John: parts are simliar in cost to any import brand. The Outback and Legacy are made in Indiana so parts are sourced from there also. Stick with us and we'll point you to a handful of on-line wholesalers that have very reasonable parts prices.
Cheaper coffee than Audi, LOL! My dealer uses Maxwell House, but then again the last time I had to pay a visit was to buy my 2nd Subie! :-)
-juice
It's OK, because they always give me a loaner, so I never have to stick around for maintenance. But they sure must have some big coffee drinkers over there!
Extended warranties are all well and good, but don't cover you if you keep a car like I do and I kept the '85 Toyota Camry liftback for seventeen happy years and 198,000 miles. (Automatic transmission was starting to go, plus a wheel bearing.)
I think I only had one really expensive repair on the Camry, something to do with suspension, though not struts or shocks, which were still original when I traded it in. It was about $1000, I just can't remember what they called it though. It was around the 140K mark I think.
I think I had a brake repair, had to replace the fuel pump once, had to do some widget a couple years back to pass smog and had to get a wheel bolt replaced after it broke. The rest was maintenance, except for one thingie covered under a recall and one expensive (or would have been) engine repair covered under extended warranty.
So far, my Outback does not seem to have exhibited any problems at all, other than alignment, but I think they got that right or mostly so on the second try.
I am a happy camper so far with my car! But it's still very new with only 650 miles on it.
Cynthia
How about their service department. I's prefer to buy locally, but obviously want to get a good deal.
Romy
Grand High Poobah
The Fraternal Order of Procrastinators
I also regularly take the deflector off to clean and/or wax underneath. In the winter, I also remove it before washing our OB and hand wash and dry the deflector indoors.
Always wondered about when those rubber bumpons would lose their grip. Mine are still on strong after 1 1/2 years. I think removing/replacing it every so often also helps you identify if there are cracks forming or if the rubber bumpons are missing.
-Brian
I recently bought a new Legacy L wagon auto, my first Sub. Owned mostly toyotas and 1 ford(never again).
Now have about 3,800 kms on it and very happy. Dealer sales experience was excellent. Only one problem found , glove box light does not work, and no, it's not the bulb, so must be bad connection, etc. Otherwise no problems at all. Seats seemed hard on test drive but I'm happy with them, on 2 hour drives anyway. Wife's happy with the car too. Raced a chev blazer in the snow and I won, heh-heh. No problem here in Calgary in recent 1 ft snowstorm. RE92 tires seem really good in the snow and ice. Outbacks are really common here, but not many L's. I'll post more info as time goes on. Really good message board here folks!
watch out, once you start wearing off some of the tread those RE92s are the biggest piece of junk on snow! When almost new they are great, I have driven Des Moines- Chicago in snowstorm with all plows pulled off the interstate when I had only 1K miles on the car.Had to do same stupid thing a year later with Arctic Alpins on the same car and the new RE92s were pretty darn good in comparison to what has been touted as one of the better winter tires. Once the RE92s wear down they are positively dangerous on snow or ice or even water! I've had 3 Subes with RE92s as OE, my MO now is to let them wear to about half tread depth and run out quick to replace them with something else (have tried Pirelli P500,P4000, Michelin XGT Pilot - the Michelin wins by a long shot but you pay for it!).
Go to www.tires.com If you like in the North West then the Michelin Pilot XGT H4's are only $111 each for 225/60/16's or $102 for the L/GT/WRX. I love them and did a lot of research before choosing. I wanted a summer tire feel with all weather traction. They cost the same as other tires I looked at too.
P.S. Deal is now sealed in at $700 over invoice, plus I am not obligated to buy the GT unless I love it. It is being brought over from South Lake Tohoe today! Wish me luck, Heather
Heather
mike k
Greg
Greg
Greg
Greg
It sounds like the same pinion /ring gear problem described by trek2002 in #5529 and in #5518.
At the 3000 m oil change, Livermore, CA Subaru said that it was standard transmission noise. I was pretty sure they didn't try very hard to track it down.
Maybe a TSB is in order.
On another note, does anyone's OB pull slightly to the right ? The dealer says everything is in spec.
I did notice that the whistle stopped when above 80mph.
I will post to the other list all the details and description of repairs when car is finished
When I took it in to have my options installed, I told them again and they took it and had it aligned again, this time the results were much better!
Spec or no spec, I'd say go ahead and continue to agitate about this if it is a problem. BTW, I bought my car from Diablo Subaru in Walnut Creek. They seem very nice so far.
As far as whistle/whine, I've only had the car up to 70mph a couple times, no problem that I noticed. She only has 700+ miles, so I'm keeping the speed mostly under 65 during break-in.
What does Livermore Subaru charge for an oil change?
Cynthia
I doubt we'll swap speakers given we usually listen to kiddie music. It's bad enough as is! ;-)
Greg: I'll be interested to hear you impressions, given those Dunlops would be my choice for my wife's car once they need tires.
-juice
Livermore Subaru charges $30 for an oil change. The service was fine. I did ask them to check alignment and for the 60 mph acceleration whistle. They said adjusted the tire pressure which did seem to help but they said the whistle was normal.
I actually bought the car in Corte Madre.
chris
Later, in the right lane, it pulled a bit to the right. So I guess it's normal, but maybe a little more sensitive to crowned roads?
My Forester seems less sensitive, for whatever reason. And the wheelbase is shorter. Odd.
-juice
Subarus and popup campers came up the other day on the popup news group I follow. (alt.rv.pop-up-trailers)
one guy suggested a "Chalet" or "A Liner". I believe both of these have the A frame shape you mention. Colman, Rockwood and Jayco also make popups that are about 1500lbs or less.
After lots of discussion it came down to lighter is better and use trailer brakes. 200lb hitch weight and 2000lb trailer are MAX values.
On guy actually towed a 1950lb trailer with a OB sport and manual trans. He said it tows great. I'd say thats pushing it a bit.
I tow my Rockwood popup with my minivan. I think the Subaru waranty is void if you have problems when towing. (I think I saw that in my owners manual.)
-mike
I take the 5th!
-juice
Bob
What I don't get is why UK owners can tow 1800kg, almost double, with no trailer brakes.
-juice
I couldn't be more pleased!
Heather
Let me be the first to congratulate you! Woo-hoo! I am psyched for you!
Now carry a big stick to beat your hubby away if he tries to steal it from you. ;-)
-juice
What a nice car! The car was driven back to Chico from Tohoe by an old couple in their 70's. That was a big relief! They loved it and said it handled perfectly over the mountain roads. I was worried a 16 year old would race it home in first gear or something. The only gripe is the Dealer in Tohoe added silver pin stripes to Chewy. My husband hates them, but I don't. He wants them removed ASAP. Other then that is seems perfect to me. I will drive it all day today after they but on the Michelin Pilot tires and report back.
Heather
They advise if the parts are outside tolerance level just slightly this noise is heared between 60-80. They advised that they have already repaired another car with this sympton.
I will post final work order info when I receive it early next week.
Contact district service manager and have him check the work being done at Jim Burke.
Good Luck
This is something of a recurrent theme. Maybe we should figure out how to post these fixes to a single locked page where all the answers to the regular questions to the Subaru Crew can be posted.
The cause of wind noise in the Subaru, as with most vehicles, is imperfections in the surface over which the moving air passes. I had a Mercedes that sang impressively when I drove through moist air (fog or mist). Pitch varied with speed. It took ages to figure out that the mobile phone aerial was vibrating in the airflow and resonating across the roof.
The most obvious airflow problems for the Subaru are the roof racks, window areas and mirrors.
The general technique for detecting all of them is to search for imperfections, remove or mask them all and then progressively reintroduce the imperfections.
Put simply, take the roof bars off first and then put masking tape over each imperfection area. Drive the car at 60-75 mph and listen for noise. If it has disappeared, you are on the right track. Remove one piece of masking tape at a time until you find the problem. When localised, search for the solution.
The most common problem is around the mirrors. There appears to be some sort of gasket or seal between the fixed base and the movable mirror surround. If this is rotated backwards and forwards a few times, it seems to seat better.
Door/window seals are also a potential problem, particularly if, like me, you have assistance from a small helper (if he reaches 21 without killing himself, he will be an engineer). These fit into a channel in the frame and can be easily pulled out or twisted slightly out of alignment. If you run your fingers up each side of the seal where it fits in the channel, easing the rubber as you go, they should seat properly. If actually out of the channel, work them back in from the point where they are secure by slightly stretching the bead (that makes it thin enough to pop in) and then repeat until all reseated.
Door seals also can deform slightly over time from the continued pressure on them. Ideally, you should leave all windows and doors (and sunroof) wide open on a hot sunny day to allow the rubber to return to its natural shape.
Finally, the roof rack rails are frequently installed the wrong way around. If they are asymmetric, the fatter part of the bar should face forward. Think of how an aeroplane wing is rounded at the front but tapers at the rear.
If you have localised the problem but cant find fix, strategically applied furry tape can alter the air flow dramatically.
As a rule, there are actually fewer problems with frameless windows than framed ones. There is one fewer area for problems at each window join, halving the protential problem areas. In addition, the rubbers are actually thicker and squishier than for framed windows.
Hope that helps
Cheers
Graham
-steve-v
Cynthia
Chewie sounds like just the car for you and it's probably a good thing that hubbie hates the color!
Personally, I think the color you chose is great looking! And if your hubby likes silver (I can't fault him there, it's my favorite car color too.) then stay away from that, or he'll be driving YOUR car.
Have fun on those corners!
Cynthia
It was also nice after taking my car to the local coin hand wash that I had no worries stepping back into the car to drive it out of the stall, since one's feet are invariably wet after washing the car.
I'll try to take pix at some point and post, so folks who haven't seen these can take a peek. I am quite fond of the looks, they seem to really go with the Outback. Or maybe it's just me.
Cynthia
Eric
My advisor/tech have already said they repaired one OBW with this symptom not too long ago.
The tech looked at all the outside noise problems well before he considered the PB/GR replacement.
The cross bars were off the car and he had me press on all the windows during driving.
Will post the final outcome once the car is back home.
Enjoy the BBQ
For the rest of us who HAVE experienced wind noise, it's not mechanical. I get the whistle near the windshield only in high cross winds. Otherwise, the car is fine and quiet. The rare times when it happens, it is annoying.
Hope you are able to cure the problem and enjoy the car.
I am thinking of a performance muffler- but which one? Street legal of course. Is the Subaru performance muffler any good?
How about a cold air intake? K&N claims 30 more HP with it. That would be nice
Let's see... What else? I don't think I need a bigger sway bar since I took very hair pin turns at 60 (without the child in the car- shh!) And it clung to the road very well with only slight body roll.
And I do not want 17 or 18 inch wheels or summer tires, so forget about that mod for me. I don't want to drop in a turbo either. I did install a K&N air filter and she likes it. Just little things like that to give it a little more umph.
I am really enjoying my GT a lot! Sure it's only been 2 days so far, but she handles as good, if not better, then my OBS. I smile when I drive her. She reminds me of a sure footed nimble jack rabbit (and the same color too!) My husband hates the color and all the better for me since it insures Chewbacca is all MINE! Hee Hee!
I just figure with a little tuning she will be even better. But stock is great too! I love this car. She's getting her spoiler next week and a bumper guard. I took the rubber mat from the trade-in Outback. And my husband installed 3-way Pioneer speakers (TSA-1664) today that are FANTASTIC! Much better then Subaru "premium" ones.
I love the soft leather wheel and it feels more torquie (sp) then the Outbacks, although the engine is the same and the car weighs to same. What is that? Is it geared differently? She asks me to shift at 2500 RPMs, but I refuse. I shift at 3000 0r 3500 to get that extra power. She has a nice roar to her engine too.
Anyway, any suggestions would be very welcome. Please post all you mods to improve performance and handling. I am sure there are a lot fo things I can do that I have not thought of. Not things to decrease my gas mileage though please. Sport Compact Car magazine "Project WRX" after Stage 0 mods, the WRX now gets 10 MPG! No thanks.
Heather- a very happy GT owner- it's been a tough 8 weeks and husband is very happy with the L.L. Bean! So it worked out great for both of us- well except the the $$$!
The Subaru muffler adds 3hp or so, and isn't cheap. You might want to shop around for a Borla SS, you can probably get 5hp.
I looked at my wife's car, and the intake grabs air from the leading edge of the hood, so it ought to be cold (i.e. fresh, not engine bay air). I don't see a big need to change it, but a foam or gauze filter is re-usable and may give you 1-3hp realistically, since it's normally aspirated.
Another option is an underdrive pulley. They claim 5hp, but what you really get is better throttle response so you can blip the throttle and match revs when shifting.
Each mod has its trade-offs. Exhausts will likely make it louder. Intakes will be louder especially at WOT (wide-open throttle). The pulley has some owners complaining that the interior lights dim at idle, because they turn the accessories a little slower.
Keep her under 4000rpm until it breaks in, though. You do have gearing 7% shorter than the Outback, so yes it'll pull off the line a little quicker. They use the same final drive and gears 1-4 have the same ratios, but 5th is actually taller on the GT so it's relaxed cruising the highway.
-juice
http://cobbtuning.com/legacy/
I want that cat-back exhaust! But will wait a while to save the $$$ for it. I will not try the cold air intake or anything else, although it all seems fun to me! I will let you all know how the 18mm swaybar is next week.
Heather
-juice
-mike
