Visitor Agreement.
I moved a bit further up their list to the Dunlop WinterSport M2, trading a bit of snow grip for ice traction and general overall handling. So far, I am pleased with my decision....
Steve
I didn't bother with winter tires last year as the Potenzas were new and the weather was mild, but winter tires were in the plan for this year. The only question was studded or not? My 32 mile commute to work is against traffic on the hilly Putnam county section of the Taconic. The NYS DOT does its best, but the main effort during storms is always in the other direction. I've been caught more than once in ice storms on I-84 or the Taconic and it's a white knuckle experience at best. Last Thursday's snow with a thin underlayer of ice put a stop to the debate -- studs. So this afternoon SueBee was equipped with a set of Nokian Hakkapolitta 2's (her birthday present -- she turns 1 tomorrow). Nokian has just started offering the Hakk 2's in the US, so it was hard to get much info about them online -- I don't read Finnish, Russian, Swedish or Norwegian. The tires are factory studded and the dealer likes the Nokian line over the Blizzaks and Alpins. (Incidently CR got their Nokians for the tire test at this dealer). They made very quick work of the icy conditions on the way home. I almost took a joyride back up the Taconic just to see what they could do on real ice!
Lyn
-mike
Greg
The only time you should encounter the need for chains is when they post the "Chains Mandatory" requirement (R3?) -- then EVERYONE, regardless of drivetrain and tires, has to mount chains to pass the checkpoint. Cal-Trans usually closes the road by then due to all of the spinouts on the pass, though, and I've never gone through under these conditions.
You can mount chains on the front tires if necessary, but your AWD and Potenza tires should be fine for occasional mtn driving.
Brian
I have the good fortune of having the service records from the previous owner. The car was well loved and not easily traded in. Their situation changed and they had to give it up.
Anyway, after about 3 weeks of driving the vehicle, and after picking it up from a service visit, there was a change in the consistency of braking that so far has not been replicated or diagnosed by the dealership. It's troubling because for the first 21 days, the vehicle responded consistently when the brakes were applied. Now there is a change in braking response after the vehicle has been driven for 20 min or so. On highways or country roads where we don't brake very often, if the brakes are applied after some time, the pedal drops, and the car brakes somewhat sluggishly. However, if the brakes are applied a few moments later, there is a much more pronounced braking response. This is much different than before having our vehicle serviced. The only service brake related was adjusting the parking brake cable.
Have any owners of 5 SPD manual trans. Legacy wagons experienced a sudden change in braking behavior anything like this? Could it be parking brake, vacuum or electronic control related? Any ideas or suggestions greatly appreciated. Thanks!
Well, I could think of a couple of things, but you might thought of it already... anyway:
*Air in the brake lines
*Brake Fluid get too hot (boiling point) or it's just not good; needs replacement with some good fluid like Motul.
*Brake Cylinder, Vacuum or Pump
I would lean more toward the brake fluid... just a guess.
Mike - last I checked, and this was some years ago, studs were legal in NY from October 30 thru April 1. I doubt Lyn would have been able to buy them here in NY if there was a total ban on them. Maybe someone can update us on this???
Greg - Maybe I missed something, but the most recent CR review puts the Dunlops second from the top overall (below the Goodyear), and tops on ice. I was also swayed by their comments about handling and response on dry roads. But lets face it, almost anything will be an improvement over what came on the car!!
Steve
My question involves the dealer-added options. Are these items for sale over the Internet for self-installation?? What's a good place?
For example, I would guess that the Tweeter Kit is an easy install, with the wires already right there. Is this the case?
Is the car pretty much ready for the Dealer-Installed accessories? The Dimming/Compass mirror and the Alarm System are other examples I'm interested in... Are they relatively simple installations, with the wiring harness already nearby?
These cars look great! Can't wait until Saturday.
http://www.subaruparts.com/
Congrats on your new Soob!
bit
Chris - I too would suspect brake fluid. Subaru recommends replacing it every 30K miles. If the change happened after the service, I would suspect air in the lines. Bring it back, maybe you can get a brake fluid flush for free now.
Greg
It appears that you are not getting normal pressure on the brakes and need to pump the brakes to get any effect. Brake fluid would be my second thought, as others have mentioned.
I also have a 2000 Legacy L 5 spd and have never encountered brake problems with this car. Had this problem with a previous car, but it was a long time ago and I don't remember what the garage did to correct it.
Jim
They may not be as highly rated as some others, but when you combine Subaru's AWD with a winter rated tire, you can't go wrong.
SueBee loves her new winter boots -- they're nice and sticky and growled at just the right pitch as I hugged the left lane driving to work this AM. The tracks that she left were aggressive, to put it mildly. (And I was more aggressive, too ;-) Winter should be a lot more manageable (dare I say fun?) now that she's properly dressed. And after the mildness of the last few years, I think this winter will be one to remember!
Steve, Greg, Let's plan for a meeting in early January. Let me know when and where...
Lyn
The NRW have been replaced by the WR, Nokians advertising mentions the WR was designed to improve upon the NRWs wet handling, so CR may have been onto something about their poor assessment of the tire in the wet though it seems fine to me.
I think its somewhere on Nokians website that I read that Nokian seems to design tires to improve "lateral stability" while Japanese tire companies are into great straight line braking and other Europeans are into higher speed handling for their winter tires.
Lyn: Good - I was pretty sure studs were still OK. Sounds like even more months than I remembered.... See you and Greg after New Years?
Steve
I turn to you for your ideas regarding my situation.
One and a half weeks ago I ordered a 2003 Outback H63.0 in black from my local dealer:
CDN MSRP: 39,995+Destination($895)
Dealer offered it to me at 37,745 incl destination, and said it was $600 above cost.
Edmunds TMV showed people were generally paying 7%below MSRP (US) and I am being offered pretty much the same deal. I ordered the car, put down a refundable $200 deposit, signed the order and was told that the car should be here in 1-2 weeks.
I got a call yesterday from the salesperson, instructed by the sales manager, to offer me a White Outback, or a Green one which is arriving on the lot shortly. I asked why they were offering me the other colours, and they said the Black Outback would take 3 months to get in. Here I am thinking that is is in transit now, but instead am just being told the avilibility.
I called the 2nd in command in the sales department today to try and figure out what is really going on. Her story again was there is a 3 month backorder on Black ones. I asked that If I were to comprimise and take the White or Green one, how much they could comprimise on the price. She said that there was not much that could be done. I proceeded to tell her that I can get the same model at the other dealer near where I live for the same $37,745 price tag, and they would be able to offer me twice as much on my trade. She looked at the pricing again and said the price I wass given is at cost and couldn't take any more off. I reminded her that I was told that it is $600 above cost, and she claimed to perform an incorrect calculation, and she could drop the $90 documentation fee, and take $100 off the White one, but not the Green one. I asked why not the green one and she went on about how it has to come from the mainland to the island, and that is an additional expense for them. The white one came from the same place a week ago.
She then transferred me back to the salesman, who took a firm position on the $37,745 price as the lowest possible, and that only the $90 documentation fee could be dropped, not the extra $100. He said she had only been working there 6 months and didn't really know the policy.
So, here I am, feeling like the dealer wants to dump the excess stock on me, while overstuffing their pockets.
Essentially, I would like the green one, probabally more than the black now I think about the option open to me again, but I want to save a little more due to the runaround they have given me.
If anyone has any ideas, please post them here.
Also, does anyone know a contact email for Subaru Canada?
Thank's much for your help
So, I wonder if that's another desperate tactic to rope me in again...
It's not my fault if they can't find cheap advertising.....
And yes, I am on Vancouver Island
Phil
Newbie: my guess is your brake master cylinder is bad. Subaru had a recall on my Forester to fix that, though it never had the symptoms. Supposedly it would only happen in extreme cold, the pedal would sink to the floor, then if you pumped it would work fine. Bring that to the dealer's attention.
Martin: sure, do-it-yourself is the way to go. You can try subaruparts.com or e-mail parts@libertysubaru.com for wholesale price quotes. Most of the stuff is easy to do, and it's rewarding IMO.
-juice
Each time we have brought it into the dealership (3 times now), they have concentrated on the pads, rotors and calipers. I have to review the service records to see if they have checked the vacuum or fluid levels. That is really good to check out on our own as well.
I have heard recently that timing belts on Subarus are recommended to be replaced around 60,000 miles. The car has about 58,000 miles on it now. Oh the things we know now that we didn't know when we bought it! Any estimates on cost for this? Ballpark estimates and ranges are fine. I know from previous vehicles that it means taking the top and or front of the engine off.
I'd guess about $300, but haven't done it yet. Do the front seals while you're at it.
-juice
Martin: try 1stsubaruparts.com. they are a dealer on the west coast but you can get prices on lots of parts on the website. (You just have to click way down to the parts price level.)
Also, consider a Subaru MasterCard. 3% rebate good for Subaru parts, accessories, service, or towards a new Subaru. It paid for a bunch of my routine maintenance parts (at discount prices) from the dealer mentioned above. (Get more info at subaru.com.)
Jim
Greg
The drive up to Ct. is a little far, though I appreciate your offer to check them out. I'll post again after I pick up the car. Thanks again.
Phil
- Lou
Body damage should not void the warranty as long as the repairs are done properly by a reputable shop. I would demand OE parts - they will not guarantee after market parts that they didn't make, of course.
Your 2002 is still very close to new, so demand OE parts.
-juice
Thanks for the info on getting over Donner Pass - that is where most of my winter driving is.
You said that chains can be put on the front tires of an OB. My OB manual states not to put chains on the stock Pontenza (P225/60R16) tires. Have you been ok doing this?
Jeremy
It is because the auto is heavier, that all things being equal, the braking distance should be longer as the brakes are also working against the engine.
Now, if there were different size brakes between the manual and the auto that would explain it.
- Lou
I called a dealer in Canada today and asked if there were any incentives or cash back for subies. I told him about the rebates you mentioned. He laughed and said they must be doing something wrong down there. "Why would they give anyone money for a Legacy SE when they're already getting 3000.00cdn in accessories for only 500!" "No," he said "there's no incentive here!"
So I'm trying to get one close to invoice, but it'll be tough as they're getting hard to find. I'd ideally like a GT, but they aren't worth an extra 7100.00 for leather and a sunroof. And there aren't any incentives on them either.
what can you do?.....
cdndriver
I did the research on Edmunds and made a great deal on my car ...
Brenda
I had called my local dealer after they gave me the runaround with the colours, and said I don't want the car and please tear up the order. (This was the assistant sales manager)
The next morning at 9:05, the head sales manager called me to discuss the matter. You can tell that my order was at the top of the pile with a big "Don't loose the sale" note on it....
So, she offered another $600 off the car, and I insisted that it be the Winterrgreen one, not the white one I was convinced they were trying to get off the lot...
Anyway, she did up the final order:
MSRP: $39,995 + 895 destination
I got: $37,145 incl destination...
Not a bad deal...
When I did the conversion 37145 = 23811 ....so you did pretty well!
OK ...just a comment : )
That technique does not apply to Subarus!
Sorry,
Jim
To begin with, as Juice said, no too cars, even if identically equipped, will net out exactly the same. A recent letter to the editor in CD magazine about two or three different WRX posted 0-60 times confirms this.
Mechanical parts wear. Performance usually gets better when surfaces 'wear in' for optimum mesh, then begin the slow degradation of various wearout modes. Disk brake swept area can vary greatly from identical vehicles, even on a single vehicle as it ages. Amt of material transfered from pad to rotor during break-in, grooving, runout, pad composition and uniformity, rotor 'soft spots', all change the braking performance with time.
In the case of brake distances, temperature makes a huge difference. In successive stops, distances get longer as heat creates fade. Yet cold pads don't work well either. Brake pad to iron rotor friction follows a bell curve - no good when too cold, very poor when too warm. Best when just right.... The problem is controlling 'just right' for performance testing.
Another variable - most brake systems can lock up the tires. So brake distance is very dependent on ABS performance, and tire adhesion to the pavement. Again, tread depth, road and tire temp, road surface moisture, tire brand - all can change the numbers.
I have seen some testers state the season and time of day, temp, RH, barametric pressure, wind speed and direction. These all must be matched if you want even identical performance from the same vehicle.
Lastly, the final number that makes the road test report may be an average or even weighted average of multiple tests, maybe even over a period of days.
Long and winded, but I hope this helps....
Steve
Up here, the SE doesn't have a sunroof, but it does have heated seats. I wish they had the sunroof, as I'd really like one. The headroom is an issue for taller drivers. I had a problem in the sedans, and forget about sitting in the back seat if you're over 5-5. The "fast back" is just too low. I guess no one at Subaru actually sat back there.
I'm waiting to hear on some offers I put in for an SE. I'll let you know what the dealers will do up here.
regards,
cdndriver.
Put it this way, I bought a 2002 L, and ended up having a moonroof put in, as well as used alloys. Save yourself the trouble. Kids tend to be in the back seat, anyway.
-juice
Incidentally, the huge snow storm we just got this past weekend let me try my new Dunlop SP Sport A2's out in some deep slush. Wow -- not the kind of confidence I was hoping for in deep snow. I honestly think the OEM Firestones hooked up better in the snow than these do. I noticed the lack of traction mostly in corners...I was going even slower than I would normally be driving in the snow and the car still felt like it was wanting to rotate around. If this snow keeps up, I may go back to Blizzak's this winter just for peace of mind!
Brian
This morning on the way to work I was driving through several inches of wet slush on the roads and had been in 3rd gear for about 3 minutes or so when I tried to upshift and found the transmission fully stuck in 3rd gear. The gearbox felt as if it was filled with cold honey...the lever barely moved and I only get from 3rd to neutral and back to third. I slowed down, stopped for a red light, and barely got it into first. As I accelerated, the engine made a pronounced "boxer" sound from 2-3K rpms, as if the muffler was gone, then refused to give me 2nd gear so I took 3rd instead.
I'm sure the bottom of the car was caked with really heavy, slushy snow, but the car was not that cold (it had been in the 45deg garage all night) and the temp this morning was close to 30deg.
How could slush affect the manual transmission? It was very bizarre...my commute to work is only 5 miles, so I didn't get to really look things over to try and diagnose it. In 43K miles, this has never happened to the car so I'm a little concerned that something's amiss. Any ideas?
Brian
But your case is pretty extreme. I would check the fluid level and condition, even smell. Maybe change it next time you get a chance, some people do this every 30k miles anyway.
-juice
B
-juice
Greg
I loved these Dunlops out on the highway (I've put about 13K on them since July), but their winter performance is pretty disappointing.
B
