my car was all wheel drive, and so they went with the AWD option because they "have to do what's in the computer" and the other one is for the "front wheel drive" models. I took a deep breath, called over the store manager and the technician with us, and we had a pow-wow on Subarus. Interestingly enough, the tech who made the error was the only one interested in learning about the different models. This is probably attributable to the fact that there are only a handful of Subarus in South Florida, but it might be worth confirming models with non-Subaru tech when having work like this performed.
Anyhow, thanks again for everyone's advice on this issue.
Pete.
Congrats on your new (to you) OB. Tell us about it. Miles, options, etc.
Pete.
-juice
Craig
Sten2 - The tweeter kit plugs straight in to the existing wiring which is tucked behind the little black triangle. It is a neat installation and the tweeters point right at your head which is how it should be; high frequency sounds are very directional. Personally I doubt that the quality of the wire makes much difference to a tweeter in a car. It is a low power device never far from the amplifier and anyway a car is hardly the perfect listening environment.
FYI, still looking for a couple more South Floridian Subaru owners! Please email me at soflasubaru@hotmail.com so I can try to organize a drive. Someone at the Miami autoshow told one of the product specialists about a gathering every Friday??? For the two others in the Ft Lauderdale area: ever heard of this?
Goose I do not know who installed your spoiler but it is installed wrong. no bolts should come through the second skin of the tailgate. all mounting bolts should be concealed between the double skins, this is why you had a bolt rubbing on the body it should not be there in the first place.
On the install after you remove some trim bits you use some existing holes for 2 of the mountings, you have to drill one hole right through both skins, you then enlarge the hole in the inside skin so that the bolt can pass through, there is a plug supplied with spoiler to cover this hole.
The other two holes are just drilled through the outside skin
Cheers Pat.
I wouldn't worry about off-roading with the 950s -- I don't think the OEM Wilderness tires are any more suited for off-road use than any other tire, and they've done OK in the limited off-roading I have done. The 950s would probably be fine, though you may want to take better care of them than the stock tires!
Speaking of the Outback GT, you should install beefier anti-sway bars -- that would really make a difference, and would help out those new tires quite a bit.
Craig
Outback GT? You mean Legacy GT, right?
-juice
I have to try to hook up with YellowBikeDon.. I'll look for him.
Pete.
mike k
By that I mean fatter sway bar, wider wheels and tires, custome intake, strut brace, sunroof, etc. So it's a Forester trying to be an RS! ;-)
-juice
-mike
Greg
-juice
Patti, can you clarify? IIRC, there was a "hold" on delivering White Frost spoilers last winter. Was there a problem matching the paint? I've noticed that while there are quite a few white H6 OBs, very few have spoilers. Is that why?
Thanks, Theo in Colo.
Do you or maybe someone else have installation intructions available to put on-line?
-mike
-juice
The reason I am asking this is that the tranny is my weak point on knowledge, so maybe I can learn something here.
Greg
As for downhill slopes, I belive that the 4eat tranny in the 00>02 subies has "grade logic" which will downshift to 3rd if it notices that you are gaining speed w/o having your foot on the gas pedal, basically signaling to the computer that you are going down a hill, and have your foot off the gas, this applies engine braking.
-mike
Noelle
Bob
Likewise, there are times when I hold the car (any car) in 3rd to hear the engine growl and enjoy the quicker response when threading through traffic on the freeway. Sometimes I will drop it to 2nd on the slower roads.
But getting back to the original question, I've never dropped down just to prevent the engine from lugging. I don't believe modern engines are susceptible to damage from lugging as were some 50's or 60's sports cars with, I think, roller bearings on the valve tappets. (Wasn't this discussed a few months ago?) My Bean has a charming little grumbly exhaust noise at around 1500 RPM in top gear that goes away if I let off the gas, and the transmission shifts down promptly if I give it a little more so I have no concerns that everything is working as it should.
I agree with Paisan that the mechanism will generate more heat by this practise, but am not sure of the extent, or how close this puts me to the design maximum of the box. Basically dropping to a lower gear will result in the input shaft, and perhaps intermediate gear clusters, rotating at a higher RPM. Higher speed = more friction = more heat. Also increased wear, decrease in life, etc.
But hey, most vehicles are designed with an operating margin above the norm, and probably includes a good bit of spirited driving too! The trick is choosing your vehicle and manufacturer carefully, and I believe in Subaru in this respect.
Happy Driving in Any Gear,
Steve
The way you described about the spoiler and that plastic pieces is exactly what we have. It's kind of bother me a bit, enough that I plan to mention it to the dealer when I bring in the car next week to have them check out the alignment
(for second time).
Thanks for your input,
Chat
This is probably how your bolt is wrongly installed, you can still correct it by drilling or filing the hole on the inside skin until the head of the bolt passes through then shorten the bolt and put two rubber plugs in the holes.
You are not supposed to see any bolts when the spoiler is installed Cheers Pat.
maybe that rally bread was "special rally bread"
-steve-v
ps kant zpel toooday
2.9% for 24 months
3.9% for 36 months
4.9% for 48 and 60 months
These rates are good until the end of December 2001, for all model lines except the Impreza.
Craig
The "Manual" button on older subarus allowed you to start the car off in 2nd or 3rd gear so that you wouldn't spin the rear wheels on ice or snow. The Limited slip differential works completly on it's own, w/o any buttons or levers. It senses slippage and moves power left or right. Kinda funny to hear a salesman put forth such fallacies.
-mike
-mike
Steve: a strut brace does not affect ride height. Steering, yes, handling, a little. They attach above the strut towers - you would have to get below those to change the ride height.
To affect that you can get lift kits, taller springs, shorter springs, or adjustable coilovers.
-juice
The explanation I got for this difference is that the paint lays differently on plastic and resin parts, to prove this if you look at the painted bumpers on most cars at cetain angles you will see a difference in colour.
Cheers Pat.
Anyone know where I can surf to for such a part?
Ralph
PS
Are the RE950s Firestones?
BTW, Subaru dropped the automatic transmission downhill downshift in 2000+ models due to customer feedback. I actually like it on my Honda...
-juice
Greg
Cheers Pat.
Second, what is to stop water getting in around the spoiler bolts and studs? There is no mention of a gasket.
By the way, if anyone is interested the 00 Legacy wagon bumper cover fits the 00 Outback wagon (there isn't one specifically for the Outback). It extends further back, protecting the top corner of the bumper that is not covered by the thin black coating that is already there. It doesn't look perfect because the coating shows at the ends. Another drawback is that it says "Legacy" on it. About a week after I stuck it on I saw a 98 or 99 Legacy Wagon with the apparently identical part stuck on its bumper...but this one said "Outback" on it. Looks like I should have got the pre-00 model year accessory instead. Duh!
Goose: I would use some silicone sealant or something around the bolt to water proof it.
-juice
mike k
As I said once in a while isn't a problem and it's not necessarily the driving it in 3rd thats a problem, it's the manually shifting an AT does a # on the bands and the TC.
Also when I auto-x I know ahead of time that I may be doing damage to my AT, I accept that, my car owes me nothing if it dies tomorrow. I'm just looking out for you guys, I know we all want to have a manumatic
I'd say my family overall has well over 300K+ miles driven on subie 4eat trannies.
-mike
